QS18UPAQ5
QS18UPAQ5
    BANNER(邦纳)
    ULTRA SEN 50-500MM PNP
QS18UPAQ5 数据手册
WORLD-BEAM QS18U Ultrasonic Sensors Datasheet Miniature ultrasonic sensors with TEACH-mode programming • • • • • • • • • • Fast, easy-to-use TEACH-Mode programming; no potentiometer adjustments Ultra-compact housing One discrete output: NPN or PNP, depending on model Two bi-colored status LEDs Rugged encapsulated version for harsh environments Choose 2 meter or 9 meter unterminated cable, 4-pin M12 or 4-pin M8 QD connectors (either integral or with 150 mm pigtail) Wide operating range of –20 °C to +60 °C (–4 °F to +140 °F) Temperature compensation Configurable for normally open or normally closed operation Fast response time (15 milliseconds) WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or de-energized (off) output condition. Models Models Sensing Range QS18UNA QS18UPA QS18UNAE TEACH Option Cable Integral push button or remote TEACH (IP67, NEMA 6P) 50 mm to 500 mm (2 in to 20 in) Remote TEACH (epoxy-encapsulated, IP68, NEMA 6P) QS18UPAE Supply Voltage Output NPN 4-wire, 2 m (6.5 ft) cable with shield PNP 12 V DC to 30 V DC NPN PNP Only standard 2 m (6.5 ft) cable models are listed. For 9 m (30 ft) shielded cable, add suffix “W/30” to the model number (e.g., QS18UNA W/30). A model with a QD connector requires a mating cordset. For QD models: • To order the 4-pin integral M12 QD model, add the suffix Q8 (for example, QS18UNAQ8). • To order the 150 mm (6 in) cable with a 4-pin M12 QD model, add the suffix Q5 (for example, QS18UNAQ5). • To order the 4-pin integral M8 QD model, add the suffix Q7 (for example, QS18UNAQ7). • To order the 150 mm (6 in) cable with a 4-pin M8 QD model, add the suffix Q (for example, QS18UNAQ). Principles of Operation Ultrasonic sensors emit one or multiple pulses of ultrasonic energy, which travel through the air at the speed of sound. A portion of this energy reflects off the target and travels back to the sensor. The sensor measures the total time required for the energy to reach the target and return to the sensor. The distance to the object is then calculated using the following formula: D = ct ÷ 2 D = distance from the sensor to the target c = speed of sound in air t = transit time for the ultrasonic pulse To improve accuracy, an ultrasonic sensor may average the results of several pulses before outputting a new value. Temperature Effects The speed of sound is dependent upon the composition, pressure and temperature of the gas in which it is traveling. For most ultrasonic applications, the composition and pressure of the gas are relatively fixed, while the temperature may fluctuate. In air, the speed of sound varies with temperature according to the following approximation: In metric units: Cm/s = 20 √273 + TC Cm/s = speed of sound in meters per second TC = temperature in °C In English units: Cft/s = 49 √460 + TF Cft/s = speed of sound in feet per second TF = temperature in °F Temperature Compensation Changes in air temperature affect the speed of sound, which in turn affects the distance reading measured by the sensor. An increase in air temperature shifts both sensing window limits closer to the sensor. Conversely, a decrease in air temperature shifts both limits farther away from the sensor. This shift is approximately 3.5% of the limit distance for a 20° C change in temperature. Original Document 119287 Rev. K 28 July 2021 119287 WORLD-BEAM QS18U Ultrasonic Sensors The QS18U series ultrasonic sensors are temperature compensated This reduces the error due to temperature by about 90%. The sensor will maintain its window limits to within 1.8% over the -20° to +60° C (−4° to +140° F) range. Note: • • • Exposure to direct sunlight can affect the sensor’s ability to accurately compensate for changes in temperature. If the sensor is measuring across a temperature gradient, the compensation will be less effective. The temperature warmup drift upon power-up is less than 7% of the sensing distance. After 5 minutes, the apparent switchpoint will be within 0.6% of the actual position. After 25 minutes, the sensing position will be stable. Sensor Programming Two TEACH methods may be used to program the sensor: • Teach individual minimum and maximum limits, or • Use Auto-Window feature to center a sensing window around the taught position The sensor may be programmed either via its push button, or via a remote switch. Remote programming also may be used to disable the push button, preventing unauthorized personnel from adjusting the programming settings. To access this feature, connect the white wire of the sensor to 0V dc, with a remote programming switch between the sensor and the voltage. Figure 1. Sensor Features Green/Red Power/Signal Strength LED Yellow/Red TEACH/Output Indicator LED Push Button (IP67 models only) Programming is accomplished by following the sequence of input pulses (see programming procedures). The duration of each pulse (corresponding to a push button “click”), and the period between multiple pulses, are defined as “T: 0.04 seconds < T < 0.8 seconds." Figure 2. TEACH Interface Maximum Operating Range Target Far Setpoint Target Target Near Setpoint Target Dead Zone Minimum Operating Range Power Output Power Output Power Output ON: Green ON: Green ON: Yellow ON: Green OFF OFF Power Output ON: Red OFF Status Indicators Power ON/OFF LED Indicates Output/Teach LED Indicates OFF Power is OFF OFF Target is outside window limits (normally open operation). ON Red Target is weak or outside sensing range. Yellow Target is within window limits (normally open operaton). ON Green Sensor is operating normally, good target. ON Red (solid) In Teach Mode, waiting for first limit. ON Red (flashing) In Teach Mode, waiting for second limit. Teaching Minimum and Maximum Limits General Notes on Programming • The sensor returns to Run mode if the first TEACH condition is not registered within 120 seconds. • After the first limit is taught, the sensor remains in Program mode until the TEACH sequence is finished. • To exit Program mode without saving any changes, press and hold the programming push button for more than 2 seconds (before teaching the second limit). The sensor reverts to the last saved limits. 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 119287 Rev. K WORLD-BEAM QS18U Ultrasonic Sensors Figure 3. Teaching independent minimum and maximum limits Normally Open Operation Minimum Limit Output OFF Maximum Limit Output ON Output OFF Normally Closed Operation Minimum Limit Output ON Maximum Limit Output OFF Output ON Procedure Result Push Button (0.04 sec ≤ Click ≤ 0.8 sec) Remote Line (0.04 sec < T < 0.8 sec) Programming Mode Press and hold push button Teach First Limit No action required; sensor is ready for 1st limit teach Output LED: ON Red Power LED: ON Green (good signal) or ON Red (no signal) Position the target for the first limit Position the target for the first limit Power LED: Must be ON Green Click the push button Single-pulse the remote line Teach Accepted Output LED: Flashing Red T Teach Unacceptable Output LED: ON Red Teach Second Limit Position the target for the second limit Click the push button Position the target for the second limit Power LED: Must be ON Green Single-pulse the remote line Teach Accepted Output LED: Yellow or OFF T Teach Unacceptable Output LED: Flashing Red Teaching Limits Using the Auto-Window Feature Teaching the same limit twice automatically centers a 20 mm window on the taught position. General Notes on Programming • The sensor returns to Run mode if the first TEACH condition is not registered within 120 seconds. • After the first limit is taught, the sensor remains in Program mode until the TEACH sequence is finished. • To exit Program mode without saving any changes, press and hold the programming push button for more than 2 seconds (before teaching the second limit). The sensor reverts to the last saved program. Figure 4. Using the Auto-Window feature for programming each output Normally Open Operation Taught Position Position - 10 mm Output OFF Position + 10 mm Output ON Output OFF Normally Closed Operation Taught Position Position - 10 mm Output ON P/N 119287 Rev. K Position + 10 mm Output OFF Output ON www.bannerengineering.com - Tel: + 1 888 373 6767 3 WORLD-BEAM QS18U Ultrasonic Sensors Procedure Result Push Button (0.04 sec ≤ Click ≤ 0.8 sec) Programming Mode Teach First Limit Remote Line (0.04 sec < T < 0.8 sec) Press and hold push button No action required; sensor is ready for 1st limit Output LED: ON Red teach Power LED: ON Green (good signal) or ON Red (no signal) Position the target for the first limit Position the target for the center of the window Power LED: Must be ON Green Click the push button Single-pulse the remote line Teach Accepted Output LED: Flashing Red T Teach Unacceptable Output LED: ON Red Re-Teach Limit Without moving the target, click the push button again Without moving the target, single-pulse the remote line again Teach Accepted Output LED: Yellow or OFF Teach Unacceptable Output LED: Flashing Red T Figure 5. An application for the Auto-Window feature (retroreflective mode) Taught Position (background surface) Near Range Position -10 mm Sensor Output ON Position +10 mm Any object in this area will switch the output, whether or not the object returns a good signal to the sensor. Sensor Output OFF Output OFF Output ON Sensing Distance Normally Open/Normally Closed Operation Select Configure the sensor for either normally open or normally closed operation using the remote teach wire (white). A series of three pulses on the line toggles between normally open (NO) and normally closed (NC) operation. Normally open is defined as the output energizing when the target is present. Normally closed is defined as the output energizing when the target is absent. (See Teaching Minimum and Maximum Limits on p. 2 and Teaching Limits Using the Auto-Window Feature on p. 3.) Result Procedure Push Button (0.04 sec ≤ Click ≤ 0.8 sec) Toggle between Not available via push button NO/NC Operation Remote Line (0.04 sec < T < 0.8 sec) Triple-pulse the remote line T T T Selects either Normally Open or Normally Closed operation depending on the previous condition. T T Push Button Lockout Enables or disables the push button to prevent unauthorized personnel from adjusting the program settings. Procedure Push Button ( 0.04 sec ≤ Click ≤ 0.8 sec) Push Button Lockout Not available via push button Result Remote Line ( 0.04 sec < T < 0.8 sec) Four-pulse the remote line T T T 4 T T T Push buttons are either enabled or disabled, depending on condition. T www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 119287 Rev. K WORLD-BEAM QS18U Ultrasonic Sensors Wiring Diagrams Banner recommends connecting the shield wire to earth ground. Shielded cordsets are recommended for all QD models. Cabled wiring diagrams are shown. Quick disconnect wiring diagrams are functionally identical. Figure 6. NPN (Sinking) Output Models Figure 7. PNP (Sourcing) Output Models bn bn 12 - 30V dc bu bk wh shield 12 - 30V dc bu bk Load wh shield Remote programming switch (normally open) Load Remote programming switch (normally open) Specifications Sensing Range 50 to 500 mm (2 to 20 inches) Supply Voltage 12 V DC to 30 V DC (10% maximum ripple); 25 mA max (exclusive of load) Ultrasonic Frequency 300 kHz, rep. rate 7.5 ms Supply Protection Circuitry Protected against reverse polarity and transient voltages Repeatability 0.7 mm Minimum Window Size 5 mm Hysteresis 1.4 mm Adjustments Sensing Window Limits: TEH-mode programming of near and far window limits may be set using the push button or remotely via TEH input Output Configuration SPST solid-state switch conducts when target is sensed within sensing window; one NPN (current sinking) or one PNP (current sourcing), depending on model. Output Protection Protected against short-circuit conditions Output Rating Rating: 100 mA maximum load; see Application Note 1 Off-state leakage current: less than 10 µA (sourcing); less than 200 µA (sinking); see Application Note 2 ON-state saturation voltage: NPN: less than 1.6 V at 100 mA; PNP: less than 3.0 V at 100 mA Output Response 15 milliseconds Delay at Power Up 300 milliseconds Indicators Range Indicator (Red/Green) and Teh/Output Indicator (Amber/Red) Range Indicator: Green - Target is within sensing range; Red - Target is outside sensing range; OFF - Sensing Power is OFF Teh/Output Indicator: Amber - Target is within taught limits; OFF - Target is outside taught window limits; Red - Sensor is in TEH mode Construction ABS housing, TPE Push Button, ABS Push Button housing, Polycarbonate lightpipes Connections 2 m (6.5 ft) or 9 m (30 ft) 4-conductor PVC jketed atthed cable, or 4-pin Euro-style integral QD (Q8), or 4-pin Pico-style integral QD (Q7), or 4-pin Euro-style 150 mm (6 in) pigtail QD (Q5), or 4-pin Pico-style 150 mm (6 in) pigtail QD (Q) Temperature Warmup Drift See Temperature Compensation on p. 1 Temperature Effect Non-encapsulated models: ± 0.05% per °C from –20 to 50 °C, ± 0.1% per °C from 50 to 60 °C Encapsulated models: ± 0.05% per °C from 0 to 60 °C, ± 0.1% per °C from –20 to 0 °C Application Notes If supply voltage is > 24 V DC, derate maximum output current 5 mA/°C above 50 °C. NPN off-state leakage current is < 200 µA for load resistances > 3 kΩ or optically isolated loads. For load current of 100 mA, leakage is < 1% of load current. Objects passing inside the specified near limit may produce a false response. Environmental Rating Leakproof design, rated NEMA 6P; IEC IP67 or IP68 depending on model; UL Type 1 Operating Conditions −20 °C to 60 °C (−4 °F to 140 °F) 100% relative humidity (non-condensing) Vibration and Mechanical Shock All models meet MIL-STD-202F, Method 201A (Vibration: 10 Hz to 60 Hz maximum, 0.06 inch (1.52 mm) double amplitude, 10G maximum acceleration) requirements. Also meets IEC 60947-5-2 (Shock: 30G 11 ms duration, half sine wave) requirements. Certifications Required Overcurrent Protection P/N 119287 Rev. K WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 www.bannerengineering.com - Tel: + 1 888 373 6767 5 WORLD-BEAM QS18U Ultrasonic Sensors Figure 9. QS18U Maximum Target Rotation Angle Figure 8. QS18U Effective Beam Pattern (Typical) 15° 50 Lateral Distance (mm) 40 10° Target Rotation 30 20 10 0 -10 -20 5° 0 -5° -10° -30 -15° -40 0 -50 0 100 200 300 400 Sensing Distance (mm) 100 200 500 300 400 500 Sensing Distance (mm) 2.5 mm rod 8 mm rod 50 mm x 50 mm plate Dimensions All measurements are listed in millimeters, unless noted otherwise. Figure 10. Cabled models Figure 11. M8 QD models Figure 12. M12 QD models 41.5 mm (1.63") 49 mm (1.93") 33.5 mm (1.32") 15.0 mm (0.59") 17.1 mm (0.67") 3 mm (0.12") 24.1 mm (0.95") 35.0 mm (1.38") M18 x 1 Thread Max. Torque 2.3 Nm (20 in-lbs) ø 3.3 mm (0.13") Max. Torque 0.6 Nm (5 in-lbs) Figure 13. Locknut (included with all models) Figure 14. Washer (included with all models) Ø 23.9 mm (0.94") 24.2 mm (0.95") 150 mm (6") Euro-Style Pigtail Integral 4-pin Pico-Style QD 150 mm (6") Pico-Style Pigtail Integral 4-pin Euro-Style QD M3 Hardware Packet Contents • 2 – M3 x 0.5 x 20 mm SS Screw • 2 – M3 x 0.5 SS Hex Nut 1.6 mm • 2 – M3 SS Washer (0.06") Ø 17.8 mm (0.70") 8.0 mm (0.32") Accessories Quick-Disconnect (QD) Cordsets 4-Pin Snap-On M8 Cordsets with Shield—Single Ended Model Length Style Dimensions ø10 mm max. (0.4") PKG4S-2 2 m (6.56 ft) Straight 28 mm max. (1.1") 6 www.bannerengineering.com - Tel: + 1 888 373 6767 Pinout (Female) 4 3 2 1 1 = Brown 2 = White 3 = Blue 4 = Black P/N 119287 Rev. K WORLD-BEAM QS18U Ultrasonic Sensors 4-Pin Snap-On M8 Cordsets with Shield—Single Ended Model Length Style Dimensions Pinout (Female) 25 mm max. (1.0") 4 1 3 PKW4ZS-2 2 m (6.56 ft) 2 20 mm (0.8") Right Angle ø12 mm max. (0.5") 4-Pin Threaded M12 Cordsets with Shield—Single Ended Model Length MQDEC2-406 2 m (6.56 ft) MQDEC2-415 5 m (16.4 ft) Style Dimensions Pinout (Female) 44 Typ. 1 Straight MQDEC2-430 9 m (29.5 ft) MQDEC2-406RA 2 m (6.56 ft) MQDEC2-415RA 5 m (16.4 ft) M12 x 1 ø 14.5 2 30 Typ. [1.18"] Right-Angle MQDEC2-430RA 3 4 32 Typ. [1.26"] 2 1 1 = Brown 2 = White 3 = Blue 4 = Black 3 4 9 m (29.5 ft) M12 x 1 ø 14.5 [0.57"] Mounting Brackets All measurements are listed in millimeters, unless noted otherwise. SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware SMBQS18RA • Right-angle mounting bracket • 14-ga. 304 stainless steel 30 C A 41 A 42 B B 17 46 32 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 Hole center spacing: A to B=20.3 Hole size: A =4.3 × 9.3, B=ø 4.3 SMB18SF • 18 mm swivel bracket with M18 × 1 internal thread • Black thermoplastic polyester • Stainless steel swivel locking hardware included 51 B 42 SMB18UR • 2-piece universal swivel bracket • 300 series stainless steel • Stainless steel swivel locking hardware included • Mounting hole for 18 mm sensor C A 137 B 25 A 64 Hole center spacing: A = 36.0 Hole size: A = ø 5.3, B = ø 18.0 42 Hole center spacing: A = 25.4, B = 46.7 Hole size: B = 6.9 × 32.0, C = ø 18.3 P/N 119287 Rev. K www.bannerengineering.com - Tel: + 1 888 373 6767 7 WORLD-BEAM QS18U Ultrasonic Sensors Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
QS18UPAQ5 价格&库存
很抱歉,暂时无法提供与“QS18UPAQ5”相匹配的价格&库存,您可以联系我们找货
QS18UPAQ5
  • 1+1733.975161+224.25014
库存:9
