Q14 Series Sensors
Datasheet
Miniature Self-Contained Opposed-Mode DC Photoelectric Sensors
Self-contained dc sensors in miniature right-angle housings
IEC IP54; NEMA 4 construction; hermetically-sealed optics
1.8 m (70 in) opposed range
Choose models for light operate or dark operate; choose either NPN or PNP output
models
Choice of integral cable or quick-disconnect connector
Mounting bracket is included
WARNING: Not To Be Used for Personnel Protection
Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death.
This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety
applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output
condition.
Models
Models
Range
Cable1
Supply Voltage
Q146E
2 m (6.5 in)
Q146EQ
3-Pin Pico-style 150 mm (6 in) QD
Q14AN6R
2 m (6.5 in)
Q14AN6RQ
Q14RN6R
2 m (6.5 in)
Q14RN6RQ
1.8 m (70 in)
Q14AP6R
2 m (6.5 in)
Q14AP6RQ
Q14RP6R
2 m (6.5 in)
Q14RP6RQ
NPN/ PNP
L.O./ D.O.
L.O.
NPN
10 V dc to 30 V dc
D.O.
L.O.
PNP
D.O.
Mounting Orientation
Screws are:
M3 x 0.5 x 20 mm
Hardware (Included)
1
Models with a quick disconnect require a mating cordset.
Original Document
45727 Rev. D
23 October 2017
45727
Q14 Series Sensors
Wiring Diagrams
Emitters
NPN Receivers
3
1
PNP Receivers
3
10-30V dc
1
10-30 V dc
1
4
10-30 V dc
3
4
Load
Key
1 = Brown
3 = Blue
4 = Black
Load
Quick disconnect (QD) wiring diagrams are functionally identical.
Specifications
Supply Voltage and Current
10 Vdc to 30 V dc (10% maximum ripple)
Emitter: 15 mA
Receiver: 15 mA (exclusive of load)
Indicators
Receiver: Two LEDs, Green and Amber
Green on = power to sensor is ON
Green flashing = output is overloaded
Amber on = light is sensed
Amber flashing = marginal excess gain (1-1.5x) in light condition
Emitter: One GREEN LED indicates power to sensor is ON
Supply Protection Circuitry
Protected against reverse polarity
Output Configuration
SPST solid-state dc switch;
Choose NPN (current sinking) or PNP (current sourcing) models
Choose light operate (N.O.) or dark operate (N.C.) models
Construction
Housings are black ABS; Rated UL 94V0
Lenses are hermetically-sealed glass
Stainless steel M3 mounting hardware is included; stainless steel mounting
bracket is included
Output Rating
150 mA maximum
Off-state leakage current:
很抱歉,暂时无法提供与“Q14AN6RQ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+829.547071+107.16944
