PH18CNR65NASA
PH18CNR65NASA
    CARLOGAVAZZI
    SENSOR RETROREFLECTIVE 6.5M NPN
PH18CNR65NASA 数据手册
Photoelectrics Retro-reflective Type PH18CNR..., DC • Miniature sensor range • Range: 6.5 m • Sensitivity adjustment by potentiometer • Modulated, infrared light 850 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP, N.O & N.C. • Degree of protection IP67, IP69K • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable, plug and pigtail versions • Excellent EMC performance Product Description Ordering Key The PH18CNR... is part of a family of inexpensive general purpose retro-reflective sensors in industrial standard 18 mm cylindrical and square ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Type Housing style square Housing size Housing material Housing type neutral Detection principle Sensing distance Output type Output configuration Connection type Sensitive adjustment Compact housing and high power LED for excellent performance-size ratio. The potentiometer used for adjustment of the sensitivity makes the sensors highly flexible. The output type is NPN or PNP and the output switching function is NO and NC. PH18CNR65PAM1SA Type Selection Housing style Range Connection Sn Ordering no. NPN Make & break switching Ordering no. PNP Make & break switching M18 Square type M18 Square type M18 Square type PH 18 CNR 65 NASA PH 18 CNR 65 NAM1SA PH 18 CNR 65 NAT1SA PH 18 CNR 65 PASA PH 18 CNR 65 PAM1SA PH 18 CNR 65 PAT1SA Specifications 6.5 m 6.5 m 6.5 m Cable Plug Pigtail M12 according to EN60947-5-2 Rated operating distance (Sn) Up to 6.5 m, reference target ER4 reflector ø 80 mm Blind zone 50 mm @ Sn max. Sensitivity control Adjustable by potentiometer Electrical adjustment 210˚ Mecanical adjustment 240˚ Adjustable distance to target 50-650 cm Temperature drift ≤ 0.2%/ºC Hysteresis (H) (differential travel) ≤ 20% Rated operational volt. (UB ) 10 to 30 VDC (ripple included) Ripple (Urpp ) ≤ 10% Output current Continuous (Ie) ≤ 100 mA Short-time (I) ≤ 100 mA (max. load capacity 100 nF) No load supply current (Io) ≤ 25 mA @ 24 VDC Minimum operational current (Im) 0.5 mA OFF-state current (Ir ) ≤ 100 µA Specifications are subject to change without notice (12.06.2017) Voltage drop (Ud ) ≤ 2.0 VDC @ 100 mA Protection Short-circuit, reverse polarity and transients Light source LED, 850 nm Light type Infrared, modulated Sensing angle ± 2º Ambient light 30.000 lux Incandescent lamp Light spot Diameter Ø 164 mm @ 3.25 m Operating frequency 500 Hz Response time OFF-ON (tON) ≤ 1.0 ms ON-OFF (tOFF ) ≤ 1.0 ms Power ON delay (tv) ≤ 100 ms Output function Type NPN or PNP Switching function NO and NC Indication Output ON LED, yellow Signal stability and power ON LED, green 1 PH18CNR... Specifications (cont.) Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock Rated insulation voltage Housing material Body Backpart Front material III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67, IP 69K* -25° to +60°C (-13° to +140°F) -40° to +70°C (-40° to +158°F) 10 to 150 Hz, 1.0 mm/15 g (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) 500 VAC (rms) IEC protection class III ABS, grey PC-Transparent PMMA, red Cable gland POM, Black Trimmer shaft POM, Dark Grey Locknuts PP, black Mounting bracket PPA, black Connection Cable PVC, grey, 2 m 4 x 0.25 mm2, Ø = 4.5 mm Plug M12, 4-pin (CONB14NF-series) Pigtail PUR, grey, 30 cm 4 x 0.25 mm2, Ø = 4.5 mm M12, 4-pin (CONB14NF-series) Weight With cable: 85 g With pigtail: 40 g With plug: 25 g CE-marking Yes Approvals cULus (UL508) supply class 2 90° * The IP69K test according to DIN 40050-9 for high-pressure, high-temperature wash-down applications. The sensor must not only be dust tight (IP6X), but also able to withstand high-pressure and steam cleaning. The sensor is exposed to high pressure water from a spray nozzle that is fed with 80°C water at 8’000– 10’000 KPa (80–100bar) and a flow rate of 14–6L/min. The nozzle is held 100 –150 mm from the sensor at angles of 0°, 30°, 60° and 90° for 30s each. The test device sits on a turntable that rotates with a speed of 5 times per minute. The sensor must not suffer any damaging effects from the high pressure water in appearance and function. 60° 30° 0° Operation Diagram Operation Diagram tv = Power ON delay Power supply ON OFF Target Present Not Present Break Output (N.C.) Present Not Present Tv ON OFF Make Output (N.O.) ON OFF Object Tv Wiring Diagrams NPN 1 BN V PNP 1 BN V 4 BK 2 WH 2 WH 4 BK 3 BU 3 BU V GND 2 V GND Specifications are subject to change without notice (12.06.2017) PH18CNR... Detection Diagram Excess Gain Sensor 6,6 (feet) 13,1 (feet) 19,7 26,2 32,8 150 5,9 100 3,9 50 2,0 0 0,0 -50 -2,0 -100 -3,9 -150 2,0 4,0 6,0 8,0 6,6 0,0 2,0 13,1 19,7 26,2 32,8 4,0 6,0 8,0 10,0 100 10 -5,9 0,0 0,0 1.000 Excess Gain (mm) 0,0 (inch) Y ER4 Reflector X 1 10,0 Distance (m) Distance (m) APH18-MB1 Signal Stability Indication Excess Gain Operation level x 1.1 1.0 0.9 Operation level Operation level x 0.9 Ø 27 1.1 6.5 Time Ø 27 Green LED ON 6.5 Yellow LED ON Mounting Systems PH18 mounting with a combination of 1 x APH18-MB1 and 1 x M18 locknut. Maximum torque 0.9 NM m m in. m 5 M .0 m . 4. 1 ax M M18 Locknut APH18-MB1 Specifications are subject to change without notice (12.06.2017) 3 PH18CNR... Dimensions Cable/Pigtail version 31.5 Operation Indicator (Yellow) Pigtail M12 Power and Stability Indicator (Green) 1 Emitter Sensitivity Control 240° 3.5 3.5 35 24.1 M18 x 1 3 15 Power and Stability Indicator (Green) 5.45 3.4 11 17.5 1.5 10.5 2 4 3 Receiver 6.3 Optical Axis Ø 9.9 Ø 4.5 Plug version 31.5 Operation Indicator (Yellow) Power and Stability Indicator (Green) 1 11 Emitter 35 24.1 M18 x 1 3 15 Power and Stability Indicator (Green) 5.45 3.4 Sensitivity Control 240° 2 3.5 3.5 17.5 1.5 10.5 3 Receiver 10.8 Optical Axis 4 M12 x 1 plug Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled 4 A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Specifications are subject to change without notice (12.06.2017) Delivery Contents Accessories • Photoelectric switch: PH 18 CNR... • Installation instruction on plastic bag • Screwdriver • Mounting bracket APH18-MB1 • 1 M18 locknuts • Packaging: Plastic bag • Connector type CONG1A.. / CONB14NF.. series • Reflector type ER.. - to be purchased separately Specifications are subject to change without notice (12.06.2017) 5
PH18CNR65NASA 价格&库存
很抱歉,暂时无法提供与“PH18CNR65NASA”相匹配的价格&库存,您可以联系我们找货
PH18CNR65NASA
  • 1+540.681381+70.08260
  • 5+504.589465+65.40440
  • 10+468.5847210+60.73750
库存:2
PH18CNR65NASA
  • 1+795.521151+103.11469
  • 5+755.749895+97.95958
库存:7
