MD17/115
MD17/115
    PEPPERL+FUCHS(倍加福)
    THRU BEAM EMITTER 0-15M
MD17/115 数据手册
Thru-beam sensor MD17/MV17/115/136 Dimensions 29.3 15 24.1 34.5 M18 x 1 10.2 ø3 13.9 Model Number MD17/MV17/115/136 Thru-beam sensor with fixed cable Electrical connection Emitter BN Receiver +UB BN +UB WH Q BU 0V BK Q Features • Compact series in universal housing for standard applications • Miniature design BU 0V • Front mounting with M18-threads or side mounting holes • 360° high visibility LEDs • Time-saving mounting with quick clamp system Indicators/operating means The ML17 sensor family offers diverse connection and installation options, which means that it can adapt to the most varied automation tasks. In addition to the usual fitting method using M4 screws, these sensors can also be installed by means of M18 threaded insert. All devices are equipped with a green Power On display and a yellow function display. These displays are arranged in such a way that they are clearly visible from different directions. 1 1 Signal display yellow 2 Operating display green 2 Release date: 2013-01-03 21:41 Date of issue: 2013-01-03 208372_eng.xml Product information = Light on = Dark on Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Thru-beam sensor MD17/MV17/115/136 Technical data Accessories System components Emitter Receiver MD17/115 MV17/115/136 General specifications Effective detection range Threshold detection range Light source Light type Ambient light limit 0 ... 15 m 20 m IRED modulated infrared light , 950 nm ≤ 10000 Lux Indicators/operating means Operating display Function display LED green LED yellow, lights up with receiver lit Electrical specifications Operating voltage Ripple No-load supply current Operating current Time delay before availability UB I0 tv Output Switching type Signal output Switching voltage Switching current Voltage drop Switching frequency Response time Ud f Ambient conditions Ambient temperature Storage temperature OMH-ML17-EZ Mounting bracket OMH-ML17 Mounting bracket OMH-ML17-1 Mounting bracket Other suitable accessories can be found at www.pepperl-fuchs.com 10 ... 30 V DC , class 2 max. 10 % < 25 mA 100 mA max per output ≤ 200 ms light/dark on 2 push-pull (4 in 1)outputs, short-circuit protected, reverse polarity protected, overvoltage protected max. 30 V DC max. 100 mA ≤ 2 V DC 150 Hz ≤ 3 ms -20 ... 55 °C (-4 ... 131 °F) -20 ... 75 °C (-4 ... 167 °F) Mechanical specifications Protection degree Connection Material Housing Optical face Mass IP67 2 m fixed cable ABS Acrylic approx. 80 g (emitter and receiver) Compliance with standards and directives Standard conformity Product standard EN 60947-5-2:2007 IEC 60947-5-2:2007 Standards EN 50178, UL 508 Approvals and certificates UL approval CCC approval cULus Products with a maximum operating voltage of ≤36 V do not bear a CCC marking because they do not require approval. Curves/Diagrams Characteristic response curve Date of issue: 2013-01-03 208372_eng.xml Offset Y [mm] 100 80 60 40 20 0 -20 -40 -60 -80 -100 5 10 15 20 25 Distance X [m] y x Release date: 2013-01-03 21:41 0 2 Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com Thru-beam sensor MD17/MV17/115/136 Relative received light strength Stability control 1000 800 600 400 200 1 0 5 10 15 20 25 Distance X [m] Release date: 2013-01-03 21:41 Date of issue: 2013-01-03 208372_eng.xml x Subject to modifications without notice Pepperl+Fuchs Group USA: +1 330 486 0001 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Germany: +49 621 776-4411 fa-info@pepperl-fuchs.com Copyright Pepperl+Fuchs Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
MD17/115 价格&库存
很抱歉,暂时无法提供与“MD17/115”相匹配的价格&库存,您可以联系我们找货
