WL9L-3P2432
WL9L-3P2432
    SICK
    SENSOR RETROREFLECTIVE 8M PNP
WL9L-3P2432 数据手册
Product data sheet WL9L-3P2432 W9 SMALL PHOTOELECTRIC SENSORS WL9L-3P2432 | W9 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WL9L-3P2432 1058175 Other models and accessories www.sick.com/W9 Illustration may differ Detailed technical data Features Device type Photoelectric sensors Sensor/ detection principle Photoelectric retro-reflective sensor, autocollimation Dimensions (W x H x D) 12.2 mm x 52.2 mm x 23.6 mm Housing design (light emission) Rectangular Mounting hole M3 Sensing range max. 0 m ... 12 m 1) Sensing range 0 m ... 8 m 1) Type of light Visible red light Light source Laser 2) Light spot size (distance) Ø 1 mm (500 mm) Wave length 650 nm Laser class 1 (IEC 60825-1 / CDRH 21 CFR 1040.10 & 1040.11) Adjustment Single teach-in button Special applications Detecting small objects 1) 2) 2  Reflector PL80A.  Average service life: 50,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-22 19:19:46 Subject to change without notice WL9L-3P2432 | W9 SMALL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple –10 °C, then cools down, and the supply voltage is subsequently not switched off. Switching on below Tu –10 °C is not permissible. Safety-related parameters MTTFD 723 years (EN ISO 13849-1) 1) DCavg 0 % 1)  Mode of calculation: Parts-Count-calculation. Classifications ECl@ss 5.0 2021-10-22 19:19:46 | Product data sheet  Subject to change without notice 27270902 PHOTOELECTRIC SENSORS | SICK 3 WL9L-3P2432 | W9 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T ECl@ss 5.1.4 27270902 ECl@ss 6.0 27270902 ECl@ss 6.2 27270902 ECl@ss 7.0 27270902 ECl@ss 8.0 27270902 ECl@ss 8.1 27270902 ECl@ss 9.0 27270902 ECl@ss 10.0 27270902 ECl@ss 11.0 27270902 ETIM 5.0 EC002717 ETIM 6.0 EC002717 ETIM 7.0 EC002717 ETIM 8.0 EC002717 UNSPSC 16.0901 39121528 Connection diagram Cd-083 BN 1 WH 2 BU 3 BK 4 4 + (L+) Q - (M) Q PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-22 19:19:46 Subject to change without notice WL9L-3P2432 | W9 SMALL PHOTOELECTRIC SENSORS Characteristic curve 100 7 10 Sensing range 3 1 5 4 2 Sensing range, typ. max. 1 m 2 4 (feet) (6.56) 6 (13.12) (19.69) 6 8 10 12 (23.25) (32.81) (39.37) Distance in m (feet) ①  Reflector PL20A ②  Reflector PL40A ③  Reflector PL80A ④  PL10F reflector ⑤  Reflector PL20F ⑥  Reflector P250F ⑦  Reflective tape REF-AC1000 Light spot size Radius in mm (inch) 16 Dimensions in mm (inch) (0.63) 12 (0.47) 8 (0.31) 4 (0.16) 0 –4 Sensing range Vertical Horizontal 0.5 m < 1.0 < 1.0 (1.64 feet) (0.04) (0.04) 1m 1.5 1.2 (3.28 feet) (0.06) (0.05) 6m 15.2 7.6 (19.69 feet) (0.60) (0.30) 12 m 32.4 16.4 (39.37 feet) (1.28) (0.65) (–0.16) –8 (–0.31) –12 (–0.47) –16 (–0.63) 2 4 6 8 10 12 (6.56) (13.12) (19.69) (26.25) (32.81) (39.37) Distance in m (feet) 2021-10-22 19:19:46 | Product data sheet  Subject to change without notice Vertical Horizontal PHOTOELECTRIC SENSORS | SICK 5 WL9L-3P2432 | W9 SMALL PHOTOELECTRIC SENSORS A B C D E F Light spot size (detailed view) Radius in mm (inch) 2.5 (0.1) 2.0 (0.08) 1.5 (0.06) 1.0 (0.04) 0.5 (0.02) 0 –0.5 (–0.02) –1.0 (–0.04) –1.5 (–0.06) –2.0 (–0.08) –2.5 (–0.1) 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 (0.66) (1.31) (1.97) (2.62) (3.28) (3.94) (4.59) (5.25) (5.91) (6.56) Distance in m (feet) H I J K L M N O P Q R S T Vertical Horizontal Sensing range diagram 1 2 3 4 5 6 7 0 4 0 6 6 8 0 8 0 3.5 0 6 4 6 0 7 0 0 12 3.5 2 (6.56) 10 8 4 6 8 10 12 (13.12) (19.69) (26.25) (32.81) (39.37) Distance in m (feet) Sensing range Sensing range typ. max. ①  Reflector PL20A ②  Reflector PL40A ③  Reflector PL80A ④  PL10F reflector ⑤  Reflector PL20F ⑥  Reflector P250F ⑦  Reflective tape REF-AC1000 6 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-22 19:19:46 Subject to change without notice WL9L-3P2432 | W9 SMALL PHOTOELECTRIC SENSORS Adjustments Single teach-in button 3 4 8 ③  LED indicator yellow: Status of received light beam ④  LED indicator green: power on ⑧  Teach-in button Dimensional drawing (Dimensions in mm (inch)) WL9L-3 5 (0.01) 0.2 6 52.5 (2.07) 22.1 (0.87) 49.8 (1.96) 8.5 8.5 19.2 (0.76) (0.33) (0.33) 2 1 5.2 (0.2) 3 4 50 (1.97) 5.2 (0.2) 23.6 (0.93) 3.7 (0.15) 19.6 (0.77) 18.2 (0.72) 3 (0.12) 12.2 (0.48) 7 ①  Sender and receiver optical axis center ②  Mounting hole M3 (Ø 3.1 mm) ③  LED indicator yellow: Status of received light beam ④  LED indicator green: power on ⑤  Connecting cable or connecting cable with connector ⑥  Male connector M8, 4-pin ⑦  Male connector M12, 4-pin Recommended accessories Other models and accessories www.sick.com/W9 Brief description Type Part no. BEF-WN-W9-2 2022855 Mounting brackets and plates Mounting bracket, steel, zinc coated, mounting hardware included 2021-10-22 19:19:46 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 WL9L-3P2432 | W9 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Brief description Type Part no. YF2A14050VB3XLEAX 2096235 STE-1204-G 6009932 PL10F 5311210 Plug connectors and cables Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 4-pin, straight Head B: Cable: unshielded Reflectors Fine triple reflector, screw connection, suitable for laser sensors, 20 mm x 32 mm, PMMA/ABS, Screw-on, 2 hole mounting 8 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-22 19:19:46 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
WL9L-3P2432 价格&库存
很抱歉,暂时无法提供与“WL9L-3P2432”相匹配的价格&库存,您可以联系我们找货
