DQ12AB6FF30
DQ12AB6FF30
    BANNER(邦纳)
    WORLD-BEAM DQ12 SERIES: FIXED-FI
DQ12AB6FF30 数据手册
WORLD-BEAM® DQ12 Series Sensor Datasheet Miniature self-contained photoelectric sensors in universal housing • • • • • • • • • Bright, visible red (645 nm) light source Standard models available with 4-wire, 2 m (6.5 ft) long cable; 150 mm (6 in) PVC cable with a 3-pin M8/Pico-style male quick disconnect; or a 150 mm (6 in) PVC cable with a 4-pin M8/Picostyle male quick disconnect Solid-state, bipolar outputs: one current sourcing (PNP) and one current sinking (NPN) standard on 4-wire models Single output solid-state PNP or NPN standard on Q3 models Light Operate (L.O.) or Dark Operate (D.O.), depending on model Compact 8 mm (0.31 in) housing mounts almost anywhere Crosstalk avoidance circuitry for applications with multiple sensors LED status indicators for Power ON, Signal Received, and Marginal Signal Advanced ASIC technology makes sensor resistant to optical and electrical noise source WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Models Model1 Sensing Mode Visible red, 645 nm Range DQ126E (emitter) DQ12AB6R DQ12AP6RQ3 Effective Beam: 5.7 mm (0.22 in) Output N/A 2 m (6.5 ft) cable DQ12RB6R OPPOSED Connection 2 m (6.5 ft) cable 1 PNP LO 3m DQ12RP6RQ3 150 mm (6 in) cable with a 3-pin M8/Pico-style QD DQ12AN6RQ3 DQ12RN6RQ3 2 m (6.5 ft) cable DQ12RB6LP DQ12AP6LPQ3 POLAR RETRO Visible red, 645 nm 150 mm (6 in) cable with a 3-pin M8/Pico-style QD DQ12AN6LPQ3 Bipolar LO Bipolar DO 1 PNP DO 1 NPN LO 1 NPN DO DQ12AB6LV 2 m (6.5 ft) cable DQ12RB6LV DQ12AP6LVQ3 Visible red, 645 nm 1 NPN LO 1 PNP LO 2m DQ12RP6LPQ3 DQ12RN6LPQ3 RETRO 1 PNP DO 1 NPN DO DQ12AB6LP P Bipolar LO Bipolar DO 150 mm (6 in) cable with a 3-pin M8/Pico-style QD DQ12AN6LVQ3 Bipolar DO 1 PNP LO 3m DQ12RP6LVQ3 Bipolar LO DQ12RN6LVQ3 1 PNP DO 1 NPN LO 1 NPN DO Performance based on use of 90% reflectance white test card. 1 • • To order the 9 m (30 ft) cable model, add the suffix W/30 to the model number. For example, DQ126E W/30. To order the 150 mm (6 in) cable with a 4-pin M8/Pico-style (M8 threaded) QD model, add the suffix Q to the model number. For example, DQ126EQ. • To order the 150 mm (6 in) cable with a 4-pin M12/Euro-style QD model, add the suffix Q5 to the model number. For example DQ126EQ5. 2 Retroreflective range is specified using one model BRT-60X40C retroreflector. Actual sensing range may be more or less than specified, depending upon efficiency and reflective area of the retroreflector(s) used. Original Document 213155 Rev. B 7 April 2020 213155 WORLD-BEAM® DQ12 Series Sensor Model1 Sensing Mode Range Connection DQ12AB6FF15 2 m (6.5 ft) cable DQ12RB6FF15 15 mm (0.6 in) cutoff; 10 mm (0.4 in) focus DQ12AP6FF15Q3 DQ12RP6FF15Q3 DQ12AN6FF15Q3 1 PNP DO 1 NPN LO DQ12RN6FF15Q3 1 NPN DO DQ12AB6FF30 Bipolar LO 2 m (6.5 ft) cable 30 mm (1.2 in) cutoff; 16 mm (0.63 in) focus DQ12AP6FF30Q3 DQ12RP6FF30Q3 DQ12AN6FF30Q3 Visible red, 645 nm Bipolar LO Bipolar DO 1 PNP LO 150 mm (6 in) cable with a 3-pin M8/Pico-style QD DQ12RB6FF30 FIXED-FIELD VISIBLE RED Output Bipolar DO 1 PNP LO 150 mm (6 in) cable with a 3-pin M8/Pico-style QD DQ12RN6FF30Q3 1 PNP DO 1 NPN LO 1 NPN DO DQ12AB6FF50 2 m (6.5 ft) cable DQ12RB6FF50 DQ12AP6FF50Q3 50 mm (2 in) cutoff; 16 mm (0.63 in) focus DQ12RP6FF50Q3 DQ12AN6FF50Q3 Bipolar LO Bipolar DO 1 PNP LO 150 mm (6 in) cable with a 3-pin M8/Pico-style QD DQ12RN6FF50Q3 1 PNP DO 1 NPN LO 1 NPN DO Indicator Features 1 1 - Amber and green LEDs • Green on: power to sensor is on • Amber on: received signal • Amber flashing: marginal signal Wiring Emitters have no connection to black and white. CAUTION: Observe proper ESD precautions (grounding) when connecting QD models. 1 To order the 9 m (30 ft) cable model, add the suffix W/30 to the model number. For example, DQ126E W/30. To order the 150 mm (6 in) cable with a 4-pin M8/Pico-style (M8 threaded) QD model, add the suffix Q to the model number. For example, DQ126EQ. • To order the 150 mm (6 in) cable with a 4-pin M12/Euro-style QD model, add the suffix Q5 to the model number. For example DQ126EQ5. 2 Retroreflective range is specified using one model BRT-60X40C retroreflector. Actual sensing range may be more or less than specified, depending upon efficiency and reflective area of the retroreflector(s) used. 2 • • www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 213155 Rev. B WORLD-BEAM® DQ12 Series Sensor Emitters Bipolar Models, Light Operate bn (1) brown wh (2) 10–30 V DC blue + 10–30 V dc – bu (3) + bk (4) – bn (1) bk (4) Load bk (4) NPN Models, Dark Operate bu (3) + 10–30 V dc – bu (3) Load – 10–30 V dc + bn (1) bk (4) Load Load Load 3-pin M8/Pico-style Male QD 1 = Brown 2 = White 3 = Blue 4 = Black – 10–30 V dc + bn (1) Load PNP Models, Dark Operate + 10–30 V dc – bu (3) Key bu (3) + 10–30 V dc – bu (3) bk (4) NPN Models, Light Operate Load bn (1) bk (4) bn (1) Load Bipolar Models, Dark Operate wh (2) PNP Models, Light Operate 4 3 1 4-pin M8/Pico-style Male QD 2 4 1 3 4-pin M12/Euro-style Male QD 2 3 1 4 Specifications Supply Voltage and Current 10 to 30 V dc (10% maximum ripple) at 20 mA maximum current Sensing Beam Visible red, 645 nm Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Protection Circuitry Protected against false pulse on power-up, short-circuit protected Output Response Time Opposed Mode: 1.3 ms ON; 900 µs OFF LP/LV Mode: 700 µs ON/OFF FF Mode: 850 µs ON/OFF 120 ms delay on power-up; outputs do not conduct during this time Construction Polarized Retro Models: Polyamide housing with glass lens All Other Models: Polyamide housing with polycarbonate lens P/N 213155 Rev. B Output Configuration Bipolar (1 NPN and 1 PNP) solid-state output or single output (PNP or NPN), light operate (LO) or dark operate (DO), depending on model Repeatability 125 microseconds Switching Frequency Opposed Mode: 385 Hz LP/LV Mode: 715 Hz FF Mode: 590 Hz Output Ratings OFF-state leakage current: NPN: 10 µA PNP: 10 µA ON-state saturation voltage: NPN: 2 V at 50 mA PNP: 2 V at 50 mA Vibration and Mechanical Shock All models meet MIL-STD-202F, Method 201A (Vibration: 10 Hz to 60 Hz maximum, 0.06 inch (1.52 mm) double amplitude, 10G maximum acceleration) requirements. Also meets IEC 60947-5-2 (Shock: 30G 11 ms duration, half sine wave) requirements. www.bannerengineering.com - Tel: + 1 888 373 6767 3 WORLD-BEAM® DQ12 Series Sensor Connections Standard Models: 2 m (6.5 ft) or 9 m (30 ft) attached PVC cable, or 150 mm (6 in) cable with M8 or M12 threaded connection, depending on the model ordered Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Environmental Rating Standard Models: IEC IP67 Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Conditions Operating Temperature: –20 °C to +55 °C (–4 °F to +131°F) Storage Temperature: –30 °C to +75 °C (–22 °F to +167 °F) 95% at +50 °C maximum relative humidity (non-condensing) Certifications Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Dimensions 12.4 mm (0.49") M3 mounting screws included 8.0 mm (0.31") 15.0 mm (0.59") 5.1 mm (0.20") 23.1 mm (0.91") 22 mm (0.86") 3.5 mm (0.14") 3.4 mm (0.13") Polarized Retro Models 4.7 mm (0.19") Emitter (opposed mode models) Emitter (all other models) Ø 3 mm (0.12") max. torque 0.9 Nm (8 in-lbf) 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 213155 Rev. B WORLD-BEAM® DQ12 Series Sensor Performance Curves Opposed Mode Excess Gain 100000 Beam Pattern DQ12 E-R.. EXCESS GAIN DQ12 E & R.. 150 mm 10000 5.9" 100 mm 3.9" 50 mm 2.0" 1000 0 100 10 1 0.01 m 0.03' 0.1 m 0.33' 1m 3.3' 0 50 mm 2.0" 100 mm 3.9" 150 mm 5.9" 0 10 m 33' 0.5 m 1.64' 1.0 m 3.28' 1.5 m 4.92' 2.0 m 6.56' 2.5 m 8.20' 3.0 m 9.84' 3.5 m 11.48' DISTANCE DISTANCE Retroreflective and polarized retroreflective performance is based on the use of a model BRT-60X40C retroreflector. Polarized Retroreflective Excess Gain Retroreflective Beam Pattern Excess Gain 1000 1000 DQ12 LP.. DQ12 LV.. 40 mm 1.6" DQ12 LP.. 30 mm 100 1.2" 20 mm 0.8" 10 mm 0.4" 0 10 10 mm 0.4" 20 mm 0.8" 30 mm 1.2" 40 mm 1 0.01 m 0.03' 0.1 m 0.33' 1m 3.3' 0 0 0.5 m 1.64' 1.0 m 3.28' 1.5 m 4.92' 2.0 m 6.56' EXCESS GAIN EXCESS GAIN Beam Pattern 1.6" 2.5 m 8.20' 2.4" 40 mm 1.6" 20 mm 0.8" 0 10 0 20 mm 0.8" 40 mm 1.6" 60 mm 2.4" 0 0.5 m 1.64' 1.0 m 3.28' 1.5 m 4.92' 2.0 m 6.56' 2.5 m 8.20' 3.0 m 9.84' 3.5 m 11.48' DISTANCE 1 0.01 m 0.03' DISTANCE 10 m 33' DQ12 LV.. 60 mm 100 0.1 m 0.33' DISTANCE 1m 3.3' 10 m 33' DISTANCE Fixed-field focus and spot sizes are typical. Performance based on use of 90% reflectance white test card.* Fixed Field -- 15 mm Fixed Field -- 30 mm Fixed Field -- 50 mm 1000 1000 1000 DQ12..FF30 10 1 1 mm 0.04" 10 mm 0.4" 100 mm 4.0" 100 10 1 1 mm 0.04" 1000 mm 40.0" 10 mm 0.4" 100 mm 4.0" 100 10 1 1 mm 0.04" 1000 mm 40.0" DISTANCE DISTANCE Standard Models: DQ12..FF50 EXCESS GAIN 100 EXCESS GAIN EXCESS GAIN DQ12..FF15 Q12..FF15 Standard Models: 10 mm 0.4" 100 mm 4.0" 1000 mm 40.0" DISTANCE Standard Models: • Ø 0.5 mm spot size at 7 mm focus • Ø 1 mm spot size at 15 mm focus • Ø 1 mm spot size at 15 mm focus • Ø 1.5 mm spot size at 15 mm cutoff • Ø 2.5 mm spot size at 30 mm cutoff • Ø 4 mm spot size at 50 mm cutoff * Using 18% gray test card: cutoff distance will be 95% of value shown. Using 6% black test card: cutoff distance will be 90% of value shown. * Using 18% gray test card: cutoff distance will be 90% of value shown. Using 6% black test card: cutoff distance will be 80% of value shown. P/N 213155 Rev. B www.bannerengineering.com - Tel: + 1 888 373 6767 * Using 18% gray test card: cutoff distance will be 80% of value shown. Using 6% black test card: cutoff distance will be 60% of value shown. 5 WORLD-BEAM® DQ12 Series Sensor Accessories Cordsets 3-Pin Threaded M8/Pico-Style Cordsets Model Length PKG3M-2 2.035 m (6.68 ft) PKG3M-5 5.035 m (16.51 ft) PKG3M-7 7.035 m (23.08 ft) PKG3M-9 9.035 m (29.64 ft) PKG3M-10 10.035 m (32.92 ft) PKW3M-2 2 m (6.56 ft) PKW3M-5 5 m (16.40 ft) Style Dimensions 35 Typ. Straight ø 9.5 M8 x 1 4 1 3 28 Typ. 1 = Brown 3 = Blue 4 = Black 20 Typ. Right-Angle PKW3M-9 Pinout (Female) 9 m (29.53 ft) M8 x 1 ø 9.5 4-Pin Threaded M8/Pico-Style Cordsets—Single Ended Model Length PKG4M-2 2 m (6.56 ft) PKG4M-5 5 m (16.4 ft) Style Dimensions Pinout (Female) 35 Typ. Straight PKG4M-9 9 m (29.5 ft) PKW4M-2 2 m (6.56 ft) PKW4M-5 5 m (16.4 ft) ø 9.5 M8 x 1 2 1 3 28 Typ. 1 = Brown 2 = White 3 = Blue 4 = Black 20 Typ. Right Angle PKW4M-9 4 9 m (29.5 ft) M8 x 1 ø 9.5 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 6 15.2 m (50 ft) 2 1 3 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC-450RA Pinout (Female) 1 = Brown 2 = White 3 = Blue 4 = Black M12 x 1 ø 14.5 [0.57"] www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 213155 Rev. B WORLD-BEAM® DQ12 Series Sensor Brackets SMBQ12T • Right-angle bracket 20-ga. 300 series stainless • steel 4X Ø3.3 2X Ø3.2 34 11 SMBQ12A • Adjustable right-angle bracket 20-ga. 300 series stainless • steel 34 Ø3.3 34 11 Hole center spacing: A to B = 7.6 Hole center spacing: A to B = 7.6 Hole size: A = 3.5 x 8.1, B=ø 3.2 Hole size: A = 3.5 x 8.1, B=ø 3.2 Ø3.2 34 Apertures Opposed-mode sensors (standard models only) may be fitted with apertures to narrow or shape the sensor’s effective beam to more closely match the size or profile of the objects being sensed. A common example is the use of “line” (or “slot”) type apertures to sense thread. Note: The use of apertures will reduce the sensing range (see table below). Model Description Pieces Reduced Sensor Range (Two Apertures Used) Circular APQ12-.5 0.5 mm (0.02 in) diameter 10 60 mm (2.4 in) APQ12-1 1 mm (0.04 in) diameter 10 190 mm (7.5 in) APQ12-1.5 1.5 mm (0.06 in) diameter 10 400 mm (15.7 in) APQ12-2 2 mm (0.08 in) diameter 10 725 mm (28.5 in) 10 350 mm (13.8 in) 10 725 mm (28.5 in) 10 450 mm (17.7 in) 10 900 mm (35.4 in) 2000 mm (78.7 in) Horizontal Slot APQ12-.5H 0.5 mm (0.02 in) APQ12-1H 1 mm (0.04 in) Vertical Slot APQ12-.5V 0.5 mm (0.02 in) APQ12-1V 1 mm (0.04 in) Protective Jacket APQ12-4S 4 mm (0.16 in) square 10 APKQ12 Kit containing two of each aperture above 18 — Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. P/N 213155 Rev. B www.bannerengineering.com - Tel: + 1 888 373 6767 7 WORLD-BEAM® DQ12 Series Sensor FCC Part 15 and CAN ICES-3 (B)/NMB-3(B) This device complies with part 15 of the FCC Rules and CAN ICES-3 (B)/NMB-3(B). Operation is subject to the following two conditions: 1. 2. This device may not cause harmful interference, and This device must accept any interference received, including interference that may cause undesired operation. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules and CAN ICES-3 (B)/NMB-3(B). These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: • Reorient or relocate the receiving antenna. • Increase the separation between the equipment and receiver. • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. • Consult the manufacturer. © Banner Engineering Corp. All rights reserved
DQ12AB6FF30 价格&库存
很抱歉,暂时无法提供与“DQ12AB6FF30”相匹配的价格&库存,您可以联系我们找货
