S-8229AAJ-M6T1U
S-8229AAJ-M6T1U
    ABLIC(艾普凌科)
    SOT23-6
    IC BATT MONITOR LI-ION SOT23-6
S-8229AAJ-M6T1U 数据手册
S-8229A Series www.ablic.com BATTERY MONITORING IC Rev.2.0_00 © ABLIC Inc., 2012-2020 The S-8229A Series is a battery monitoring IC developed using CMOS technology. Compared with conventional CMOS voltage detectors, the S-8229A Series is ideal for the applications that require high-withstand voltage due to its maximum operation voltage as high as 24 V. The S-8229A Series is capable of confirming the voltage in stages since it detects three voltage values.  Features • Detection voltage accuracy: • Hysteresis characteristics: • Current consumption: • Operation voltage range: • Detection voltage: • • • • Output form: Output logic*2: Operation temperature range: Lead-free (Sn 100%), halogen-free *1. *2. ±1.0% VHYS1 to VHYS3 = 0 mV, 50 mV, 300 mV, 400 mV, 500 mV During operation: IDD1 = 9.0 μA max. (−VDETtotal*1 ≥ 42 V) IDD1 = 11.0 μA max. (−VDETtotal*1 < 42 V) During power-off: IDD2 = 0.1 μA max. VDD = 3.6 V to 24 V −VDET1(S) to −VDET2(S) = 10.5 V to 21.5 V (0.1 V step) −VDET3(S) = 7.5 V to 21.5 V (0.1 V step) Nch open-drain output Full charge all on, full charge all off Ta = −40°C to +85°C −VDETtotal: Total detection voltage −VDETtotal = −VDET1(S) + −VDET2(S) + −VDET3(S) Full charge all on: When the input voltage is equal to or higher than each of the three detection voltage values, VOUT1 = VOUT2 = VOUT3 = VSS. Full charge all off: When the input voltage is equal to or higher than each of the three detection voltage values, VOUT1 = VOUT2 = VOUT3 = "High-Z".  Application • Rechargeable lithium-ion battery pack  Packages • SOT-23-6 • SNT-6A 1 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Block Diagram VDD OUT1 ON / OFF + Nch 1 − OUT2 + Nch 2 − OUT3 + VREF − VSS Remark Diodes in the figure are parasitic diodes. Figure 1 2 Nch 3 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Product Name Structure 1. Product name S-8229 A xx - xxxx U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M6T1: SOT-23-6, Tape I6T1: SNT-6A, Tape Serial code*2 Sequentially set from AA to ZZ *1. *2. 2. Refer to the tape drawing. Refer to "3. Product name list". Packages Table 1 Package Name SOT-23-6 SNT-6A Package Drawing Codes Dimension Tape Reel MP006-A-P-SD PG006-A-P-SD MP006-A-C-SD PG006-A-C-SD MP006-A-R-SD PG006-A-R-SD Land − PG006-A-L-SD 3 BATTERY MONITORING IC S-8229A Series 3. Rev.2.0_00 Product name list 3. 1 SOT-23-6 Table 2 Detection Detection Detection Hysteresis Hysteresis Voltage 1 Voltage 2 Voltage 3 Width 2 Width 1 [−VDET1(S)] [−VDET2(S)] [−VDET3(S)] [VHYS1(S)] [VHYS2(S)] S-8229AAA-M6T1U 19.400 V 18.100 V 15.300 V 0V 0V S-8229AAB-M6T1U 19.400 V 18.100 V 15.300 V 0.500 V 0.500 V S-8229AAC-M6T1U 19.500 V 18.000 V 15.500 V 0.050 V 0.050 V S-8229AAG-M6T1U 15.600 V 14.800 V 13.600 V 0.500 V 0.500 V S-8229AAH-M6T1U 20.000 V 18.500 V 16.000 V 0.500 V 0.500 V S-8229AAI-M6T1U 20.000 V 18.500 V 16.000 V 0.050 V 0.050 V S-8229AAJ-M6T1U 15.100 V 14.300 V 13.100 V 0.500 V 0.500 V S-8229AAK-M6T1U 15.600 V 14.400 V 12.400 V 0V 0V S-8229AAL-M6T1U 19.000 V 17.500 V 15.000 V 0V 0V S-8229AAM-M6T1U 19.200 V 17.900 V 12.500 V 0V 0V S-8229AAN-M6T1U 11.500 V 10.700 V 7.500 V 0V 0V S-8229AAO-M6T1U 19.900 V 19.000 V 18.100 V 0V 0V *1. Full charge all on: When the input voltage is equal to or higher than each values, VOUT1 = VOUT2 = VOUT3 = VSS. Full charge all off: When the input voltage is equal to or higher than each values, VOUT1 = VOUT2 = VOUT3 = "High-Z". Product Name Remark 3. 2 Hysteresis Width 3 Output Logic*1 [VHYS3(S)] 0V Full charge all on 0.500 V Full charge all on 0.050 V Full charge all on 0.500 V Full charge all on 0.500 V Full charge all on 0.050 V Full charge all on 0.500 V Full charge all on 0V Full charge all on 0V Full charge all on 0V Full charge all on 0V Full charge all on 0V Full charge all on of the three detection voltage of the three detection voltage Please contact our sales representatives for products other than the above. SNT-6A Table 3 Detection Detection Detection Hysteresis Hysteresis Voltage 1 Voltage 2 Voltage 3 Width 2 Width 1 [−VDET1(S)] [−VDET2(S)] [−VDET3(S)] [VHYS1(S)] [VHYS2(S)] S-8229AAF-I6T1U 18.000 V 15.000 V 21.500 V 0.050 V 0.050 V *1. Full charge all on: When the input voltage is equal to or higher than each values, VOUT1 = VOUT2 = VOUT3 = VSS. Full charge all off: When the input voltage is equal to or higher than each values, VOUT1 = VOUT2 = VOUT3 = "High-Z". Product Name Remark 4 Hysteresis Width 3 Output Logic*1 [VHYS3(S)] 0.050 V Full charge all on of the three detection voltage of the three detection voltage Please contact our sales representatives for products other than the above. BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Pin Configurations 1. SOT-23-6 Top view Table 4 6 5 4 Pin No. 1 2 3 4 5 6 1 2 3 Figure 2 2. Symbol OUT1 OUT2 OUT3 VSS VDD ON / OFF Description Voltage detection output pin 1 Voltage detection output pin 2 Voltage detection output pin 3 GND pin Voltage input pin ON / OFF pin SNT-6A Top view 1 2 3 Table 5 6 5 4 Figure 3 Pin No. 1 2 3 4 5 6 Symbol OUT3 OUT2 OUT1 ON / OFF VDD VSS Description Voltage detection output pin 3 Voltage detection output pin 2 Voltage detection output pin 1 ON / OFF pin Voltage input pin GND pin 5 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Absolute Maximum Ratings Table 6 (Ta = +25°C unless otherwise specified) Item Symbol Absolute Maximum Rating Unit VSS − 0.3 to VSS + 26 VDD V Input voltage VSS − 0.3 to VSS + 26 VON / OFF V VSS − 0.3 to VSS + 26 Output voltage n VOUTn V −40 to +85 Operation ambient temperature Topr °C −40 to +125 Storage temperature Tstg °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Remark n = 1 to 3  Thermal Resistance Value Item Symbol Table 7 Condition Board A Board B Board C SOT-23-6 Board D Board E Junction-to-ambient thermal resistance*1 θJA Board A Board B SNT-6A Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark 6 Refer to " Power Dissipation" and "Test Board" for details. Min. − − − − − − − − − − Typ. 159 124 − − − 224 176 − − − Max. − − − − − − − − − − Unit °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Electrical Characteristics Table 8 (Ta = +25°C unless otherwise specified) Item Symbol Detection voltage n*1 −VDETn Hysteresis width n*2 VHYSn ON / OFF pin input voltage "H" ON / OFF pin input voltage "L" Operation voltage range between VDD pin and VSS pin Condition Test Circuit V 1 V 1 V 1 V1 = V3 = 22 V 1.5 − − V 1 VSL V1 = V3 = 22 V − − 0.3 V 1 3.6 − 24 V − − 4.0 9.0 μA 2 − 5.0 11.0 μA 2 − − 0.1 μA 2 10 − − mA 3 5 − − mA 3 − − 0.1 μA 3 − ±100 ±200 ppm/°C 1 VDD − V1 = 22 V, V2 = 0 V IOUTn Full charge all on, V1 = 22 V, V2 = 3 V, V3 = 1 V Full charge all off, V1 = 10 V, V2 = 3 V, V3 = 1 V V1 = 22 V, V2 = 0 V, V3 = 22 V Output leak current n ILEAKn Detection voltage temperature coefficient*4 Δ−VDETn Ta = −40°C to +85°C*5 ΔTa • −VDETn *5. Unit VSH Current consumption during IDD2 power-off *4. Max. −VDETn(S) −VDETn(S) −VDETn(S) × 0.99 × 1.01 −VHYSn(S) −VHYSn(S) −VHYSn(S) 300 mV ≤ VHYSn(S) ≤ 500 mV × 0.8 × 1.2 −VHYSn(S) −VHYSn(S) −VHYSn(S) 0 V ≤ VHYSn(S) ≤ 50 mV − 0.025 + 0.025 V1 = 22 V, V2 = 3 V, −VDETtotal*3 ≥ 42 V V1 = 22 V, V2 = 3 V, −VDETtotal*3 < 42 V *1. *2. *3. Typ. − Current consumption during IDD1 operation Output sink current n Min. −VDETn: Actual detection voltage value, −VDETn(S): Set detection voltage VHYSn: Actual hysteresis width, −VHYSn(S): Set hysteresis width −VDETtotal: Total detection voltage −VDETtotal = −VDET1(S) + −VDET2(S) + −VDET3(S) The Change in temperature of the detection voltage [mV/°C] is calculated by using the following equation. Δ − VDETn Δ − VDETn [mV/°C]*1 = −VDETn(S) (typ.) [V]*2 × [ppm/°C]*3 ÷ 1000 ΔTa ΔTa • −VDETn *1. Change in temperature of the detection voltage *2. Set detection voltage *3. Detection voltage temperature coefficient Since products are not screened at high and low temperature, the specification for this temperature range is guaranteed by design, not tested in production. Remark n = 1 to 3 7 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Test Circuits 100 kΩ 100 kΩ 100 kΩ OUT1 VDD V3 OUT2 ON / OFF V1 OUT3 VSS VOUT1 V2 V Figure 4 VOUT2 V VOUT3 V Test Circuit 1 IDD A OUT1 VDD OUT2 ON / OFF V1 VSS V2 Figure 5 Test Circuit 2 IOUT1 A VDD V1 VSS OUT3 V2 Figure 6 8 IOUT2 A IOUT3 A OUT1 OUT2 ON / OFF OUT3 Test Circuit 3 V3 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Standard Circuit ROUT1 R1 VDD ROUT2 ROUT3 OUT1 OUT2 C1 ON / OFF VSS OUT3 Figure 7 Table 9 Symbol Purpose Constants for External Components Typ. R1*1 For power fluctuation 470 Ω C1 For power fluctuation 0.1 μF ROUTn*2 For output pin pull-up 100 kΩ Remark Set the value as small as possible to prevent deterioration of the detection voltage. Set R1 × C1 ≥ 40 × 10−6. Make sure the power dissipation of the S-8229A Series is not exceeded. *1. Set up R1 as 100 kΩ or less to prevent oscillation. *2. Set up each of ROUTn as 620 Ω or more so that the power dissipation is not exceeded. Caution 1. The constants may be changed without notice. 2. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. Remark n = 1 to 3 9 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Operation 1. Basic operation The basic operation when VON / OFF ≥ VSH is shown as follows. 1. 1 When the power supply voltage (VDD) increases The OUTn pin becomes release status if VDD is equal to or higher than the release voltage (+VDETn). Table 10 Set Conditions at Releasing Output Logic Full charge all on Full charge all off 1. 2 VOUTn VSS High-Z Nch n On Off When VDD decreases The OUTn pin becomes detection status if VDD is equal to or lower than the detection voltage (−VDETn). Table 11 Set Conditions at Detecting Output Logic Full charge all on Full charge all off 1. 3 VOUTn High-Z VSS Nch n Off On When VDD ≤ minimum operation voltage The OUTn pin voltage is indefinite. Remark 2. n = 1 to 3 ON / OFF pin This pin starts and stops the S-8229A Series. When VON / OFF is set to VSL or lower, the entire internal circuit stops operating, and Nch n (refer to Figure 1 in " Block Diagram") is turned off, reducing current consumption significantly. The ON / OFF pin is configured as shown in Figure 8. The ON / OFF pin is not internally pulled up or pulled down, so do not use the ON / OFF pin in the floating status. When not using the ON / OFF pin, connect the pin to the VDD pin. VDD ON / OFF VSS Figure 8 Remark 10 n = 1 to 3 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Timing Charts 1. Nch open-drain output (full charge all on, VON / OFF ≥ VSH) +VDET1 −VDET1 +VDET2 −VDET2 VDD pin voltage +VDET3 −VDET3 Minimum operation voltage High-Z OUT1 pin voltage VSS High-Z OUT2 pin voltage VSS High-Z OUT3 pin voltage VSS Figure 9 Remark When VDD is equal to or lower than the minimum operation voltage, the output voltage from the OUT1 pin to the OUT3 pin is indefinite in the shaded area. 11 BATTERY MONITORING IC S-8229A Series 2. Rev.2.0_00 Nch open-drain output (full charge all off, VON / OFF ≥ VSH) +VDET1 −VDET1 +VDET2 −VDET2 VDD pin voltage +VDET3 −VDET3 Minimum operation voltage High-Z OUT1 pin voltage VSS High-Z OUT2 pin voltage VSS High-Z OUT3 pin voltage VSS Figure 10 Remark 12 When VDD is equal to or lower than the minimum operation voltage, the output voltage from the OUT1 pin to the OUT3 pin is indefinite in the shaded area. BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Application Circuits 1. Detection of residual quantity of the battery used by LED R1 OUT1 VDD ROUT1 ROUT2 ROUT3 LED1 LED2 LED3 OUT2 C1 ON / OFF VSS OUT3 Figure 11 Caution 1. 2. 2. The constants may be changed without notice. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. Change of detection voltage When the detection voltage is changed by using a resistance divider, set RA ≤ 100 kΩ to prevent oscillation, as shown in Figure 12. The detection voltage after changing is calculated by using the following equation. Detection voltage = RA + RB × −VDETn + RA × IDD RB ROUT1 ROUT2 ROUT3 RA OUT1 VDD RB OUT2 C1 ON / OFF VSS OUT3 Figure 12 Caution 1. 2. 3. Remark Note that the detection voltage may deviate from the value determined by the ratio of RA and RB in the case of the above connection diagram. The constants may be changed without notice. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. n = 1 to 3 13 BATTERY MONITORING IC S-8229A Series 3. Rev.2.0_00 Short-circuit of the output pin In the case of −VDET1(S) = −VDET2(S) = −VDET3(S), +VDET1 = +VDET2 = +VDET3, the load current can be increased by short-circuiting the output pin, as shown in Figure 13. ROUT*1 R1 OUT1 VDD OUT2 C1 ON / OFF *1. VSS OUT3 Set up ROUT as 220 Ω or more so that the power dissipation is not exceeded. Figure 13 Caution 1. 2. 14 The constants may be changed without notice. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. Rev.2.0_00 BATTERY MONITORING IC S-8229A Series  Precautions • The application conditions for the input voltage, output voltage, and output pin pull-up resistance should not exceed the package power dissipation. • Wiring patterns for the VDD pin, the VOUT pin and the VSS pin should be designed so that the impedance is low. • Note that the detection voltage may deviate due to the resistance component of output sink current and the VSS pin wiring. • In applications where a resistor is connected to the input (refer to Figure 7 in " Standard Circuit"), the feed-through current which is generated when the output switches causes a voltage drop equal to feed-through current × input resistance. In this state, the feed-through current stops and its resultant voltage drop disappears, and the output switches. The feed-through current is then generated again, a voltage drop appears. Note that an oscillation may be generated for this reason. • When designing for mass production using an application circuit described herein, the product deviation and temperature characteristics should be taken into consideration. ABLIC Inc. shall not bear any responsibility for patent infringements related to products using the circuits described herein. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 15 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Characteristics (Typical Data) 1. Detection voltage 1. 1 −VDETn vs. Ta −VDETn(S) = 17.5 V 17.7 21.6 17.6 −VDETn [V] −VDETn [V] −VDETn(S) = 21.5 V 21.7 21.5 21.4 21.3 −40 −25 17.5 17.4 17.3 0 25 Ta [°C] 50 75 85 −40 −25 0 25 Ta [°C] 50 75 85 −VDETn(S) = 10.5 V 10.60 −VDETn [V] 10.55 10.50 10.45 10.40 2. −40 −25 0 25 Ta [°C] 50 75 85 Hysteresis width 2. 1 −VHYSn vs. Ta −VHYSn(S) = 0.5 V −VHYSn(S) = 0.3 V 0.36 0.60 0.34 VHYSn [V] VHYSn [V] 0.55 0.50 0.45 0.40 −40 −25 25 Ta [°C] 50 75 85 VHYSn [V] 0.07 0.06 0.05 0.04 0.03 16 0.28 0.24 0 −VHYSn(S) = 0.05 V Remark 0.30 0.26 0.08 0.02 0.32 −40 −25 n = 1 to 3 0 25 Ta [°C] 50 75 85 −40 −25 0 25 Ta [°C] 50 75 85 BATTERY MONITORING IC S-8229A Series Rev.2.0_00 3. Current consumption 3. 1 IDD1 vs. VDD 3. 2 Ta = +25°C S-8229AAA 12 S-8229AAA 6.0 IDD1 [μA] IDD1 [μA] 9 6 3 0 5 10 15 VDD [V] 20 VDD = 22 V 4.0 2.0 0 0 3. 3 IDD1 vs. Ta 25 −40 −25 0 25 Ta [°C] 75 85 50 IDD2 vs. Ta S-8229AAA 0.10 VDD = 22 V IDD2 [μA] 0.08 0.06 0.04 0.02 0 0 25 Ta [°C] 50 75 85 Output current 4. 1 IOUTn vs. VOUTn 4. 2 IOUTn vs. VDD VDD = 22 V 120 VOUTn = 1 V 70 Ta = −40°C 100 Ta = +25°C 80 60 Ta = +85°C 40 40 30 20 0 10 Remark 0.5 1.0 VOUTn [V] 1.5 2.0 Ta = +25°C 50 20 0 Ta = −40°C 60 IOUTn [mA] IOUTn [mA] 4. −40 −25 Ta = +85°C 5 10 15 20 VDD [V] 25 30 n = 1 to 3 17 BATTERY MONITORING IC S-8229A Series 5. Rev.2.0_00 Response time 5. 1 tDETn vs. Δ−VDETn 5. 2 tRELn vs. Δ+VDETn Δ−VDETn = −VDETn − VDD, Ta = +25°C Δ+VDETn = VDD − (+VDETn), Ta = +25°C 20 100 −VDETn = 21.5 V −VDETn = 17.5 V 60 tRELn [ms] tDETn [ms] 80 −VDETn = 10.5 V 40 20 0 +VDETn = 22.0 V 15 +VDETn = 17.5 V 10 +VDETn = 10.5 V 5 0 1 10 100 Δ−VDETn [mV] 1000 1 10 100 Δ+VDETn [mV] Δ + VDETn +VDETn VDD pin voltage −VDETn Δ − VDETn VOUTn OUTn pin voltage (Full charge all on) VDD tDETn tRELn tDETn tRELn VSS VOUTn OUTn pin voltage (Full charge all off) VDD VSS Figure 14 Remark 1. 2. 18 Refer to "Figure 4 n = 1 to 3 Test Condition of Response Time Test Circuit 1" for the test condition of the response time. 1000 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Marking Specifications 1. SOT-23-6 Top view 6 5 (1) to (3): (4): 4 Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code Product Code (1) (2) (3) Y S A Y S B Y S C Y S G Y S H Y S I Y S J Y S K Y S L Y S M Y S N Y S O Product Name S-8229AAA-M6T1U S-8229AAB-M6T1U S-8229AAC-M6T1U S-8229AAG-M6T1U S-8229AAH-M6T1U S-8229AAI-M6T1U S-8229AAJ-M6T1U S-8229AAK-M6T1U S-8229AAL-M6T1U S-8229AAM-M6T1U S-8229AAN-M6T1U S-8229AAO-M6T1U 2. SNT-6A Top view 6 5 (1) to (3): (4) to (6): 4 Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) (5) (6) 1 2 3 Product name vs. Product code Product Name S-8229AAF-I6T1U Product Code (1) (2) (3) Y S F 19 BATTERY MONITORING IC S-8229A Series Rev.2.0_00  Power Dissipation SOT-23-6 SNT-6A Tj = +125°C max. 0.8 B 0.6 A 0.4 0.2 0.0 0 25 50 75 100 125 150 175 Tj = +125°C max. 1.0 Power dissipation (PD) [W] Power dissipation (PD) [W] 1.0 0.8 B 0.6 A 0.4 0.2 0.0 0 25 Ambient temperature (Ta) [°C] Board A B C D E 20 Power Dissipation (PD) 0.63 W 0.81 W − − − 50 75 100 125 150 Ambient temperature (Ta) [°C] Board A B C D E Power Dissipation (PD) 0.45 W 0.57 W − − − 175 SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. SNT-6A Test Board (1) Board A IC Mount Area Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SNT6A-A-Board-SD-1.0 ABLIC Inc. 2.9±0.2 1.9±0.2 6 0.95 4 5 1 2 3 +0.1 0.15 -0.05 0.95 0.35±0.15 No. MP006-A-P-SD-2.1 TITLE SOT236-A-PKG Dimensions No. MP006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 6 Feed direction No. MP006-A-C-SD-3.1 TITLE SOT236-A-Carrier Tape No. MP006-A-C-SD-3.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP006-A-R-SD-2.1 TITLE SOT236-A-Reel No. MP006-A-R-SD-2.1 ANGLE QTY UNIT mm ABLIC Inc. 3,000 1.57±0.03 6 1 5 4 2 3 +0.05 0.08 -0.02 0.5 0.48±0.02 0.2±0.05 No. PG006-A-P-SD-2.1 TITLE SNT-6A-A-PKG Dimensions No. PG006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 0.25±0.05 +0.1 1.85±0.05 ø0.5 -0 4.0±0.1 0.65±0.05 3 2 1 4 5 6 Feed direction No. PG006-A-C-SD-2.0 TITLE SNT-6A-A-Carrier Tape No. PG006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PG006-A-R-SD-1.0 SNT-6A-A-Reel TITLE No. PG006-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 5,000 0.52 1.36 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package ( 1.30 mm ~ 1.40 mm ). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) No. PG006-A-L-SD-4.1 TITLE SNT-6A-A -Land Recommendation No. PG006-A-L-SD-4.1 ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-8229AAJ-M6T1U 价格&库存
很抱歉,暂时无法提供与“S-8229AAJ-M6T1U”相匹配的价格&库存,您可以联系我们找货
