GRL18S-P2338
GRL18S-P2338
    SICK
    SENSOR RETROREFLECTV 7.2M NPN LO
GRL18S-P2338 数据手册
Product data sheet GRL18S-P2338 GR18S CYLINDRICAL PHOTOELECTRIC SENSORS GRL18S-P2338 | GR18S CYLINDRICAL PHOTOELECTRIC SENSORS A B C D E F Ordering information Type Part no. GRL18S-P2338 1058212 Other models and accessories www.sick.com/GR18S Illustration may differ Detailed technical data H I J K L M N O P Q R S T Features Sensor/ detection principle Photoelectric retro-reflective sensor, Dual lens Dimensions (W x H x D) 18 mm x 18 mm x 38.1 mm Housing design (light emission) Cylindrical Thread diameter (housing) M18 x 1 Optical axis Radial Sensing range max. 0.03 m ... 7.2 m 1) Sensing range 0.06 m ... 6 m 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 175 mm (7 m) Wave length 650 nm Adjustment None Indication LED indicator green Operating indicator Static: power on LED indicator yellow Status of received light beam Static: object not present Static off: object present 1) 2) 2  Reflector PL80A.  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-01 16:33:33 Subject to change without notice GRL18S-P2338 | GR18S CYLINDRICAL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple 49 °C, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected.  At Uv
GRL18S-P2338 价格&库存
很抱歉,暂时无法提供与“GRL18S-P2338”相匹配的价格&库存,您可以联系我们找货
