VS8EAPLLP
VS8EAPLLP
    BANNER(邦纳)
    VS8 SERIES: LASER POLARIZED RETR
VS8EAPLLP 数据手册
VS8 Series Retroreflective Sensor Datasheet Sub-Miniature Retroreflective Photoelectric Sensor This guide is designed to help you set up and install the VS8. For complete information on programming, performance, troubleshooting, dimensions, and accessories, please refer to the Instruction Manual at www.bannerengineering.com. Search for p/n 201958 to view the Instruction Manual. Use of this document assumes familiarity with pertinent industry standards and practices. • • • • • • • Sub-miniature sensor for installation in the smallest of spaces Red laser models provide bright, precise laser light spot for optimum small part detection Red LED models provide a more cost effective option and excellent part detection capability Suitable for use with numerous different reflectors User-friendly operation using electronic push button or remote input provides reliable and precise detection Robust, glass-fiber-reinforced plastic housing PNP or NPN output, depending on model WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. AVERTISSEMENT: Ne pas utiliser pour la protection de personnes Ces produits ne doivent pas être utilisés comme systèmes de détection pour la protection de personnes. Une utilisation dans de telles conditions pourrait entraîner des dommages corporels graves, voire mortels. Ce produit n'est pas équipé du circuit redondant d'autodiagnostic nécessaire pour être utilisé dans des applications de protection personnelle. Une panne du capteur ou un mauvais fonctionnement peut entraîner l'activation ou la désactivation de la sortie. Models Model Sensing Mode Range Output VS8EAPLP Connection PNP VS8EANLP Red LED Retro Reflective VS8EAPLPQ 0.1 m to 1.6 m (3.9 in to 62.9 in) with BRT-2X2 PNP VS8EANLPQ NPN VS8EAPLLP PNP VS8EANLLP Red Laser Retro Reflective VS8EAPLLPQ 2 m (6.5 ft) unterminated 4-wire PUR cable NPN 0.1 m to 2 m (3.9 in to 78.7 in) with BRT-51X51BM 200 mm (7.8 in) PUR cable with a 4-pin M8/Picostyle male quick disconnect (QD) 2 m (6.5 ft) unterminated 4-wire PUR cable NPN PNP VS8EANLLPQ 200 mm (7.8 in) PUR cable with a 4-pin M8/Picostyle male quick disconnect (QD) NPN Wiring Diagrams NPN Models 1 3 4 2 Original Document 201942 Rev. B 068-14794 PNP Models + 10-30V dc – Load Remote Input 1 3 4 2 Key + 10-30V dc – 1. 2. 3. 4. Brown White Blue Black Load Remote Input 15 November 2017 201942 VS8 Series Retroreflective Sensor Specifications Supply Voltage and Current LED models: 10 V dc to 30 V dc (10% max. ripple) at less than 20 mA, exclusive of load Laser models: 10 V dc to 30 V dc (10% max. ripple) at less than 12 mA, exclusive of load Connections 2 m (6.5 ft) unterminated 4-wire PUR cable or 200 mm (7.8 in) PUR cable with a 4-pin M8/Pico-style or 4-pin M12/Euro-style male quick disconnect, depending on model Models ending in suffix "Q", "Q3", or "Q5" must be used with a UL recognized cordset R/C (CYJV2) Search p/n 201958 at www.bannerengineering.com to view the Instruction Manual for more information on cordsets Operating Conditions LED models: –20 °C to +60 °C (–4 °F to +140 °F) Laser models: –20 °C to +50 °C (–4 °F to +122 °F) Storage Temperature: –20 °C to +80 °C (–4 °F to +176 °F) UL Operating Temperature: –20 °C to +30 °C (–4 °F to +86 °F) Laser Classifications All Models: Class 1; wavelength: 655 nm; frequency: 5 kHz; pulse duration: 3.2 µs; limit value pulse: ≤ 2.3 mW. Reference IEC 60825-1:2001, Section 8.2. All Models: Complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to laser Notice No. 50 dated June 24, 2007. Dimensions 8 LED 2 Required Overcurrent Protection LED 1 Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. ø3 .3 4.6 8 Emitter 5.5 18.3 3.3 21.1 Receiver ø2.6 ø4.9 Sensor with Bracket (SMBVS8DT) 8.2 AVERTISSEMENT: Les raccordements électriques doivent être effectués par du personnel qualifié conformément aux réglementations et codes électriques nationaux et locaux. Une protection de surintensité doit être fournie par l'installation du produit final, conformément au tableau fourni. Vous pouvez utiliser un fusible externe ou la limitation de courant pour offrir une protection contre la surtension dans le cas d'une source d'alimentation de classe 2. Les fils d'alimentation < 24 AWG ne peuvent pas être raccordés. Pour obtenir un support produit supplémentaire, rendez-vous sur le site www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) Câblage d'alimentation (AWG) Protection contre la surtension requise (ampères) 20 5.0 20 5.0 22 3.0 22 3.0 24 2.0 24 2.0 26 1.0 26 1.0 28 0.8 28 0.8 30 0.5 30 0.5 ø3 .3 20.6 15 9.6 6.8 Indicators 2 LED indicators on sensor top Green on: Power on Amber on: Output conducting Emitter LED Wavelength Red LED models: 650 nm Laser models: 655 nm Switching Frequency ≤ 1000 Hz Chemical Compatibility ECOLAB® certified (2 m cabled models only) Environmental Rating IEC IP67 Certifications Protection contre la surintensité requise WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. 14.6 2.8 Teach-in Supply Protection Circuitry Protected against reverse polarity and short-circuit Output Configuration Single PNP or NPN on pin 4 (black wire) with remote input on pin 2 (white wire) Delay Before Power-Up < 300 ms Output Protection Circuitry Protected against output short-circuit, continuous overload, and false pulse on power-up Output Rating 50 mA Output Response Time 500 µs Construction Housing, cable: PUR Front screen: PMMA Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
VS8EAPLLP 价格&库存
很抱歉,暂时无法提供与“VS8EAPLLP”相匹配的价格&库存,您可以联系我们找货
