Q45BB6DL W/30
Q45BB6DL W/30
    BANNER(邦纳)
    RANGE: 1.8 M; INPUT: 10-30V DC
Q45BB6DL W/30 数据手册
Q45BB6 Series Sensors 10 to 30V dc photoelectric sensors with sinking and sourcing solid-state outputs Q45BB6 Series Features R • Advanced one-piece photoelectric sensors with outstanding optical performance and extremely rugged design • Operate from: 10 to 30V dc • Bipolar NPN (sinking)/PNP (sourcing) outputs on all models • Multiple sensing modes include: opposed, diffuse, retroreflective and convergent, plus glass and plastic fiber optic models • Switchable light/dark operate • Highly visible Power, Signal (AID™ System*), and Output indicator LEDs • Versatile plug-in modules available for output timing logic and/or signal strength display • Choice of prewired 2 m (6.5') or 9 m (30') unterminated cable, plus Mini-style or Euro-style quick-disconnect fittings • Versatile mounting options • Designed to withstand 1200 psi washdown; exceeds its NEMA 6P and IEC IP67 rating LISTED *U.S. Patent no. 4356393 Because of their extremely high excess gain, these opposed-mode sensors are an excellent option for sensing in contaminated or dirty areas, and are also the best choice for long-range sensing. Infrared, 880 nm Q45BB6 Series Opposed-Mode Emitter (E) and Receiver (R) Models Models Range Q456EQ5 Emitter Q45BB6RQ5 Receiver NOTES: Output Type Excess Gain 60 m (200') 4-Pin Mini-style QD Beam Pattern Effective Beam: 13 mm 1000 4-wire 2m (6.5') Q45BB6R Receiver Q45BB6RQ Receiver Supply Voltage 2-wire 2m (6.5') Q456E Emitter Q456EQ Emitter Cable 10 to 30V dc Bipolar NPN/PNP E X C E S S G A I N Q45E/R Opposed Mode 100 60 in Opposed Mode 1.0 m 40 in 0.5 m 20 in 0 10 0 0.5 m 20 in 1.0 m 40 in 1.5 m 1 0.1 m 0.33 ft 4-Pin Euro-style QD Q45E/R 1.5 m 60 in 0 1.0 m 3.3 ft 10 m 33 ft 100 m 330 ft 12 m 40 ft 24 m 80 ft 36 m 120 ft 48 m 160 ft 60 m 200 ft DISTANCE DISTANCE i) 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., Q456E W/30) ii) A model with a QD connector requires a mating cable; see page 10. IMPORTANT: SEE SAFETY USE WARNING ON BACK PAGE Printed in USA 09/01 P/N 36578 rev D Q45BB6 Series The visible red sensing beam of these sensors makes them very easy to align. Model Q45BB6LP polarizes the emitted light and filters out unwanted reflections, making sensing possible in applications otherwise considered unsuited to retroreflective sensing. Performance is specified using the model BRT-3 3" reflector (see the Accessories section of your current Banner Photoelectric Sensors catalog for further information). P Visible red, 680 nm Non-Polarized Polarized Q45BB6 Series Retroreflective-Mode Models Models Range Cable Supply Voltage Output Type Excess Gain Beam Pattern Non-Polarized 1000 Q45LV Q45BB6LV Q45BB6LVQ E X C E S S 4-wire 2 m (6.5') 0.08 to 9 m (3" to 30') Q45BB6LVQ5 4-Pin Mini-style QD 10 to 30V dc Bipolar NPN/PNP Retroreflective Mode 100 Q45LV 75 mm 2.0 in 25 mm 1.0 in 0 G A I N With BRT-3 Reflector .10 m .33 ft 1.0 m 3.3 ft 0 With BRT-3 Reflector 10 1 .01 m .033 ft 4-Pin Euro-style QD 3.0 in Retroreflective Mode 50 mm 25 mm 1.0 in 50 mm 2.0 in 75 mm 10 m 33 ft 3.0 in 0 3m 10 ft DISTANCE 6m 20 ft 9m 30 ft 12 m 40 ft 15 m 50 ft DISTANCE Polarized 1000 Q45LP Q45BB6LP Q45BB6LPQ Q45BB6LPQ5 E X C E S S 4-wire 2 m (6.5') 0.15 to 6 m (6" to 20') 4-Pin Mini-style QD 4-Pin Euro-style QD 10 to 30V dc Bipolar NPN/PNP Retroreflective Mode 100 Q45LP 75 mm Retroreflective Mode 50 mm 25 mm G A I N With BRT-3 Reflector 1 .01 m .033 ft .10 m .33 ft 1.0 m 3.3 ft DISTANCE 10 m 33 ft 0 With BRT-3 Reflector 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 0 1.5 m 5 ft 3m 10 ft 4.5 m 15 ft 6m 20 ft DISTANCE NOTES: i) 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., Q45BB6LV W/30) ii) A model with a QD connector requires a mating cable; see page 10. page 2 2.0 in 1.0 in 0 10 3.0 in Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 7.5 m 25 ft Q45BB6 Series Infrared, 880 nm These diffuse-mode models detect objects by sensing the reflection of their own emitted light. Ideal for use when the reflectivity and profile of the object to be sensed are sufficient to return a large percentage of emitted light back to the sensor. Model Q45BB6DX is the first choice for diffuse-mode applications when there are no background objects to falsely return light. Q45BB6 Series Diffuse-Mode Models Models Range Supply Voltage Cable Output Type Excess Gain Beam Pattern Performance based on 90% reflectance white test card Short Range 1000 Q45BB6D Q45BB6DQ E X C E S S 4-wire 2 m (6.5') 450 mm (18") Q45BB6DQ5 4-Pin Mini-style QD 10 to 30V dc Bipolar NPN/PNP G A I N Q45D 0.6 in Q45D 10 mm 0.4 in Diffuse Mode 5 mm 100 0.2 in 0 10 0 5 mm 0.2 in 10 mm 0.4 in 15 mm 0.6 in 0 1 1.0 mm 0.04 in 4-Pin Euro-style QD 15 mm Diffuse Mode 10 mm 0.4 in 100 mm 4.0 in 100 mm 200mm 300 mm 400 mm 500 mm 4.0 in 8.0 in 12.0 in 16.0 in 20.0 in DISTANCE 1000 mm 40 in DISTANCE Long Range 1000 Q45DL Q45DL 4-wire 2 m (6.5') Q45BB6DL Q45BB6DLQ E X C E S S 1.8 m (6') 4-Pin Mini-style QD 10 to 30V dc Bipolar NPN/PNP G A I N Q45BB6DLQ5 3.0 in 50 mm 2.0 in 25 mm 1.0 in 0 10 0 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 0 1 .01 m .033 ft 4-Pin Euro-style QD Diffuse Mode 100 Diffuse Mode 75 mm .10 m .33 ft 1.0 m 3.3 ft 0.6 m 2 ft 1.2 m 4 ft 1.8 m 6 ft 2.4 m 8 ft 3.0 m 10 ft DISTANCE 10 m 33 ft DISTANCE High Power 1000 4-wire 2 m (6.5') Q45BB6DX Q45BB6DXQ Q45BB6DXQ5 3m (10') 4-Pin Mini-style QD 10 to 30V dc 4-Pin Euro-style QD Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Bipolar NPN/PNP E X C E S S G A I N Q45DX Q45DX 75 mm Diffuse Mode 100 3.0 in Diffuse Mode 50 mm 2.0 in 25 mm 1.0 in 0 10 0 25 mm 1.0 in 50 mm 2.0 in 75 mm 1 0.01 m 0.033 ft 3.0 in 0 0.1 m 0.33 ft 1.0 m 3.3 ft DISTANCE 10 m 33 ft 0.6 m 2 ft 1.2 m 4 ft 1.8 m 6 ft 2.4 m 8 ft 3.0 m 10 ft DISTANCE page 3 Q45BB6 Series These sensors are ideal for reflective sensing of very small parts or profiles, and can accurately sense the position of parts approaching from the side. Will ignore all but highly reflective objects that are outside the sensing range. Visible red, 680 nm Q45BB6 Series Convergent-Mode Models Models Focus Cable Supply Voltage Output Type Excess Gain Beam Pattern Performance based on 90% reflectance white test card 1000 Q45BB6CV Q45BB6CVQ Q45BB6CVQ5 38 mm (1.5") Spot Size at Focus: 1.3 mm (0.05") 4-wire 2 m (6.5') 4-Pin Mini-style QD 10 to 30V dc Bipolar NPN/PNP 4-Pin Euro-style QD E X C E S S G A I N Q45CV Convergent Mode Q45CV 3.8 mm 2.5 mm 0.10 in 1.2 mm 0.05 in 0 10 1 1 mm .04 in 0.15 in Convergent Mode 100 10 mm .4 in 100 mm 4 in 0 1.2 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 0.15 in 0 1000 mm 40 in 38 mm 1.5 in 75 mm 113 mm 150 mm 190 mm 3.0 in 4.5 in 6.0 in 7.5 in DISTANCE DISTANCE 1000 Q45BB6CV4 100 mm (4") Q45BB6CV4Q Q45BB6CV4Q5 Spot Size at Focus: 1.5 mm (0.06") 4-wire 2 m (6.5') 4-Pin Mini-style QD 4-Pin Euro-style QD 10 to 30V dc Bipolar NPN/PNP E X C E S S Q45CV4 Convergent Mode Q45CV4 3.8 mm 2.5 mm 0.10 in 1.2 mm 0.05 in 0 G A I N 10 0 1.2 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 1 1 mm .04 in 10 mm .4 in 100 mm 4 in DISTANCE 1000 mm 40 in 0.15 in 0 38 mm 1.5 in 75 mm 113 mm 150 mm 190 mm 3.0 in 4.5 in 6.0 in 7.5 in DISTANCE NOTES: i) 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., Q45BB6CV W/30) ii) A model with a QD connector requires a mating cable; see page 10. page 4 0.15 in Convergent Mode 100 Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Q45BB6 Series Infrared, 880 nm and Visible red, 650 nm These models are an excellent choice for glass fiber optic applications where faster sensor response is not important. Their high excess gain means that opposed individual fibers can operate reliably in many very hostile environments. Also, special miniature bifurcated fiber optic assemblies with bundle sizes as small as .5 mm (.020") dia. may be used successfully for diffuse-mode sensing when using sensor model Q45BB6F(Q). For more information on compatible glass fiber optics, refer to your current Banner Photoelectric Sensors catalog. Q45BB6 Series Glass Fiber-Optic Models Models Range Supply Voltage Cable Output Type Excess Gain Diffuse mode performance based on 90% reflectance white test card Infrared, 880 nm 1000 E X C E S S Q45BB6F Q45BB6FQ Q45BB6FQ5 Range varies by sensing mode and fiber optics used Beam Pattern G A I N 4-wire 2 m (6.5') Q45F Q45F 150 mm Opposed Mode 100 4.0 in IT23S Fibers 50 mm 0 IT23S Fibers 10 IT13S Fibers 2.0 in 100 mm 4.0 in 6.0 in 0.1 m 0.33 ft 1.0 m 3.3 ft 10 m 33 ft 0.4 m 15 in 4-Pin Mini-style QD 10 to 30V dc Bipolar NPN/PNP 1.2 m 45 in 1.6 m 60 in 2.0 m 75 in DISTANCE 4-Pin Euro-style QD 1000 E X C E S S Visible Red, 650 nm Q45F Q45F BP Q45F opp.eps 0.15 in Diffuse Mode 0.10 in 3.8 mm Diffuse Mode 2.5 mm 100 BT13S Fiber 1.3 mm 0.05 in BT23S Fiber 0 BT23S Fiber 10 BT13S Fiber 0.05 in 2.5 mm 0.10 in 3.8 mm 0.15 in 0 10 mm 0.4 in 100 mm 4.0 in 0 1.3 mm 25 mm 1 in 1000 mm 40 in 50 mm 2 in 75 mm 100 mm 125 mm 3 in 4 in 5 in DISTANCE 1000 E X C E S S Q45FV Q45FV 30 mm Opposed Mode 100 G A I N 4-wire 2 m (6.5') 1.2 in Opposed Mode 20 mm 0.8 in IT23S Fibers 10 mm 0.4 in 0 IT23S Fibers 0 10 mm Q45BB6FVQ5 0.8 m 30 in DISTANCE DISTANCE Q45BB6FVQ 0 50 mm 0 1 1 mm 0.04 in Range varies by sensing mode and fiber optics used 2.0 in IT13S Fibers 150 mm 1 0.01 m 0.03 ft G A I N Q45BB6FV 6.0 in Opposed Mode 100 mm 10 0.4 in IT13S Fibers 20 mm IT13S Fibers 1 1.0 mm 0.04 in 0.8 in 30 mm 1.2 in 0 10 mm 0.4 in 100 mm 4 in 100 mm 150 mm 200 mm 250 mm 300 mm 4 in 6 in 8 in 10 in 12 in 1000 mm 40 in DISTANCE DISTANCE 4-Pin Mini-style QD 10 to 30V dc 4-Pin Euro-style QD Bipolar NPN/PNP 1000 E X C E S S G A I N Q45FV Diffuse Mode 0.08 in 0.04 in BT13S Fiber 0 0 1.0 mm 10 BT13S Fiber 0.04 in BT23S Fiber 2.0 mm 0.12 in 0 10 mm 0.4 in 100 mm 4.0 in DISTANCE 0.08 in 3.0 mm BT23S Fiber 1000 mm 40 in 0.12 in Diffuse Mode 1.0 mm 1 1 mm 0.04 in Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Q45FV 3.0 mm 2.0 mm 100 5 mm 0.2 in 10 mm 0.4 in 15 mm 0.6 in 20 mm 0.8 in 25 mm 1.0 in DISTANCE page 5 Q45BB6 Series Lower in cost than glass fiber optics, plastic fiber optics are ideal for use in situations where environmental conditions allow (for example, low levels of acids, alkalis, and solvents). Most are easily cut to length in the field, and are available in a variety of sensing end styles. For more information on compatible plastic fiber optics, refer to your current Banner Photoelectric Sensors catalog. Visible red, 660 nm Q45BB6 Series Plastic Fiber-Optic Models Models Range Cable Supply Voltage Output Type Excess Gain Beam Pattern Diffuse mode performance based on 90% reflectance white test card 1000 E X C E S S Q45FP 100 Q45BB6FP Q45BB6FPQ Q45BB6FPQ5 Range varies by sensing mode and fiber optics used 4-wire 2 m (6.5') 4-Pin Mini-style QD 0.6 in 0 0 PIT26U Fibers 10 15 mm 0.6 in 30 mm 1.2 in 45 mm 1.8 in PIT26U Fibers 0 10 mm 0.4 in 100 mm 4.0 in 25 mm 1.0 in 50 mm 2.0 in 1000 mm 40 in 75 mm 100 mm 125 mm 3.0 in 4.0 in 5.0 in DISTANCE DISTANCE Bipolar NPN/PNP 4-Pin Euro-style QD 1.2 in PIT46U Fibers 15 mm 1 1 mm 0.04 in 10 to 30V dc 1.8 in Opposed Mode 30 mm PIT46U Fibers G A I N Q45FP 45 mm Opposed Mode 1000 E X C E S S G A I N Q45FP Q45FP 18 mm Diffuse Mode 100 PBT46U Fiber 0.75 in Diffuse Mode 12 mm 0.50 in PBT46U Fiber 6 mm 0.25 in 0 10 0 6 mm 0.25 in 12 mm 0.50 in 18 mm PBT26U Fiber 1 0.1 mm 0.004 in 1 mm 0.04 in 0.75 in 0 10 mm 0.4 in 100 mm 4 in 10 mm 0.4 in 20 mm 0.8 in 30 mm 1.2 in 40 mm 1.6 in 50 mm 2.0 in DISTANCE DISTANCE NOTES: i) 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., Q45BB6FP W/30) ii) A model with a QD connector requires a mating cable; see page 10. page 6 Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Q45BB6 Series Q45BB6 Series Specifications Supply Voltage and Current 10 to 30V dc (10% maximum ripple), at less than 50 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Bipolar: one current sourcing (PNP) and one current sinking (NPN) open-collector transistor Output Rating 250 mA maximum each output up to 50°C, derated to 150 mA at 70°C (derates 5 mA/°C) Off-state leakage current less than 1 microamp Output saturation voltage (both outputs) less than 1 volt at 10 mA and less than 2 volts at 250 mA Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short circuit of outputs Output Response Time Opposed mode: 2 milliseconds ON, 1 millisecond OFF All other sensing modes: 2 milliseconds ON/OFF (NOTE: 100 millisecond delay on power-up. Output is non-conducting during this time.) Repeatability Opposed mode: 0.25 milliseconds All other sensing modes: 0.5 milliseconds Response time and repeatability specifications are independent of signal strength. Adjustments Beneath sensor’s transparent cover: Light/Dark Operate select switch and multi-turn Sensitivity control (allows precise sensitivity setting – turn clockwise to increase gain). Optional logic and logic/display modules have adjustable timing functions (see page 10). Indicators Indicator LEDs are clearly visible beneath a raised transparent Lexan® dome on top of the sensor. Power (green) LED lights whenever 10 to 30V dc power is applied, and flashes to indicate output overload or output short circuit Signal (red) AID™ System LED lights whenever the sensor sees its modulated light source, and pulses at a rate proportional to the strength of the received light signal Load (yellow) LED lights whenever the output is energized Optional 7-element LED signal strength display modules Construction Molded reinforced thermoplastic polyester housing, o-ring-sealed transparent Lexan® cover, molded acrylic lenses, and stainless steel hardware. Q45s are designed to withstand 1200 psi washdown. The base of cabled models has a 1/2" NPS integral internal conduit thread. Environmental Rating NEMA 6P, IEC IP67 Connections PVC-jacketed 2 m (6.5') or 9 m (30') cables; or 4-pin Mini-style (“Q” suffix models) or 4-pin Euro-style (“Q5” suffix models) quick-disconnect (QD) fittings are available. QD cables are ordered separately; see page 10. Operating Conditions Temperature: -40° to +70°C (-40° to +158°F) Maximum relative humidity: 90% at 50°C (non-condensing) Application Notes Optional output timing modules are available. See page 10 for more information. Certifications R LISTED Lexan® is a registered trademark of General Electric Co. Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 page 7 Q45BB6 Series Q45BB6 Series Dimensions Opposed, Retro, and Diffuse Sensing Modes (model suffix E, R, D, DL, DX, LP & LV) Mini-Style Quick-Disconnect Cabled 54.1 mm* (2.13") Euro-Style Quick-Disconnect *57.9 mm (2.28") for LP models 44.5 mm (1.75") Lens Centerline 50.8 mm (2.00") 69.0 mm (2.72") 6.4 mm (0.25") 87.6 mm (3.45") 4.5 mm (#10) Screw Clearance (2) 7.1 mm (0.28") 30.0 mm (1.18") Internal Thread (1/2–14NPSM) External Thread M30 X 1.5 ø 6.1 (0.24") 2m (6.5') Cable External Thread M30 X 1.5 14 mm (0.6") Mounting Nut is Supplied Convergent Sensing Mode (model suffix CV & CV4) Glass Fiber Optic (model suffix F and FV) 60.5 mm (2.38") 61.7 mm (2.43") Mini-style QD Connector 15 mm (0.6") Euro-style QD Connector Plastic Fiber Optic (model suffix FP) 59.8 mm (2.35") Lens Centerline 50.8 mm (2.00") page 8 Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Q45BB6 Series Q45BB6 Series Indicators and Controls Status indicator LEDs for Power, Signal and Output are clearly visible beneath a raised dome in the sensor’s transparent o-ring-sealed Lexan® cover. The Power indicator lights whenever power is applied to the sensor. The Signal LED lights whenever the sensor sees its modulated light source, and pulses at a rate proportional to the strength of the received light signal; this is the AID™ Alignment Indicating Device*. The Output indicator lights whenever the sensor’s output is conducting. This indicator is especially useful when a timing logic module is used and Signal and Output conditions are not concurrent. Also located beneath the sensor’s o-ring-sealed cover are controls for light/dark operate selection and Sensitivity adjustment. Figure 1. Indicators and controls on the Q45BB6 series sensors * US patent no. 4356393 Q45BB6 Series Hookups Q45BB6 Sensors with Attached Cable bn + 10-30V dc – bu wh bk Load Load Q456E Emitters with Attached Cable Q45BB6 Sensors with Quick-Disconnect 4-Pin Mini-Style or 4-Pin Euro-Style (model suffix Q and Q5) bn wh bk bu + 10-30V dc – Load Load Q456E Emitters with Quick-Disconnect 4-Pin Mini-Style or 4-Pin Euro-Style (model suffix Q and Q5) bn bn + 10-30V dc – bu bu + 10-30V dc – wh bk Quick Disconnect (QD) Option DC Q45BB6 Series sensors are sold with either a 2 m (6.5') or a 9 m (30') PVC-covered unterminated cable, or with a 4-pin Mini-style or 4-pin Euro-style Quick-Disconnect (QD) cable fitting. Mini-style QD sensors are identified by the suffix “Q” in their model number and 4-pin Euro-style sensors are identified by the suffix “Q5”. Mating cables required for QD Q45BB6 sensors are specified on page 10. Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 page 9 Q45BB6 Series Accessories Quick-Disconnect Cables Cable: PVC jacket; polyurethane connector body; nylon coupling nut (Mini), chrome-plated brass coupling nut (Euro) Conductors: 18 AWG (Mini), 22 or 20 AWG (Euro) high-flex stranded, PVC insulation, gold plated contacts Temperature: -40° to +80°C (-40° to +176°F) (Mini); -48° to +90° (-40° to +194°F) (Euro) Voltage Rating: 250V ac/300V dc Style 4-Pin Euro-Style Straight Model MQDC-406 MQDC-415 MQDC-430 Length 2 m (6.5') 5 m (15') 10 m (30') Dimensions ø15 mm (0.6") MBCC-406 MBCC-412 MBCC-430 2 m (6.5') 4 m (12') 9 m (30') White Wire Brown Wire M12 x 1 Black Wire 44 mm max. (1.7") 61 mm max. (2.4") 4-Pin Mini-Style Straight Pin-Out (Female View) Blue Wire 7/8-16UN-2B White Wire ø28 mm max. (1.1") Brown Wire Black Wire Blue Wire Contact factory for right-angle connectors. Retroreflective Targets Banner offers a wide selection of high-quality retroreflective targets. See the Accessories section of your current Banner Photoelectric Sensors catalog for complete information. NOTE: Polarized sensors require corner cube type retroreflective targets only. Non-polarized sensors may use any retroreflective target. Output Timing Logic and Signal Strength Display Modules Q45 sensors easily accept the addition of output timing logic and signal strength display functions. Display modules have a seven-element display which gives a more precise indication of excess gain than does the AID™ system LED that is standard on Q45 sensors. The modules listed below may be used with all Q45BB6 Series sensors. See the data sheet packed with the module for more information. Model 45LM58 45LM58D 45LMD page 10 Logic and/or Display Function Programmable output timing logic Programmable output timing logic plus signal strength display Signal strength display only (no timing function) Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Q45BB6 Series Mounting Brackets Model Description Dimensions 56.0 mm (2.20") SMB30C • 30 mm split clamp, black reinforced thermoplastic polyester bracket 13 mm (0.5") 63.0 mm (2.48") 31.5 mm (1.24") • Stainless steel mounting hardware included 13.5 mm (0.53") Nut Plate 2.5 mm (0.10") 45.0 mm (1.77") M5 x 0.8 x 80 mm Screw (2) 25.4 mm (1.00") 6.4 mm (0.25") ø 30.15 mm (1.187" dia.) 57.0 mm (2.25") SMB30MM • 30 mm, 11-gauge, stainless steel bracket with curved mounting slots for versatility and orientation • Clearance for M6 (1/4") hardware 25.4 mm (1.00") 7.1 mm .28 x 90° (2 Slots) 34.9 mm (1.38") 25.4 mm (1.00") ø 5.1 mm (0.20" dia.) ø 6.4 mm (0.25" dia.) 57.2 mm (2.25") 25.4 mm (1.00") R 25.4 mm (1.00") 35.1 mm 57.2 mm (1.38") (2.25") 69.9 mm (2.75") 50.8 mm (2.00") SMB30SC 12.7 mm (0.50") • 30 mm swivel, black reinforced thermoplastic polyester bracket • Stainless steel mounting hardware included 58.7 mm (2.31") 30.0 mm (1.18") 66.5 mm (2.62") Banner Engineering Corp. • Minneapolis, MN U.S.A. www.bannerengineering.com • Tel: 763.544.3164 29.0 mm (1.14") page 11 Q45BB6 Series WARRANTY: Banner Engineering Corp. warrants its products to be free from defects for one year. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture found to be defective at the time it is returned to the factory during the warranty period. This warranty does not cover damage or liability for the improper application of Banner products. This warranty is in lieu of any other warranty either expressed or implied. ! WARNING . . . Not To Be Used for Personnel Protection Never use these products as sensing devices for personnel protection. Doing so could lead to serious injury or death. These sensors do NOT include the self-checking redundant circuitry necessary to allow their use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Consult your current Banner Safety Products catalog for safety products which meet OSHA, ANSI and IEC standards for personnel protection. Banner Engineering Corp., 9714 Tenth Ave. No., Minneapolis, MN 55441 • Phone: 763.544.3164 • www.bannerengineering.com • E-mail: sensors@bannerengineering.com
Q45BB6DL W/30 价格&库存
很抱歉,暂时无法提供与“Q45BB6DL W/30”相匹配的价格&库存,您可以联系我们找货
Q45BB6DL W/30
  • 1+2147.498071+279.12238
库存:3
