HIP4086AP
HIP4086AP
    L3HARRIS
    DIP24
    80V, 0.5A THREE PHASE DRIVER
HIP4086AP 数据手册
HIP4086 ® Data Sheet July 2004 FN4220.6 80V, 0.5A Three Phase Driver Features The HIP4086 is a Three Phase Bridge N-Channel MOSFET driver IC. The HIP4086 is specifically targeted for PWM motor control. It makes bridge based designs simple and flexible. Like the HIP4081, the HIP4086 has a flexible input protocol for driving every possible switch combination. Unlike the HIP4081, the user can override the shoot-through protection for switched reluctance applications. The HIP4086 has reduced drive current compared to the HIP4081 (0.5A vs 2.5A) and a much wider range of programmable dead times (0.25µs to 4.5µs) - like the HIP4082. The HIP4086 is suitable for applications requiring DC to 100kHz. Unlike the previous family members, the HIP4086 has a programmable undervoltage set point. • Independently Drives 6 N-Channel MOSFETs in Three Phase Bridge Configuration Also refer to the HIP4083, three phase upper only MOSFET driver, for a lower current solution optimized for smaller motors. Ordering Information • Bias Supply Operation from 7V to 15V • 1.25A Peak Turn-Off Current • User-Programmable Dead Time (0.25µs to 4.5µs) • Charge-Pump and Bootstrap Maintain Upper Bias Supplies • Programmable Bootstrap Refresh Time • Drives 1000pF Load with Typical Rise Time of 20ns and Fall Time of 10ns • DIS (Disable) Overrides Input Control • Input Logic Thresholds Compatible with 5V to 15V Logic Levels • Dead Time Disable Capability TEMP. RANGE (oC) PART NUMBER • Bootstrap Supply Max Voltage to 95VDC PACKAGE PKG. DWG. # • Programmable Undervoltage Set Point • Pb-free available HIP4086AB* -40 to 125 24 Ld SOIC M24.3 HIP4086ABZ* (See Note) -40 to 125 24 Ld SOIC (Pb-free) M24.3 HIP4086AP -40 to 125 24 Ld PDIP E24.3 HIP4086APZ (See Note) -40 to 125 24 Ld PDIP (Pb-free) E24.3 Applications • Brushless Motors • AC Motor Drives *Add “-T” suffix to part number for tape and reel packaging. • Switched Reluctance Motor Drives NOTE: Intersil Pb-free products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate termination finish, which is compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J Std-020B. • Battery Powered Vehicles Application Block Diagram 80V Pinout HIP4086 (PDIP, SOIC) TOP VIEW 12V BHB 1 24 BHO BHI 2 23 BHS BLI 3 22 BLO ALI 4 21 ALO AHI 5 20 VDD VSS 6 19 CLO RDEL 7 18 AHS 8 17 AHO RFSH 9 16 AHB DIS 10 15 CHS CLI 11 14 CHO CHI 12 13 CHB UVLO 1 HIP4086 GND GND CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 321-724-7143 | Intersil (and design) is a registered trademark of Intersil Americas Inc. Copyright © Intersil Americas Inc. 2004. All Rights Reserved All other trademarks mentioned are the property of their respective owners. HIP4086 Functional Block Diagram (1/3 of HIP4086 ) CHARGE PUMP 16 AHB AHI DRIVER 5 TURN-ON DELAY LEVEL SHIFTER 17 AHO DIS 10 VDD 20 UVLO 8 RFSH 9 UNDERVOLTAGE DETECTOR 10ns DELAY 18 AHS UV DEAD TIME DISABLE UV 20 VDD RFSH PULSE DRIVER TURN-ON DELAY ALI RDEL 21 ALO 4 6 DEAD TIME CURRENT MIRRORS 7 VSS DEAD TIME DISABLE 2µs DELAY + 100mV +VSS TRUTH TABLE INPUT OUTPUT ALI, BLI, CLI AHI, BHI, CHI UV DIS RDEL ALO, BLO, CLO AHO, BHO, CHO X X X 1 X 0 0 X X 1 X X 0 0 1 X 0 0 >100mV 1 0 0 0 0 0 X 0 1 0 1 0 0 X 0 0 1 0 0 0
HIP4086AP 价格&库存
很抱歉,暂时无法提供与“HIP4086AP”相匹配的价格&库存,您可以联系我们找货
