KT5G-2P1112
KT5G-2P1112
    SICK
    SEN CONTRAST PNP 10MM M12-5
KT5G-2P1112 数据手册
Product data sheet KT5G-2P1112 KT5 CONTRAST SENSORS KT5G-2P1112 | KT5 CONTRAST SENSORS A B C D E F Ordering information Type Part no. KT5G-2P1112 1016628 Other models and accessories www.sick.com/KT5 Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Dimensions (W x H x D) 30.4 mm x 53 mm x 80 mm Sensing distance 10 mm 1) Housing design (light emission) Rectangular Light source LED, green 2) Wave length 520 nm Light emission Long and short side of housing, exchangeable Light spot size 1.2 mm x 4.2 mm Light spot direction Vertical 3) Adjustment Teach-in button Teach-in mode 1-point teach-in 1) 2) 3)  From front edge of lens.  Average service life: 100,000 h at TU = +25 °C.  In relation to long side of housing. Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ≤ 5 Vpp 2) Current consumption 10 V ... < Uv Retention time (ET) 25 ms, non-volatile memory Connection type Male connector M12, 5-pin Protection class II 7) Circuit protection UV connections, reverse polarity protected Output Q short-circuit protected Interference pulse suppression Weight 400 g Housing material Metal, zinc diecast 1) 2) 3) 4) 5) 6) 7)  Limit values when operated in short-circuit protected network: max. 8 A.  May not exceed or fall below Uv tolerances.  Without load.  With light/dark ratio 1:1.  Signal transit time with resistive load.  Short-circuit-proof.  Reference voltage DC 50 V. Ambient data Ambient operating temperature –10 °C ... +55 °C Ambient temperature, storage –25 °C ... +75 °C Shock load According to IEC 60068 UL File No. NRKH.E181493 & NRKH7.E181493 Classifications ECl@ss 5.0 27270906 ECl@ss 5.1.4 27270906 ECl@ss 6.0 27270906 ECl@ss 6.2 27270906 ECl@ss 7.0 27270906 ECl@ss 8.0 27270906 ECl@ss 8.1 27270906 ECl@ss 9.0 27270906 ECl@ss 10.0 27270906 ECl@ss 11.0 27270906 ETIM 5.0 EC001820 ETIM 6.0 EC001820 ETIM 7.0 EC001820 ETIM 8.0 EC001820 UNSPSC 16.0901 39121528 2021-09-24 16:53:32 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 3 KT5G-2P1112 | KT5 CONTRAST SENSORS Dimensional drawing (Dimensions in mm (inch)) KT5-2 Teach-in, KT5-2 Display Sensing distance 40 mm (1.57 inch) Ø 26 3.5 4.5 17.4 (0.14) (0.18) (0.69) (1.02) Sensing distance 20 mm (0.79 inch) (1.00) (1.00) 30.4 (1.20) 21 (0.83) 1 2 Ø 25.5 Sensing distance 10 mm (0.39 inch) (1.10) Ø 25.6 56 (2.20) 28 9 (0.35) M5 5 17 4 3 5 28 (1.10) 52 (2.05) 80 (3.15) 13 (0.51) (0.12) 25 (0.98) 40 (1.57) 53 (2.09) 2 M A B C D E F 3 (0.67) H I J K L M N O P Q R S T ①  Lens (light transmission), can be exchanged for pos. 4 ②  M5 threaded mounting hole, 5.5 mm deep ③  See dimensional drawings of lenses ④  Blind screw can be replaced by pos. 1 ⑤  Connector M12 (rotatable up to 90°) Adjustments KT5-2 Teach-in, KT5G-xxx2 RUN 1 fine T E A C H Q RUN 2 coarse 3 TEACH ①  Function signal indicator (yellow) ②  Pre-selection switch for minimum contrast ③  Teach-in button 4 REGISTRATION SENSORS | SICK Product data sheet | 2021-09-24 16:53:32 Subject to change without notice KT5G-2P1112 | KT5 CONTRAST SENSORS Connection diagram Cd-326 BN 1 BK 4 BU 3 WH 2 GY 5 +(L+) Q -(M) Fine/Coarse Teach Sensing distance Sensing distance 100 90 1 80 70 60 Relative sensitivity in % 50 2 40 30 20 3 10 0 10 20 30 40 50 (0.39) (0.79) (1.18) (1.57) (1.97) Sensing distance in mm (inch) ①  Sensing distance 10 mm ②  Sensing distance 20 mm ③  Sensing distance 40 mm Recommended accessories Other models and accessories www.sick.com/KT5 Brief description Type Part no. Lens, 40 mm sensing distance, M20 x 0.75 OBJ-210 2010945 Lens, 10 mm sensing distance, M20 x 0.75 OBJ-211 1004936 Lens, 20 mm sensing distance, M20 x 0.75 OBJ-212 1011506 Lenses and accessories 2021-09-24 16:53:32 | Product data sheet  Subject to change without notice REGISTRATION SENSORS | SICK 5 KT5G-2P1112 | KT5 CONTRAST SENSORS A B C D E F Brief description Type Part no. BEF-KHS-G01 2022464 BEF-KHS-K01 2022718 BEF-KHS-KH1 2022726 BEF-MS12G-A 4056054 BEF-MS12G-B 4056055 BEF-MS12L-A 4056052 BEF-MS12L-B 4056053 YF2A15020VB5XLEAX 2096239 YF2A15050VB5XLEAX 2096240 YF2A15100VB5XLEAX 2096241 YG2A15020VB5XLEAX 2096215 YG2A15050VB5XLEAX 2096216 YG2A15100VB5XLEAX 2096217 DOS-1205-G 6009719 DOS-1205-W 6009720 Universal bar clamp systems Plug connectors and cables H I J K L M N O P Q R S T 6 REGISTRATION SENSORS | SICK Product data sheet | 2021-09-24 16:53:32 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
KT5G-2P1112 价格&库存
很抱歉,暂时无法提供与“KT5G-2P1112”相匹配的价格&库存,您可以联系我们找货
