BOS021R
BOS021R
    BALLUFF(巴鲁夫)
    SERIES=R01E, DIMENSION=20 X 32 X
BOS021R 数据手册
Photoelectric Sensors BOS R01E-X-KS20-00,2-S49 Order Code: BOS021R 1) Optical axis emitter Basic features Environmental conditions Approval/Conformity Ecolab Ambient temperature -5...55 °C cULus Contamination scale 3 CE EN 60068-2-27, Shock Half-sinus, 100 gn, 2 ms, 3x8000 WEEE Half-sinus, 30 gn, 11 ms, 3x6 Basic standard IEC 60947-5-2 Principle of operation Photoelectric sensor 3x30 min Reference receiver BOS R01E-..-KE20-.. 10…2000 Series R01E gn, 3x5 h Style Square IP rating IP67 Connection 90° IP rating per DIN 40050 Housing IP69K, Connector IP67 EN 60068-2-6, Vibration Electrical connection 10…55 Hz, amplitude 1 mm, Hz, amplitude 1 mm, 30 Functional safety Cable diameter D 3.00 mm Cable length L 0.2 m MTTF (40 °C) Connection Cable with connector, M8x1-Male, 548.1 a Material 3-pin, 0.20 m, PUR Contact, surface protection Polarity reversal protected Protection against device mix-ups Gold plated yes yes Stainless steel (1.4404) Material jacket PUR Material sensing surface PA Mechanical data Electrical data No-load current Io max. at Ue 10 mA Operating voltage Ub 10...30 VDC Rated insulation voltage Ui 75 V DC Rated operating voltage Ue DC 24 V Internet Housing material Dimension 20 x 32 x 9 mm Mounting part Screw M3 www.balluff.com eCl@ss 9.1: 27-27-09-01 Subject to change without notice: 249152 ETIM 6.0: EC002716 BOS021R_2.94_2021-07-13 1/2 Photoelectric Sensors BOS R01E-X-KS20-00,2-S49 Order Code: BOS021R Optical features Smallest part typ. 0.4 mm at 1 m. R0 = 2 m Wave length 650 nm Beam characteristic Divergent LED group per IEC 62471 Exempt Group Light spot size Ø 3.0 mm Light exit Range/Distance Light type LED, red light Range 0...2.2 m Principle of optical operation Through-beam sensor Rated operating distance Sn 2.2 m Remarks Order accessories separately. For additional information, refer to user's guide. Only for applications per NFPA 79 (machines with a supply voltage of maximum 600 V). Use an R/C (CYJV2) cable with suitable properties for attaching the device. The sensor is functional again after the overload has been eliminated. For more information about MTTF and B10d see MTTF / B10d Certificate Indication of the MTTF- / B10d value does not represent a binding composition and/or life expectancy assurance; these are simply experiential values with no warranty implications. These declared values also do not extend the expiration period for defect claims or affect it in any way. Connector Drawings Wiring Diagrams 1) Emitter Opto Symbols Internet www.balluff.com eCl@ss 9.1: 27-27-09-01 Subject to change without notice: 249152 ETIM 6.0: EC002716 BOS021R_2.94_2021-07-13 2/2
BOS021R 价格&库存
很抱歉,暂时无法提供与“BOS021R”相匹配的价格&库存,您可以联系我们找货
