T8AN6D100
T8AN6D100
    BANNER(邦纳)
    PHOTO SEN 100MM NPN
T8AN6D100 数据手册
T8 Series Diffuse-Mode Sensors Datasheet Miniature self-contained sensors • • • • • • • Extremely small package self-contained miniature sensors 10 V DC to 30 V DC operation Visible red sensing beam Choose dark or light operate models Choose models with NPN or PNP output 3-wire hookup; output load capacity to 50 mA Choice of integral cable or quick-disconnect connector WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or de-energized (off) output condition. Models Models1 Range Cable Supply Voltage T8AN6D50 2 m (6.5 ft) T8AN6D50Q 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect T8RN6D50 2 m (6.5 ft) T8RN6D50Q 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect T8AP6D50 50 mm (2 in) 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect T8RP6D50 2 m (6.5 ft) T8RP6D50Q 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect T8AN6D100 2 m (6.5 ft) T8AN6D100Q 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect T8RN6D100 2 m (6.5 ft) T8RN6D100Q 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect 100 mm (4 in) NPN Light Operate NPN Dark Operate 2 m (6.5 ft) T8AP6D50Q T8AP6D100 Output Type PNP Light Operate PNP Dark Operate 10 V DC to 30 V DC NPN Light Operate NPN Dark Operate 2 m (6.5 ft) T8AP6D100Q 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect T8RP6D100 2 m (6.5 ft) T8RP6D100Q 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect PNP Light Operate PNP Dark Operate Overview T8 Series self-contained miniature sensors are designed for precision sensing in small areas previously accessible only to remote sensors and fiber optic cable. Typical applications include mounting on compact conveyors, packaging machines, circuit board and semi-conductor wafer handling equipment, document handling equipment, robot end-effectors, feeder bowls, between the rollers of narrow conveyors, or as replacements for damaged small-diameter inductive proximity sensors. The sensing range of the T8 is many times greater than that of the typical 8 mm diameter inductive sensor. And it provides a low-cost alternative to diffuse (bifurcated) fiber optic sensors. 1 To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. (for example, T8AN6D50 W/30). Models with a quick disconnect require a mating cordset. Original Document 67584 Rev. C 24 April 2020 67584 T8 Series Diffuse-Mode Sensors Wiring Quick disconnect wiring diagrams are functionally identical. 4 bu (3) – 10–30 V dc + bn (1) bk (4) bn (1) + 10–30 V dc – bu (3) bk (4) Load Load 1 3 Key 1. Brown 3. Black 4. Blue Figure 2. PNP Outputs Figure 1. NPN Outputs Specifications Supply Voltage and Current 10 V DC to 30 V DC (10% maximum ripple) at less than 25 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration SPST solid-state switch Choose NPN or PNP models Choose light operate (N.O.) or dark operate (N.C.) models Output Rating 50 mA maximum Off-state leakage current: < 1 microamp at 24 V DC On-state saturation voltage: < 0.25 V at 10 mA DC; < 0.5 V at 50 mA DC Output Protection Circuitry Protected against output short-circuit, continuous overload, and false pulse on powerup Overload trip point ≥ 100 mA Output Response Time 1 millisecond ON and OFF Note: 150 millisecond delay maximum on power-up: output does not conduct during this time Repeatability 160 microseconds Sensing Beam Visible red, 680 nm Indicator Red LED: On when light is sensed Construction Reinforced polycarbonate/ABS alloy housing, acrylic window Environmental Rating IEC IP67; NEMA 6 Connections 2 m (6.5 ft) unterminated 3-wire PVC-jacketed cable: three #28 ga stranded conductors with PE insulation; or 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect. Models with a quick disconnect require a mating cordset. Operating Conditions Temperature: –20 °C to +55 °C (–4 °F to +131°F) 80% at +50 °C maximum relative humidity (non-condensing) Application Notes Optional mounting bracket is available. Reinforced polycarbonate/ABS alloy 8 mm threaded nut (included). Dimensions All measurements are listed in millimeters [inches], unless noted otherwise. M8 X 1 Thread 16.3 mm (0.64") 15.8 mm (0.62") 8.8 mm (0.35") Red Signal Indicator 19.1 mm (0.75") 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 67584 Rev. C T8 Series Diffuse-Mode Sensors Performance Curves Beam Patterns T8xx6D50 60 mm T8xx6D100 2.4 in 60 mm 40 mm 1.6 in 40 mm 1.6 in 20 mm 0.8 in 20 mm 0.8 in Diffuse Mode 0 0 2.4 in Diffuse Mode 0 0 20 mm 0.8 in 20 mm 0.8 in 40 mm 1.6 in 40 mm 1.6 in 60 mm 2.4 in 60 mm 2.4 in 0 20 mm 0.8 in 40 mm 1.6 in 60 mm 2.4 in 80 mm 3.2 in 100 mm 4.0 in 0 20 mm 0.8 in DISTANCE 40 mm 1.6 in 60 mm 2.4 in 80 mm 3.2 in 100 mm 4.0 in DISTANCE Figure 4. 100 mm Models Figure 3. 50 mm Models Excess Gain Curves 1000 1000 E X C E S S G A I N T8xx6D50 E X C E S S Diffuse Mode 100 G A I N 10 1 1.0 mm 0.04 in 10 mm 0.4 in 100 mm 4 in 1000 mm 40 in T8xx6D100 Diffuse Mode 100 10 1 1.0 mm 0.04 in 10 mm 0.4 in 100 mm 4 in 1000 mm 40 in DISTANCE DISTANCE Figure 5. 50 mm Models Figure 6. 100 mm Models Accessories Cordsets 3-Pin Threaded M8/Pico-Style Cordsets Model Length PKG3M-2 2.035 m (6.68 ft) PKG3M-5 5.035 m (16.51 ft) PKG3M-7 7.035 m (23.08 ft) PKG3M-9 9.035 m (29.64 ft) PKG3M-10 10.035 m (32.92 ft) P/N 67584 Rev. C Style Dimensions Pinout (Female) 4 35 Typ. Straight ø 9.5 M8 x 1 www.bannerengineering.com - Tel: + 1 888 373 6767 1 3 1 = Brown 3 = Blue 4 = Black 3 T8 Series Diffuse-Mode Sensors Bracket SMB8MM • Right-angle bracket • 300 series stainless steel Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
T8AN6D100 价格&库存
很抱歉,暂时无法提供与“T8AN6D100”相匹配的价格&库存,您可以联系我们找货
T8AN6D100
  • 1+1365.989471+176.71159
库存:13
