SLO Series Slot Sensor
Datasheet
Self-Contained Opposed-Mode Sensor Pair
An easy-to-use self-contained opposed-mode sensor pair in a rugged U-shaped housing
Easy and economical to mount
Molded-in beam guides simplify mounting and beam placement
30 mm slot width for a wide variety of sensing applications
Applications include hole detection, gear tooth detection, edge guiding and counting of
opaque materials
10 V dc to 30 V dc operation
Bipolar PNP/NPN outputs
Choose 1 millisecond or 300 microsecond response
2 mm effective beam
Dark or light operate
Choose integral, unterminated cable or QD models
WARNING: Not To Be Used for Personnel Protection
Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or
death. This device does not include the self-checking redundant circuitry necessary to allow its use in
personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized
sensor output condition.
Models
Models
Sensing Beam
Slot Width
SLO30VB6
SLO30VB6Q
SLO30VB6Y
SLO30VB6YQ
Cable1
Output
2 m (6.5ft) 5-wire cable
Infrared, 890 nm
30 mm (1.2 in)
5-Pin Euro-style QD
5-Pin Euro-style QD
Response
Repeatability
1 ms
250 µs
300 µs
75 µs
Bipolar
NPN/PNP
Overview
The SLO Series Slot Sensor (sometimes called a “Fork Sensor”)
comprises an opposed-mode emitter and its receiver inside a
single convenient housing.
Opposed-mode sensing is very reliable, and the single selfcontained housing provides easy installation, with no sensor
alignment required. In addition, the molded-in arrow on the
emitter portion of the housing and the slotted design on the
receiver portion of the housing show at a glance the position of
the beam, simplifying installation placement.
Emitter
Signal LED
Power ON LED
Receiver (Beam Aligns at Groove)
Figure 1. Features
1
To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, SLO30VB6 W/30. Models with a quick
disconnect require a mating cordset.
Original Document
60073 Rev. B
23 February 2018
60073
Gear Tooth Detection
Edge Detection
Code Reading (Holes in Opaque Materials)
Figure 2. Typical Applications
LED Indicators
The Slot Sensor features two LED Indicators: Power (green) and Signal (amber). They indicate the following:
Green ON: Power ON
Amber ON: Sensor sees light
Amber flashing: Excess gain is marginal (1 to 1.5×) in light condition
Select Light Operate/Dark Operate
Connect the gray wire to +V (10 V dc to 30 V dc) for Dark Operate; and to dc common (or open) for Light Operate. See wiring
diagrams.
Wiring Diagrams
Wiring Key
1
10-30V dc
3
2
4
5*
L
L
1.
2.
3.
4.
5.
Brown
White
Blue
Black
Gray*
*For Dark operate, connect gray wire to + (brown). For Light operate, connect gray wire
to - (blue).
Note: Quick disconnect (QD) wiring diagrams are functionally identical.
2
www.bannerengineering.com - Tel: +1-763-544-3164
P/N 60073 Rev. B
Specifications
Supply Voltage and Current
10 to 30V dc, 30 mA
Required Overcurrent Protection
WARNING: Electrical connections must be
made by qualified personnel in accordance with
local and national electrical codes and
regulations.
Supply Protection Circuitry
Protected against reverse polarity and transient voltages
Output Configuration
Bipolar: PNP and NPN
Output Rating
150 mA each output
Output Protection Circuitry
Protected against output short-circuit and false pulse on power up
Output Response Time
1 millisecond or 300 microseconds, depending on model
Overcurrent protection is required to be provided by end product
application per the supplied table.
Overcurrent protection may be provided with external fusing or via Current
Limiting, Class 2 Power Supply.
Supply wiring leads < 24 AWG shall not be spliced.
For additional product support, go to www.bannerengineering.com.
Supply Wiring (AWG)
Required Overcurrent Protection (Amps)
22
3.0
24
2.0
26
1.0
28
0.8
30
0.5
Repeatability
250 microseconds or 75 microseconds, depending on model
Operating Conditions
Operating Temperature: −40 °C to +70 °C (−40 °F to +158 °F)
90% at +50 °C maximum relative humidity (non-condensing)
Slot Opening
30 mm (1.18 in) wide × 45 mm (1.8 in) deep; beam is 10 mm (0.4 in) from
outer edge
Adjustments
None
Indicators
Green: Power on/off indicator
Amber: Signal condition indicator
Certifications
Construction
Housing: ABS and polycarbonate
Lenses: acrylic
E224071
Connections
2 m (6.5 ft) or 9 m (30 ft) 5-conductor PVC-jacketed attached cable or 5-pin
Euro-style quick-disconnect
Environmental Rating
IEC IP67; NEMA 6
Dimensions
30.2 mm
(1.19")
10.9 mm
(0.43")
10.0 mm
(0.39)
45.0 mm
(1.77")
72.0 mm
(2.84")
Power LED
(Green)
Signal LED
(Amber)
6.0 mm
(0.24")
6.0 mm
(0.24")
40.0 mm
(1.58")
52.0 mm
(2.05")
20.2 mm (0.80")
2x ø5.6 mm
(0.22")
M12 x 1
18.8 mm
(0.74")
All measurements are listed in millimeters [inches], unless noted otherwise.
P/N 60073 Rev. B
3
Accessories
Cordsets
5-Pin Threaded M12/Euro-Style Cordsets—Single Ended
Model
Length
MQDC1-501.5
Style
0.50 m (1.5 ft)
MQDC1-506
1.83 m (6 ft)
MQDC1-515
4.57 m (15 ft)
MQDC1-530
9.14 m (30 ft)
MQDC1-506RA
1.83 m (6 ft)
MQDC1-515RA
4.57 m (15 ft)
Dimensions
44 Typ.
Straight
M12 x 1
ø 14.5
2
1
3
4
32 Typ.
[1.26"]
30 Typ.
[1.18"]
Right-Angle
MQDC1-530RA
Pinout (Female)
9.14 m (30 ft)
5
1 = Brown
2 = White
3 = Blue
4 = Black
5 = Gray
M12 x 1
ø 14.5 [0.57"]
Brackets
SMBSL
Angled bracket
304 stainless steel
Hardware included
52
40
41
6X
Ø5.5
19
Banner Engineering Corp. Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or
replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not
cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO
BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES
RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT,
STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously
manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the
product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will
void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at
any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to:
© Banner Engineering Corp. All rights reserved
很抱歉,暂时无法提供与“SLO30VB6Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1275.564781+165.76290
