M18-3VPDL-Q8
M18-3VPDL-Q8
    BANNER(邦纳)
    SEN PHOTO 750MM PNP
M18-3VPDL-Q8 数据手册
M18-3 Nickel-Plated Brass 18 mm Barrel Sensors Datasheet Next Generation of Self-Contained DC-Operated Sensors • • • • • • • Complete family of sensors, all housed in the popular 18 mm threaded metal barrel Economical photoelectric sensors for cost sensitive and high volume installations Powerful and bright visible red emitter beam for easy alignment and set-up Highly visible output and dual-function power and stability indicators Advanced ASIC technology is resistant to optical and electrical noise source Wide operating temperature range: −40 °C to +70 °C (−40 °F to +158 °F) Robust 250° adjustment potentiometer on select models WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Emitter/Receiver Models 1 Model Number Range M18-3NAEL-2M M18-3NAEJ-2M 25 m (82 ft) Emitter 25 m (82 ft) with beam inhibit M18-3NAES-2M M18-3VNRS-2M M18-3VPRS-2M None 25 m (82 ft) with adjustment M18-3VNRL-2M M18-3VPRL-2M Output 25 m (82 ft) Receiver 25 m (82 ft) with adjustment Complementary NPN Complementary PNP Complementary NPN Complementary PNP Polarized Retroreflective Models 1 Model Number M18-3VNLP-2M M18-3VPLP-2M M18-3VNLPC-2M M18-3VPLPC-2M Range 6 m (19.7 ft) with BRT-84 reflector 6 m (19.7 ft) with BRT-84 reflector, with adjustment Output Complementary NPN Complementary PNP Complementary NPN Complementary PNP Retroreflective Models 1 Model Number M18-3VNLV-2M M18-3VPLV-2M Range 7.5 m (24.6 ft) with BRT-84 reflector, with adjustment Output Complementary NPN Complementary PNP 1 Standard 2 m (6.5 ft) cable models are listed. • To order the 4-pin M12/Euro-style integral quick disconnect model, add the suffix "Q8". For example, M18-3VNDL-Q8. • To order the 150 mm (6 in) cable with a 4-pin M12/Euro-style quick disconnect model, add the suffix "Q5". For example, M18-3VNDLQ5. Original Document 185178 Rev. C 13 July 2016 185178 M18-3 Nickel-Plated Brass 18 mm Barrel Sensors Diffuse Models 1 Model Number Range M18-3VNDL-2M Output Complementary NPN 750 mm (29.5 in) with adjustment M18-3VPDL-2M M18-3VNDS-2M Complementary PNP Complementary NPN 300 mm (11.8 in) with adjustment M18-3VPDS-2M Complementary PNP Fixed-Field Models 1 Model Number Range M18-3VNFF30-2M Output Complementary NPN 30 mm (1.2 in) M18-3VPFF30-2M M18-3VNFF50-2M Complementary PNP Complementary NPN 50 mm (1.9 in) M18-3VPFF50-2M M18-3VNFF75-2M Complementary PNP Complementary NPN 75 mm (2.9 in) M18-3VPFF75-2M M18-3VNFF100-2M Complementary PNP Complementary NPN 100 mm (3.9 in) M18-3VPFF100-2M M18-3VNFF150-2M Complementary PNP Complementary NPN 150 mm (5.9 in) M18-3VPFF150-2M M18-3VNFF200-2M Complementary PNP Complementary NPN 200 mm (7.8 in) M18-3VPFF200-2M Complementary PNP Installing the M18-3 Sensor To install the M18-3 Sensor: 1. Align the sensor as required for the application. For the most sensitive object detection, align the sensor so that the objects move across the sensor's axis. 2. Secure the sensor to a bracket. 3. Wire sensor as shown in the wiring diagrams. 4. Adjust the gain adjuster (sensitivity pot) if necessary. Amber LED Gain adjustment Green LED Amber LED Figure 1. M18-3 Features and Installation Wiring Diagrams Emitter Emitter with Active High Beam Inhibit 3 3 1 2 – 1 10-30V dc 4 + www.bannerengineering.com - Tel: +1-763-544-3164 − 10–30 V dc + 10–30 V dc P/N 185178 Rev. C M18-3 Nickel-Plated Brass 18 mm Barrel Sensors Complementary Current Sinking (NPN) 3 2 1 – 10-30V dc + 1 4 Complementary Current Sourcing (PNP) + 10-30V dc – 3 4 Load 2 Load Load Load NOTE: Open lead wires must be connected to a terminal block. Specifications Supply Voltage 10 V to 30 V dc for ambient temperature ≤ 55 °C 10 V to 24 V dc for ambient temperature > 55 °C Supply Protection Circuitry Protected against reverse polarity and transient voltages Supply Current (Exclusive of Load Current) Diffuse: 16 mA Opposed Mode Emitters: 17 mA Opposed Mode Receivers: 8 mA Retroreflective and Polarized Retroreflective: 16 mA Fixed-Field: 16 mA Output Configuration Complementary PNP or NPN by model number Output Rating ≤ 50 mA total current for ambient temperatures > 55 °C ≤ 100 mA total current through both outputs ≤ 55 °C Output Protection Circuitry OFF-State Leakage Current: < 50 µA at 30 V dc Protected against false pulse on power-up and continuous short ON-State Saturation Voltage: < 1.5 V at 10 mA; < 3.0 V at 100 circuit of outputs. Short circuit protection at elevated mA temperature may require a power cycle to reset. Repeatability Output Response Time Repeatability is independent of signal strength Response is independent of signal strength Opposed mode: 170 microseconds Opposed mode: 1.5 milliseconds ON, 1.0 milliseconds OFF Retro, Polarized Retro, and Diffuse modes: 100 microseconds Retro, Polarized Retro, and Diffuse: 1.5 milliseconds ON, 0.75 Fixed-Field mode: 100 microseconds milliseconds OFF Fixed-Field: 1.5 milliseconds ON, 1.0 milliseconds OFF Emitter LED Delay on Power-up: 100 milliseconds; outputs do not conduct Visible red during this time Adjustments Diffuse (DL, DS), Emitter (ES), Receiver (RS), Polarized Retroreflective (LPC), Retroreflective (LV) models: Single turn sensitivity (gain) adjustment potentiometer Emitter Beam Inhibit (EJ) models: Tie black wire to 10 V to 30 V dc for beam inhibit Indicators Three LEDs (1 green, 2 amber) Green solid: indicates power applied and sensor ready Green flashing: indicates marginal sensing signal Amber solid: indicates Pin 4 (black wire) output conducting P/N 185178 Rev. C Construction Housing: Nickel-plated brass Front window: PMMA Indicator windows: Clear Polysulfone (PSU) Indicator cover and gain pot driver: Black PSU Cable: PVC jacket Short cable QD: Nickel-plated brass and PVC jacket QD connector and mounting nuts: Nickel-plated brass www.bannerengineering.com - Tel: +1-763-544-3164 3 M18-3 Nickel-Plated Brass 18 mm Barrel Sensors Operating Conditions Temperature: −40 °C to +70 °C (−40 °F to +158 °F) 95% at +50 °C maximum relative humidity (non-condensing) Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Environmental Rating IEC 60529 IP67 and IP69K Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements. Method 201A (Vibration; frequency 10 to 60 Hz, max., double amplitude 0.06 in acceleration 10G). Method 213B conditions H&I (Shock: 75G with unit operating; 100G for non-operation) Certifications Industrial Control Equipment 3TJJ Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to http:// www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Class 2 power UL Environmental Rating: Type 1 Performance Curves Diffuse Models (300 mm Range) Beam Pattern Excess Gain 20 15 5 0 EXCESS GAIN BEAM PATTERN (mm) 1000 10 −5 −10 100 10 −15 −20 0 50 10 0 15 0 20 0 25 0 30 0 35 0 1 40 0 DISTANCE (mm) 10 1 100 DISTANCE (mm) 1000 Diffuse Models (750 mm Range) Beam Pattern Excess Gain 100 10 EXCESS GAIN BEAM PATTERN (mm) 15 5 0 -5 - 10 - 15 0 100 200 300 400 500 DISTANCE (mm) 4 10 600 700 800 1 1 10 100 1000 DISTANCE (mm) www.bannerengineering.com - Tel: +1-763-544-3164 P/N 185178 Rev. C M18-3 Nickel-Plated Brass 18 mm Barrel Sensors Emitter/Receiver Models (Effective Beam Size: 15.2 mm) Beam Pattern Excess Gain EXCESS GAIN BEAM PATTERN (mm) 1000 1000 800 600 400 200 0 - 200 - 400 - 600 - 800 - 1000 0 5 10 15 20 100 25 10 1 DISTANCE (m) 0.1 1 10 100 DISTANCE (m) Polarized Retroreflective Models Beam Pattern Excess Gain 100 BRT-92x92C BRT-84 BRT-60x40C BRT-40x19A BRT-60x40IP BRT-THG-2-100 40 EXCESS GAIN BEAM PATTERN (mm) 60 20 0 - 20 10 - 40 - 60 0 1 2 3 4 5 6 DISTANCE (m) 1 0.01 0.1 1 10 DISTANCE (m) Retroreflective Models Beam Pattern Excess Gain 100 BRT-92x92C BRT-84 BRT-60x40C BRT-40x19A BRT-60x40IP BRT-THG-2-100 80 40 EXCESS GAIN BEAM PATTERN (mm) 60 20 0 -20 10 -40 -60 -80 0 1 2 3 4 5 DISTANCE (m) 6 7 8 1 0.01 0.1 1 10 DISTANCE (m) P/N 185178 Rev. C www.bannerengineering.com - Tel: +1-763-544-3164 5 M18-3 Nickel-Plated Brass 18 mm Barrel Sensors Fixed Field Models - Excess Gain Target for Excess Gain Curves use a 90% Reflective White Card 1000 100 EXCESS GAIN EXCESS GAIN 1000 10 100 10 1 1 10 100 1 1000 1 10 100 1000 DISTANCE (mm) DISTANCE (mm) M18-3FF30 M18-3FF50 Emitter Image Size: 4.0 mm square at 15 mm and 3.5 mm square at 30 mm Emitter Image Size: 4 mm square at 25 mm and 3 mm square at 50 mm 18% Gray Test Card: Cutoff distance will be 98% of value shown 18% Gray Test Card: Cutoff distance will be 98% of value shown 6% Black Test Card: Cutoff distance will be 95% of value shown 6% Black Test Card: Cutoff distance will be 95% of value shown 100 100 EXCESS GAIN 1000 EXCESS GAIN 1000 10 1 1 10 1 1000 100 10 1 DISTANCE (mm) 10 100 1000 DISTANCE (mm) M18-3FF75 M18-3FF100 Emitter Image Size: 4.5 mm square at 37 mm and 4.0 mm square at 75 mm Emitter Image Size: 4.5 mm square at 50 mm and 4.5 mm square at 100 mm 18% Gray Test Card: Cutoff distance will be 98% of value shown 18% Gray Test Card: Cutoff distance will be 95% of value shown 6% Black Test Card: Cutoff distance will be 95% of value shown 6% Black Test Card: Cutoff distance will be 90% of value shown 6 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 185178 Rev. C M18-3 Nickel-Plated Brass 18 mm Barrel Sensors Fixed Field Models - Excess Gain Target for Excess Gain Curves use a 90% Reflective White Card 1000 EXCESS GAIN EXCESS GAIN 1000 100 10 100 10 1 1 1 10 100 10 1 1000 100 1000 DISTANCE (mm) DISTANCE (mm) M18-3FF150 M18-3FF200 Emitter Image Size: 5 mm square at 75 mm and 8 mm square at 150 mm Emitter Image Size: 5 mm square at 100 mm and 8 mm square at 200 mm 18% Gray Test Card: Cutoff distance will be 90% of value shown 18% Gray Test Card: Cutoff distance will be 85% of value shown 6% Black Test Card: Cutoff distance will be 70% of value shown 6% Black Test Card: Cutoff distance will be 60% of value shown Dimensions All measurements are listed in millimeters [inches], unless noted otherwise. Cable Models P/N 185178 Rev. C QD Models www.bannerengineering.com - Tel: +1-763-544-3164 7 M18-3 Nickel-Plated Brass 18 mm Barrel Sensors Accessories Cordsets All measurements are listed in millimeters, unless noted otherwise. 4-Pin Threaded M12/Euro-Style Cordsets Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 3 4 1 2 3 4 30 Typ. [1.18"] 15.2 m (50 ft) 2 1 32 Typ. [1.26"] Right-Angle MQDC-450RA Pinout (Female) = = = = Brown White Blue Black M12 x 1 ø 14.5 [0.57"] Washdown Cordsets 4-Pin Threaded M12/Euro-Style Cordsets—Washdown, Stainless Steel Model Length Style MQDC-WDSS-0406 1.83 m (6 ft) MQDC-WDSS-0415 4.57 m (15 ft) Pinout (Female) 1 Straight MQDC-WDSS-0430 Dimensions 2 3 4 Ø15.5 mm Ø4.8 mm 9.14 m (30 ft) 1 = Brown 2 = White 3 = Blue 4 = Black 43.5 mm Apertures 8 Model Units Aperture Description AP18SCN 3 Kit includes round apertures of 0.5 mm (0.02 in), 1.0 mm (0.04 in), and 2.5 mm (0.10 in) diameter. AP18SRN 3 Kit includes rectangular apertures of 0.5 mm (0.02 in), 1.0 mm (0.04 in), and 2.5 mm (0.10 in) wide. Each kit also includes a thread-on housing, Teflon® FEP® lens, and o-ring. APG18S 1 Kit with glass lens to protect plastic sensor lens from chemical environments and weld splatter damage. Product www.bannerengineering.com - Tel: +1-763-544-3164 P/N 185178 Rev. C M18-3 Nickel-Plated Brass 18 mm Barrel Sensors Brackets SMB18SF • 18 mm swivel bracket with M18 × 1 internal thread • Black thermoplastic polyester • Stainless steel swivel locking hardware included SMBS18-2-1 • 30% glass-filled PBT 51 M18 - 1 x 6G B 42 4.5 ø28 25 A Hole center spacing: A = 36.0 Hole size: A = ø 5.3, B = ø 18.0 SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware 30 C A B 46 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 41 SMB18FA.. • Swivel bracket with tilt and pan movement for precision adjustment • Easy sensor mounting to extruded rail T-slots • Metric and inch size bolts available • 18 mm sensor mounting hole 66 B 69 A Hole size: B=ø 18.1 Model Bolt Thread (A) SMB18FA 3/8 - 16 × 2 in SMB18FAM10 M10 - 1.5 × 50 SMB18FAM12 n/a; no bolt included. Mounts directly to 12 mm (½ in) rods For additional brackets, check the current Banner catalog or visit www.bannerengineering.com. All measurements are listed in millimeters, unless noted otherwise. Reflectors BRT-2X2 • • • • • Square, acrylic target Reflectivity factor: 1.0 Max. temperature: +50 °C (+122 ºF) Optional brackets are available Approximate size: 51 mm × 51 mm P/N 185178 Rev. C BRT-84X84A • • • • Square, acrylic target Reflectivity Factor: 2.0 Temperature: −20 °C to +60 °C (−4 °F to +140 °F) Approximate size: 84 mm × 84 mm www.bannerengineering.com - Tel: +1-763-544-3164 9 M18-3 Nickel-Plated Brass 18 mm Barrel Sensors BRT-40X19A • Rectangular, acrylic target • Reflectivity Factor: 1.3 • Temperature: −20 °C to +60 °C (−4 °F to +140 °F) • Approximate size: 19 mm × 60 mm overall; 19 mm × 40 mm reflector BRT-84 • Round, acrylic target • Reflectivity Factor: 1.4 • Temperature: −20 °C to +60 °C (−4 °F to +140 °F) • Optional brackets are available • Size: 84 mm diameter • Mounting Hole: 4.5 mm diameter BRT-60X40C • Rectangular, acrylic target • Reflectivity Factor: 1.4 • Temperature: −20 °C to +60 °C (−4 °F to +140 °F) • Optional brackets are available • Approximate size: 40 mm × 60 mm Retroreflective Tape Model Reflectiv ity Factor Maximum Temperatur e Size BRTTHG-2-100 0.7 +60 °C (+140 °F) 50 mm (2 in) wide, 2.5 m (100 in) long Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Copyright Notice Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved. www.bannerengineering.com - Tel: +1-763-544-3164
M18-3VPDL-Q8 价格&库存
很抱歉,暂时无法提供与“M18-3VPDL-Q8”相匹配的价格&库存,您可以联系我们找货
