WLG16P-2416212BA00
WLG16P-2416212BA00
    SICK
    SENSOR RETROREFLCTV 5M NPN/PNP
WLG16P-2416212BA00 数据手册
Online data sheet WLG16P-2416212BA00 W16 SMALL PHOTOELECTRIC SENSORS WLG16P-2416212BA00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WLG16P-2416212BA00 1219814 Other models and accessories www.sick.com/W16 Illustration may differ Detailed technical data Features Sensor/ detection principle Photoelectric retro-reflective sensor, autocollimation Dimensions (W x H x D) 20 mm x 55.7 mm x 42 mm Housing design (light emission) Rectangular Sensing range max. 0 m ... 5 m 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) Ø 80 mm (5 m) Wave length 635 nm Adjustment BluePilot: Teach-in plus user mode selector, IO-Link, Bluetooth Pin 2 configuration External input, Teach-in, switching signal Special applications Detecting transparent objects Special features Detecting transparent objects 1) 2) 2  Reflector P250F.  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Online data sheet | 2019-11-22 17:11:33 Subject to change without notice WLG16P-2416212BA00 | W16 SMALL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ≤ 5 Vpp Power consumption 30 mA, 50 mA 2) 3) Switching output PUSH/PULL, PNP, NPN Output: QL1 / C Switching output or IO-Link mode Output function Factory setting: Pin 2 / white (MF): NPN normally closed (light switching), PNP normally open (dark switching), Pin 4 / black (QL1 / C): NPN normally open (dark switching), PNP normally closed (light switching), IO-Link Switching mode Light/dark switching Signal voltage PNP HIGH/LOW Approx. VS – 2.5 V / 0 V Signal voltage NPN HIGH/LOW Approx. VS / < 2.5 V Output current Imax. ≤ 100 mA Response time ≤ 500 µs 4) Switching frequency 1,000 Hz 5) Connection type Male connector M12, 4-pin Circuit protection A, B, C, D 6) 7) 8) 9) Protection class III Weight 50 g Polarisation filter ✔ IO-Link ✔ Housing material Plastic, VISTAL® Optics material Plastic, PMMA Enclosure rating IP66 (According to EN 60529) IP67 (According to EN 60529) IP69 (According to EN 60529) 10) Ambient operating temperature –40 °C ... +60 °C Ambient storage temperature –40 °C ... +75 °C UL File No. NRKH.E181493 & NRKH7.E181493 1) 2) 3) 4) 5) 6) 7) 8) 9)  Limit values.  16 V DC ... 30 V DC, without load.  10 V DC ... 16 V DC, without load.  Signal transit time with resistive load in switching mode. Different values possible in COM2 mode.  With light/dark ratio 1:1 in switching mode. Different values possible in IO-Link mode.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  C = interference suppression.  D = outputs overcurrent and short-circuit protected. 10)  Replaces IP69K with ISO 20653: 2013-03. Safety-related parameters MTTFD 538 years DCavg 0% Classifications ECl@ss 5.0 2019-11-22 17:11:33 | Online data sheet  Subject to change without notice 27270904 PHOTOELECTRIC SENSORS | SICK 3 WLG16P-2416212BA00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T ECl@ss 5.1.4 27270904 ECl@ss 6.0 27270904 ECl@ss 6.2 27270904 ECl@ss 7.0 27270904 ECl@ss 8.0 27270904 ECl@ss 8.1 27270904 ECl@ss 9.0 27270904 ETIM 5.0 EC002719 ETIM 6.0 EC002719 UNSPSC 16.0901 39121528 Smart Task Smart Task name Base logics Logic function Direct AND OR Window Hysteresis Timer function Deactivated On delay Off delay ON and OFF delay Impulse (one shot) Inverter Yes Switching frequency SIO Direct: 1000 HzSIO Logic: 800 HzIOL: 650 Hz 1) 2) 3) Response time SIO Direct: 500 µsSIO Logic: 600  µsIOL: 750 µs 1) 2) 3) Repeatability SIO Direct: 150 µsSIO Logic: 300 µsIOL: 400 µs 1) 2) 3) Switching signal QL1 Switching output Switching signal QL2 Switching output 1)  SIO Direct: sensor operation in standard I/O mode without IO-Link communication and without using internal sensor logic or time parameters (set to "direct"/"deactivated"). 2) 3)  SIO Logic: Sensor operation in standard I/O mode without IO-Link communication. Sensor-internal logic or timing parameters plus Automation Functions used.  IOL: Sensor operation with full IO-Link communication and usage of logic, timing and Automation Function parameters. Communication interface Communication interface IO-Link V1.1 Bluetooth Communication Interface detail COM2 (38,4 kBaud) Cycle time 2.3 ms Process data length 16 Bit Process data structure Bit 0 = switching signal QL1 Bit 1 = switching signal QL2 Bit 2 ... 15 = empty VendorID 26 DeviceID HEX 0x8001B2 DeviceID DEZ 8389042 4 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2019-11-22 17:11:33 Subject to change without notice WLG16P-2416212BA00 | W16 SMALL PHOTOELECTRIC SENSORS Connection diagram Cd-390 1 BN WH 2 BU 3 BK 4 + (L+) MF – (M) QL1/C Light spot size WLG16P-xxxxx1xx Radius in mm (inch) 60 (2.36) 40 (1.57) 20 (0.79) 0 –20 (–0.79) –40 (–1.57) –60 (–2.36) 0 1 2 3 (3.28) (6.56) 4 5 (9.84) (13.12) (16.4) Distance in m (feet) Sensing range diagram WLG16P-xxxxx1xx 1 2 3 4 5 6 0 1.2 0 4 0 2.8 0 2.5 0 3.5 0 0 5 1 2 3 4 5 6 (3.28) (6.56) (9.84) (13.12) (16.4) (19.69) Distance in m (feet) Sensing range ①  PL10F CHEM reflector ②  Reflective tape REF-AC1000 (50 x 50 mm) ③  PL10FH-1 reflector ④  PL10F reflector ⑤  Reflector PL20F ⑥  Reflector P250F 2019-11-22 17:11:33 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 WLG16P-2416212BA00 | W16 SMALL PHOTOELECTRIC SENSORS Dimensional drawing (Dimensions in mm (inch)) WLG16, connector 18 17.5 (0.24) 29.9 (0.18) 52.9 (2.08) 6 2 7 (0.28) 55.7 (2.19) 45.5 (1.79) 5 (0.2) 34.5 (1.36) 1 (0.24) 6.5 (0.26) 3 (0.12) 15 (0.59) 3 7.5 M12 (0.3) Ø 4.1 (0.16) 39.9 (1.57) 55.4 (2.18) 42 (1.65) 4.1 (0.16) 20 (0.79) (0.71) A B C D E F 28 (1.1) 35.5 (1.4) 4 H I J K L M N O P Q R S T 16 5 67 ①  Center of optical axis ②  Mounting hole, Ø 4.1 mm ③  Connection ④  LED indicator green: power ⑤  LED indicator yellow: Status of received light beam ⑥  Teach-Turn adjustment of mode and sensitivity ⑦  BluePilot blue: Mode selection Recommended accessories Other models and accessories www.sick.com/W16 Brief description Type Part no. BEF-KHS-N02 2051608 BEF-WN-REFX 2064574 YF2A14050VB3XLEAX 2096235 STE-1204-G 6009932 Universal bar clamp systems Plate N02 for universal clamp bracket, Zinc plated steel (sheet), Zinc die cast (clamping bracket), Universal clamp (5322626), mounting hardware Mounting brackets and plates Universal mounting bracket for reflectors, steel, zinc coated Plug connectors and cables Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 4-pin, straight Head B: Cable: unshielded 6 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2019-11-22 17:11:33 Subject to change without notice WLG16P-2416212BA00 | W16 SMALL PHOTOELECTRIC SENSORS Brief description Type Part no. Rectangular, screw connection, 47 mm x 47 mm, PMMA/ABS, Screw-on, 2 hole mounting P250 5304812 Reflectors 2019-11-22 17:11:33 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
WLG16P-2416212BA00 价格&库存
很抱歉,暂时无法提供与“WLG16P-2416212BA00”相匹配的价格&库存,您可以联系我们找货
