VSM5AN6CV50
VSM5AN6CV50
    BANNER(邦纳)
    VSM SERIES: 5 MM THREADED BARREL
VSM5AN6CV50 数据手册
VSM Series Micro Sensors Datasheet Miniature self-contained sensors in stainless steel housing • • • • • • • Tough - 300 series stainless steel body withstands a wide variety of chemicals and cutting fluids Tiny sensors are available as small as a 4 mm barrel (about the size of a single optical fiber assembly) Economical, self-contained sensors are available in diffuse or opposed sensing modes; no separate amplifier required Advanced optical design provides high performance, and very repeatable sensing Well-focused, narrow beam allows the entire barrel sensor to be recessed into fixtures (excluding 50 mm range models) Smooth, stainless steel barrel is perfect for hygienic applications that require routine cleaning A choice of threaded or smooth barrel housings or flat-pack sidelooking housing WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Housing Style: 4 mm Smooth Barrel NPN Models PNP Models Range1 Sensing Mode VSM46E Emitter — VSM46EQ7 Emitter VSM4RN6R VSM4RP6R VSM4RN6RQ7 VSM4RP6RQ7 VSM4AN6CV10 VSM4AP6CV10 VSM4AN6CV10Q7 VSM4AP6CV10Q7 VSM4AN6CV20 VSM4AP6CV20 VSM4AN6CV20Q7 VSM4AP6CV20Q7 VSM4AN6CV50 VSM4AP6CV50 VSM4AN6CV50Q7 VSM4AP6CV50Q7 Output Type 250 mm (9.84 in) OPPOSED DO DIFFUSE 50 to 140 mm (1.97 to 5.51 in) typical 2 m (6.6 ft) 3-Pin Pico QD 2 m (6.6 ft) 3-Pin Pico QD 2 m (6.6 ft) 10 to 30 mm (0.39 to 1.18 in) typical 20 to 50 mm (0.79 to 1.97 in) typical Connection 3-Pin Pico QD LO 2 m (6.6 ft) 3-Pin Pico QD 2 m (6.6 ft) 3-Pin Pico QD 1 Application Note: These sensors have a specified minimum detection range on a 90% reflectivity diffuse white card, but the maximum detection range varies with target reflectivity, target angle, and sensor tolerance. If reliable background suppression is required in your application, please contact Banner Engineering to specify a fixed-field or adjustable field sensor with background suppression technology. Original Document 157367 Rev. F 7 June 2016 157367 VSM Series Micro Sensors Housing Style: 5 mm Threaded Barrel NPN Models PNP Models Sensing Mode Range2 VSM56E Emitter — VSM56EQ7 Emitter VSM5RN6R VSM5RP6R VSM5RN6RQ7 VSM5RP6RQ7 VSM5AN6CV10 VSM5AP6CV10 VSM5AN6CV10Q7 VSM5AP6CV10Q7 VSM5AN6CV20 VSM5AP6CV20 VSM5AN6CV20Q7 VSM5AP6CV20Q7 VSM5AN6CV50 VSM5AP6CV50 VSM5AN6CV50Q7 VSM5AP6CV50Q7 Output Type 250 mm (9.84 in) OPPOSED DO 2 m (6.6 ft) 3-Pin Pico QD 2 m (6.6 ft) 3-Pin Pico QD 2 m (6.6 ft) 10 to 30 mm (0.39 to 1.18 in) typical 20 to 50 mm (0.79 to 1.97 in) typical Connection 3-Pin Pico QD LO DIFFUSE 2 m (6.6 ft) 3-Pin Pico QD 2 m (6.6 ft) 50 to 140 mm (1.97 to 5.51 in) typical 3-Pin Pico QD Housing Style: Flat-Pack Side-Looker NPN Models PNP Models Sensing Mode Range2 VSMQAN6CV20 VSMQAP6CV20 20 to 50 mm (0.79 to 1.97 in) typical VSMQAN6CV50 VSMQAP6CV50 50 to 140 mm (1.97 to 5.51 in) typical Output Type Connection LO 2 m (6.6 ft) DIFFUSE VSMQAN6CV90 VSMQAP6CV90 90 to 200 mm (3.54 to 7.87 in) typical 2 Application Note: These sensors have a specified minimum detection range on a 90% reflectivity diffuse white card, but the maximum detection range varies with target reflectivity, target angle, and sensor tolerance. If reliable background suppression is required in your application, please contact Banner Engineering to specify a fixed-field or adjustable field sensor with background suppression technology. 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 157367 Rev. F VSM Series Micro Sensors Specifications Supply Voltage and Current 10 to 30 V dc (10% maximum ripple) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Single-output: 1 NPN or 1 PNP; light operate (LO) or dark operate (DO), depending on model Output Rating 100 mA max OFF-state leakage current: less than 1 µA ON-state saturation voltage: less than 2 V at 100 mA Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to http:// www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Output Protection Circuitry Protected against false power-up and continuous overload or short circuit of outputs Overload trip point ≥ 100 mA Response Time 2.5 milliseconds Delay at Power-Up 20 milliseconds Repeatability 1 millisecond Indicators Yellow LED: light sensed Construction 300 series stainless steel with PVC cable CV10, CV20: sapphire lens CV50, emitter and receiver: glass lens Environmental Rating IP67 Connection 2 m PVC-jacketed cable or 3-pin Pico-style integral QD (Q7), depending on model. Operating Conditions Temperature: 0 °C to +55 °C (+32 °F to +131 °F) Certifications Dimensions 4 mm Smooth Barrel Emitter/Receiver Cable and 50 mm CV Models P/N 157367 Rev. F 4 mm Smooth Barrel Emitter/Receiver QD and 50 mm CV Models www.bannerengineering.com - Tel: +1-763-544-3164 3 VSM Series Micro Sensors 5 mm Threaded Barrel Emitter/Receiver Cable and 50 mm CV Models VSM5 Emitter/Receiver QD and 50 mm CV Models 4 mm Smooth Barrel Cable/10 and 20 mm CV Models 4 mm Smooth Barrel QD/10 and 20 mm CV Models 5 mm Threaded Barrel Cable/10 and 20 mm CV Models 5 mm Threaded Barrel QD/10 and 20 mm CV Models 4 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 157367 Rev. F VSM Series Micro Sensors Flat-Pack Side-Looker Excess Gain Curves Diffuse Mode VSM4 and VSM5 Opposed Mode VSM4 and VSM5 Range 250 mm Range 10 mm Range 20 mm 25 1000 Range 50 mm 20 100 10 10 20 100 15 10 10 1 1 5 0 4 mm 8 mm 12 mm 16 mm 0 20 mm 10 mm 20 mm 30 mm 40 mm 50 mm 60 mm 0 1 0 50 mm 100 mm 150 mm 200 mm 250 mm 300 mm 0 2 mm 4 mm 6 mm 8 mm 10 mm Diffuse Mode VSMQ Range 20 mm 25 Range 50 mm Range 90 mm 100 100 10 10 20 15 10 5 1 0 0 4 mm P/N 157367 Rev. F 8 mm 12 mm 16 mm 20 mm 1 0 10 mm 20 mm 30 mm 40 mm 50 mm 60 mm www.bannerengineering.com - Tel: +1-763-544-3164 0 18 mm 36 mm 54 mm 72 mm 96 mm 5 VSM Series Micro Sensors Beam Patterns Opposed Mode VSM4 and VSM5 Diffuse Mode VSM4 and VSM5 Range 250 mm Range 10 mm Range 20 mm Range 50 mm 100 mm 5 mm 50 mm 50 mm 80 mm 4 mm 40 mm 40 mm 60 mm 3 mm 30 mm 30 mm 40 mm 2 mm 20 mm 20 mm 20 mm 1 mm 10 mm 10 mm 0 mm 0 mm 0 mm 0 mm 20 mm 1 mm 10 mm 10 mm 40 mm 2 mm 20 mm 20 mm 3 mm 30 mm 30 mm 4 mm 40 mm 40 mm 5 mm 50 mm 60 mm 80 mm 100 mm 50 100 150 200 2 mm 4 mm 6 mm 8 mm 250 4 mm 8 mm 12 mm 16 mm 20 mm 10 mm DISTANCE DISTANCE (mm) 50 mm 10 mm 20 mm 30 mm 40 mm 50 mm DISTANCE DISTANCE Diffuse Mode VSMQ Range 20 mm Range 50 mm Range 90 mm 5 mm 50 mm 50 mm 4 mm 40 mm 40 mm 3 mm 30 mm 30 mm 2 mm 20 mm 20 mm 10 mm 1 mm 10 mm 0 mm 0 mm 0 mm 1 mm 10 mm 10 mm 2 mm 20 mm 20 mm 3 mm 30 mm 30 mm 4 mm 40 mm 5 mm 50 mm 4 mm 8 mm 12 mm 16 mm 20 mm 40 mm 10 mm 20 mm 30 mm 40 mm 50 mm 50 mm 20 mm 40 mm 60 mm 80 mm 100 mm DISTANCE DISTANCE DISTANCE Wiring Emitters 1 PNP Models + 10-30V dc 3 6 – 1 + 10-30V dc – 3 4 NPN Models Load www.bannerengineering.com - Tel: +1-763-544-3164 3 – 10-30V dc + 1 4 Load P/N 157367 Rev. F VSM Series Micro Sensors Accessories Cordsets 3-Pin Threaded M8/Pico-Style Cordsets Model Length Style PKG3M-2 2 m (6.56 ft) Straight PKG3M-5 5 m (16.40 ft) PKG3M-7 7 m (22.97 ft) PKG3M-9 9 m (29.53 ft) PKG3M-10 10 m (32.81 ft) PKW3M-2 2 m (6.56 ft) PKW3M-5 5 m (16.40 ft) PKW3M-9 9 m (29.53 ft) Dimensions Pinout 4 35 Typ. 1 3 ø 9.5 M8 x 1 1 = Brown 3 = Blue 4 = Black Right-Angle 28 Typ. 20 Typ. M8 x 1 ø 9.5 Brackets SMBVSM4 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Copyright Notice Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved. www.bannerengineering.com - Tel: +1-763-544-3164
VSM5AN6CV50 价格&库存
很抱歉,暂时无法提供与“VSM5AN6CV50”相匹配的价格&库存,您可以联系我们找货
