TM18RP6LPQ5
TM18RP6LPQ5
    BANNER(邦纳)
    TM18RP6LPQ5 EZ BEAM TM18: POLARI
TM18RP6LPQ5 数据手册
TM18 Series Sensors Datasheet • • • • • • • • • • • • Heavy duty metal housing with 18 mm threaded barrel mount and integral metal QD prevents sensor damage during machine assembly, transport, maintenance, and operation Right angle "T" mounting fits in tight places, prevents sensor damage, and avoids personnel catch points Models with dedicated 3-wire output NPN or PNP for OEM machine builders — designed to work with I/O block splitters for reduced wiring costs Models with 4-wire complementary NPN or PNP outputs available Featuring EZ-BEAM technology provides reliable sensing without adjustments Visible red LED models available in opposed, polarized retroreflective, diffuse, and fixed-field (background suppression) modes Infrared models available in fixed-field (background suppression) mode Completely epoxy encapsulated electronics to provide superior durability, especially in harsh sensing environments Sensors rated IP69K for resistance to intermittent high pressure washdown Innovative dual indicator systems takes the guess work out of sensor performance monitoring Enhanced immunity to fluorescent lights on fixed field and diffuse sensors Cross talk avoidance allows two sensors to be used in close proximity on polarized retro, diffuse, and fixed field sensors To order the 9 m (30 ft) cable models, add the suffix "W/30" to the cabled model number. For example, "TM186E W/30". To order the 4-pin Euro M12 integral QD models, add suffix Q8 (for example, TM186EQ8). To order the 4-pin Euro M12 pigtail QD models: add suffix Q5 (for example, TM186EQ5). Opposed Mode Sensors Model Number Mode Range TM186E LED Visible red 625 nm Output None TM18AP6R PNP, LO 3-wire TM18RP6R PNP, DO 3-wire TM18VP6R 20 m None OPPOSED TM18AN6R PNP, LO/DO 4-wire NPN, LO 3-wire TM18RN6R NPN, DO 3-wire TM18VN6R NPN, LO/DO 4-wire Polarized Retroreflective Model Number Mode Range LED Output TM18AP6LP PNP, LO 3-wire TM18RP6LP PNP, DO 3-wire TM18VP6LP TM18AN6LP P 5.5 m 1 Visible red 624 nm POLAR RETRO PNP, LO/DO 4-wire NPN, LO 3-wire TM18RN6LP NPN, DO 3-wire TM18VN6LP NPN, LO/DO 4-wire 1 Range specified with BRT-84 reflector. Original Document 155853 Rev. F 3 September 2015 155853 TM18 Series Sensors Fixed-Field Background Suppression Model Number Mode Range LED TM18AP6FF25 Output PNP, LO 3-wire TM18VP6FF25 PNP, LO/DO 4-wire 25 mm TM18AN6FF25 NPN, LO 3-wire TM18VN6FF25 NPN, LO/DO 4-wire TM18AP6FF50 PNP, LO 3-wire TM18VP6FF50 TM18AN6FF50 50 mm Visible red 660 nm FIXED-FIELD PNP, LO/DO 4-wire NPN, LO 3-wire TM18VN6FF50 NPN, LO/DO 4-wire TM18AP6FF100 PNP, LO 3-wire TM18VP6FF100 PNP, LO/DO 4-wire 100 mm TM18AN6FF100 NPN, LO 3-wire TM18VN6FF100 NPN, LO/DO 4-wire TM18AP6FF25IR PNP, LO 3-wire TM18VP6FF25IR PNP, LO/DO 4-wire 25 mm TM18AN6FF25IR NPN, LO 3-wire TM18VN6FF25IR NPN, LO/DO 4-wire TM18AP6FF50IR PNP, LO 3-wire TM18VP6FF50IR TM18AN6FF50IR 50 mm Infrared, 880 nm FIXED-FIELD PNP, LO/DO 4-wire NPN, LO 3-wire TM18VN6FF50IR NPN, LO/DO 4-wire TM18AP6FF100IR PNP, LO 3-wire TM18VP6FF100IR PNP, LO/DO 4-wire 100 mm TM18AN6FF100IR NPN, LO 3-wire TM18VN6FF100IR NPN, LO/DO 4-wire Diffuse Visible Mode Model Number Mode Range LED Output TM18AP6DV PNP, LO 3-wire TM18RP6DV PNP, DO 3-wire TM18VP6DV TM18AN6DV 500 mm Visible red 660 nm DIFFUSE PNP, LO/DO 4-wire NPN, LO 3-wire TM18RN6DV NPN, DO 3-wire TM18VN6DV NPN, LO/DO 4-wire WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 155853 Rev. F TM18 Series Sensors Specifications Supply Voltage and Current - Class 2 10 to 30 V dc (10% max. ripple within specified limits); supply current (exclusive of load current): Emitters: 25 mA Receivers: 20 mA Polarized Retroreflective: 20 mA Diffuse and Fixed-Field: 35 mA Supply Protection Circuitry Protected against reverse polarity and transient voltages Effective Beam 13 mm for opposed mode sensors Output Configuration NPN (current sinking) or PNP (current sourcing), depending on model Light Operate: Output conducts when sensor receives its own (or the emitter’s) modulated light Dark Operate: Output conducts when sensor does not receive it own (or the emitter fts) modulated light Connections 2 m (6.5 ft) or 9 m (30 ft) PVC attached cable Integral 4-pin M12/Euro-style quick disconnect 4-pin M12/Euro-style PVC pigtail quick disconnect Construction Housing: Zinc die cast with nickel plating Lens: PMMA or PC (opposed mode only) Black Cover: PBT polyester housing Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short circuit of outputs Output Rating 150 mA maximum each output at 25 °C, derated to 100 mA at 70 °C (derate about 1 mA per °C) OFF-state leakage current: < 1 microamp at 30 V dc ON-state saturation voltage: < 1 V at 10 mA dc; < 1.5 V at 150 mA dc Environmental Rating IEC IP67; quick disconnect models are IEC IP69K when mated with a washdown rated (IEC IP69K) cordset Operating Conditions −40 °C to +70 °C (−40 °F to +158 °F) 90% at +50 °C maximum relative humidity (non-condensing) Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements. Method 201A (Vibration; frequency 10 to 60 Hz, max., double amplitude 0.06 in acceleration 10G). Method 213B conditions H&I (Shock: 75G with unit operating; 100G for non-operation) P/N 155853 Rev. F Adjustments Diffuse models only: single turn rear panel sensitivity control Indicators Two LEDs (green and amber) Complementary (4-Wire) Models Indicator Description Green ON Power ON Green Flashing* Output is overloaded Amber ON N.O. Output is conducting Amber Flashing* Marginal excess gain (1 to 1.5x) * Not valid for Diffuse or Fixed Field Models. Single Output (3-Wire) Models Indicator Description Green ON Power ON Green Flashing N.A. Amber ON Output is conducting Amber Flashing N.A. Output Response Time (TM18) Opposed mode: 1.5 ms ON, 0.75 ms OFF Retro: 3 ms ON and OFF Diffuse and Fixed Field: 3 ms ON, 1.5 ms OFF Note: 100 ms delay on power-up; outputs do not conduct during this time. Repeatability (TM18) Opposed mode: 190 µs Retro: 585 µs Diffuse and Fixed Field: 185 µs Certifications Class 2 supply Required; Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to http:// www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 www.bannerengineering.com - Tel: +1-763-544-3164 3 TM18 Series Sensors Performance Curves Opposed Mode Sensors Excess Gain Beam Pattern 1000 500 mm 400 mm 300 mm 200 mm 100 mm TM18 EXCESS GAIN E&R Excess Gain TM18 E&R Beam Pattern 0 100 100 mm 200 mm 300 mm 400 mm 500 mm 10 0 5m 10 m 15 m 20 m DISTANCE 1 0.1 m 1m 10 m 100 m DISTANCE Polarized Retroreflective Excess Gain Beam Pattern Beam Pattern 40 mm TM18LP 20 mm Polarized Retroreflective EXCESS GAIN TM18LP 60 mm 1000 with BRT-84 Reflector 0 100 20 mm 40 mm 60 mm 10 0 1m 2m 3m 4m 5m 6m DISTANCE 1 0.01 m .033' 0.1 m .33' 1m 3.3' 10 m 33' DISTANCE 4 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 155853 Rev. F TM18 Series Sensors Diffuse Excess Gain Beam Pattern TM18 Diffuse 15 mm 1000 Beam Pattern 10 mm TM18 Diffuse EXCESS GAIN 5 mm 0 100 5 mm 10 mm 15 mm 10 0 100 200 300 400 500 600 DISTANCE (mm) 1 10 1 100 1000 DISTANCE (mm) Fixed Field (Visible Red and Infrared) Excess Gain 25 mm 50 mm 100 mm 1000 TM18FF 50 mm 1000 100 10 TM18FF 100 mm 10 mm spot size at 50 mm 10 mm spot size at 100 mm 100 EXCESS GAIN EXCESS GAIN 10 mm spot size at 10 mm 10 mm spot size at 25 mm EXCESS GAIN 1000 10 mm spot size at 25 mm 10 mm spot size at 50 mm TM18FF 25 mm 10 100 10 1 0.1 1 0.1 1 10 100 1 10 100 1 0.1 DISTANCE (mm) • • Using 18% gray test card: Cutoff distance will be 95% of value shown. Using 6% black test card: Cutoff distance will be 90% of value shown. P/N 155853 Rev. F 1 10 100 DISTANCE (mm) DISTANCE (mm) • • Using 18% gray test card: Cutoff distance will be 90% of value shown. Using 6% black test card: Cutoff distance will be 85% of value shown. www.bannerengineering.com - Tel: +1-763-544-3164 • • Using 18% gray test card: Cutoff distance will be 85% of value shown. Using 6% black test card: Cutoff distance will be 75% of value shown. 5 TM18 Series Sensors Dimensions 30 mm [1.18”] TM18 LP Cable 30 mm dia [1.18”] 15 mm [0.59”] CL 26 mm [1.03”] 41.1 mm [1.62”] M18 x 1 6g TM18 LP QD 30 mm dia [1.18”] M18 x 1 6g 49 mm [1.93”] 34 mm [1.34”] M12 x 1 6g CL 15 mm [0.59”] 30 mm [1.18”] Maximum Torque specification: 5.6 nm or 50 in-lbs. Lockwasher and M18 nut included. Wiring NPN L.O. 3-Wire Emitter 3 10 - 30V dc 1 Wiring Key 1 2 3 4 6 = = = = Brown White Blue Black 3 1 4 1 3 4 10 - 30V dc Load NPN D.O. 3-Wire 3 1 4 PNP L.O. 3-Wire 10 - 30V dc Load PNP D.O. 3-Wire 10 - 30V dc Load www.bannerengineering.com - Tel: +1-763-544-3164 1 3 4 10 - 30V dc Load P/N 155853 Rev. F TM18 Series Sensors QD and cabled emitter wiring functionality is identical; black and white wires have no connection when not shown. PNP L.O./D.O. 4-Wire NPN L.O./D.O. 4-Wire 3 1 4 2 1 3 4 2 10 - 30V dc Load Load 10 - 30V dc Load Load Accessories Cordsets 4-Pin Threaded M12/Euro-Style Cordsets Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 15.2 m (50 ft) 1 4 2 3 32 Typ. [1.26"] 1 = Brown 30 Typ. [1.18"] Right-Angle MQDC-450RA Pinout (Female) 2 = White 3 = Blue 4 = Black M12 x 1 ø 14.5 [0.57"] Apertures AP18SCN Kit includes round apertures of 0.5 mm (0.02 in), 1.0 mm (0.04 in), and 2.5 mm (0.10 in) diameter. Used with T18, TM18 models. AP18SRN Kit includes rectangular apertures of 0.5 mm (0.02 in), 1.0 mm (0.04 in), and 2.5 mm (0.10 in) wide. Each kit also includes a thread-on housing, Teflon® FEP® lens, and o-ring. Used with T18, TM18 APG18S Kit with glass lens to protect plastic sensor lens from chemical environments and weld splatter damage. Used with S18, M18, T18, TM18, and Q4X P/N 155853 Rev. F www.bannerengineering.com - Tel: +1-763-544-3164 7 TM18 Series Sensors Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. www.bannerengineering.com - Tel: +1-763-544-3164
TM18RP6LPQ5 价格&库存
很抱歉,暂时无法提供与“TM18RP6LPQ5”相匹配的价格&库存,您可以联系我们找货
