WORLD-BEAM® Q20 Series Sensor
Datasheet
Photoelectric sensors in a compact, rugged, sealed, over-molded plastic housing
Standard 3 mm threaded mounting holes on 25.4 mm (1 in) spacing
Advanced electronic design for excellent noise immunity and cross-talk avoidance
Threaded metal M8 connector on certain quick-disconnect models
10 V DC to 30 V DC operation with complementary solid-state outputs (1 normally open, 1
normally closed); PNP or NPN, depending on model
Complete offering of mounting brackets and apertures available
Crosstalk prevention filters available for visible red opposed mode pairs
Exceptional optical performance with easy to align visible red emitters
Background suppression models provide reliable detection up to 150 mm while ignoring objects
in the background
Background suppression models provide stable detection in the presence of fluorescent lights
WARNING:
• Do not use this device for personnel protection
• Using this device for personnel protection could result in serious injury or death.
• This device does not include the self-checking redundant circuitry necessary to allow its use in
personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition.
Models
Model 1
Q20E
Q20PR
Q20NR
Sensing Mode
Opposed, 624 nm Visible
Red
Effective Beam: 10 mm
(0.4 in)
Q20EL
Q20PRL
Q20NRL
Q20PLP
Q20NLP
Q20PLV
Q20NLV
Q20PDL
Q20NDL
Opposed, 850 nm
Infrared
(0.4 in)
Range
Output 2
Model 1
Sensing Mode
Range
Output 2
N/A
Q20PDXL
12 m (39.4 ft)
PNP
Q20NDXL
Long Range DIffuse, 850
nm Infrared
1500 mm (59
in)
NPN
Short Range Diffuse, 624
nm Visible Red
250 mm (10 in)
Small Spot Diffuse, 660 nm
Visible Red
250 mm (10 in)
20 m (65.6 ft)
Polarized Retroreflective,
645 nm Visible Red
4 m (13 ft)
(specified using
reflector BRT-84)
Retroreflective, 645 nm
Visible Red
6 m (20 ft)
(specified using
reflector BRT-84)
Long-Range Diffuse, 624
nm Visible Red
800 mm (32 in)
NPN
Q20PD
N/A
Q20ND
PNP
Q20PDVS
NPN
Q20NDVS
PNP
Q20PFF50
NPN
PNP
50 mm (2 in)
cutoff
Q20NFF50
Q20PFF100
Q20NFF100
NPN
Q20PFF150
PNP
Q20NFF150
Fixed Field, 655 nm Visible
Red
PNP
PNP
NPN
PNP
NPN
PNP
NPN
PNP
100 mm (4 in)
cutoff
NPN
150 mm (6 in)
cutoff
NPN
PNP
NPN
Diffuse-mode and fixed-field performances are based on the use
of a 90% reflectance white test card.
1 Integral 2 m (6.5 ft) unterminated cable models are listed.
To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, Q20E W/30.
To order the 4-pin M8 integral quick disconnect model, add the suffix "Q7" to the model number. For example, Q20EQ7.
To order the 150 mm (6 in) PVC cable model with a 4-pin M8 quick disconnect, add the suffix "Q" to the model number. For example, Q20EQ.
To order the 150 mm (6 in) PVC cable model with a 4-pin M12 quick disconnect, add the suffix "Q5" to the model number. For example, Q20EQ5.
To order the 150 mm (6 in) PUR cable model with a 4-pin M12 quick disconnect, add the suffix "QPMA" to the model number. For example,
Q20EQPMA.
Models with a quick disconnect require a mating cordset.
2 Available with Health or Alarm Mode output; contact Banner Engineering for details.
Original Document
127816 Rev. N
6 December 2021
127816
Overview
Banner’s Q20 family of sensors offers a full complement of sensing
modes, with the excellent performance expected of much larger
sensors. Their compact plastic housings feature overmolded
construction for superior robustness and sealing. Their popular
rectangular design is easy to mount into tight spaces; integral
threaded mounting holes eliminate the need for separate mounting
nuts.
(varies with model)
3
1. Output LED
2. Power LED
3. Single-Turn Gain
Potentiometer (Retro
and Diffuse models
only)
2
1
The single-turn Gain potentiometer on most models and bright
LEDs (positioned on top of the housing for 360° visibility) provide
easy alignment and configuration for reliable sensing.
Wiring Diagrams
Cabled wiring diagrams are shown. Quick disconnect wiring diagrams are functionally identical.
Emitter
PNP Output
NPN Output
bn (1)
brown
bu (3)
10–30 V DC
blue
bk (4)
4-pin M8 Male QD
2
4
1
3
10–30 V dc
wh (2)
bu (3)
Load
wh (2)
Load
10–30 V dc
bn (1)
bk (4)
Key
1.
Brown
2.
White
3.
Blue
4.
Black
Load
Load
4-pin M12 Male QD
2
3
1
4
Specifications
Supply Voltage
Fixed-Field: 10 V DC to 30 V DC (10% maximum ripple within specified limits)
at less than 25 mA, exclusive of load
All others: 10 V DC to 30 V DC (10% maximum ripple within specified limits)
at less than 18 mA, exclusive of load
Supply Protection Circuitry
Protected against reverse polarity and transient voltages
2
Repeatability
Opposed mode: 140 microseconds
All other models: 90 microseconds
Construction
ABS housing; PMMA lenses; PBT Gain Adjuster (Retro and Diffuse models
only)
www.bannerengineering.com - Tel: + 1 888 373 6767
P/N 127816 Rev. N
Connections
2 m (6.5 ft) or 9 m (30 ft) 4-wire PVC cable, 150 mm (6 in) cable with 4-pin
threaded M8 (Q) or M12 (Q5) connector, or 4-pin integral threaded M8
connector (Q7), depending on the model ordered
Output Configuration for Receiver
100 mA with short circuit protection
OFF-state leakage current:
NPN: < 200 µA sinking (see Application Note 2);
PNP: < 10 µA sourcing
ON-state saturation voltage
NPN: < 1.6 V at 100 mA
PNP: < 3.0 V at 100 mA
Indicators
Two LED Indicators: Power (green) and Output (amber)
Fixed-Field models:
Green on: Power ON
Amber on: Black (LO) wire conducting
All other models:
Green on: Power ON
Amber flashing: Marginal excess gain (1 to 1.5×)
Output Configuration for all Other Models
Maximum Current ≤ 100 mA
PNP Output Voltage:
High ≥ Vsupply – Vsaturation
Low ≤ 1 V (≤ 1M Ω)
NPN Output Voltage:
High ≥ Vsupply – 1 V (≤ 1M Ω)
Low ≤ Vsaturation
Vsaturation ≤ 3 V
Adjustments
Diffuse, Retroreflective, and Polarized Retroreflective models (only):
Single-turn Sensitivity (Gain) adjustment potentiometer
Output Response Time
Opposed mode: 1 millisecond ON/600 microseconds OFF
All other models: 850 microseconds ON/OFF
100 millisecond delay on power-up; outputs do not conduct during this time
Applications Notes
1.
2.
Required Overcurrent Protection
Opposed mode sensor spacing can be reduced by alternating
emitters and receivers or by applying cross talk filters (visible red
models only)
For receiver only: NPN off-state leakage current is 3kΩ or optically isolated loads. For load currents of
100 mA, leakage is
很抱歉,暂时无法提供与“SGSA-Q20PLPQ5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1199.480621+155.87557
