MAHCVN-1
MAHCVN-1
    BANNER(邦纳)
    HIGH-RES MINI-ARRAY: CONTROLLER
MAHCVN-1 数据手册
A-GAGE® High-Resolution MINI-ARRAY® Instruction Manual Original Instructions 64118 Rev. D 30 August 2019 © Banner Engineering Corp. All rights reserved 64118 A-GAGE® High-Resolution MINI-ARRAY® Contents 1 Product Description ........................................................................................................................................................3 1.1 Emitter and Receiver Models ..........................................................................................................................................................3 1.2 Control Module Models .................................................................................................................................................................. 4 2 System Overview ............................................................................................................................................................5 2.1 System Features ............................................................................................................................................................................. 5 2.2 Supplied System Software ............................................................................................................................................................. 6 2.3 Typical Applications ........................................................................................................................................................................6 3 Installation Instructions ...................................................................................................................................................8 3.1 Emitter and Receiver Mounting ...................................................................................................................................................... 8 3.2 Control Module Mounting ............................................................................................................................................................... 9 3.3 Wiring ..............................................................................................................................................................................................9 3.3.1 Emitter and Receiver Wiring ..................................................................................................................................................10 3.3.2 Inputs .....................................................................................................................................................................................10 3.3.3 Outputs ..................................................................................................................................................................................11 3.4 Install the Software ....................................................................................................................................................................... 11 4 Control Module Configuration ...................................................................................................................................... 13 4.1 Communications Setup ................................................................................................................................................................ 13 4.1.1 Ping Routine .......................................................................................................................................................................... 13 4.1.2 Factory Settings .................................................................................................................................................................... 14 4.2 System Alignment .........................................................................................................................................................................14 4.2.1 Push-Button Alignment Routine ............................................................................................................................................14 4.2.2 Software Alignment Routine ..................................................................................................................................................14 4.2.3 Blanking .................................................................................................................................................................................15 4.3 Programming Control Module Response ..................................................................................................................................... 17 4.3.1 Selected Controller and Serial Communication .................................................................................................................... 18 4.3.2 Control Mode Selection .........................................................................................................................................................19 4.3.3 Scanning Method .................................................................................................................................................................. 19 4.3.4 Scan Analysis Mode Selection .............................................................................................................................................. 22 .................................................................................................. 22 4.3.5 Analog Output Configuration (Analysis Mode Assignment) 4.3.6 Zero Value ............................................................................................................................................................................. 23 ................................................................................................ 23 4.3.7 Discrete Output Configuration (Analysis Mode Assignment) 4.4 Serial Communication with a Host Controller ...............................................................................................................................24 4.4.1 Serial Data Transmission .......................................................................................................................................................24 4.4.2 Transmission Type ................................................................................................................................................................ 25 4.4.3 Serial Options ........................................................................................................................................................................ 25 4.5 Transfer of PSF to the Control Module .........................................................................................................................................25 4.5.1 Saving and Recalling PSF Files .............................................................................................................................................25 4.5.2 PSF Output Analysis ............................................................................................................................................................. 25 4.5.3 Quit and Exit ..........................................................................................................................................................................26 5 System Diagnostics 5.1 Diagnostic Indicators 5.2 Diagnostics Routine 6 Specifications ......................................................................................................................................................27 .................................................................................................................................................................... 27 ......................................................................................................................................................................28 ............................................................................................................................................................... 29 6.1 Emitter and Receiver Specifications ............................................................................................................................................. 29 6.2 Emitter and Receiver Dimensions .................................................................................................................................................30 6.3 Emitter/Receiver Mounting Bracket Dimensions .......................................................................................................................... 31 ..................................................................................................................................................... 31 6.4 Control Module Specifications 6.5 Control Module Dimensions ......................................................................................................................................................... 33 7 Accessories ................................................................................................................................................................... 34 7.1 Cordsets ........................................................................................................................................................................................ 34 8 Additional Information .................................................................................................................................................. 35 8.1 Host Mode Command String ........................................................................................................................................................35 8.2 Serial Data Format and Header String ..........................................................................................................................................35 8.2.1 ASCII Format Data Transmission .......................................................................................................................................... 35 8.2.2 Binary Format Data Transmission ......................................................................................................................................... 36 8.3 Max Meas Mode Command String ...............................................................................................................................................37 8.4 Glossary ........................................................................................................................................................................................ 38 9 Product Support and Maintenance .............................................................................................................................. 39 9.1 Contact Us .....................................................................................................................................................................................39 9.2 Banner Engineering Corp Limited Warranty ................................................................................................................................. 39 A-GAGE® High-Resolution MINI-ARRAY® 1 Product Description For Controllers with 2 Analog and 2 Discrete Outputs • • • • • • • • • • • • Excels at high-speed, precise process monitoring and inspection applications A comprehensive combination of scanning modes and outputs: ◦ 10 measurement (Scan Analysis) modes ◦ 3 scanning methods ◦ Beam blanking ◦ Selectable continuous, gated or host-controlled scan initiation ◦ Programmable hysteresis for high and low limits ◦ Serial communication options Storable scanning programs eliminate reprogramming for repeated applications Non-volatile memory stores alignment settings All models with both Analog and Discrete outputs Analog output Null setting Low cost, compared with similar systems Precision sensors have a 380 mm to 1.8 m (15 in to 6 ft) working range Wide field of view, easily aligned Alignment routine equalizes gain of each beam for reliable 2.5 mm (0.10 in) object detection throughout the array Host computer or PLC may be used to initiate scans and/or process scan data Unique addresses for up to 15 control modules on one EIA-485 Party Line WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or de-energized (off) output condition. 1.1 Emitter and Receiver Models Emitter Model Receiver Model Array Length Y MAHE6A Emitter MAHR6A Receiver 163 mm (6.4 in) 64 MAHE13A Emitter MAHR13A Receiver 325 mm (12.8 in) 128 MAHE19A Emitter MAHR19A Receiver 488 mm (19.2 in) 192 MAHE26A Emitter MAHR26A Receiver 650 mm (25.6 in) 256 MAHE32A Emitter MAHR32A Receiver 813 mm (32.0 in) 320 MAHE38A Emitter MAHR38A Receiver 975 mm (38.4 in) 384 MAHE45A Emitter MAHR45A Receiver 1138 mm (44.8 in) 448 MAHE51A Emitter MAHR51A Receiver 1300 mm (51.2 in) 512 MAHE58A Emitter MAHR58A Receiver 1463 mm (57.6 in) 576 MAHE64A Emitter MAHR64A Receiver 1626 mm (64.0 in) 640 MAHE70A Emitter MAHR70A Receiver 1788 mm (70.4 in) 704 MAHE77A Emitter MAHR77A Receiver 1951 mm (76.8 in) 768 www.bannerengineering.com - Tel: + 1 888 373 6767 Total Beams 3 A-GAGE® High-Resolution MINI-ARRAY® 1.2 Control Module Models Controller Model Solid-State Discrete Outputs Analog Outputs MAHCVP-1 2 PNP (2) 0 V to 10 V Sourcing MAHCVN-1 2 NPN (2) 0 V to 10 V Sourcing MAHCIP-1 2 PNP (2) 4 mA to 20 mA Sinking MAHCIN-1 2 NPN (2) 4 mA to 20 mA Sinking 4 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® 2 System Overview The A-GAGE® High-Resolution MINI-ARRAY® measuring light screen is ideal for applications such as on-the-fly product sizing and profiling, edge-guiding and center-guiding, loop tensioning control, hole detection, parts counting and similar uses. A typical A-GAGE High-Resolution MINI-ARRAY system has five components: a high-resolution emitter/receiver pair, each with quick-disconnect (QD) connectors; one of four compact control modules; and quick-disconnect cables to connect them. Software is included to interface any PC-compatible computer (running Windows®1 XP, Vista, or 7) with the control module for system configuration. A host computer or PLC may be used to control and/or receive input from the system. Sensors are available in twelve array lengths from 163 mm to 1951 mm (6.4 in to 76.8 in), in 163 mm (6.4 in) increments. The emitter has two columns of infrared LEDs spaced 5 mm (0.2 in) apart. The columns are separated by 7.5 mm (0.3 in) and are staggered from each other by 2.5 mm (0.1 in). The receiver is configured opposite to the emitter, with the identical length and beam spacing. This high-resolution sensor pair is capable of detecting a 12.7-mm long by 2.54-mm diameter (0.5 in by 0.1 in diameter) cylindrical rod (held perpendicular to the sensor). The sensors have a wide field of view and are easily aligned, with a working range of 380 mm to 1.8 m (15 in to 6 ft). Each of the four versatile microcontroller-based control modules are configured using a PC-compatible computer running Windows XP, Vista, or 7, and the supplied software, via the built-in RS-232 interface. 2.1 System Features Built-in features simplify the operation of the A-GAGE High-Resolution MINI-ARRAY system. High-resolution emitters and receivers, available in twelve lengths, feature two closely spaced columns of beams to provide a precise, high-resolution light screen for exacting applications. The Alignment routine automatically equalizes the excess gain of each beam for reliable 2.5-mm (0.10-in) object detection throughout the array and stores this data in non-volatile memory. The Alignment routine does not need to be performed again unless the sensing application changes, or if the emitter and/or receiver is moved. Programmable beam blanking accommodates machine components or other fixtures that must remain in or move through the light screen. Blanking may be set automatically as part of the initial setup, or by using the included configuration software. Built-in diagnostic programming and easy-to-see indicators on the sensors and the control module make alignment and troubleshooting easy. The emitter has a red LED that signals proper operation. The receiver has three bright LEDs: green signals that the sensors are properly aligned; yellow signals marginal alignment; and red signals misalignment or a blocked condition. The control module has four status indicators: 3 red LEDs signal discrete output #1 conducting, Alarm output (discrete output #2) conducting, and gate signal received; a green LED signals that the sensors are properly aligned. A segmented LED Diagnostics Indicator provides detailed system status using single-digit codes; a period in the indicator window indicates the presence of blanking. A key to the diagnostics codes is printed on the side of the control module for simplified troubleshooting. The A-GAGE High-Resolution MINI-ARRAY system provides a wide selection of sensing and output options, including: measurement (scan analysis) modes and scanning methods that can determine the target object’s location, overall size, total height or total width. Scanning may be continuous or controlled by a host process controller or a gate sensor. Up to 15 systems may be networked. 1 Microsoft and Windows are registered trademarks of Microsoft Corporation in the United States and/or other countries. www.bannerengineering.com - Tel: + 1 888 373 6767 5 A-GAGE® High-Resolution MINI-ARRAY® High-Resolution Emitter 7.6 mm (0.30") High-Resolution Receiver 5.1 mm (0.20") 2.5 mm (0.10") DIN-Rail-Mountable Control Module MAHCVP-1 HIGH RESOLUTION MINI-ARRAY CONTROLLER POWER 1 2 3 4 5 F1 BR BU + 7 8 10 11 12 13 14 15 16 17 18 19 20 TX TX BK WH 0-10VOLTS 25mA (MAX) V OUT 1 +V – 16-30V dc 1A MAX + – + – 10-30VDC 10-30VDC GATE ALIGN 0-10VOLTS 25mA (MAX) V OUT 2 +V D OUT 1 150mA MAX ALARM 150mA MAX ALIGN ALIGNMENT SWITCH GATE RCVR DIAGNOSTICS INDICATOR ALARM EMTR Alignment Button 9 OUTPUT Diagnostics Indicator 6 +12V COM DRN T/R T/R RS-232 2 - TX 3 - RX 5 - COM POWER Red Operational LED Green Alignment LED Red Blocked LED Yellow Marginal Alignment LED Red Discrete Output #1 LED Red Alarm (Discrete Output #2) LED Red Gate LED Green Align LED RS-232 Port Figure 1. A-GAGE High-Resolution MINI-ARRAY System Features 2.2 Supplied System Software The supplied software program, used to configure each system control module, may be run on any PC running Windows® XP, Vista, or 7. The menu-driven program walks the user through the many scanning and output options. After the desired options are selected, the user can save the combination of selections in a Parameter Setup File (PSF), and store it in the control module’s non-volatile memory. Any number of PSFs may be stored in the computer and recalled as needed. The software also provides alignment and diagnostics routines. An Alignment screen displays the individual status of each beam in the light screen, as well as the total number of beams in the system, and totals of beams blocked, made, and blanked. Built-in system diagnostics can be used to assess emitter and receiver hardware errors. 2.3 Typical Applications Figure 2. Log Profiling for Lumber Optimization 6 www.bannerengineering.com - Tel: + 1 888 373 6767 Figure 3. Box Profiling A-GAGE® High-Resolution MINI-ARRAY® Figure 4. Maintaining Center of Opaque Rolled Goods Figure 5. Inspection Applications www.bannerengineering.com - Tel: + 1 888 373 6767 7 A-GAGE® High-Resolution MINI-ARRAY® 3 Installation Instructions 3.1 Emitter and Receiver Mounting Banner MINI-ARRAY emitters and receivers are small, lightweight, and easy to handle during mounting. The mounting brackets (supplied) allow ±30° rotation. From a common point of reference, make measurements to locate the emitter and receiver in the same plane with their midpoints directly opposite each other. Mount the emitter and receiver brackets using the vibration isolators and M4 Keps nuts (all supplied). Standard M4 or #8-32 bolts may be substituted (and the vibration isolators eliminated) in situations where the emitter and receiver are not subjected to shock or vibration forces. While the internal circuits of the emitter and receiver are able to withstand heavy impulse forces, the vibration isolators dampen impulse forces and prevent possible damage due to resonant vibration of the emitter or receiver assembly. M4 x 10 mm Slotted Hex Head with Compression Washer (2) Mounting Surface Mounting Bracket M4 Keps Nut (8) Emitter or receiver Anti-Vibration Mount (4) Studs: M4 x 0.7 9.5 mm (0.38") long Mounting Bracket Washer Nut Figure 6. A-GAGE High-Resolution MINI-ARRAY emitter and receiver mounting hardware 1. Mount the emitter and receiver in their mounting brackets; see Figure 6 (p. 8). 2. Position the red lenses of the two units directly facing each other. The connector ends of both sensors must point in the same direction. 3. Measure from one or more reference planes (for example, the floor) to the same points on the emitter and receiver to verify their mechanical alignment. If the sensors are positioned exactly vertical or exactly horizontal, a carpenter’s level may be useful for checking alignment. Extending a straight-edge or a string between the sensors may help with positioning. 4. Also check by eye for line-of-sight alignment. 8 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® 5. Make any necessary final mechanical adjustments, and hand-tighten the bracket hardware. 6. See System Diagnostics (p. 27) for information on alignment indicators and Control Module Configuration (p. 13) for information on the use of the alignment software which is supplied with the controller. 3.2 Control Module Mounting Install the controller inside an enclosure with a NEMA (or IEC) rating suitable for the operating environment. Mounting dimensions for the controller are shown in Control Module Dimensions (p. 33). The controller is supplied with M3.5 hardware for direct mounting to a surface, or it can be mounted onto standard 35 mm DIN rail. 3.3 Wiring Refer to the following figures for the appropriate wiring information. POWER 5 6 – BLUE + BROWN F1 16-30V dc 1 A max 7 8 9 10 11 12 13 14 15 16 17 18 25 mA max + – 10-30V dc GATE SIGNAL WHITE 4 BLACK 3 DRAIN (BARE) 2 1 EMITTER and RECEIVER CABLES 0-10V ANALOG OUTPUT #1 DISCRETE OUTPUT#1 150 mA max 19 TX TX RS-485 + – 10-30V dc ALIGN DISCRETE OUTPUT#2 (ALARM) 25 mA max 0-10V ANALOG OUTPUT #2 +30V dc max 20 150 mA max +30V dc max Figure 7. MAHCVN-1 Wiring 5 – 16-30V dc 1 A max BLUE + BROWN F1 6 7 8 9 10 11 12 13 14 15 16 17 25 mA max + – 10-30V dc GATE SIGNAL WHITE 4 BLACK 3 DRAIN (BARE) POWER 1 2 0-10V ANALOG OUTPUT #1 DISCRETE OUTPUT#1 EMITTER and RECEIVER CABLES 18 19 TX TX RS-485 + – 10-30V dc ALIGN DISCRETE OUTPUT#2 (ALARM) 25 mA max 150 mA max 0-10V ANALOG OUTPUT #2 150 mA max 20 5 6 + – 16-30V dc 1 A max BROWN F1 7 EMITTER and RECEIVER CABLES 8 9 10 DISCRETE OUTPUT#1 150 mA max +30V dc 11 12 13 + – 10-30V dc GATE SIGNAL WHITE 4 BLACK 3 DRAIN (BARE) POWER 1 2 BLUE Figure 8. MAHCVP-1 Wiring 14 15 16 17 19 20 TX TX RS-485 + – 10-30V dc ALIGN Load 18 Load 4-20 mA ANALOG OUTPUT#1 4-20 mA ANALOG OUTPUT#2 +16-30V +16-30V DISCRETE OUTPUT#2 (ALARM) 150 mA max +30V dc max Figure 9. MAHCIN-1 Wiring www.bannerengineering.com - Tel: + 1 888 373 6767 9 5 6 + – 16-30V dc 1 A max BROWN F1 7 EMITTER and RECEIVER CABLES 8 9 10 11 DISCRETE OUTPUT#1 150 mA max 12 13 + – 10-30V dc GATE SIGNAL WHITE 4 BLACK 3 DRAIN (BARE) POWER 1 2 BLUE A-GAGE® High-Resolution MINI-ARRAY® 4-20 mA ANALOG OUTPUT #1 14 15 + – 16 17 18 19 20 TX TX RS-485 10-30V dc ALIGN DISCRETE OUTPUT#2 (ALARM) 4-20 mA ANALOG OUTPUT #2 Load 150 mA max Load +16 – 30V dc +16 – 30V dc Figure 10. MAHCIP-1 Wiring 3.3.1 Emitter and Receiver Wiring Connect emitters and receivers together in parallel to terminals #4 through #8 of the control module (identical for all control module models). See the figures in Wiring (p. 9) for wire color information. Trim braided shield flush with cable Trim foil shield flush with cable Uninsulated drain wire Note: The “drain wire” is the uninsulated stranded wire which runs between the braided shield and the foil shield. The foil shield and the braided shield should be removed at the point where the wires exit the cable. Figure 11. Emitter and Receiver Cable Preparation 3.3.2 Inputs System Power: Connect a source of 16 V dc to 30 V dc, rated at 1 amp or greater, to control module terminals #1 (+) and #2 (-). Connect a good earth ground to terminal #3 to provide electrical and RF noise immunity to the System. Note: Remove power before making other connections to the controller. Gate Signal: A source of 10 V dc to 30 V dc switched to terminals #12(+) and #13(-) provides a gating input (if required). The gating voltage typically is switched by the open-collector output transistor of a dc sensing device. The gate signal controls scanning when one of four Gate options is selected in the Control Mode Selection menu of the PSF configuration routine (see Control Mode Selection (p. 19)) . Align: A source of 10 V dc to 30 V dc switched to terminals #14(+) and #15(-) provides a remote means of running the automatic alignment and blanking routines. The switch sequence is identical to the procedure described in Push-Button Alignment Routine (p. 14) for the Alignment switch on the front of the control module. 10 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® 3.3.3 Outputs Control Module Analog Outputs (Terminals #10 and 16) Discrete Outputs2 (Terminals #9 and 20) 0 V to 10 V Sourcing NPN open-collector MAHCVN-1 Figure 7 (p. 9) 15 mA maximum 30 V dc maximum 150 mA maximum MAHCVP-1 0 V to 10 V Sourcing PNP open-collector 15 mA maximum 30 V dc maximum 4 mA to 20 mA NPN open-collector Sinking 30 V dc maximum 16 V dc to 30 V dc 150 mA maximum 4 mA to 20 mA PNP open-collector Sinking 30 V dc maximum 16 V dc to 30 V dc 150 mA maximum Figure 8 (p. 9) MAHCIN-1 Figure 9 (p. 9) MAHCIP-1 Figure 10 (p. 10) Serial Communication RS-232: All A-GAGE High-Resolution MINI-ARRAY Systems may communicate with a host computer or controller via RS-232 or RS-485 serial protocol. See Section 5.3.1 for selectable communications parameters. Prepare an RS-232 cable using a male DB-9 connector with connections as shown. Note: DO NOT use a “null modem” RS-232 cable RS-232 5 3 2 2 - TX 3 - RX 5 - COM DB-9 Pin # Function 2 Transmit (TX) 3 Receive (RX) 5 Ground (GND) Figure 12. DB-9 connections between the control module and the PC RS-485: RS-485 serial port is located at terminals #18 (TX) and #19 (TX). 3.4 Install the Software The Parameter Setup Software CD includes an installation program that quickly and easily loads the MINI-ARRAY configuration program into the computer. The MINI-ARRAY configuration program requires approximately 50 MB of hard disk space. Install as follows: 1. Use the Parameter Setup Software CD included with the controller, or download from www.bannerengineering.com as required. 2 Discrete Output #2 is labeled Alarm on the control module. www.bannerengineering.com - Tel: + 1 888 373 6767 11 A-GAGE® High-Resolution MINI-ARRAY® 2. Insert the Software CD into the CD drive. • If the program does not auto-start, browse to your CD drive, click Setup.exe, then select START, then select RUN. The Welcome dialog box displays. Select Next, and follow the prompts in the dialog boxes as they appear. • If the program does auto-start, the Welcome dialog box appears. Select Next, and follow the prompts in the dialog boxes as they appear. 3. The installation program decompresses the files. A status dialog box monitors the progress of the installation. 4. An Installation Completed dialog box appears. Select OK. 5. Reboot your computer for the changes to take effect. After the software is installed, a MINI-ARRAY shortcut icon is placed on your desktop. Double-click the MINIARRAY icon to launch the program, then follow the configuration instructions. 12 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® 4 Control Module Configuration Configure the A-GAGE High-Resolution MINI-ARRAY control module using a Windows® menu-style routine; the configuration routine requires the Banner-supplied HRMA software and a PC-compatible computer (running Windows® XP, Vista, or 7). Make a serial data connection between the computer and the DB9 connector on the control module. 4.1 Communications Setup 1. After installing the software, attach the serial communication cable between the control module and the PC. Note: If an RS-232 interface is used, only one control module is allowed on the line at any one time. The minimum connections to the control module’s DB-9 connector are shown in Figure 12 (p. 11). 2. Launch the High-Resolution MINI-ARRAY program. 3. Configure the serial communications port of the PC. a) Select Options > Serial Port from the High-Resolution MINI-ARRAY main menu. The program supports serial communication via the COM1-COM20.port of the computer. b) Highlight the desired serial port to select it. c) Select Save Settings on Exit to store the serial port selection, if it is not already ON. Parity is selected here also: Even, Odd or None. 4.1.1 Ping Routine Perform the Ping routine during system configuration, and before any Diagnostic, Alignment, or Edit routine. The routine polls all control modules on the communications line (one, in the case of the standard RS-232 line, or up to 15 modules, on an RS-485 circuit). It then is used to select an individual control module for configuration or alignment. 1. If needed, apply power to the system control module and allow the system to complete its power-up routine. 2. Press F5 or access the MINI-ARRAY menu. 3. Select Ping to perform the Ping routine. All connected control modules identify themselves with an ID value and baud rate; the routine takes approximately 15 to 20 seconds. After the Ping is performed, all valid control module ID values display in a chart on the screen, under their appropriate baud rates. Control modules are identified in the chart as X. Figure 13. Screen showing the result of a completed Ping routine 4. Point to a valid ID and click to select a control module. System Diagnostics, Alignment, or Edit routines may now be performed for the selected control module. www.bannerengineering.com - Tel: + 1 888 373 6767 13 A-GAGE® High-Resolution MINI-ARRAY® 4.1.2 Factory Settings Of the 15 available control module ID values (A through O), the factory software setting is A. Selectable communication baud rates are 9600, 19200, and 38400; the factory setting is 9600. See Selected Controller and Serial Communication (p. 18) for information on changing these settings. 4.2 System Alignment The emitter/receiver pairs have a wide field of view and are easy to align. The recommended distance between the emitter and receiver ranges from 380 mm to 1829 mm (15 in to 72 in). Shorter sensor separation can be achieved; consult Banner Engineering for details. Perform the Alignment process at System installation and repeat it every time one or both of the sensors is moved. Alignment of the System can be specified automatically using either the Alignment routine of the configuration software or the Alignment switch on the control module’s front panel. The System also may be aligned remotely, using pins 14 and 15 on the terminal block. Apply 10 V dc to 30 V dc power to the pins to approximate the push-button procedure. For example, apply input signal for 3 seconds to access Alignment mode. 1. Make sure the sensors have been wired as shown in Wiring (p. 9). 2. Apply power to the control module via terminals #1 and #2 (16 V dc to 30 V dc). The Diagnostics Indicator shows the sensors going though a power-up test: first the receiver, then the emitter. After the sensors have been tested and the System is ready for service, the Diagnostics Indicator shows — or —.; see figure. ALIGNMENT SWITCH 150mA MAX ALIGN RCVR DIAGNOSTICS INDICATOR GATE EMTR ALARM ALIGN GATE ALIGNMENT SWITCH ALARM RCVR DIAGNOSTICS INDICATOR OUTPUT EMTR With Blanking ON 150mA MAX OUTPUT With Blanking OFF R R Denotes Blanking Figure 14. Diagnostics Indicator Showing a Clear Condition 4.2.1 Push-Button Alignment Routine Re-align the System at installation or whenever the emitter and/or receiver is moved. 1. Press the Alignment switch on the control module front panel for 3 seconds. The letter A displays on the Diagnostics Indicator; the System is learning a clear condition. 2. Rotate the sensors as required (but do not change the distance between them). When the green Alignment LED is displayed on the control module and receiver, the sensors are adequately aligned. 3. To leave Alignment mode, press the Alignment switch for 3 seconds. During the alignment procedure, the System polls each receiver channel to measure excess gain and performs a coarse gain adjustment. When the System exits the alignment procedure, each channel’s signal strength is stored in non-volatile memory. The System is now ready for operation and does not require re-alignment unless the emitter or receiver is moved. 4.2.2 Software Alignment Routine The green LED indicator on the receiver and also on the control module continuously displays Alignment status. When all unblanked beams are clear, the green Alignment indicators are ON. To better understand blocked, clear, and blanked beams, launch the Alignment routine (press F8 or select Alignment under the MINI-ARRAY menu). The screen shows the state of all of the beam channels, grouped into sets of 16. Key information provided on the Alignment screen is the sensor size, plus the number of beams blocked, made, and blanked. The sensor size is given the title of Total; this refers to the total number of beam channels in the array. The number of beams blocked is a running total of blocked beams, excluding any blanked beams. The Made value is a count of unblocked beams. The Blanked value is a count of the number of beam channels that are blanked (channels that are ignored for measurement mode applications). 14 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® The Alignment screen provides the following functions: Start, Stop, Step, Clear Blanking Fields, Restore Control module Settings, Auto Blanking, Abort Auto Blanking, Save to File, Read From File, Cancel, OK, and Edit. To access any of these sub-routines, first click Stop, then the selected option. Start causes the control module to continuously scan and report All Channel Data. This data is used to update the state of each beam channel. Stop causes the control module to stop scanning. Step produces one scan and then stops until another command is issued. Clear Blanking Fields is a quick way to remove blanking specifications. Restore Control Module Settings recalls the blanking specifications in effect prior to Alignment/Blanking being entered. Auto Blanking is used to scan and determine which beams are blocked; blocked beams automatically become blanked beams. The Auto Blanking values can then be Accepted or Aborted. Edit is used to control the blanking specifications of any channel manually. This is useful for adding any number of blanked beam channels above and/or below a blanked object to allow for vibration or other movement of the object to be ignored. Blanking specifications can be saved and read from a computer file using Save To File and Read From File commands. Figure 15. Alignment screen 4.2.3 Blanking If a machine fixture or other equipment will continuously block one or more beams, the affected beam channels may be blanked. The Blanking option causes the control module to ignore the status of blanked beams for measurement mode calculations. For example, if a machine fixture blocks one or more beams during System operation, the output data will be incorrect; if beams blocked by the fixture are blanked, the output data will be correct. Blanking may be configured using the push-button Alignment switch on the control module, or by using the System software and a computer. Push-Button Blanking Setup Routine To specify blanking using the control module’s Alignment switch, position the object or part to be ignored in the path of the beams before beginning the Alignment routine. 1. Press the Alignment switch for 3 seconds. The Diagnostics Indicator shows the letter A. 2. Press the Alignment switch momentarily (about 0.5 seconds maximum). The Diagnostics Indicator shows the letter b to indicate it is ready to learn the blanking pattern. 3. Press the Alignment switch momentarily (about 0.5 seconds maximum) to set the blanking fields. Both the control module and the receiver indicate a clear condition (green Align indicator ON) and the Diagnostics Indicator shows A. (the period following the A indicates that blanking is in use). The beams blocked during the routine are now blanked. 4. To return to Run mode, again press the Alignment switch for 3 seconds. When the System is ready for operation and configured for beams to be blanked, the period on the Diagnostics Indicator remains lit, showing —.. www.bannerengineering.com - Tel: + 1 888 373 6767 15 A-GAGE® High-Resolution MINI-ARRAY® System Software Blanking Setup Routine 1. Position the object to be blanked in the path of the beams (this can be done at any time before beginning the blanking routine). 2. Perform the Ping routine to select the proper control module. 3. Press F8 or select the Alignment option from the MINI-ARRAY menu. 4. From the screen menu, select Stop. The Diagnostics Indicator on the control module shows the letter A. 5. Select Auto Blanking. The Diagnostics Indicator shows the letter b. 6. Select Accept Auto Blanking. Both the control module and the receiver indicate a clear condition (green Align indicator ON) and the Diagnostics Indicator shows A. (the period following the A indicates that blanking is in use). The beams blocked during the routine are now blanked and appear as the letter B on the grid instead of 0. Figure 16. Alignment screen, showing beams #1-11 blocked Figure 17. Alignment screen, showing beams #1-11 blanked 7. To blank additional beams, use Edit to manually set additional blanking (see Scanning Mode Limitations for Blanking (p. 16)). 8. To leave Alignment mode, click OK. When the System is ready for operation and configured for beams to be blanked, the period on the Diagnostics Indicator will remain lit, showing —.. Scanning Mode Limitations for Blanking All blanking features are available with Continuous Scan mode. For single-and double-edge scan, blanking is limited to four blanking fields. Other blanking features are ignored. To accommodate parts or components that will move through the array, blanking may be manually adjusted for one or more individual beam channels. 1. After using the system software to specify blanking, select Edit from the Alignment screen. The Diagnostics Indicator continues to show the letter b and a grid displays on the computer screen. The beams are numbered from the sensors’ cabled ends, with the beam closest to the cable being beam #1. 16 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® Figure 18. Edit channel blank state screen, showing beam #22 and beams #35-42 blanked; beams #65-80 are highlighted, ready to be selected for blanking 2. To set the blanking fields, click each grid box representing a beam you wish to blank. 3. Clicking again on a blanked beam channel removes the blanking specification. 4. To select or clear the blanking specification for several rows of channels, place the cursor directly to the left of the row to be selected and click the mouse. The rows highlight. 5. Select Blank Selected (to accept the blanking status) or Clear Selected (to reject the blanking status) option. 6. To leave Alignment mode, click OK. Both the control module and the receiver indicate a clear condition (green Align indicator ON) and the Diagnostics Indicator shows A.. When the system is ready for operation and configured for beams to be blanked, the period on the Diagnostics Indicator remains lit, showing —.. 4.3 Programming Control Module Response Use the Parameter Setup File (PSF) Configuration routine to configure the control module for a specific application. After performing the Ping routine to select a control module, access the PSF Configuration screen by selecting Edit PSF (F4) from the MINI-ARRAY menu. The Edit PSF process may also be performed with no control module selected, to configure and save a PSF for multiple control modules. In such a case, some fields on the PSF Configuration screen will not be accessible. The process of configuring the control module involves selecting among options for each of the parameters listed in this section, including serial communication, control mode, scanning method, scan analysis mode, serial transmission, and analog/discrete outputs. The resulting combination of options causes the control module to react as required for the application, to changes in the light screen. The configuration process produces a Parameter Setup File (PSF). PSF files may be saved and retrieved as computer files via File Save PSF and File Retrieve PSF (see Saving and Recalling PSF Files (p. 25)) . After it is configured, a PSF may be sent to the control module via the Send PSF command. The PSF currently loaded into the control module may be displayed by using the Upload PSF command. www.bannerengineering.com - Tel: + 1 888 373 6767 17 A-GAGE® High-Resolution MINI-ARRAY® Selected Controller Identifies the specific control module being configured. Control Mode Selection Analysis (Measurement) Mode Selection Choose the measurement option that best tells you the size and/or position of objects as they relate to the array. Serial Communication Changes the identification and baud rate of the controller being configured. Continuous Mode: The control module constantly polls the array for status. Host Mode: The control module polls the array for status when prompted by a host controller. Gate Mode: The control module polls the array for status when prompted by an input from a Gate sensor. Serial Transmission Specifies the type of data transmitted from the control module to its host after each scan. Measurement Mode Result: Data transmitted will reflect the Analysis Mode selections. All Mode: Transmits all data. Max. Meas. Mode: Sends only the largest measurement in each measuring event, to decrease transmission size and speed response. Choose to send when the array is clear or send at the host’s request. Transmission Type: ASCII or Binary, defines the format in which the data will be sent. Serial Options: Suppress Clear Data or Suppress Header to decrease transmission size and speed response. Scanning Method Straight scan polls each beam sequentially to determine the target object’s overall size. This is the most accurate and precise measurement, but also the most time-consuming. Single Edge scan requires the target object to block beam 1 (closest to the sensors’ cabled ends), then conducts a time-saving binary search to “hunt” for the target’s overall height (one variable edge). Double Edge scan conducts a time-saving search of the entire array to “hunt” for the target’s overall width (two variable edges) Zero Value Zero Value is used to specify the analog output when the measurement mode value is zero. The user can specify a value of LAST, NULL, or SPAN. LAST: Output holds the last non-zero value before the light screen became clear. Scan #: (1-9) Analog outputs are updated with an average value of the data received during the selected number of scans; discrete outputs respond only if the received data is identical for all of the selected number of consecutive scans. NULL: Provides the minimum value. SPAN: Provides the maximum value. Trigger/Trigger Channel Number Analog and Discrete Output Assignment Assigns an analysis (measurement) mode to each output. May be used to trigger (or gate) the scan sequence of another A-GAGE High-Resolution MINI-ARRAY controller; in straight scanning mode, it defines when during each scan discrete Output #2 will change state. Set Point and Hysteresis Selection Assigns the set point to determine where within the array the output(s) will respond and hysteresis values to smooth output response. Alarm: Causes the control module to turn on discrete Output #2 whenever the System detects a sensing error or if the optical signal becomes marginal. Figure 19. Use the PSF Configuration Screen to Program Each Control Module Individually 4.3.1 Selected Controller and Serial Communication The Selected Controller box displays information about the control module being configured. Two of these settings may be changed in the Serial Communication box. The settings selected and displayed in these boxes are those used to identify the control module during the Ping routine. Controller ID (assigned a letter, A through O) is used to identify each individual control module when multiple discreteoutput control modules (up to 15) are connected on one EIA-485 party line. Note: Analog output control modules do not offer RS-485 communication; choose any ID letter (A through O) when programming an analog-output control module. 18 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® Baud Rate is the data communication rate between the control module and the computer used for configuration and also the process controller. Choose from three values: 9600, 19200, and 38400. Parity: Select Odd, Even, or None. All controllers on one EIA-485 party line should have the same parity settings. 4.3.2 Control Mode Selection The control mode determines the method used to control scanning of the light screen array. Choose from three main control modes: • Continuous Scan Mode • Serial Host Command Mode • Gate Mode, which has four options In Continuous Scan mode, the control module begins a new scan as soon as it updates the outputs from the previous scan. This is the fastest scan control method; it is used in most analog output applications and whenever continuous updating of the outputs is acceptable. Host mode allows the control module to communicate with a host computer or control module via RS-232 (all models) or RS-485 (discrete-output models only) serial protocol. The host directs the control module to scan on demand and receives the output data from the control module in binary or ASCII form. Baud rates of 9600, 19200, and 38400 are selectable in the Serial communications menu. See Additional Information (p. 35) for more information on Host mode data format. Gate mode activates an optically isolated external Gate input between terminals 12 (+) and 13 (-) of the control module. The Gate input has impedance of 7.5 kΩ and accepts a 10 V dc to 30 V dc signal. A dc device such as a photoelectric sensor or optical encoder typically supplies the Gate input. Gate input signals must be greater than 150 microseconds in duration; the time between successive Gate inputs must be greater than the minimum scan time for the light screen array (see Scanning Method (p. 19) for scan time information). Gate mode has four options: • Gate ON: the control module will scan as long as the gate is active. • Gate OFF: the control module will scan whenever the gate is not active. • Gate ON/OFF: the control module will scan once for each gate transition from ON to OFF. • Gate OFF/ON: the control module will scan once for each gate transition from OFF to ON. 4.3.3 Scanning Method The control module may be configured for one of three scanning methods: • Straight Scan • Single-Edge Scan • Double-Edge Scan Straight scan is the default mode in which all beams are scanned in sequence from the bottom end (cable end) to the top end of the array. This scanning method requires the longest scan times and provides the smallest object detection size (2.5 mm, 0.1 in diameter). Single-Edge scan is used to measure the height of a single object. A good application for this scanning method is box height measurement. For Single-Edge scan, the system always activates the first beam channel (nearest the cable end, or bottom). If the first beam is blocked, the sensor performs a binary search to hunt for the last beam blocked. Single-Edge scan works as follows: 1. The receiver scans only the bottom beam until that beam is blocked. 2. When the bottom beam is blocked, the sensor looks to see whether the middle beam is blocked or made (unblocked). 3. If the middle beam is made (unblocked), the sensor checks the bottom quarter beam; if the middle beam is blocked, the sensor checks the top quarter beam. This is called a binary search. 4. This routine continues to narrow the field until the edge is found. www.bannerengineering.com - Tel: + 1 888 373 6767 19 A-GAGE® High-Resolution MINI-ARRAY® Step #1 High-Resolution Emitter Step #2 Beam #1 of 64 Blocked MAHCN-1 Control Module Step #3 Beam #32 Blocked Beam #48 Clear High-Resolution Receiver N-1 MAHC R ROLLE CONT RRAY No. — 1 2 3 4 N MINI-A LUTIO 8 9 DIAG Error Type System OK Align / blank Output Short E/ R Mismatc Receive h r Error NOS TICS Error 4 5 6 7 8 RESO HIGH No. POWER 2 1 Error Type Emitter Error Serial Comm EEPROM CPU Null 3 + 10 11 12 + 14 15 + 16 – 17 18 20 19 NC TX TX RS-485 ALARM 10-30Vdc ALIGN – MAX 30V(MAX) 150mA STICS OR DIAGNO INDICAT EMTR ENT ALIGNM SWITCH 3 4 5 6 7 8 9 TX 2RX 3COM 5- 2 RS-23 RCVR – dc 16-30V MAX 1A Error / Span POWER 2 1 13 10-30Vdc GATE NC 7 6 T/R 5 T/R WH 4 DRN OUTPUT#1 BK COM NC +12V BU 5 Wires BR 30V MAX 150mA F1 OUTPUT ALARM GATE ALIGN Error 10 11 12 13 14 15 16 17 18 19 20 Step #4 Step #5 Beam #40 Blocked Step #6 Beam #44 Clear Step #7 Beam #42 Blocked Beam #43 Blocked Figure 20. Finding an Edge Using a Binary Search Note that the receiver always checks the bottom beam first, and only if that beam is blocked does the binary search continue. Therefore, Single-Edge scan will not work in instances where an item that does not block the first beam is to be measured. Single-Edge scan is also ineffective if the object does not present a continuous blocked pattern. In other words, Single-Edge scan is used for single, solid objects that block the first beam. Double-Edge scan is used to detect two edges of a single object, for example, box width measurements. Double-Edge Scan requires the selection of a step size: 2, 4, 8, 16 or 32 beams. The sensor uses the steps to skip over beams. DoubleEdge scan works as follows: 1. The sensor activates beam #1 (the beam closest to the sensor cable end). 2. The sensor activates the next beam, determined by the step size. For example, if the step size is 2, beam #3 is next; if the step size is 8, beam #9 is next. 3. As long as the activated beam is unblocked (or made), the sensor continues the stepping routine until a blocked beam is found. 4. When a blocked beam is found, a binary search is conducted to find the object’s bottom edge. 5. When the bottom edge is found, the sensor begins stepping again through the array until the sensor finds the next unblocked beam. 6. A binary search is again performed to find the second edge. Note that this scanning method sacrifices object detection size for speed. Similar to Single-Edge scan, Double-Edge scan has some restrictions: the object should provide a solid obstruction; the size of the object will determine the maximum step size. Table 1: The Effect of Step Size on Minimum Object Detection Size Number of Beams Step Size Minimum Object Detection Size 2 4 8 16 32 5 mm (0.2 in) 10 mm (0.4 in) 20 mm (0.8 in) 40 mm (1.6 in) 80 mm (3.2 in) Sensor response time is a function of sensor length and scanning method. Typical scan times are shown in the following table. Table 2: The Effect of Sensor Length and Scanning Method on Scan Time (Typical) Maximum Scan Time (in milliseconds) Array Length 163 mm (6.4 in) 20 Double-Edge Scan Straight Scan Single-Edge Scan Step 2 Beams Step 4 Beams Step 8 Beams Step 16 Beams Step 32 Beams 5.8 1.8 4.8 3.4 2.7 2.5 2.6 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® Maximum Scan Time (in milliseconds) Double-Edge Scan Straight Scan Single-Edge Scan Step 2 Beams Step 4 Beams Step 8 Beams Step 16 Beams Step 32 Beams 325 mm (12.8 in) 10.6 1.9 8.1 5.1 3.6 3.0 2.7 488 mm (19.2 in) 15.0 2.1 11.5 6.8 4.5 3.4 3.0 650 mm (25.6 in) 20.1 2.1 14.9 8.5 5.3 3.9 3.2 812 mm (32.0 in) 24.9 2.1 18.3 10.1 6.1 4.2 3.5 975 mm (38.4 in) 30.0 2.1 21.7 11.8 7.0 4.7 3.6 1138 mm (44.8 in) 34.5 2.1 25.0 13.5 7.9 5.1 3.8 1300 mm (51.2 in) 39.3 2.1 28.4 15.2 8.7 5.5 4.1 1463 mm (57.6 in) 44.0 2.2 31.8 16.9 9.5 5.9 4.3 1626 mm (64.0 in) 48.0 2.3 35.1 18.6 10.4 6.4 4.5 1788 mm (70.4 in) 53.6 2.3 38.5 20.3 11.2 6.8 4.7 1951 mm (76.8 in) 58.4 2.3 41.9 21.9 12.1 7.2 4.9 Array Length Note: Scan times are exclusive of serial communication transmission times. www.bannerengineering.com - Tel: + 1 888 373 6767 21 A-GAGE® High-Resolution MINI-ARRAY® 4.3.4 Scan Analysis Mode Selection The control module may be programmed, if desired, for any one or two of seven Scan Analysis (measurement) Modes. Each selected mode may be assigned individually to an output (see section Analog Output Configuration (Analysis Mode Assignment) (p. 22) or Zero Value (p. 23)). The beams in the array are numbered in sequence, with beam #1 located at the cabled end of the emitter and the receiver. Beam Location Modes • First Beam Blocked (FBB): The control module identifies the location of the First Beam Blocked. • First Beam Made (FBM): The control module identifies the location of the First Beam Made (unblocked). • Last Beam Blocked (LBB): The control module identifies the location of the Last Beam Blocked. • Last Beam Made (LBM): The control module identifies the location of the Last Beam Made (unblocked). • Middle Beam Blocked (MBB): The control module identifies the location of the Middle Beam Blocked, midway between the first and last beams blocked. Beam Total Modes • Total Beams Blocked (TBB): The control module totals the number of blocked beams. • Total Beams Made (TBM): The control module totals the number of made (unblocked) beams. • Contiguous Beams Blocked (CBB): The control module identifies the largest number of consecutively blocked beams. • Contiguous Beams Made (CBM): The control module identifies the largest number of consecutively made beams. • Transitions (TRN): The control module counts changes from blocked to clear and clear to blocked. For instance, if beams 6-34 are blocked, then there is a clear-to-blocked transition from beam 5 to beam 6, and a blocked-to-clear transition from beam 34 to beam 35. Transition mode can be used to count objects within the array. Receiver Last Beam Made (LBM) First Beam Made (FBM) Emitter 48 40 32 24 16 In Last Beam Made mode, last beam is #37 of 48 In First Beam Made mode, first beam is #26 of 48 8 Receiver Last Beam Blocked (LBB) First Beam Blocked (FBB) Emitter 48 40 In Last Beam Blocked mode, last beam is #43 of 48 32 24 16 In First Beam Blocked mode, first beam is #15 of 48 8 Receiver Total Beams Made (TBM) Total Beams Blocked (TBB) Emitter 48 40 In Total Beams Made mode, 34 of 48 possible beams are made 32 24 16 8 In Total Beams Blocked mode, 14 of 48 possible beams are blocked Figure 21. Examples of MINI-ARRAY Scan Analysis Modes The Analysis Mode(s) programmed may be assigned to any one of the available outputs. Each output can be set for MEAS1, MEAS2, MEAS1 Inverted, or MEAS2 Inverted. 4.3.5 Analog Output Configuration (Analysis Mode Assignment) Analog outputs #1 and #2 may each be assigned to one of the analysis modes. When the selected Scan Analysis Mode involves first or last beam blocked or made (unblocked), the assigned output will vary in proportion to the beam number identified during a scan. When the Scan Analysis Mode involves total beams blocked or made, that assigned output will vary in proportion to the total beams counted during a scan. Note that the menus used for assignment of the Scan Analysis Modes to the analog outputs include two Inverted selections. When either MEAS1 Inverted or MEAS2 Inverted is selected, that analog output will decrease as the measurement mode value increases. An inverted output is at full scale (Span value) when the scan analysis value is zero; and at maximum scan analysis value, the output is at the Null value. The Null/Span Configuration screen , may be used to adjust the zero and full scale reading for either analog output. To display the Null/Span Configuration screen, click on the Null/Span button at the bottom of the PSF Configuration screen. Each output is independent and must be adjusted separately. Adjust the Null and Span values either by moving the slide bars, or by entering a new value on the keyboard. Note: When in the Null/Span screen, the controller has a diagnostic code of 8. 22 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® Figure 22. Null/Span Configuration screen To Measure: Analog Voltage Output: Connect the voltmeter between terminals 10 or 16 (+) and 17 (–). Analog Current Output: Connect the ammeter between terminals 10 or 16 (–) and 1 (+). Analog Output Type Null Span Minimum Maximum Minimum Maximum Voltage 10 mV 2.3 V 4.8 V 10.1 V Current 3.9 mA 7.8 mA 11.9 mA 20.2 mA Adjust the Null and Span ranges as follows: 1. To read the new values on the meter, click Null or Span Update. 2. Click OK to save the new settings and return the program to the PSF Configuration screen. Clicking Cancel returns the program to the previously saved null and span settings. Note: Null and Span are factory set to specified values and usually require no changes. Scan # provides a way to smooth output response and avoid unstable analog output conditions. The menu allows selection of 1 to 9 scans. For analog outputs, if scan # is set at more than 1, the scan analysis value is averaged for all of the selected number of consecutive scans, preventing dips and spikes in the outputs. For total beam values (TBB and TBM analysis modes), programming of blanked beams will affect the proportional analog outputs. Blanked beams are ignored both in the number of blocked or made beams and the total number of beams. For example, if a 64-beam array has 20 blanked beams and 22 of the remaining 44 beams are blocked, the output values will be at mid-range. 4.3.6 Zero Value Zero value is used to specify the analog output when the measurement mode value is zero. Select an analog output of Last, Null, or Span. Last: Output holds the last non-zero value before the light screen became clear. Null: Provides the minimum value. Span: Provides the maximum value. 4.3.7 Discrete Output Configuration (Analysis Mode Assignment) Discrete outputs #1 and #2 (Alarm) may each be individually assigned to one of the Scan Analysis Modes programmed in Scan Analysis Mode Selection (p. 22). www.bannerengineering.com - Tel: + 1 888 373 6767 23 A-GAGE® High-Resolution MINI-ARRAY® Figure 23. Assigning an Analysis Mode to each Discrete output (PSF Configuration screen); Alarm and Trigger output options are available only for Discrete Output #2 Next to each discrete output assignment menu are Low Set Point and High Set Point boxes. The number in each box identifies a beam in the array (beam #1 being closest to the cabled end of the emitter and the receiver). Change the Low and High Set Points by clicking on a box and entering a new number. When the selected Scan Analysis Mode involves first or last beam blocked or made (unblocked), the assigned output will energize when the beam identified during a scan falls within the range of the set points. When the Scan Analysis Mode involves total beams blocked or made, that assigned output will energize when the value of total beams counted during a scan falls within the range of the set points. Note that the menus used for assignment of the Scan Analysis Modes to the discrete outputs include two Inverted selections. When either MEAS1 Inverted or MEAS2 Inverted is selected, that discrete output will de-energize (turn OFF) whenever a scan analysis value falls within the range of the set points. Hysteresis values for each end of the set point range may also be set. Hysteresis determines the amount of change that must occur at each set point (High and Low) to cause the associated output to change state. Hysteresis prevents unstable output conditions when the scan analysis value exactly matches one of the set points. The default hysteresis setting is one beam less than the Low Set Point and one beam more than the High Set Point. Scan # provides another way, in addition to hysteresis settings, to smooth output response. Outputs are updated only after the selected number of identical (within the hysteresis limits) scans. The menu allows selection of 1 to 9 scans. For discrete outputs, the scan analysis value must stay either inside or outside the hysteresis limits for all of the selected number of consecutive scans, in order for the output to respond. Alarm and Trigger Discrete output #2 (only) has two additional options: Alarm and Trigger. Alarm: Output #2 energizes whenever the System detects a sensor error (such as a disconnected cable) or whenever the excess gain of one or more beams becomes marginal. Trigger: can be used to gate a second control module when Continuous Scan Method is also used. When the control module is in straight scanning mode, Trigger Channel Number defines the beam number during a scan at which the trigger output will occur. The Trigger output is a 100 microsecond (0.0001 second) pulse. If the control module is set for single or double edge scan, the Trigger pulse comes at the end of the scan (Trigger Channel Number is ignored). 4.4 Serial Communication with a Host Controller The control module communicates with a host process controller via RS-232 or RS-485 protocol and at the baud rate specified in the Serial Communications box. The System provides a number of data transmission options. 4.4.1 Serial Data Transmission The serial transmission portion of the PSF Configuration screen activates the serial port(s), specifies the data format, and provides data suppression options. These settings are required to allow a control module to communicate with a host computer or process controller. If No Serial Communication is selected (the default setting), the serial port(s) will not transmit sensing data. Measurement Mode Result: Data transmitted are the values output for the Scan Analysis Mode selections. Up to two Scan Analysis Mode selections can be active. 24 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® ALL Mode: The status of each beam in the light screen array is transmitted for each scan. In ALL mode, blanked channels are transmitted as unblocked (or clear) beams. Max Meas Mode: The control module records the maximum measurement value registered while the light screen is blocked. That data may be transmitted to the host either when the array is clear at the end of the sensing event (select Send On Clear), or when prompted by the host (select Send On Request). This mode reduces the amount of serial data sent. 4.4.2 Transmission Type Transmission type defines the format in which data is sent. The ASCII option causes the control module to send data in three ASCII-coded bytes. The Binary option causes data to be sent in binary format, reducing the amount of data per measurement mode from three bytes to two. For more information on the data formats, refer to Additional Information (p. 35). 4.4.3 Serial Options The Serial Options box provides two options: Suppress Clear Data and Suppress Header. Suppress Clear Data provides one method to reduce the amount of data being transmitted by the control module, accomplished by not sending data when no object is detected. The control module transmits serial data only when one or more unblanked beams of the light screen array are blocked. When the array goes from blocked to clear, data is sent one additional time, indicating the clear condition. Suppress Header is used to prevent transmission of the three-byte identification string (“header string”) associated with either ASCII or Binary data formats. The header string consists of two bytes at the start of the data, and a termination byte to mark the end of the serial transmission. See Additional Information (p. 35) for more information on serial data formats. 4.5 Transfer of PSF to the Control Module After making all of the selections in the PSF Configuration screen, send the PSF to the control module by clicking Send PSF. This command loads the PSF into the non-volatile memory of the control module, and automatically overwrites the current PSF. The program confirms that the PSF was accepted, or notifies the user of changes required to the PSF. To check the values of the PSF currently loaded into the control module, select Upload PSF. The current PSF displays on the PSF Configuration screen. 4.5.1 Saving and Recalling PSF Files To place the displayed PSF into a file that can be retrieved at any time: 1. Click File Save PSF. 2. When asked if you want to save the PSF to a file, select Yes. A subscreen titled FileSave displays. 3. Overtype *.psf in the File Name entry box with the name of the file to be stored (up to 8 characters), plus the .psf extension. 4. Click OK (or press Enter). The PSF is stored on the selected drive (default is c:) and the program automatically returns to the PSF Configuration screen. To retrieve a filed PSF: 1. Click File Retrieve PSF. The FileBox subscreen displays. 2. Select the desired PSF from the File Name list. 3. Click OK (or press Enter). The selected PSF loads to the PSF Configuration screen, and it can then be loaded into the controller using the Send PSF command. 4.5.2 PSF Output Analysis To view activity in the array in response to the currently loaded PSF: 1. Select Execute. The Measurement Output screen displays. www.bannerengineering.com - Tel: + 1 888 373 6767 25 A-GAGE® High-Resolution MINI-ARRAY® Figure 24. Measurement Output Screen 2. Select Run. The table displays the status for the selected measurement mode(s), including the Present value and the High and Low values for the Run period. 3. Select Stop to freeze the data. 4. Select Step to initiate a single scan of the array to simulate a snapshot of what is viewed by the array at the instant that Step is selected. Use of the Execute command is beneficial for testing the response of a gated system. Run simulates the Continuous Scanning mode, and Step simulates a gate input command. 4.5.3 Quit and Exit To close the PSF Configuration screen, select either Quit or Exit. Selecting Quit erases the Edit PSF Screen and sends the user back to the Main Window; the present PSF Screen values are not retained. The Exit command is similar to the Quit command, except the user is prompted to save the configuration values to a parameter setup file (PSF). 26 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® 5 System Diagnostics Perform System diagnostics by using the status and diagnostics indicators on the control module and sensors, or by using the diagnostics software routine, or by a combination of the two. 5.1 Diagnostic Indicators Bright, easy-to-see LED indicators on both sensors and on the front panel of the control module provide an ongoing display of the system’s operating status. High-Resolution Emitter 7.6 mm (0.30") High-Resolution Receiver 5.1 mm (0.20") 2.5 mm (0.10") DIN-Rail-Mountable Control Module MAHCVP-1 HIGH RESOLUTION MINI-ARRAY CONTROLLER POWER 1 2 3 4 5 6 F1 BR BU + 8 10 11 12 13 14 15 16 17 18 19 20 TX TX BK WH 0-10VOLTS 25mA (MAX) V OUT 1 +V – 16-30V dc 1A MAX + – + – 10-30VDC 10-30VDC GATE ALIGN 0-10VOLTS 25mA (MAX) V OUT 2 D OUT 1 150mA MAX +V ALARM 150mA MAX ALIGN ALIGNMENT SWITCH GATE RCVR DIAGNOSTICS INDICATOR ALARM EMTR Alignment Button 9 OUTPUT Diagnostics Indicator 7 +12V COM DRN T/R T/R Red Operational LED RS-232 2 - TX 3 - RX 5 - COM POWER Green Alignment LED Red Blocked LED Yellow Marginal Alignment LED Red Discrete Output #1 LED Red Alarm (Discrete Output #2) LED Red Gate LED Green Align LED RS-232 Port Figure 25. A-GAGE High-Resolution MINI-ARRAY System Diagnostics and Status Indicators Note: Status indicators appear to freeze if the controller has been configured for Gate or Host mode, and no signal is present to cause a scan update. Control Module OUTPUT (red): Displays the status of Discrete Output #1. ALARM (red): Displays the status of Discrete Output #2. This output may be assigned to an analysis mode, or it may be used as a system diagnostics alarm or as a trigger alarm to gate another A-GAGE High-Resolution MINI-ARRAY System. GATE (red): Displays the status of the gate input. ALIGN (green): Indicates proper emitter/receiver alignment and a clear, unblocked light screen. This indicator is ON when either the green or both the green and yellow LEDs of the receiver are ON. Diagnostics Indicator: This bright, segmented LED display on the control module front panel indicates one of ten system status conditions, plus the presence or absence of blanking. Blanking ON causes a period to appear in the Diagnostics Indicator window, in addition to the System’s other status condition. See the table for the key to these error types and status conditions; this chart is also located on the side of the control module. Table 3: Key to System Diagnostics Indicator codes Error Number Error Type Action – System is OK None A/b Align / blank Status www.bannerengineering.com - Tel: + 1 888 373 6767 27 A-GAGE® High-Resolution MINI-ARRAY® Error Number Error Type Action 1 Output Short Check output load & wiring 2 E / R Mismatch System must use same length emitter and receiver 3 Receiver Error • • Check receiver cable Replace receiver 4 Emitter Error • • Check emitter cable Replace emitter 5 Serial Comm 6 EEPROM 7 CPU Error Replace control module 8 Null / Span Status Check serial cable • • • Reconfigure PSF Replace control module Reconfigure blanking Emitter OPERATIONAL (red): LED indicates power to the emitter is ON, and unit is operational. Receiver BLOCKED (red): LED indicates some of the array beams are blocked. MARGINAL (yellow): LED indicates that array alignment is marginal. ALIGNMENT (green): LED indicates that array alignment is satisfactory. To improve alignment, adjust the position of the emitter and receiver until the green LED lights, making sure that no unblanked beams are interrupted. Then use one of the methods in System Alignment (p. 14) to realign the system. 5.2 Diagnostics Routine Emitter or receiver problems may be further diagnosed using the Diagnostics routine included with the MINI-ARRAY software. Launch the program by selecting Diagnostics under the MINI-ARRAY menu or by pressing F2. The Diagnostics screen displays the size of each emitter and receiver (expressed in the number of 64-element boards it contains) and its functional status (or state). If an error has occurred, the specific problem beam channel is identified. Additionally, if there is a problem with an emitter or receiver cable connection, a “No Response” message displays. Figure 26. Diagnostics screen, accessible from the MINI-ARRAY menu The Diagnostics routine also displays the part number and date code of the controller, information that may be useful if Banner-assisted troubleshooting is required. 28 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® 6 Specifications 6.1 Emitter and Receiver Specifications Emitter/Receiver Range 380 mm to 1.8 m (15 in to 6 ft) Sensor Scan Time 1.8 milliseconds to 58.4 milliseconds, depending on scanning method and sensor length See Scanning Method (p. 19) for detailed information Minimum Object Sensitivity 2.5 mm (0.1 in) Construction Aluminum, with black anodized finish; acrylic lens cover Status Indicators Emitter: Red LED lights to indicate proper emitter operation Receiver: Power Requirements 12 V dc ± 2%, supplied by controller Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Green indicates sensors aligned Yellow indicates marginal alignment of one or more beams Red indicates sensors misaligned or one or more beam(s) blocked Connections Sensors connect to controller using two 5-conductor quick-disconnect cables (one each for emitter and receiver), ordered separately Use only Banner cables, which incorporate a “twisted pair” for noise immunity Cables measure 8.1 mm (0.32 in) in diameter and are shielded and PVCjacketed Conductors are 20 gauge (0.9 mm) Emitter and receiver cables may not exceed 75 m (250 ft) long, each Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 Operating Conditions 0 °C to +50 °C (+32 °F to +122 °F) 95% at +50 °C maximum relative humidity (non-condensing) 24 2.0 26 1.0 Certifications 28 0.8 30 0.5 Environmental Rating NEMA 4, 13 (IEC IP65) www.bannerengineering.com - Tel: + 1 888 373 6767 29 A-GAGE® High-Resolution MINI-ARRAY® 6.2 Emitter and Receiver Dimensions All measurements are listed in millimeters [inches], unless noted otherwise. 53.8 mm (2.12") L1 38.1 mm Square (1.50") L3 L2 2.5 mm (0.10") 47.2 mm (1.86") 18.3 mm (0.72") 10.2 mm (0.40") 71 mm (2.8") R13 mm (0.5") Minimum Bend Figure 27. Emitter and Receiver Dimensions Housing Length Model Distance Between Bracket Holes Emitter Receiver L1 L2 L3 MAHE6A Emitter MAHR6A Receiver 236 mm (9.3 in) 268 mm (10.5 in) 211 mm (8.3 in) MAHE13A Emitter MAHR13A Receiver 399 mm (15.7 in) 430 mm (16.9 in) 373 mm (14.7 in) MAHE19A Emitter MAHR19A Receiver 561 mm (22.1 in) 593 mm (23.3 in) 536 mm (21.1 in) MAHE26A Emitter MAHR26A Receiver 724 mm (28.5 in) 756 mm (29.7 in) 699 mm (27.5 in) MAHE32A Emitter MAHR32A Receiver 887 mm (34.9 in) 918 mm (36.2 in) 861 mm (33.9 in) MAHE38A Emitter MAHR38A Receiver 1049 mm (41.3 in) 1081 mm (42.6 in) 1024 mm (40.3 in) MAHE45A Emitter MAHR45A Receiver 1215 mm (47.8 in) 1246 mm (49.1 in) 1189 mm (46.8 in) MAHE51A Emitter MAHR51A Receiver 1377 mm (54.2 in) 1409 mm (55.5 in) 1352 mm (53.2 in) MAHE58A Emitter MAHR58A Receiver 1540 mm (60.6 in) 1572 mm (61.9 in) 1515 mm (59.6 in) MAHE64A Emitter MAHR64A Receiver 1703 mm (67.0 in) 1734 mm (68.3 in) 1677 mm (66.0 in) MAHE70A Emitter MAHR70A Receiver 1865 mm (73.4 in) 1897 mm (74.7 in) 1840 mm (72.4 in) MAHE77A Emitter MAHR77A Receiver 2028 mm (79.8 in) 2060 mm (81.1 in) 2003 mm (78.8 in) 30 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® 6.3 Emitter/Receiver Mounting Bracket Dimensions QD End ø30.5 mm (1.20") NON-QD End 6.4 mm (0.25") ø6.8 mm (2) (0.27") ø13.2 mm (0.52") 3.8 mm (0.15") 57.2 mm (2.25") 38.1 mm (1.50") 44.5 mm (1.75") Slots have clearance for M4 bolts (supplied) and allow 30 rotation 3.0 mm (0.12") 34.8 mm (1.37") 11.9 mm (0.47") 4.8 mm (2) (0.19") 6.4 mm R (0.25") Full R (4) 10.2 mm (2) (0.40") Min. R. 24.6 mm (0.97") 53.8 mm (2.12") Material: Cold Rolled Steel Finish: Black, Zinc Plated Chromate Dip Figure 28. Emitter/Receiver Mounting Bracket Dimensions 6.4 Control Module Specifications Power Requirements 16 V dc to 30 V dc at 1.0 A (typical: 0.5 A at 16 V dc) Output Configuration MAHCVP-1: Two PNP discrete (switched), two 0 V to 10 V voltage sourcing MAHCVN-1: Two NPN discrete (switched), two 0 V to 10 V voltage sourcing MAHCIP-1: Two PNP discrete (switched), two 4 mA to 20 mA current sinking MAHCIN-1: Two NPN discrete (switched), two 4 mA to 20 mA current sinking Construction Polycarbonate housing; mounts to flat surface or directly onto 35 mm DIN rail Environmental Rating Control Module: NEMA 1, IEC IP20 Emitter/Receiver: NEMA 4, 13; IEC IP65 Operating Conditions 0 °C to +50 °C (+32 °F to +122 °F) 95% at +50 °C maximum relative humidity (non-condensing) www.bannerengineering.com - Tel: + 1 888 373 6767 31 A-GAGE® High-Resolution MINI-ARRAY® Inputs Sensor input: Emitter and receiver wire in parallel to five terminals. Gate input: Optically isolated, requires 10 V dc to 30 V dc (7.5 kΩ impedance) for gate signal Remote alignment input: Optically isolated, requires 10 V dc to 30 V dc (7.5 kΩ impedance) for alignment sequence signal Discrete (Switched) Outputs NPN outputs: Open collector NPN transistor rated at 30 V dc maximum, 150 mA maximum PNP outputs: Open collector PNP transistor rated at 30 V dc maximum, 150 mA maximum All discrete outputs: OFF-state leakage current: < 10 μA at 30 V dc ON-state saturation voltage: < 1 V at 10 mA and < 1.5 V at 150 mA Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Analog Outputs Voltage-sourcing outputs: 0 V dc to 10 V dc (25 mA current limit) Current-sinking outputs: 4 mA to 20 mA (16 V dc to 30V dc input) Resolution: Span / Number of sensing channels Linearity: 0.1% of full scale Temperature variation: 0.01% of full scale per °C Serial Data Outputs RS-232 or RS-485 interface. (Up to 15 control modules may be given unique addresses on one RS-485 party line.) ASCII or binary data format 9600, 19.2 K, or 38.4 K baud rate 8 data bits, 1 stop bit, and even, odd, or no parity System Programming Via RS-232 interface to PC-compatible computer running Windows® XP, Vista, or 73 and using software supplied with each control module. Certifications Status Indicators Output 1 (red): Lights to indicate Discrete Output #1 is active Alarm (red): Lights to indicate Discrete Output #2 is active Gate (red): Lights to indicate GATE input is active Align (green): Lights to indicate emitter and receiver are aligned Diagnostics indicator: (Key on controller side label) Identifies system errors and status 3 Microsoft and Windows are registered trademarks of Microsoft Corporation in the United States and/or other countries. 32 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® 6.5 Control Module Dimensions All measurements are listed in millimeters [inches], unless noted otherwise. 115.0 mm (4.53") 106.0 mm (4.17") 5.0 mm (0.20") 69.0 mm (2.72 ") 5.5 mm (0.22") 81.0 mm (3.19") 96.0 mm (3.78") 35.0 mm (1.38") DIN mounting slot Slot for M3.5 screws (2) Figure 29. Control Module Dimensions www.bannerengineering.com - Tel: + 1 888 373 6767 33 A-GAGE® High-Resolution MINI-ARRAY® 7 Accessories 7.1 Cordsets 5-Pin Mini-Style Cordsets with Shield—Single Ended Model Length QDC-515C 4.57 m (15 ft) QDC-525C 7.62 m (25 ft) Style Dimensions Pinout (Female) 58 7/8-16UNF 2 4 3 Straight QDC-550C 1 5 1 = Black 2 = Blue 3 = Drain 4 = Brown 5 = White ø 26 15.2 m (50 ft) Communication Cable Model Length Style Dimensions Pinout (Female) 55.5 mm MASC 2 m (6.5 ft) 5 DB9, straight RS-232 cable 16.2 mm 31.5 mm 34 www.bannerengineering.com - Tel: + 1 888 373 6767 4 9 3 8 2 7 1 6 A-GAGE® High-Resolution MINI-ARRAY® 8 Additional Information 8.1 Host Mode Command String As discussed in this manual, the control module has three control mode options: continuous, gate, and host. Host mode requires a serial transmission string from a separate device, typically a PC or process controller. The serial transmission medium can be either RS-485 or RS-232. When Host control mode is selected, the host process controller initiates scans using a command string. The command string is a three-byte message, consisting of: • Control byte with decimal value 248 • Controller ID (the identification of a specific control module on the string, indicated by one of 15 ASCII letters A through O, and specified in the PSF) • Scan initiation byte (ASCII letter S) The command string is further defined as follows: /*the below C code will define an array called msg that will contain the Host Scan Command */ unsigned char msg[3]; /*declare three byte unsigned character array using C language */ msg[0]=248; /*control byte */ msg[1]=65; /*assume the controller ID is the letter A */ msg[2]=83; /*assume initiation byte which is the ASCII letter S */ The host transmits this three-byte message at the defined baud rate. The format is one start bit, one stop bit, even parity, and eight data bits. When the control module receives this message, it initiates a scan (assuming Host mode is selected) and then updates its outputs as required. The control module then waits for the next Host Command message before initiating another scan. 8.2 Serial Data Format and Header String The programmed measurement mode or modes determine the type of information that is serially transmitted. For example if Meas1 is set for FBB and Meas2 is set for LBB, then the data transmitted to the host contains the values of the first and last beam blocked. The All measurement mode provides the status of all beams to the host. In addition to measurement mode information, the data transmission also contains a two-byte start string and a termination byte. The start string consists of a first byte that does not change, followed by the controller ID. The first byte value is a hex 1C or 28 decimal. At the end of the string, the control module will place a termination byte. The termination bye is the ASCII character for a linefeed (hex value 0A). These three bytes collectively are called the Serial Header string. 8.2.1 ASCII Format Data Transmission There are two ways to use ASCII format to represent data. The one used depends upon which measurement modes are selected. www.bannerengineering.com - Tel: + 1 888 373 6767 35 A-GAGE® High-Resolution MINI-ARRAY® For ALL measurement mode, each data byte is presented in an eight-bit ASCII format that conveys the status of four consecutive channels (four consecutive beams). Each subsequent byte conveys the status of the next four channels, until the status of every channel is reported. The allowable data values for All measurement mode are ASCII numbers 0 to 9 and ASCII letters A to F. In the table, a 0 represents an unblocked beam channel, and 1 represents a blocked channel. Table 4: Definitions for ASCII Data Values For the ALL Measurement Mode Character Ch 4 Ch 3 Ch 2 Ch 1 F 1 1 1 1 E 1 1 1 0 D 1 1 0 1 C 1 1 0 0 B 1 0 1 1 A 1 0 1 0 9 1 0 0 1 8 1 0 0 0 7 0 1 1 1 6 0 1 1 0 5 0 1 0 1 4 0 1 0 0 3 0 0 1 1 2 0 0 1 0 1 0 0 0 1 0 0 0 0 0 For example, assume that a 64-channel system has been configured for the All measurement Serial transmission option. Channels 1 through 4 are blocked, as is channel 63. The serial string starts with 0x1c, and the ID (assume an ‘A’) followed by 16 ASCII values and terminated with 0x0A. The string would appear: 0x1c, ‘A’, ‘F’, ‘0’,’0’, ‘0’,’0’, ‘0’,’0’, ‘0’,’0’, ‘0’,’0’, ‘0’,’0’, ‘0’,’0’, ‘0’,’4’, 0x0a The string shows that beams 1 through 4 are blocked, as is beam 63. All other beams are unblocked. If the user had requested suppression of the header, then 0x1c, ‘A’, and the 0x0a would have been deleted. For transmitting Measurement mode data, use three ASCII bytes to represent each measurement mode. For example, if Meas1 is FBB, Meas2 is LBB, the measured values are 6 and 120, and the controller ID is B, the data string is as follows: 0x1c ‘B’, ‘0’, ‘0’, ‘6’, ‘1’, ‘2’, ‘0’, 0x0a As with ALL mode, the header and clear data could be suppressed. For clear data suppression, the control module sends the status of a clear condition only on the first clear scan. After that, the control module will continue to scan but will not transmit data until the sensor is again blocked. 8.2.2 Binary Format Data Transmission Similar to ASCII format, binary format may be used to represent data in two ways. One method involves the All Data transmission mode; the other, Measurement mode. For All Data transmission mode, the control module represents the status of eight consecutive data channels for each byte. Each bit of each byte is directly related to the status of an individual channel. The first data byte represents channels 1 through 8; the second data byte represents channels 9 through 16. The bit pattern for the first and second data bytes is as shown in the table. Second Data Byte First Data Byte 36 Channel Bit Position Channel Bit Position 1 7 9 7 2 6 10 6 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® First Data Byte Second Data Byte Channel Bit Position Channel Bit Position 3 5 11 5 4 4 12 4 5 3 13 3 6 2 14 2 7 1 15 1 8 0 16 0 For each bit position, 1 represents a blocked beam and 0 represents an unblocked beam. For example, for a 64-channel system with beams 1-6 blocked, beam 43 blocked and beams 62-64 blocked, the data transmitted from control module ‘A’ is as follows: 0x1c, ‘A’, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x07, 0x0A This string would have the start byte, controller ID, followed by the eight data bytes and terminated with the 0x0A. The header bytes may be suppressed if necessary. For Measurement mode analysis, the binary format uses two data bytes for each measurement mode. (If we have one measurement mode, then there are two data bytes. For two measurement modes, there are four data bytes.) For example, assume that control module B is configured for one measurement mode (FBB), and the value is 78. The string from the control module is as follows: 0x1c, ‘B’, 0x00, 0x4E, 0x0A. (a total of five bytes) or 0x00, 0x4E (a total of two bytes with Suppress Header option) Now assume that control module B is configured for FBB and LBB with values of 74 and 303, respectively. The string from the control module is as follows: 0x1c,’B’, 0x00, 0x4A, 0x01, 0x2F, 0x0A (a total of seven bytes) or 0x00, 0x4A, 0x01, 0x2F (a total of four bytes with Suppress Header option) 8.3 Max Meas Mode Command String Max Meas Mode causes the control module to retain the maximum measurement values for a given object. These values are transmitted either immediately after the control module is cleared or when prompted by the Host. The Max Meas Mode Command String is a four-byte string that appears as follows: • Control byte with decimal value 248 • Controller ID (one of 15 ASCII letters A through O, as specified in the PSF) • Max Meas Command Transmit (ASCII letter T) • Termination byte with decimal value 13 www.bannerengineering.com - Tel: + 1 888 373 6767 37 A-GAGE® High-Resolution MINI-ARRAY® The command string is further defined: /*the below C code will define an array called msg which will contain the Max Meas Mode Command String*/ unsigned char msg[4]; /*declare four byte unsigned character array using C language */ msg[0]=248; /*control byte */ msg[1]=65; /*assume the controller ID is the letter A */ msg[2]=84; /*assume initiation byte which is the ASCII letter T */ msg[3]=13; /*termination byte */ When the host sends this string, the control module sends the maximum values stored from the previous scanned object. If the sensor is presently scanning an object when the message is sent, the control module gives the maximum values for the present object. 8.4 Glossary Blanked Beam A beam that is ignored by the receiver, as a result of a blanking program being applied to it. Beams (or groups of beams) are blanked when a component or fixture will remain in or move through the light screen array; blanking the affected beams prevents the component or fixture from causing false outputs. Blocked Beam A beam that is obstructed between the emitter and the receiver, and is not blanked. Clear Beam A beam that runs unobstructed from the emitter to the receiver (same as a made or unblocked beam). Excess Gain A measurement of the amount of light falling on the receiver from the emitter over and above the minimum amount required for operation. A-GAGE High-Resolution MINI-ARRAY emitters and receivers automatically perform an Alignment procedure to equalize the amount of excess gain at each element along the array. Host A computer or process controller that controls and receives input from the High-Resolution MINIARRAY System, and/or other equipment and systems within a factory. Made Beam A beam that runs unobstructed from the emitter to the receiver (same as an unblocked or clear beam). Unblocked Beam A beam that runs unobstructed from the emitter to the receiver (same as a made or clear beam). 38 www.bannerengineering.com - Tel: + 1 888 373 6767 A-GAGE® High-Resolution MINI-ARRAY® 9 Product Support and Maintenance 9.1 Contact Us Banner Engineering Corp. headquarters is located at: 9714 Tenth Avenue North Minneapolis, MN 55441, USA Phone: + 1 888 373 6767 For worldwide locations and local representatives, visit www.bannerengineering.com. 9.2 Banner Engineering Corp Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. www.bannerengineering.com - Tel: + 1 888 373 6767 39
MAHCVN-1 价格&库存
很抱歉,暂时无法提供与“MAHCVN-1”相匹配的价格&库存,您可以联系我们找货
