HSE18L-P4A5BA
HSE18L-P4A5BA
    SICK
    SENSOR THROUGH-BEAM 50M PNP
HSE18L-P4A5BA 数据手册
Product data sheet HSE18L-P4A5BA SureSense HYBRID PHOTOELECTRIC SENSORS HSE18L-P4A5BA | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F Ordering information Type Part no. HSE18L-P4A5BA 1074776 Other models and accessories www.sick.com/SureSense Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Device type Photoelectric sensors Sensor/ detection principle Through-beam photoelectric sensor Dimensions (W x H x D) 16.2 mm x 48.5 mm x 31.8 mm Housing design (light emission) Hybrid Thread diameter (housing) M18 Mounting system type M18, nose / side (24.1 … 25.4 mm) Housing color Blue Sensing range max. 0 m ... 60 m Sensing range 0 m ... 50 m Type of light Visible red light Light source Laser 1) 2) Light spot size (distance) 2 mm (1.5 m) Wave length 655 nm Laser class I Adjustment Potentiometer, right None Potentiometer, left None Special applications Detecting small objects Special features Signal strength light bar 1) 2)  Average service life: 50,000 h at TU = +25 °C.  CLASS 1 LASER PRODUCT EN60825-1:2014, IEC60825-1:2014, Maximum pulse power < 2,5 mW, Pulse length: 4 μs, Wavelength: 650 ... 670 nm, Complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to Laser Notice No. 50, dated June 24, 2007. 2 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HSE18L-P4A5BA | SureSense HYBRID PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC Ripple –10 °C. Sensor cannot be turned on below Ta= –10 °C. Classifications ECl@ss 5.0 27270901 ECl@ss 5.1.4 27270901 ECl@ss 6.0 27270901 ECl@ss 6.2 27270901 ECl@ss 7.0 27270901 ECl@ss 8.0 27270901 2021-12-08 22:34:56 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 3 HSE18L-P4A5BA | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F ECl@ss 8.1 27270901 ECl@ss 9.0 27270901 ECl@ss 10.0 27270901 ECl@ss 11.0 27270901 ETIM 5.0 EC002716 ETIM 6.0 EC002716 ETIM 7.0 EC002716 ETIM 8.0 EC002716 UNSPSC 16.0901 39121528 Connection/pin assignment Connection type Male connector M12, 4-pin Pin assignmentsender BN 1 + (L+) WH 2 Not connected BU 3 - (M) H I J K L M N O P Q R S T BK 4 Test IN Pin assignmentreceiver BN 1 + (L+) WH 2 Q2 BU 3 - (M) BK 4 Q1 4 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HSE18L-P4A5BA | SureSense HYBRID PHOTOELECTRIC SENSORS Dimensional drawing (Dimensions in mm (inch)) 16.2 (0.64) 31.4 (1.24) 10.1 (0.40) D 10.5 (0.41) B 4 7.5 (0.30) 25.4 (1.00) 24.1 (0.95) 12.7 3 (0.34) 8.6 C (0.50) 48.5 (1.91) A M12 x 1 0.9 (0.04) 2 15 (0.59) 5 M18 x 1 1 ①  LED indicator yellow: Status of received light beam ②  LED indicator green: power on ③  M3 mounting hole ④  Snap Connection for flush ring (sold seperatly) ⑤  Potentiometer (if selected) or LED Indicators Dimensions in mm (inch) Receiver Sender A B C D HTB18 / HTF18 - 1.1 (0.04) 1.1 (0.04) 4.7 (0.19) 0.6 (0.02) HTE18 / HL18 / HSE18 2.5 (0.1) 0.0 (0.0) 4.0 (0.16) 0.0 (0.0) HTB18L / HTF18L / HL18L / HSE18L 2.5 (0.1) 0.0 (0.0) 3.5 (0.14) 0.0 (0.0) Connection type See table: Connection/Pin assignment 1 2 2 1 2 1 3 4 3 4 ①  Sender ②  Receiver 2021-12-08 22:34:56 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 HSE18L-P4A5BA | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Adjustments possible 2 1 3 ①  LED indicator yellow: Status of received light beam ②  LED indicator green: power on ③  Signal strength light bar Characteristic curve Operating reserve 10,000 1,000 100 10 1 0 10 20 (32.81) (65.62) 30 40 50 60 (65.62) (131.23) (164.04) (196.85) Distance in m (feet) 6 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HSE18L-P4A5BA | SureSense HYBRID PHOTOELECTRIC SENSORS Light spot size mm (inch) 60 Dimensions in mm (inch) (2.36) 50 (1.97) 40 (1.57) 30 (1.18) Sensing range Vertical Horizontal 0.3 m 1.2 2.2 (0.98 feet) (0.05) (0.09) 1.5 m 2.0 2.0 (4.92 feet) (0.08) (0.08) 18 m 15.0 7.5 (59.06 feet) (0.59) (0.30) 60 m 50.0 25.0 (196.85 feet) (1.97) (0.98) 20 (0.79) 10 (0.39) 0 10 20 (32.81) (65.62) 30 40 50 60 (65.62) (131.23) (164.04) (196.85) Distance in m (feet) Vertical Horizontal Sensing range diagram 0 0 50 10 20 30 40 60 50 60 (32.81) (65.62) (98.43) (131.23) (164.04) (196.85) Distance in m (feet) Sensing range Sensing range max. Functions 100 % 100 % 100 % 100 % 100 % 0% 0% 0% 0% 0% 2021-12-08 22:34:56 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 HSE18L-P4A5BA | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Recommended accessories Other models and accessories www.sick.com/SureSense Brief description Type Part no. YF2A14050VB3XLEAX 2096235 STE-1204-G 6009932 Plug connectors and cables Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 4-pin, straight Head B: Cable: unshielded 8 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
HSE18L-P4A5BA 价格&库存
很抱歉,暂时无法提供与“HSE18L-P4A5BA”相匹配的价格&库存,您可以联系我们找货
