PD30CNP50PAPS
PD30CNP50PAPS
    CARLOGAVAZZI
    SENSOR RETROREFLECTIVE 5M PNP
PD30CNP50PAPS 数据手册
 PD30CNP50xxPS Photoelectrics, Polarized retro-reflective - PointSpot Main features • • • • • • • • • • • • • Miniature sensor range PointSpot light source Sensing range: 5 m Sensitivity adjustment by potentiometer Modulated, red light 621 nm Supply voltage: 10 to 30 VDC Output: 100 mA, NPN or PNP preset Make and break switching function LED indication for output, stability and power ON Protection: reverse polarity, short circuit and transients Cable and plug versions Excellent EMC performance Easy mounting since only the sensor must be aligned with the reflector • Power supply necessary only on one side of the application Main functions Description The PD30CNP50... sensor family comes in a compact 10 x 30 x 20 mm ABS housing. They are designed for use in applications where a compact lightbeam without "halo" light is required to assure a high sensing performance. The potentiometer function for adjustment of the sensitivity makes the sensors highly flexible. The output types NPN or PNP feature both N.O. and N.C. output. Element A B C Component Potentiometer 2 LEDs 2 M3 26/01/2017 PD30CNP50xxPS ENG • Detects presence or absence of objects that cut off light reflected from a reflector • The polarized light makes it possible to detect highly reflecting objects • The PointSpot light source removes halo light and increases detection reliability. Function Adjustment Green LED: Power ON / Signal stability.Yellow LED: Output Fixing holes for sensor mounting Carlo Gavazzi Industri A/S 1 PD30CNP50xxPS  References Product selection key PD30CNP50 A PS Enter the code entering the corresponding option instead of Code P D 30 C N P 50 A PS Option N P M5 - Description Photoelectric sensor Rectangular housing Length of housing Plastic housing Normal trimmer (back trimmer) Polarized retro-reflective Distance [dm] NPN PNP Output: N.O. and N.C. Cable, 2 m Connector M8 PointSpot emitter Type selection Connection Cable Plug Output Code NPN PNP NPN PNP PD30CNP50NAPS PD30CNP50PAPS PD30CNP50NAM5PS PD30CNP50PAM5PS 26/01/2017 PD30CNP50xxPS ENG Carlo Gavazzi Industri A/S 2 PD30CNP50xxPS  Sensing Detection ≤5m ≤3m 2.5 ... 5 m 210° 240° ≤ 100 mm @ Sn max 3% ... 20% 621 nm Red modulated ± 0.6° 9.5 cm ± 1.0° Rated operating distance (Sn) Sensitivity adjustment Blind zone Hysteresis Light source Light type Detection angle Light spot size Emitter beam angle @ Reference target, reflector: ER4 (Ø80 mm) @ Reference target, reflector: ER4060 Single-turn potentiometer Electrical adjustment Mechanical adjustment @ Reference target, reflector: ER4 (Ø80 mm) or ER4060 Red - PointSpot @ 3.0 m (half sensing distance) @ 3.0 m (half sensing distance) @ 3.0 m (half sensing distance) Accuracy Temperature drift ≤ 0.2%/ºC Detection diagram A 0,0 60 C 3,3 6,6 9,8 13,1 16,4 19,7 23,0 2,4 40 1,6 20 0,8 0 0,0 E D Y X -20 -0,8 -40 -1,6 -60 0 1,0 2,0 3,0 4,0 5,0 6,0 F -2,4 7,0 B A B C Detection width (mm) Sensing range (mm) Detection width (inches) 26/01/2017 PD30CNP50xxPS ENG D E F Sensing range (inches) Sensor ER4 reflector Carlo Gavazzi Industri A/S 3 PD30CNP50xxPS  Excess gain C 0,3 3,2 32,8 1 0,1 1,0 10,0 6 5 4 A 3 2 B A B Excess gain Distance (m) 26/01/2017 PD30CNP50xxPS ENG C Distance (feet) Carlo Gavazzi Industri A/S 4 PD30CNP50xxPS  Features Power Supply Rated operational voltage (UB) Ripple (Urpp ) No load supply current (Io) Power-ON delay (tv) 10 ... 30 VDC (ripple included) ≤ 10% ≤ 25 mA @ UB Max. ≤ 30 ms Outputs Output functions Output switching function NPN or PNP by sensor type Open collector N.O. and N.C. < 100 mA Continuous(Ie) ≤ 100 mA @ 100 nF load Short-time (I) 0.5 mA 100 μA 2 VDC @ (Ie) Max. Short circuit, reverse polarity and transients Control of resistive loads and DC-12 solid-state loads with optical isolation DC-13 Control of electromagnets Output current Minimum operational current (Im) OFF-state current(Ir) Voltage drop (Ud) Protection Utilization category Operation diagram Tv = Power-ON delay Power supply Target Break output (N.C.) Make output (N.O.) ON Present ON Tv Tv ON Response times Operating frequency (f) Response times 26/01/2017 PD30CNP50xxPS ENG ≤ 1000 Hz ≤ 0.5 ms ≤ 0.5 ms OFF-ON (tON) ON-OFF (tON) Carlo Gavazzi Industri A/S 5 PD30CNP50xxPS  Indication Green LED ON OFF OFF ON Yellow LED OFF OFF ON ON Power ON ON or OFF ON ON Output OFF (stable)* OFF ON ON (stable)* *See signal stability curve Signal stability indication Y 1.10 C1 1.0 0.90 C C2 X A B A B X Y Green LED ON Yellow LED OFF Time Excess gain C1 C C2 Operation level x 1.10 Operation level Operation level x 0.90 Environmental Ambient temperature Ambient light Vibration Shock Drop test Rated insulation voltage (Ui) Dielectric insulation voltage Rated impulse withstand voltage Pollution degree Overvoltage category Degree of protection NEMA Enclosure Types Ambient humidity range 1) 2) -25°... +60°C (-13°... +140°F) -40° ... +70°C (-40° ... +158°F) ≤ 45 000 lux 10 ...150 Hz, 1.0 mm/15 g 30 gn / 11ms, 6 pos, 6 neg per axis 2 x 1 m and 100 x 0.5 m 50 VDC ≥ 500 VAC rms 1 kV 3 III IP67 1 35% ... 95% 35% ... 95% Operating 1) Storage 1) @ 3000 … 3200 °K EN 60068-2-6 EN60068-2-27 EN 60068-2-31 50/60 Hz for 1 min. 1.2/50 µs EN60947-1 IEC60664; EN60947-1 IEC60539; EN60947-1 NEMA 250 Operating 2) Storage 2) Do not bend the cable in temperatures below -10°C With no icing or condensation 26/01/2017 PD30CNP50xxPS ENG Carlo Gavazzi Industri A/S 6 PD30CNP50xxPS  EMC Electrostatic discharge immunity test Radiated radio-frequency electromagnetic field immunity test (80 MHz ... 1 GHz and 1..4 GHz ... 2 GHz) Electrical fast transient/Burst immunity test Conducted disturbances induced by radio-frequency fields immunity test (150 kHz ... 80 MHz) Power frequency magnetic field immunity test 26/01/2017 PD30CNP50xxPS ENG ± 8 kV @ air discharge or ± 4 kV @ contact discharge IEC 61000-4-2 10 V/m IEC 61000-4-3 2 kV / 5 kHz using the capacitive coupling clamp IEC 61000-4-4 10 Vrms IEC 61000-4-6 30 A/m 38 µT IEC 61000-4-8 Carlo Gavazzi Industri A/S 7 PD30CNP50xxPS  Mechanics/electronics Connection Cable Plug 2 m, 4-wire 4 x 0.14 mm2, Ø = 3.3 mm, PVC, Black M8, 4-pin, male Wiring BN 1BN 1BN 2WH 4BK 4BK 2WH 3BU 3BU Fig. 1 NPN Fig. 2 PNP Brown WH White Colour code BK Black BU Blue Housing Body Front glass Trimmer shaft Indication Sealing Dimensions Weight 26/01/2017 PD30CNP50xxPS ENG ABS PMMA, Red POM, Grey TPU NBR70 10.8 x 30 x 20 mm ≤ 50 g Cable version ≤ 20 g Plug version Carlo Gavazzi Industri A/S 8 PD30CNP50xxPS  20 10.6 Dimensions 10.6 10.8 15 5.5 5.5 22 25.4 30 7 1.1 17 20 10.6 Fig. 3 Cable 10.6 10.8 15 5.5 5.5 22 25.4 30 7 1.1 17 10.25 Fig. 4 Plug 26/01/2017 PD30CNP50xxPS ENG Carlo Gavazzi Industri A/S 9 PD30CNP50xxPS  Compatibility and conformity Approvals and markings General reference MTTFd Sensor designed according to EN60947-5-2 164.2 years @ 40°C (+104°F) EN ISO 13849-1, SN 29500 CE-marking Approvals 26/01/2017 PD30CNP50xxPS ENG (UL508 + C22.2) Carlo Gavazzi Industri A/S 10 PD30CNP50xxPS  Delivery contents and accessories Delivery contents • Photoelectric switch: PD30CNP50… • Screwdriver • Packaging: Plastic bag Accessories • Mounting bracket: ADP30-MB1 or APD30-MB2 to be purchased separately • Connector type: CO..54NF... series to be purchased separately • ER.. Reflectors to be purchased separately COPYRIGHT ©2017 Content subject to change. Download the PDF: www.productselection.net 26/01/2017 PD30CNP50xxPS ENG Carlo Gavazzi Industri A/S 11
PD30CNP50PAPS 价格&库存
很抱歉,暂时无法提供与“PD30CNP50PAPS”相匹配的价格&库存,您可以联系我们找货
PD30CNP50PAPS
  • 1+691.212771+86.04950
  • 5+645.101665+80.30910
  • 10+606.3429210+75.48400
PD30CNP50PAPS
  • 5+806.870605+100.44782
PD30CNP50PAPS
  • 2+544.74802
  • 5+504.43662
库存:14
