S-93A66BD0A-J8T2U3
S-93A66BD0A-J8T2U3
    ABLIC(艾普凌科)
    SOP-8
    IC EEPROM 4KBIT SPI 2MHZ 8SOPJ
S-93A66BD0A-J8T2U3 数据手册
S-93A46B/56B/66B/76B/86B www.ablic.com FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM Rev.1.3_00 © ABLIC Inc., 2016-2019 This IC is a high temperature operation 3-wire serial E2PROM for automotive components. This IC has the capacity of 1 K-bit, 2 K-bit, 4 K-bit, 8 K-bit and 16 K-bit, and the organization is 64 words × 16-bit, 128 words × 16-bit, 256 words × 16-bit, 512 words × 16-bit and 1024 words × 16-bit, respectively. Sequential read is available, at which time addresses are automatically incremented in 16-bit blocks. The communication method is by the Microwire bus. Caution Before using the product in automobile control unit or medical equipment, it is imperative to contact our sales representatives.  Features • Memory capacity S-93A46B: 1 K-bit (64-word × 16-bit) S-93A56B: 2 K-bit (128-word × 16-bit) S-93A66B: 4 K-bit (256-word × 16-bit) S-93A76B: 8 K-bit (512-word × 16-bit) S-93A86B: 16 K-bit (1024-word × 16-bit) • Operation voltage range Read: 2.5 V to 5.5 V Write: 2.5 V to 5.5 V • Operation frequency: 2.0 MHz max. • Write time: 4.0 ms max. • Sequential read • CMOS schmitt input (CS, SK, DI) • Write protect function during the low power supply voltage • Function to protect against write due to erroneous instruction recognition 106 cycle / word*1 (Ta = +85°C) • Endurance: 8 × 105 cycle / word*1 (Ta = +105°C) 5 × 105 cycle / word*1 (Ta = +125°C) • Data retention: 100 years (Ta = +25°C) 50 years (Ta = +125°C) • Initial delivery state: FFFFh • Wafer level burn-in (standard specification) • Operation temperature range: Ta = −40°C to +125°C • Lead-free (Sn 100%), halogen-free • AEC-Q100 qualified *2 *1. *2. For each address (Word: 16-bit) Contact our sales representatives for details.  Packages • 8-Pin SOP (JEDEC) 5 8 4 1 (5.0 × 6.0 × t1.75 mm) • 8 8-Pin TSSOP 5 1 4 (3.0 × 6.4 × t1.1 mm) • 8 TMSOP-8 5 4 1 (2.9 × 4.0 × t0.8 mm) • 5 8 HSNT-8(2030) 4 1 (3.0 × 2.0 × t0.5 mm) 1 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00  Block Diagram Memory array VCC Address decoder Data register GND Output buffer DI Mode decode logic CS Clock pulse monitoring circuit SK 2 Clock generator Voltage detector DO FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00  AEC-Q100 Qualified This IC supports AEC-Q100 for operation temperature grade 1. Contact our sales representatives for details of AEC-Q100 reliability specification.  Product Name Structure 1. Product name S-93AxxB D0 A - xxxx U 3 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specification*1 J8T2: 8-Pin SOP (JEDEC), Tape T8T2: 8-Pin TSSOP, Tape K8T2: TMSOP-8, Tape A8T1: HSNT-8(2030), Tape Operation temperature A: Ta = −40°C to +125°C Fixed Product name S-93A46B: S-93A56B: S-93A66B: S-93A76B: S-93A86B: *1. 2. 1 K-bit 2 K-bit 4 K-bit 8 K-bit 16 K-bit Refer to the tape drawing. Packages Package Name 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 HSNT-8(2030) Dimension FJ008-A-P-SD FT008-A-P-SD FM008-A-P-SD PP008-A-P-SD Tape FJ008-D-C-SD FT008-E-C-SD FM008-A-C-SD PP008-A-C-SD Reel FJ008-D-R-S1 FT008-E-R-S1 FM008-A-R-SD PP008-A-R-SD Land − − − PP008-A-L-SD 3 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B 3. Product name list Product Name S-93A46BD0A-J8T2U3 S-93A46BD0A-T8T2U3 S-93A46BD0A-K8T2U3 S-93A46BD0A-A8T1U3 S-93A56BD0A-J8T2U3 S-93A56BD0A-T8T2U3 S-93A56BD0A-K8T2U3 S-93A56BD0A-A8T1U3 S-93A66BD0A-J8T2U3 S-93A66BD0A-T8T2U3 S-93A66BD0A-K8T2U3 S-93A66BD0A-A8T1U3 S-93A76BD0A-J8T2U3 S-93A76BD0A-T8T2U3 S-93A76BD0A-K8T2U3 S-93A76BD0A-A8T1U3 S-93A86BD0A-J8T2U3 S-93A86BD0A-T8T2U3 S-93A86BD0A-K8T2U3 S-93A86BD0A-A8T1U3 4 Capacity 1 K-bit 1 K-bit 1 K-bit 1 K-bit 2 K-bit 2 K-bit 2 K-bit 2 K-bit 4 K-bit 4 K-bit 4 K-bit 4 K-bit 8 K-bit 8 K-bit 8 K-bit 8 K-bit 16 K-bit 16 K-bit 16 K-bit 16 K-bit Package Name 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 HSNT-8(2030) 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 HSNT-8(2030) 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 HSNT-8(2030) 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 HSNT-8(2030) 8-Pin SOP (JEDEC) 8-Pin TSSOP TMSOP-8 HSNT-8(2030) Rev.1.3_00 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00  Pin Configuration 1. 8-Pin SOP (JEDEC) Top view 2. 1 8 2 7 3 6 4 5 1 2 3 4 8 7 6 5 Description Chip select input Serial clock input Serial data input Serial data output Ground Test No connection Power supply Pin No. 1 2 3 4 5 6 7 8 Symbol CS SK DI DO GND TEST*1 NC VCC Description Chip select input Serial clock input Serial data input Serial data output Ground Test No connection Power supply TMSOP-8 Top view 1 2 3 4 *1. Symbol CS SK DI DO GND TEST*1 NC VCC 8-Pin TSSOP Top view 3. Pin No. 1 2 3 4 5 6 7 8 Pin No. 8 7 6 5 1 2 3 4 5 6 7 8 Symbol CS SK DI DO GND TEST*1 NC VCC Description Chip select input Serial clock input Serial data input Serial data output Ground Test No connection Power supply Connect to GND or the VCC pin, or set to open. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. 5 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B 4. Rev.1.3_00 HSNT-8(2030) Top view Pin No. 1 8 4 5 Bottom view 8 1 5 4 1 2 3 4 5 6 7 8 Symbol CS SK DI DO GND TEST*2 NC VCC Description Chip select input Serial clock input Serial data input Serial data output Ground Test No connection Power supply *1 *1. *2. 6 Connect the heat sink of backside at shadowed area to the board, and set electric potential open or GND. However, do not use it as the function of electrode. Connect to GND or the VCC pin, or set to open. Even if this pin is not connected, performance is not affected so long as the absolute maximum rating is not exceeded. FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00  Absolute Maximum Ratings Table 1 Item Power supply voltage Input voltage Output voltage Operation ambient temperature Storage temperature Symbol VCC VIN VOUT Topr Tstg Absolute Maximum Rating −0.3 to +6.5 −0.3 to +6.5 −0.3 to VCC + 0.3 −40 to +125 −65 to +150 Unit V V V °C °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Recommended Operating Conditions Table 2 Item Symbol Power supply voltage VCC High level input voltage Low level input voltage VIH VIL Condition READ, EWDS, WRITE, ERASE, WRAL, ERAL, EWEN − − Ta = −40°C to +125°C Min. Max. Unit 2.5 5.5 V 0.8 × VCC 0.0 VCC 0.2 × VCC V V  Pin Capacitance Table 3 Item Input capacitance Output capacitance Symbol CIN COUT Condition VIN = 0 V VOUT = 0 V (Ta = +25°C, f = 1.0 MHz, VCC = 5.0 V) Min. Max. Unit 8 pF − 10 pF −  Endurance Item Endurance Symbol NW Table 4 Operation Ambient Temperature Ta = −40°C to +85°C Ta = −40°C to +105°C Ta = −40°C to +125°C Min. 106 8 × 105 5 × 105 Max. − − − Unit cycle / word*1 cycle / word*1 cycle / word*1 Table 5 Operation Ambient Temperature Ta = +25°C Ta = −40°C to +125°C Min. 100 50 Max. − − Unit year year *1. For each address (Word: 16-bit)  Data Retention Item Data retention Symbol − 7 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00  DC Electrical Characteristics Table 6 Item Symbol Current consumption (read) ICC1 Condition No load at DO pin Ta = −40°C to +125°C VCC = 2.5 V to 4.5 V, VCC = 4.5 V to 5.5 V, fSK = 2.0 MHz fSK = 2.0 MHz Min. Max. Min. Max. − − 0.5 0.8 Unit mA Table 7 Item Symbol Current consumption (write) ICC2 Condition No load at DO pin Ta = −40°C to +125°C VCC = 2.5 V to 4.5 V VCC = 4.5 V to 5.5 V Min. Max. Min. Max. − − 3.0 3.0 Unit mA Table 8 Item Symbol Standby current consumption ISB Input leakage current ILI Output leakage current ILO Pull-down current IPD Low level output voltage VOL High level output voltage VOH Data hold voltage of write enable latch 8 VDH Condition CS = GND, DO = Open, Other input pins are VCC or GND CS, SK, DI, VIN = GND to VCC DO, VOUT = GND to VCC TEST, VIN = GND ~ VCC IOL = 2.1 mA IOL = 100 μA IOH = −400 μA IOH = −100 μA IOH = −10 μA Only program disable mode Ta = −40°C to +125°C VCC = 2.5 V to 4.5 V VCC = 4.5 V to 5.5 V Min. Max. Min. Max. Unit − 8.0 − 8.0 μA − 1.5 − 1.5 μA − 1.5 − 1.5 μA − 2.0 − 2.0 μA − − − VCC − 0.3 VCC − 0.2 − 0.2 − − − − − 2.4 VCC − 0.3 VCC − 0.2 0.6 0.2 − − − V V V V V 1.5 − 1.5 − V FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00  AC Electrical Characteristics Table 9 Measurement Conditions 0.1 × VCC to 0.9 × VCC 0.5 × VCC 100 pF Input pulse voltage Output reference voltage Output load Table 10 Ta = −40°C to +125°C Item Symbol Unit VCC = 2.5 V to 5.5 V VCC = 4.5 V to 5.5 V Min. Max. Min. Max. CS pin setup time tCSS 0.15 − 0.15 − μs CS pin hold time tCSH 0 − 0 − μs CS pin deselect time tCDS 0.2 − 0.2 − μs Data setup time tDS 0.1 − 0.1 − μs Data hold time tDH 0.1 − 0.1 − μs Output delay time tPD − 0.25 − 0.25 μs Clock frequency*1 0 2.0 0 2.0 MHz fSK Clock pulse width tSKH, tSKL 0.2 − 0.1 − μs Output disable time tHZ1, tHZ2 0 0.2 0 0.15 μs Output enable time tSV 0 0.2 0 0.15 μs Write time tPR − 4.0 − 4.0 ms *1. The clock cycle of the SK clock (frequency fSK) is 1/fSK μs. This clock cycle is determined by a combination of several AC characteristics. Note that the clock cycle cannot be set as (1/fSK) = tSKL (min.) + tSKH (min.) by minimizing the SK clock cycle time. 1/fSK*2 tCSS tCDS CS tSKH tSKL tCSH SK tDS DI tPD tPD High-Z High-Z tSV (READ) DO tDH Valid data Valid data *1 DO tDS tDH High-Z tHZ1 tHZ2 High-Z (VERIFY) *1. *2. Indicates high impedance. 1/fSK is the SK clock cycle. This clock cycle is determined by a combination of several AC characteristics. Note that the clock cycle cannot be set as (1/fSK) = tSKL (min.) + tSKH (min.) by minimizing the SK clock cycle time. Figure 1 Timing Chart 9 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00  Pin Functions 1. CS (chip select input) pin This is an input pin to set a chip in the select status. In the "L" input level, this IC is in the non-select status and its output is "High-Z". This IC is in standby as long as it is not in write inside. This IC goes in active by setting the chip select to "H". Input any instruction code after power-on and a rising of chip select. 2. SK (serial clock input) pin This is a clock input pin to set the timing of serial data. A start bit, an operation code, an address and a write data are received at a rising edge of clock. Data is output during rising edge of clock. 3. DI (serial data input) pin This pin is to input serial data. This pin receives a start bit, an operation code, an address and a write data. This pin latches data at rising edge of serial clock. 4. SO (serial data output) pin This pin is to output serial data. The data output changes at rising edge of serial clock. 5. TEST (test input) pin This is an input pin in test mode. Connect to GND or the VCC pin, or set to open. Because this pin has a built-in pull-down element, pull-down current flows when it connected to VCC pin.  Initial Delivery State Initial delivery state of all addresses is "FFFFh". 10 Rev.1.3_00 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B  Instruction Sets 1. S-93A46B Table 11 Operation Instruction Start Bit Address Data Code SK input clock 1 2 3 4 5 6 7 8 9 10 to 25 READ (Data read) 1 1 0 A5 A4 A3 A2 A1 A0 D15 to D0 output*1 WRITE (Data write) 1 0 1 A5 A4 A3 A2 A1 A0 D15 to D0 input ERASE (Data erase) 1 1 1 A5 A4 A3 A2 A1 A0 − WRAL (Chip write) 1 0 0 0 1 x x x x D15 to D0 input ERAL (Chip erase) 1 0 0 1 0 x x x x − EWEN (Write enable) 1 0 0 1 1 x x x x − EWDS (Write disable) 1 0 0 0 0 x x x x − *1. When the 16-bit data in the specified address has been output, the data in the next address is output. Remark x = Don't care. 2. S-93A56B Table 12 Operation Instruction Start Bit Address Data Code SK input clock 1 2 3 4 5 6 7 8 9 10 11 12 to 27 READ (Data read) 1 1 0 x A6 A5 A4 A3 A2 A1 A0 D15 to D0 output*1 WRITE (Data write) 1 0 1 x A6 A5 A4 A3 A2 A1 A0 D15 to D0 input ERASE (Data erase) 1 1 1 x A6 A5 A4 A3 A2 A1 A0 − WRAL (Chip write) 1 0 0 0 1 x x x x x x D15 to D0 input ERAL (Chip erase) 1 0 0 1 0 x x x x x x − EWEN (Write enable) 1 0 0 1 1 x x x x x x − EWDS (Write disable) 1 0 0 0 0 x x x x x x − *1. When the 16-bit data in the specified address has been output, the data in the next address is output. Remark x = Don't care. 3. S-93A66B Table 13 Instruction SK input clock READ (Data read) WRITE (Data write) ERASE (Data erase) WRAL (Chip write) ERAL (Chip erase) EWEN (Write enable) EWDS (Write disable) *1. Start Bit 1 1 1 1 1 1 1 1 Operation Code 2 3 1 0 0 1 1 1 0 0 0 0 0 0 0 0 Address 4 A7 A7 A7 0 1 1 0 5 A6 A6 A6 1 0 1 0 6 A5 A5 A5 x x x x 7 A4 A4 A4 x x x x 8 A3 A3 A3 x x x x Data 9 A2 A2 A2 x x x x 10 A1 A1 A1 x x x x 11 A0 A0 A0 x x x x 12 to 27 D15 to D0 output*1 D15 to D0 input − D15 to D0 input − − − When the 16-bit data in the specified address has been output, the data in the next address is output. Remark x = Don't care. 11 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B 4. Rev.1.3_00 S-93A76B Table 14 Operation Address Data Instruction Start Bit Code SK input clock 1 2 3 4 5 6 7 8 9 10 11 12 13 14 to 29 READ (Data read) 1 1 0 x A8 A7 A6 A5 A4 A3 A2 A1 A0 D15 to D0 output*1 WRITE (Data write) 1 0 1 x A8 A7 A6 A5 A4 A3 A2 A1 A0 D15 to D0 input − ERASE (Data erase) 1 1 1 x A8 A7 A6 A5 A4 A3 A2 A1 A0 WRAL (Chip write) 1 0 0 0 1 x x x x x x x x D15 to D0 input − ERAL (Chip erase) 1 0 0 1 0 x x x x x x x x − EWEN (Write enable) 1 0 0 1 1 x x x x x x x x − EWDS (Write disable) 1 0 0 0 0 x x x x x x x x *1. When the 16-bit data in the specified address has been output, the data in the next address is output. Remark x = Don't care. 5. S-93A86B Table 15 Instruction SK input clock Operation Start Bit Code 1 2 3 READ (Data read) 1 0 4 5 6 A9 A8 A7 7 8 9 Data 10 11 A6 A5 A4 A3 A2 12 13 14 to 29 A1 A0 D15 to D0 output*1 WRITE (Data write) 1 0 1 A9 A8 A7 A6 A5 A4 A3 A2 A1 A0 ERASE (Data erase) 1 1 1 A9 A8 A7 A6 A5 A4 A3 A2 A1 A0 WRAL (Chip write) 1 0 0 0 1 x x x x x x x x ERAL (Chip erase) 1 0 0 1 0 x x x x x x x x D15 to D0 input − EWEN (Write enable) 1 0 0 1 1 x x x x x x x x − EWDS (Write disable) 1 0 0 0 0 x x x x x x x x − *1. D15 to D0 input − When the 16-bit data in the specified address has been output, the data in the next address is output. Remark x = Don't care. 12 1 Address Rev.1.3_00 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B  Operation All instructions are executed by inputting the DI pin in synchronization with the rising of the SK pulse after the CS pin goes to "H". An instruction set is input in the order of start bit, instruction, address, and data. Instruction input finishes when the CS pin goes to "L". "L" must be input to the CS pin between commands during tCDS. While "L" is being input to the CS pin, this IC is in standby mode, so the SK pin and the DI pin inputs are invalid and no instructions are allowed. 1. Start Bit A start bit is recognized when the DI pin goes to "H" at the rising of the SK pulse after the CS pin goes to "H". After the CS pin goes to "H", a start bit is not recognized even if the SK pulse is input as long as the DI pin is "L". 1. 1 Dummy clock The SK clocks input while the DI pin is "L" before a start bit is input are called dummy clocks. Dummy clocks are effective when aligning the number of instruction sets (clocks) sent by the CPU with those required for serial memory operation. For example, when the CPU instruction set is 16 bits, the number of instruction set clocks can be adjusted by inserting the 7-bit dummy clock in S-93A46B, the 5-bit dummy clock in S-93A56B/66B and the 3-bit dummy clock in S-93A76B/86B. 1. 2 Start bit input failure (1) When the output of the DO pin is "H" during the verify period after a write operation, if "H" is input to the DI pin at the rising of the SK pulse, this IC recognizes that a start bit has been input. To prevent this failure, input "L" to the DI pin during the verify operation period (refer to "3. 1 Verify operation"). (2) When a 3-wire interface is configured by connecting the DI input pin and the DO output pin, a period in which the data output from the CPU and the serial memory collide may be generated, preventing successful input of the start bit. Take the measures described in " 3-Wire Interface (Direct Connection between DI Pin and DO Pin)". 2. Reading (READ) The READ instruction reads data from a specified address. After the CS pin goes to "H", input an instruction in the order of the start bit, read instruction, and address. Since the last input address (A0) has been latched, the output status of the DO pin changes from "High-Z" to "L", which is held until the next rising of the SK pulse. 16-bit data starts to be output in synchronization with the next rising of the SK pulse. 2. 1 Sequential read After the 16-bit data at the specified address has been output, inputting the SK pulse while the CS pin is "H" automatically increments the address, and causes the 16-bit data at the next address to be output sequentially. The above method makes it possible to read the data in the whole memory space. The last address (An  A1 A0 = 1  1 1) rolls over to the top address (An  A1 A0 = 0  0 0). 13 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00 CS SK 1 DI 2 3 1 0 4 A5 5 6 7 A4 A3 A2 8 9 11 12 22 23 24 25 26 27 38 39 40 41 42 43 A1 A0 High-Z DO 10 0 D15 D14 D13 D2 D1 D0 D15 D14 D13 D2 D1 D0 D15 D14 D13 ADRINC Figure 2 High-Z ADRINC Read Timing (S-93A46B) CS SK 1 DI 2 1 3 4 0 5 6 A6 A5 8 9 A4 A3 A2 10 11 12 13 14 24 25 26 27 28 40 29 41 42 43 44 45 A1 A0 x: S-93A56B A7: S-93A66B High-Z DO 7 0 D15 D14 D13 D2 D1 D0 D15 D14 D13 D2 D1 D0 D15 D14 D13 ADRINC High-Z ADRINC Figure 3 Read Timing (S-93A56B/66B) CS SK DI DO 1 2 1 3 0 4 5 6 A8 A7 High-Z 7 8 9 A6 A5 A4 10 A3 11 A2 12 A1 13 14 15 16 26 27 28 29 30 31 43 44 45 46 47 A0 x: S-93A76B A9: S-93A86B 0 D15 D14 D13 D2 D1 D0 D15 D14 D13 D2 D1 D0 D15 D14 D13 ADRINC ADRINC Figure 4 Read Timing (S-93A76B/86B) 14 42 High-Z FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00 3. Writing (WRITE, ERASE, WRAL, ERAL) A write operation includes four write instructions: data write (WRITE), data erase (ERASE), chip write (WRAL), and chip erase (ERAL). A write instruction (WRITE, ERASE, WRAL, ERAL) starts a write operation to the memory cell when "L" is input to the CS pin after a specified number of clocks have been input. The SK pin and the DI pin inputs are invalid during the write period, so do not input an instruction. Input an instruction while the output status of the DO pin is "H" or "High-Z". A write operation is valid only in program enable mode (refer to "4. Write enable (EWEN) / write disable (EWDS)"). 3. 1 Verify operation A write operation executed by any instruction is completed within 4 ms (write time tPR), so if the completion of the write operation is recognized, the write cycle can be minimized. A sequential operation to confirm the status of a write operation is called a verify operation. 3. 1. 1 Operation method After the write operation has started (CS pin = "L"), the status of the write operation can be verified by confirming the output status of the DO pin by inputting "H" to the CS pin again. This sequence is called a verify operation, and the period that "H" is input to the CS pin after the write operation has started is called the verify operation period. The relationship between the output status of the DO pin and the write operation during the verify operation period is as follows. (1) DO pin = "L": Writing in progress (busy) (2) DO pin = "H": Writing completed (ready) 3. 1. 2 Operation example There are two methods to perform a verify operation: Waiting for a change in the output of the DO pin while keeping the CS pin "H", or suspending the verify operation (CS pin = "L") once and then performing it again to verify the output of the DO pin. The latter method allows the CPU to perform other processing during the wait period, allowing an efficient system to be designed. Caution 1. Input "L" to the DI pin during a verify operation. 2. If "H" is input to the DI pin at the rising of the SK pulse when the output status of the DO pin is "H", this IC latches the instruction assuming that a start bit has been input. In this case, note that the DO pin immediately enters "High-Z". 15 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B 3. 2 Rev.1.3_00 Writing data (WRITE) To write 16-bit data to a specified address, change the CS pin to "H" and then input the WRITE instruction, address, and 16-bit data following the start bit. The write operation starts when the CS pin goes to "L". There is no need to set the data to "1" before writing. When the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the WRITE instruction. For details of the clock pulse monitoring circuit, refer to " Function to Protect Against Write due to Erroneous Instruction Recognition". tCDS CS Standby Verify SK 1 DI 2 3 0 1 4 5 6 7 8 9 10 25 A5 A4 A3 A2 A1 A0 D15 D0 High-Z DO tSV tHZ1 busy ready High-Z tPR Figure 5 Data Write Timing (S-93A46B) tCDS CS Standby Verify SK 1 DI 2 0 3 4 1 5 6 7 8 9 A6 A5 A4 A3 A2 10 A1 11 12 27 A0 D15 D0 tSV x: S-93A56B High-Z DO tHZ1 A7: S-93A66B busy ready High-Z tPR Figure 6 Data Write Timing (S-93A56B/66B) tCDS CS SK 1 DI DO 2 0 3 4 1 High-Z 5 6 7 8 9 10 11 12 13 14 29 A8 A7 A6 A5 A4 A3 A2 A1 A0 D15 D0 x: S-93A76B A9: S-93A86B tSV tHZ1 busy tPR Figure 7 16 Standby Verify Data Write Timing (S-93A76B/86B) ready High-Z FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00 3. 3 Erasing data (ERASE) To erase 16-bit data at a specified address, set all 16 bits of the data to "1", change the CS pin to "H", and then input the ERASE instruction and address following the start bit. There is no need to input data. The data erase operation starts when the CS pin goes to "L". When the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the ERASE instruction. For details of the clock pulse monitoring circuit, refer to " Function to Protect Against Write due to Erroneous Instruction Recognition". tCDS Standby Verify CS SK 1 2 DI 1 3 1 4 5 6 7 8 A5 A4 A3 A2 A1 9 A0 tSV High-Z DO tHZ1 busy ready High-Z tPR Figure 8 Data Erase Timing (S-93A46B) tCDS CS Standby Verify SK 1 2 DI 1 3 4 1 5 6 7 8 9 A6 A5 A4 A3 A2 A1 11 A0 tSV x: S-93A56B A7: S-93A66B High-Z DO 10 busy tHZ1 ready High-Z tPR Figure 9 Data Erase Timing (S-93A56B/66B) tCDS SK 1 2 DI 1 DO Standby Verify CS 3 4 1 High-Z 5 6 7 8 9 A8 A7 A6 A5 A4 x: S-93A76B A9: S-93A86B 10 A3 11 A2 12 A1 13 A0 tSV busy tPR Figure 10 tHZ1 ready High-Z Data Erase Timing (S-93A76B/86B) 17 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B 3. 4 Rev.1.3_00 Writing to chip (WRAL) To write the same 16-bit data to the entire memory address space, change the CS pin to "H", and then input the WRAL instruction, an address, and 16-bit data following the start bit. Any address can be input. The write operation starts when the CS pin goes to "L". There is no need to set the data to "1" before writing. When the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the WRAL instruction. For details of the clock pulse monitoring circuit, refer to " Function to Protect Against Write due to Erroneous Instruction Recognition". tCDS CS Standby Verify SK 1 2 DI 0 3 0 4 5 0 6 7 8 1 10 25 D15 D0 4xs High-Z DO 9 tSV tHZ1 busy ready High-Z tPR Figure 11 Chip Write Timing (S-93A46B) tCDS CS Standby Verify SK 1 2 DI 0 3 4 0 5 0 6 7 9 10 11 1 12 27 D15 D0 tSV 6xs High-Z DO 8 tHZ1 busy ready High-Z tPR Figure 12 Chip Write Timing (S-93A56B/66B) tCDS CS SK 1 2 DI 0 DO 3 0 4 0 5 6 7 8 9 10 1 8xs High-Z 11 12 13 14 29 D15 D0 tSV tHZ1 busy tPR Figure 13 18 Standby Verify Chip Write Timing (S-93A76B/86B) ready High-Z FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00 3. 5 Erasing chip (ERAL) To erase the data of the entire memory address space, set all the data to "1", change the CS pin to "H", and then input the ERAL instruction and an address following the start bit. Any address can be input. There is no need to input data. The chip erase operation starts when the CS pin goes to "L". When the clocks more than the specified number have been input, the clock pulse monitoring circuit cancels the ERAL instruction. For details of the clock pulse monitoring circuit, refer to " Function to Protect Against Write due to Erroneous Instruction Recognition". CS SK 1 2 3 4 DI 0 0 1 5 6 7 9 0 t HZ1 tSV 4xs High-Z DO 8 Standby Verify tCDS Busy Ready High-Z tPR Figure 14 Chip Erase Timing (S-93A46B) CS SK 1 2 3 4 DI 0 0 1 5 6 7 8 9 10 Standby Verify tCDS 11 0 t HZ1 tSV 6xs High-Z Busy DO Ready High-Z tPR Figure 15 Chip Erase Timing (S-93A56B/66B) CS tCDS SK 1 2 3 4 DI 0 0 1 DO 5 6 7 8 9 10 11 12 Standby Verify 13 0 8xs High-Z tSV tHZ1 busy ready High-Z tPR Figure 16 Chip Erase Timing (S-93A76B/86B) 19 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B 4. Rev.1.3_00 Write enable (EWEN) / write disable (EWDS) The EWEN instruction is an instruction that enables a write operation. The status in which a write operation is enabled is called the program enable mode. The EWDS instruction is an instruction that disables a write operation. The status in which a write operation is disabled is called the program disable mode. After the CS pin goes to "H", input an instruction in the order of the start bit, EWEN or EWDS instruction, and address (optional). Each mode becomes valid by inputting "L" to the CS pin after the last address (optional) has been input. Standby CS SK 1 DI 2 3 0 4 5 6 7 8 9 0 4xs 11 = EWEN 00 = EWDS Figure 17 Write Enable / Disable Timing (S-93A46B) Standby CS SK 1 DI 2 0 3 4 5 6 7 8 9 10 11 0 6xs 11 = EWEN 00 = EWDS Figure 18 Write Enable / Disable Timing (S-93A56B/66B) Standby CS SK 1 DI 2 0 3 4 5 6 7 8 9 10 11 12 13 0 11 = EWEN 00 = EWDS Figure 19 8xs Write Enable / Disable Timing (S-93A76B/86B) Remark It is recommended to execute an EWDS instruction for preventing an incorrect write operation if a write instruction is erroneously recognized when executing instructions other than write instruction, and immediately after power-on and before power-off. 20 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00  Write Protect Function during the Low Power Supply Voltage This IC provides a built-in detection circuit to detect a low power supply voltage. When the power supply voltage is low or at power-on, the write instructions (WRITE, ERASE, WRAL, and ERAL) are cancelled, and the write disable (EWDS) status is automatically set. The detection voltage is 1.55 V typ., the release voltage is 1.85 V typ., and there is a hysteresis of about 0.3 V (refer to Figure 20). Therefore, when a write operation is performed after the power supply voltage has dropped and then risen again up to the level at which writing is possible, a write enable instruction (EWEN) must be sent before a write instruction (WRITE, ERASE, WRAL, or ERAL) is executed. When the power supply voltage drops during a write operation, the data being written to an address at that time is not guaranteed. Hysteresis about 0.3 V Power supply voltage Detection voltage (−VDET) 1.55 V typ. Release voltage (+VDET) 1.85 V typ. Write instructions are cancelled Write disable status (EWDS) is automatically set Figure 20 Operation during the Low Power Supply Voltage 21 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Rev.1.3_00  Function to Protect Against Write due to Erroneous Instruction Recognition This IC provides a built-in clock pulse monitoring circuit which is used to prevent an erroneous write operation by canceling write instructions (WRITE, ERASE, WRAL, and ERAL) recognized erroneously due to an erroneous clock count caused by the application of noise pulses or double counting of clocks. Instructions are cancelled if a clock pulse whose count other than the one specified for each write instruction (WRITE, ERASE, WRAL, or ERAL) is detected. Example: Erroneous Recognition of EWDS as ERASE Example of S-93A76B/86B Noise pulse CS 1 2 3 4 5 6 7 8 9 10 11 12 13 SK DI 0 0 0 0 0 0 0 0 0 0 0 0 Erroneous recognition as ERASE 1 1 1 0 instruction due to noise pulse 0 0 00 0 0 0 0 0 0 0 0 Input EWDS instruction 1 In products that do not incorporate a clock pulse monitoring circuit, "FFFFh" is mistakenly written to address 00h. However the S-93A76B/86B detects the overcount and cancels the instruction without performing a write operation. Figure 21 22 Example of Clock Pulse Monitoring Circuit Operation Rev.1.3_00 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B  3-Wire Interface (Direct Connection between DI Pin and DO Pin) There are two types of serial interface configurations: a 4-wire interface configured using the CS pin, the SK pin, the DI pin and the DO pin and a 3-wire interface that connects the DI pin and the DO pin. When the 3-wire interface is employed, a period in which the data output from the CPU and the data output from the serial memory collide may occur, causing a malfunction. To prevent such a malfunction, connect the DI pin and the DO pin of this IC via a resistor (10 kΩ to 100 kΩ) so that the data output from the CPU takes precedence in being input to the DI pin (refer to Figure 22). CPU S-93A46B/56B/66B/76B/86B SIO DI DO R: 10 kΩ to 100 kΩ Figure 22 Connection of 3-Wire Interface  Input Pin and Output Pin 1. Connection of input pin All input pins in this IC have the CMOS structure. Do not set these pins in "High-Z" during operation when you design. Especially, set the CS pin to "L" at power-on, power-off, and during standby. The error write does not occur as long as the CS pin is "L". Set the CS pin to GND via a resistor (the pull-down resistor of 10 kΩ to 100 kΩ). To prevent the error for sure, it is recommended to use equivalent pull-down resistors for input pins other than the CS pin. 2. Equivalent circuit of input pin and output pin Figure 23, Figure 24 and Figure 25 show the equivalent circuits of input pins in this IC. In Figure 23 and Figure 24, none of the input pins incorporate pull-up and pull-down elements, so special care must be taken when designing to prevent a floating status. In Figure 25, the TEST pin has a built-in pull-down element. Figure 26 shows the equivalent circuit of the output pin. This pin has the tri-state output of "H" / "L" / "High-Z". 23 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B 2. 1 Input pin CS Figure 23 CS Pin SK, DI Figure 24 SK, DI Pin Figure 25 TEST Pin TEST 24 Rev.1.3_00 Rev.1.3_00 2. 2 FOR AUTOMOTIVE 125°C OPERATION 3-WIRE SERIAL E2PROM S-93A46B/56B/66B/76B/86B Output pin VCC DO Figure 26 3. DO Pin Input pin noise suppression time This IC has a built-in low-pass filter at the SK pin, the DI pin and the CS pin to suppress noise. If the supply voltage is 5.0 V, noise with a pulse width of 20 ns or less at room temperature can be suppressed by the low-pass filter. Note that noise with a pulse width of more than 20 ns is recognized as a pulse since the noise can not be suppressed if the voltage exceeds VIH / VIL.  Precautions • Do not operate these ICs in excess of the absolute maximum ratings. Attention should be paid to the power supply voltage, especially. The surge voltage which exceeds the absolute maximum ratings can cause latch-up and malfunction. Perform operations after confirming the detailed operation condition in the data sheet. • Operations with moisture on this IC's pins may occur malfunction by short-circuit between pins. Especially, in occasions like picking this IC up from low temperature tank during the evaluation. Be sure that not remain frost on this IC's pin to prevent malfunction by short-circuit. Also attention should be paid in using on environment, which is easy to dew for the same reason. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement of the products including this IC upon patents owned by a third party. 25 5.02±0.2 8 5 1 4 1.27 0.20±0.05 0.4±0.05 No. FJ008-A-P-SD-2.2 TITLE SOP8J-D-PKG Dimensions FJ008-A-P-SD-2.2 No. ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.55±0.05 0.3±0.05 ø2.0±0.05 8.0±0.1 2.1±0.1 6.7±0.1 1 8 4 5 Feed direction No. FJ008-D-C-SD-1.1 TITLE SOP8J-D-Carrier Tape No. FJ008-D-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. 60° 2±0.5 13.5±0.5 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FJ008-D-R-S1-1.0 TITLE SOP8J-D-Reel No. FJ008-D-R-S1-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 +0.3 3.00 -0.2 8 5 1 4 0.17±0.05 0.2±0.1 0.65 No. FT008-A-P-SD-1.2 TITLE TSSOP8-E-PKG Dimensions No. FT008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.05 ø1.55±0.05 0.3±0.05 +0.1 8.0±0.1 ø1.55 -0.05 (4.4) +0.4 6.6 -0.2 1 8 4 5 Feed direction No. FT008-E-C-SD-1.0 TITLE TSSOP8-E-Carrier Tape FT008-E-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. 13.4±1.0 17.5±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.5 No. FT008-E-R-S1-1.0 TITLE TSSOP8-E-Reel No. FT008-E-R-S1-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 2.90±0.2 8 5 1 4 0.13±0.1 0.2±0.1 0.65±0.1 No. FM008-A-P-SD-1.2 TITLE TMSOP8-A-PKG Dimensions No. FM008-A-P-SD-1.2 ANGLE UNIT mm ABLIC Inc. 2.00±0.05 4.00±0.1 4.00±0.1 1.00±0.1 +0.1 1.5 -0 1.05±0.05 0.30±0.05 3.25±0.05 4 1 5 8 Feed direction No. FM008-A-C-SD-2.0 TITLE TMSOP8-A-Carrier Tape FM008-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part 13±0.2 (60°) (60°) No. FM008-A-R-SD-1.0 TITLE TMSOP8-A-Reel No. FM008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 2.0±0.1 8 5 (1.70) 1 4 +0.05 0.08 -0.02 0.5 0.23±0.1 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PP008-A-P-SD-2.0 TITLE HSNT-8-A-PKG Dimensions No. PP008-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.0±0.05 4.0±0.1 0.25±0.05 +0.1 ø1.0 -0 0.60±0.05 4.0±0.1 2.3±0.05 4 321 5 6 78 Feed direction No. PP008-A-C-SD-1.0 TITLE HSNT-8-A-Carrier Tape No. PP008-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PP008-A-R-SD-1.0 HSNT-8-A-Reel TITLE No. PP008-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 5,000 1.6 0.30 0.50 No. PP008-A-L-SD-1.0 TITLE No. HSNT-8-A -Land Recommendation PP008-A-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-93A66BD0A-J8T2U3 价格&库存
很抱歉,暂时无法提供与“S-93A66BD0A-J8T2U3”相匹配的价格&库存,您可以联系我们找货
