QS18VN6AF300 W/30
QS18VN6AF300 W/30
    BANNER(邦纳)
    WORLD-BEAM: ADJUSTABLE FIELD BAC
QS18VN6AF300 W/30 数据手册
WORLD-BEAM QS18 Datasheet Miniature self-contained photoelectric sensors in universal housing • • • • • • • • Easily fits (or retrofits) almost any mounting situation Exceptional optical performance, comparable to larger “MINI-style” or barrel sensors 10 to 30 V dc operation, with complementary (SPDT) NPN or PNP outputs, depending on model Bright LED operating status indicators are visible from 360° Rugged sealed housing, protected circuitry Models available with or without 18 mm threaded “nose” Less than 1 millisecond output response for excellent sensing repeatability Choose 2 m (6.5 ft) or 9 m (30 ft) cable or 150 mm (6 inch) Pico-style pigtail QD WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models To order the 9 m (30 ft) cable models, add the suffix "W/30" to the cabled model number. QD Models. For 4-pin integral Euro-style QD, add suffix “Q8” (for example, QS186EQ8). For 4-pin integral Pico-style QD, add suffix “Q7” (for example, QS186EQ7). For 4-pin 150 mm (6 in) Euro-style pigtail, add suffix “Q5” (for example, QS186EQ5). For 4-pin 150 mm (6 in) Pico-style pigtail, add suffix “Q” (for example, QS186EQ). Opposed Mode Model Range Effective beam: 13 mm (0.5 inch) QS186EV (624 nm Visible Red) QS186E (940 nm Infrared) QS18VN6R OPPOSED OPPOSED Effective beam: 13 mm (0.5 inch) 20 m (66 ft) N/A NPN PNP QS186EB (940 nm Infrared) N/A 3 m (10 ft) QS18VP6RB Polarized Retroreflective Mode Model 630 nm Visible Red QS18VN6LP P N/A QS18VP6R QS18VN6RB OPPOSED Output NPN PNP Range Output NPN 3.5 m (12 ft) QS18VP6LP PNP POLAR RETRO Retroreflective Mode Model 628 nm Visible Red QS18VN6LV Range Output NPN 6.5 m (21 ft) QS18VP6LV PNP RETRO Original Document 63908 Rev. I 31 July 2015 63908 WORLD-BEAM QS18 Convergent Mode Model Range 630 nm Visible Red QS18VN6CV15 QS18VP6CV15 QS18VN6CV45 CONVERGENT VISIBLE RED QS18VP6CV45 Output NPN 16 mm (0.63 in) PNP NPN 43 mm (1.7 in) PNP Diffuse Mode Model 940 nm Infrared QS18VN6D Range Output NPN QS18VP6D PNP 450 mm (18 in) DIFFUSE QS18VN6DB (Diffuse, wide) NPN QS18VP6DB (Diffuse, wide) PNP DIFFUSE Divergent Mode Model Range 940 nm Infrared QS18VN6W Output NPN DIVERGENT 100 mm (4 in) QS18VP6W PNP DIFFUSE Fixed Field Mode Model Range 660 nm Visible Red QS18VN6FF50 QS18VN6FF100 QS18VP6FF100 Plastic Fiber Optic Mode Model 660 nm Visible Red QS18VN6FP NPN 50 mm (2 in) QS18VP6FF50 FIXED-FIELD Output PNP NPN 100 mm (4 in) PNP Range Output NPN QS18VP6FP Range varies by sensing mode and fiber optics used Glass Fiber Optic Mode Model Range 940 nm Infrared QS18VN6F PNP PLASTIC FIBER Output NPN Range varies by sensing mode and fiber optics used QS18VP6F PNP GLASS FIBER Wiring Diagrams QS18 with NPN (Sinking) Outputs 3 – 10-30V dc + 1 4 2 2 Load Load QS18 with PNP (Sourcing) Outputs 1 + 10-30V dc – 3 4 2 QS18 Emitters bn (1) Load Load www.bannerengineering.com - Tel: +1-763-544-3164 bu (3) + 10–30V dc − P/N 63908 Rev. I WORLD-BEAM QS18 Installing Fibers Cutting Unterminated Plastic Fibers QS18V..6FP Unterminated plastic fibers are designed to be cut by the user to the length required for the application. To facilitate cutting, a Banner model PFC-1 cutting device is supplied with the fiber. Cut the fiber as follows: Lift to Open Ports Use small ports for fiber sizes: Cutting Ports • • 0.25 mm (0.01 inches) 0.5 mm (0.02 inches) Use large ports for fiber sizes: • • • 0.75 mm (0.03 inches) 1.0 mm (0.04 inches) 1.5 mm (0.06 inches) Figure 1. PFC-1 Cutting Device 1. Locate the control end of the fiber (the unfinished end). 2. Determine the length of fiber required for the application. If using a bifurcated fiber, separate the two halves of the fiber at least 51 mm (2 inches) beyond the fiber cutting location. 3. Lift the top (blade) of the cutter to open the cutting ports. 4. Insert one of the control ends through one of the cutting ports on the cutter so that the excess fiber protrudes from the back of the cutter. 5. Double-check the fiber length, and close the cutter until the fiber is cut. 6. Using a different cutting port, cut the second control end to the required length. NOTE: To ensure a clean cut each time, do not use a cutting port more than once. 7. Gently wipe the cut ends of the fiber with a clean, dry cloth to remove any contamination. Do not use solvents or abrasives on any exposed optical fiber. Installing Plastic Fibers QS18V..6FP Follow these steps to install the plastic fibers. A C Fiber end Adapter B Adapter Installation Figure 2. Installing Plastic Fibers 1. Slide the fiber gripper up to unlock it (A). 2. If using 0.25 mm or 0.5 mm core fibers, slide the plastic fiber adapters onto the fibers, flush with the fiber ends. 3. Carefully insert the prepared plastic fiber ends into the ports (B) as far as possible without applying extra force. 4. Slide the fiber gripper down to lock the fibers in place (C). P/N 63908 Rev. I www.bannerengineering.com - Tel: +1-763-544-3164 3 WORLD-BEAM QS18 Installing Glass Fibers QS18V..6F Follow these steps to install the glass fibers. Retaining Clip O-rings Figure 3. Installing Glass Fibers 1. Slide the supplied o-ring on the sensor end of the fibers, as shown. 2. Press the fiber ends firmly into the ports located on the front of the sensor. 3. Slide the supplied u-shaped retaining clip into the slot in the sensor’s barrel until the clip snaps into place. Specifications Supply Voltage 10 to 30 V dc (10% maximum ripple) at less than 25 mA, exclusive of load; Protected against reverse polarity and transient voltages Repeatability Opposed Mode: 100 microseconds FF Mode: 160 microseconds All others: 150 microseconds Light Source Output Configuration Glass Fiber Optic, Opposed and Diffuse mode models: Infrared, 940 nm Solid-state complementary (SPDT): NPN or PNP (current sinking or sourcing), depending on model; Plastic Fiber Optic, Retroreflective, Convergent and FF mode models: Visible red, 660 nm Rating: 100 mA maximum each output at 25 °C Off-state Leakage Current (FF Mode): less than 200 μA @ 30V dc Adjustments Off-state Leakage Current (All others): less than 50 μA @ 30V dc Glass Fiber Optic, Plastic Fiber Optic, Convergent, Diffuse, and ON-state Saturation Voltage: less than 1 V @ 10 mA; less than 1.5 Retroreflective mode models (only): Single-turn sensitivity (Gain) V @ 100 mA adjustment potentiometer Protected against false pulse on power-up and continuous overload or Indicators short circuit of outputs 2 LED indicators on sensor top: Output Response Green solid: Power on Opposed Mode: 750 microseconds ON; 375 microseconds OFF Amber solid: Light sensed FF Mode: 850 microseconds ON/OFF Green flashing: Output overloaded All others: 600 microseconds ON/OFF Amber flashing: Marginal excess gain (1 to 1.5x excess gain) Note: 100 millisecond delay on power-up; outputs do not conduct Note:Prior to date code 0223, the output indicator was red. during this time Required Overcurrent Protection Construction ABS housing WARNING: Electrical connections must be 3 mm mounting hardware included made by qualified personnel in accordance with local and national electrical codes and Connections regulations. 2 m (6.5 ft) 4-wire PVC cable, 9 m (30 ft) 4-wire PVC cable, 4-pin Picostyle or Euro-style QD, 4-pin Pico-style or Euro-style 150 mm (6 in) Overcurrent protection is required to be provided by end product pigtail QD, depending on model application per the supplied table. Environmental Overcurrent protection may be provided with external fusing or via IEC IP67; NEMA 6 Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. Operating Conditions For additional product support, go to http:// Temperature: –20 °C to 70 °C (–4 °F to 158 °F) www.bannerengineering.com. Relative Humidity: 90% @ 50 °C (non-condensing) 4 Supply Wiring Required Overcurrent Protection 20 5.0 Amps 22 3.0 Amps 24 2.0 Amps 26 1.0 Amps 28 0.8 Amps 30 0.5 Amps Certifications—All models Certifications—QS18Vx6FFxxx models www.bannerengineering.com - Tel: +1-763-544-3164 P/N 63908 Rev. I WORLD-BEAM QS18 Dimensions and Features Model Suffix E, EV, R, and FF 15.0 mm (0.59") Model Suffix DB, W Model Suffix EB, RB 31.0 mm (1.22") 17.1 mm (0.67") Yellow LED 3.0 mm (0.12") 3.0 mm (0.12") 3.0 mm (0.12") 24.1 mm (0.95") 21.1 mm (0.82") 21.1 mm (0.82") Green LED 35.0 mm (1.38") Ø3.3 mm (0.13") Max. torque 0.6 Nm (5 in-lbs) Model Suffix FP 27.5 mm (1.09") Single-turn Sensitivity Adjustment 15.0 mm (0.59") 17.1 mm (0.67") Model Suffix F Model Suffix CV15, CV45, D, LV, LP 7.5 mm (0.30") 31.0 mm (1.22") † 36.9 mm (1.45") 3.0 mm (0.12") 17.1 mm (0.67") † 13.4 mm (0.53") 19.8 mm (0.78") CV Models: 33.2 mm (1.31") 5.2 mm (0.21") 7.6 mm (0.30") M18x1 Thread Max. torque 2.3 Nm (20 in-lbs) Model Suffix Q5 Model Suffix Q (e.g. QS186EQ5) (e.g. QS186EQ) Model Suffix Q7 Model Suffix Q8 (e.g. QS186EQ7) (e.g. QS186EQ8) 41.5 mm (1.63") 150 mm (6") Euro-style Pigtail 150 mm (6") Pico-style Pigtail Integral 4-pin Pico-Style QD 49 mm (1.93") Integral 4-pin Euro-Style QD M18 x 1 Jam Nut 24.2 mm (0.95") Slot for Fiber Clip Packing List M3 hardware packet contents: Sensor 2 - M3 x 0.5 x 20 mm stainless steel screw M18 x 1 jam nut 2 - M3 x 0.5 stainless steel hex nut M3 hardware packet 2 - M3 stainless steel washer Installation sheet, p/n 63687 8.0 mm (0.32") P/N 63908 Rev. I www.bannerengineering.com - Tel: +1-763-544-3164 5 WORLD-BEAM QS18 Performance Curves Opposed Mode Excess Gain Curve Beam Pattern 1000 E X C E S S G A I N 30 in Opposed Mode 500 mm Opposed Mode 20 in 250 mm 100 10 in 0 0 10 250 mm 10 in 500 mm 20 in 750 mm 30 in 0 4m 12 ft 8m 26 ft 12 m 40 ft 16 m 52 ft 20 m 66 ft DISTANCE 1 0.1 m 0.3 ft 1m 3.3 ft 10 m 33 ft E X C E S S G A I N QS186EB and QS18...RB 100 QS18...LP 30 mm Retroreflective Mode 20 mm 18 in .75 m 2.5 ft 1.5 m 5 ft 2.25 m 7.5 ft 3.0 m 10 ft 3.75 m 12.5 ft DISTANCE 0.1 m 0.33 ft 1m 3.3 ft 10 m 33 ft Excess Gain Curve 1.2 in 0.8 in Retroreflective Mode 0.4 in with BRT-84 Reflector 0 0 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in 0 .75 m 2.5 ft 1.5 m 5 ft 2.25 m 7.5 ft 3.0 m 10 ft 3.75 m 12.5 ft DISTANCE 1m 3.3 ft 12 in Beam Pattern 1000 QS18...LP 10 mm 100 0.1 m 0.33 ft 6 in 300 mm Retroreflective Beam Pattern 1000 1 0.01 m 0.03 ft 0 150 mm DISTANCE Excess Gain Curve 10 6 in 450 mm Polarized Retroreflective G A I N 12 in 150 mm 0 1 0.01 m 0.03 ft 18 in Opposed Mode 300 mm 0 10 100 m 330 ft with BRT-84 Reflector QS186EB and QS18...RB 450 mm Opposed Mode DISTANCE E X C E S S Beam Pattern 1000 QS186E, EV and QS18...R 750 mm QS186E, EV and QS18...R Excess Gain Curve E X C E S S G A I N 150 mm 100 mm QS18...LV 10 4 in 2 in with BRT-84 Reflector 0 0 50 mm 2 in 100 mm 4 in 150 mm with BRT-84 Reflector 6 in 0 DISTANCE 6 in Retroreflective Mode 50 mm 100 1 0.01 m 0.03 ft 10 m 33 ft QS18...LV Retroreflective Mode 1.5 m 5 ft 3.0 m 10 ft 4.5 m 15 ft 6.0 m 20 ft 7.5 m 25 ft DISTANCE 0.1 m 0.33 ft 1m 3.3 ft 10 m 33 ft DISTANCE Convergent (Performance is based on a 90% reflectance white test card.) Excess Gain Curve Beam Pattern 1000 E X C E S S G A I N QS18...CV15 100 .16 in 2 mm .08 in 0 10 0 2 mm .08 in 4 mm .16 in 6 mm .24 in 0 1 1 mm 0.04 in .24 in Convergent Mode 4 mm Convergent Mode 1000 QS18...CV15 6 mm Excess Gain Curve 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in 40 mm 1.6 in 50 mm 2.0 in DISTANCE 10 mm 0.4 in 100 mm 4.0 in E X C E S S G A I N QS18...CV45 QS18...CV45 6 mm Convergent Mode 100 .16 in 2 mm .08 in 0 0 2 mm .08 in 4 mm .16 in 6 mm 10 .24 in 0 DISTANCE .24 in Convergent Mode 4 mm 1 1 mm 0.04 in 1000 mm 40.0 in Beam Pattern 15 mm 0.6 in 30 mm 1.2 in 45 mm 1.8 in 60 mm 2.4 in 75 mm 3.0 in DISTANCE 10 mm 0.4 in 100 mm 4.0 in 1000 mm 40.0 in DISTANCE Diffuse (Performance is based on a 90% reflectance white test card.) Excess Gain Curve Beam Pattern 1000 E X C E S S G A I N QS18...D Diffuse Mode .08 in 0 10 0 2 mm .08 in 4 mm .16 in 6 mm .24 in 0 100 mm 4.0 in 200 mm 8.0 in 300 mm 12.0 in DISTANCE 10 mm 0.4 in 100 mm 4.0 in DISTANCE 6 .16 in 2 mm 100 1 1 mm 0.04 in .24 in Diffuse Mode 4 mm 1000 mm 40.0 in Beam Pattern 1000 QS18...D 6 mm Excess Gain Curve 400mm 16.0 in 500 mm 20.0 in E X C E S S G A I N QS18...DB QS18...DB 30 mm Diffuse Mode 0.8 in 10 mm 100 0.4 in 0 10 0 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in 0 1 1 mm 0.04 in 1.2 in Diffuse Mode 20 mm 100 mm 4.0 in 200 mm 8.0 in 300 mm 12.0 in 400mm 16.0 in 500 mm 20.0 in DISTANCE 10 mm 0.4 in 100 mm 4.0 in 1000 mm 40.0 in DISTANCE www.bannerengineering.com - Tel: +1-763-544-3164 P/N 63908 Rev. I WORLD-BEAM QS18 Divergent (Performance is based on a 90% reflectance white test card.) Excess Gain Curve Beam Pattern 1000 QS18...W 30 mm QS18...W E X C E S S Divergent Diffuse Mode 100 G A I N 1.2 in Divergent Diffuse Mode 20 mm 0.8 in 10 mm 0.4 in 0 10 0 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in 0 20 mm 0.8 in 40 mm 1.6 in 60 mm 2.4 in 80 mm 3.2 in 100 mm 4.0 in DISTANCE 1 1 mm 0.04 in 10 mm 0.4 in 100 mm 4.0 in 1000 mm 40.0 in DISTANCE Fixed Field - 50 mm Excess Gain Curve Spot Sizes G A I N Excess Gain Curve At 25 mm: 7.5 × 5.7 mm At 50 mm: 6.3 × 4.9 mm 1000 E X C E S S Fixed Field - 100 mm QS18...FF50 Fixed-Field 100 10 1 0.1 mm 0.004 in G A I N 1.0 mm 0.04 in 10.0 mm 0.4 in Excess Gain Curve PIT66U 20 mm Opposed Mode Plastic Fibers 1.6 in 0.8 in PIT46U 0 0 20 mm 0.8 in 40 mm 1.6 in Opposed Mode Plastic Fibers 60 mm PIT46U Fiber 0 50 mm 2 in 2.4 in 100 mm 4 in 150 mm 6 in 200 mm 250 mm 8 in 10 in DISTANCE 10 mm .40 in 100 mm 4.0 in E X C E S S G A I N 100 1000 mm 40 in G A I N Opposed Mode Glass Fibers 3 in Opposed Mode 2 in 25 mm 1 in IT13S IT23S 25 mm 50 mm IT23S Fibers 2 in 3 in 0 100 mm 4 in 200 mm 8 in 300 mm 12 in DISTANCE 1m 3.3 ft P/N 63908 Rev. I 10 m 33 ft 0 1 in 75 mm DISTANCE 10 mm PBT66U Fiber 0.4 in 0 10 mm 0.4 in PBT46U 20 mm 10 0.8 in 30 mm 1.2 in 0 20 mm 0.8 in PBT46U Fiber 40 mm 1.6 in 60 mm 2.4 in 80 mm 3.2 in 100 mm 4.8 in DISTANCE 1 mm .04 in 10 mm .4 in 100 mm 4 in Excess Gain Curve 50 mm 0 10 .1 m .33 ft 0.8 in PBT66U 0 1000 QS18F 75 mm IT23S Fibers w/L9 lenses 1 .01 m .033 ft 1.2 in Diffuse Mode Plastic Fibers Bifurcated - Glass Fiber (Performance is based on a 90% reflectance white test card.) Beam Pattern QS18F IT13S Fibers QS18..FP QS18..FP 20 mm DISTANCE Excess Gain Curve 100 Beam Pattern 30 mm Diffuse Mode Plastic Fibers 1 .1 mm .004 in Opposed - Glass Fiber (Performance is based on a 90% reflectance white test card.) 1000 100 mm 4.0 in QS18..FP QS18..FP DISTANCE E X C E S S 10.0 mm 0.4 in Excess Gain Curve 2.4 in 40 mm 10 1 1 mm .04 in 1.0 mm 0.04 in 1000 QS18..FP QS18..FP 60 mm PIT66U Fiber G A I N 10 Bifurcated - Plastic Fiber (Performance is based on a 90% reflectance white test card.) Beam Pattern QS18..FP QS18..FP 100 Fixed-Field 100 DISTANCE Opposed - Plastic Fiber 1000 QS18...FF100 1 0.1 mm 0.004 in 100 mm 4.0 in DISTANCE E X C E S S At 50 mm: 6.1 × 4.6 mm At 100 mm: 2.9 × 2.9 mm 1000 E X C E S S Spot Sizes 400 mm 500 mm 16 in 20 in E X C E S S G A I N QS18F 1.9 mm 0.65 mm BT23S Fiber 0.025 in BT13S BT23S 0.025 in 1.3 mm 0.050 in 1.9 mm BT13S Fiber 0 0.65 mm 0.075 in 0 1 1 mm .04 in 0.050 in Diffuse Mode 0 10 0.075 in QS18F 1.3 mm Diffuse Mode Glass Fibers 100 Beam Pattern 7.5 mm 0.3 in 15 mm 0.6 in 22.5 mm 0.9 in 30 mm 1.2 in 37.5 mm 1.5 in DISTANCE 10 mm .4 in 100 mm 4 in 1000 mm 40 in DISTANCE www.bannerengineering.com - Tel: +1-763-544-3164 7 WORLD-BEAM QS18 Accessories Cordsets 4-Pin Threaded M12/Euro-Style Cordsets Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 2 1 3 4 32 Typ. [1.26"] 1 = Brown 30 Typ. [1.18"] Right-Angle MQDC-450RA Pinout (Female) 2 = White 3 = Blue 4 = Black 15.2 m (50 ft) M12 x 1 ø 14.5 [0.57"] 4-Pin Snap-on M8/Pico-Style Cordsets Model Length Style Dimensions Pinout (Female) 32 Typ. PKG4-2 2 m (6.56 ft) Straight 4 ø 9.0 2 1 3 29 Typ. 1 = Brown PKW4Z-2 2 m (6.56 ft) Right-Angle 2 = White 15 Typ. 3 = Blue 4 = Black ø 10.9 WORLD-BEAM QS18 Brackets SMB18A • SMB312S Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware • 30 C A B Stainless steel 2-axis, side-mount bracket 41 46 C A B 32 46 20 A = 4.3 × 7.5, B = diam. 3, C = 3 × 15.3 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 All measurements are in millimeters. 8 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 63908 Rev. I WORLD-BEAM QS18 Retroreflective Targets See the Accessories section of your current Banner Engineering Corp catalog for complete information. NOTE: Polarized sensors require corner cube type retroreflective targets only. Plastic and Glass Fiber Optics See the Accessories section of your current Banner Engineering Corp catalog for a list of plastic and glass fiber optic cables. Banner Engineering Corp Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. www.bannerengineering.com - Tel: +1-763-544-3164
QS18VN6AF300 W/30 价格&库存
很抱歉,暂时无法提供与“QS18VN6AF300 W/30”相匹配的价格&库存,您可以联系我们找货
