TM186EQ8
TM186EQ8
    BANNER(邦纳)
    EZ-BEAM SEN EMITTER 20M
TM186EQ8 数据手册
EZ-BEAM® TM18 Series Sensors Installation Guide View or download additional Information on this product, including excess gain curves, beam patterns, and accessories, at www.bannerengineering.com/155853. WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Opposed Mode: 20 m Range Model Number Output Polarized: 5.5 m* Range Model Number Output Diffuse: 500 mm Range Model Number Output TM186E None TM18AP6LP PNP, LO 3-wire TM18AP6DV PNP, LO 3-wire TM18AP6R PNP, LO 3-wire TM18RP6LP PNP, DO 3-wire TM18RP6DV PNP, DO 3-wire TM18RP6R PNP, DO 3-wire TM18VP6LP PNP, LO/DO 4-wire TM18VP6DV PNP, LO/DO 4-wire TM18VP6R PNP, LO/DO 4-wire TM18AN6LP NPN, LO 3-wire TM18AN6DV NPN, LO 3-wire TM18AN6R NPN, LO 3-wire TM18RN6LP NPN, DO 3-wire TM18RN6DV NPN, DO 3-wire TM18RN6R NPN, DO 3-wire TM18VN6LP NPN, LO/DO 4-wire TM18VN6DV NPN, LO/DO 4-wire TM18VN6R NPN, LO/DO 4-wire * Range specified with BRT-84 reflector Fixed Field: 25 mm Range Model Number Output Fixed Field: 50 mm Range Model Number Output QD Models are also available Fixed Field: 100 mm Range Model Number Output TM18AP6FF25 PNP, LO 3-wire TM18AP6FF50 PNP, LO 3-wire TM18AP6FF100 PNP, LO 3-wire TM18VP6FF25 PNP, LO/DO 4-wire TM18VP6FF50 PNP, LO/DO 4-wire TM18VP6FF100 PNP, LO/DO 4-wire TM18AN6FF25 NPN, LO 3-wire TM18AN6FF50 NPN, LO 3-wire TM18AN6FF100 NPN, LO 3-wire TM18VN6FF25 NPN, LO/DO 4-wire TM18VN6FF50 NPN, LO/DO 4-wire TM18VN6FF100 NPN, LO/DO 4-wire Fixed Field: 25 mm Range Model Number Output Fixed Field: 50 mm Range Model Number Output Fixed Field: 100 mm Range Model Number Output TM18AP6FF25IR PNP, LO 3-wire TM18AP6FF50IR PNP, LO 3-wire TM18AP6FF100IR PNP, LO 3-wire TM18VP6FF25IR PNP, LO/DO 4-wire TM18VP6FF50IR PNP, LO/DO 4-wire TM18VP6FF100IR PNP, LO/DO 4-wire TM18AN6FF25IR NPN, LO 3-wire TM18AN6FF50IR NPN, LO 3-wire TM18AN6FF100IR NPN, LO 3-wire TM18VN6FF25IR NPN, LO/DO 4-wire TM18VN6FF50IR NPN, LO/DO 4-wire TM18VN6FF100IR NPN, LO/DO 4-wire To order the 9 m (30 ft) cable models, add the suffix "W/30" to the cabled model number. For example, "TM186E W/30". To order the 4-pin Euro M12 integral QD models, add suffix Q8 (for example, TM186EQ8). To order the 4-pin Euro M12 pigtail QD models: add suffix Q5 (for example, TM186EQ5). Original Document 151948 Rev. F 1 July 2015 151948 EZ-BEAM® TM18 Series Sensors Wiring NPN L.O. 3-Wire Emitter 3 10 - 30V dc 1 Wiring Key 1 2 3 4 = = = = 3 1 4 1 3 4 10 - 30V dc Load 3 1 4 Load 1 3 4 10 - 30V dc Load 10 - 30V dc Load PNP L.O./D.O. 4-Wire NPN L.O./D.O. 4-Wire 3 1 4 2 10 - 30V dc PNP D.O. 3-Wire NPN D.O. 3-Wire Brown White Blue Black QD and cabled emitter wiring functionality is identical; black and white wires have no connection when not shown. PNP L.O. 3-Wire 1 3 4 2 10 - 30V dc Load Load 10 - 30V dc Load Load Specifications Supply Voltage and Current - Class 2 10 to 30 V dc (10% max. ripple within specified limits); supply current (exclusive of load current): Emitters: 25 mA Receivers: 20 mA Polarized Retroreflective: 20 mA Diffuse and Fixed-Field: 35 mA Supply Protection Circuitry Protected against reverse polarity and transient voltages Effective Beam 13 mm for opposed mode sensors Output Configuration NPN (current sinking) or PNP (current sourcing), depending on model Light Operate: Output conducts when sensor receives its own (or the emitter’s) modulated light Dark Operate: Output conducts when sensor does not receive it own (or the emitter fts) modulated light Connections 2 m (6.5 ft) or 9 m (30 ft) PVC attached cable Integral 4-pin M12/Euro-style quick disconnect 4-pin M12/Euro-style PVC pigtail quick disconnect Construction Housing: Zinc die cast with nickel plating Lens: PMMA or PC (opposed mode only) Black Cover: PBT polyester housing Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short circuit of outputs Output Rating 150 mA maximum each output at 25 °C, derated to 100 mA at 70 °C (derate about 1 mA per °C) OFF-state leakage current: < 1 microamp at 30 V dc ON-state saturation voltage: < 1 V at 10 mA dc; < 1.5 V at 150 mA dc 2 Adjustments Diffuse models only: single turn rear panel sensitivity control Indicators Two LEDs (green and amber) Complementary (4-Wire) Models Indicator Description Green ON Power ON Green Flashing* Output is overloaded Amber ON N.O. Output is conducting Amber Flashing* Marginal excess gain (1 to 1.5x) * Not valid for Diffuse or Fixed Field Models. Single Output (3-Wire) Models Indicator Description Green ON Power ON Green Flashing N.A. Amber ON Output is conducting Amber Flashing N.A. Output Response Time (TM18) Opposed mode: 1.5 ms ON, 0.75 ms OFF Retro: 3 ms ON and OFF Diffuse and Fixed Field: 3 ms ON, 1.5 ms OFF Note: 100 ms delay on power-up; outputs do not conduct during this time. Repeatability (TM18) Opposed mode: 190 µs Retro: 585 µs Diffuse and Fixed Field: 185 µs www.bannerengineering.com - Tel: +1-763-544-3164 P/N 151948 Rev. F EZ-BEAM® TM18 Series Sensors Environmental Rating IEC IP67; quick disconnect models are IEC IP69K when mated with a washdown rated (IEC IP69K) cordset Certifications Class 2 supply Required; Operating Conditions −40 °C to +70 °C (−40 °F to +158 °F) 90% at +50 °C maximum relative humidity (non-condensing) Required Overcurrent Protection Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements. Method 201A (Vibration; frequency 10 to 60 Hz, max., double amplitude 0.06 in acceleration 10G). Method 213B conditions H&I (Shock: 75G with unit operating; 100G for non-operation) WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to http:// www.bannerengineering.com. Supply Wiring Required Overcurrent Protection 20 5.0 Amps 22 3.0 Amps 24 2.0 Amps 26 1.0 Amps 28 0.8 Amps 30 0.5 Amps Dimensions 30 mm [1.18”] TM18 LP Cable 30 mm dia [1.18”] 15 mm [0.59”] CL 26 mm [1.03”] 41.1 mm [1.62”] M18 x 1 6g TM18 LP QD 30 mm dia [1.18”] M18 x 1 6g 49 mm [1.93”] 34 mm [1.34”] M12 x 1 6g CL 15 mm [0.59”] 30 mm [1.18”] Maximum Torque specification: 5.6 nm or 50 in-lbs. Lockwasher and M18 nut included. P/N 151948 Rev. F www.bannerengineering.com - Tel: +1-763-544-3164 3 EZ-BEAM® TM18 Series Sensors Banner Engineering Corp Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. www.bannerengineering.com - Tel: +1-763-544-3164
TM186EQ8 价格&库存
很抱歉,暂时无法提供与“TM186EQ8”相匹配的价格&库存,您可以联系我们找货
