ML6-8-H-120-RT/59/65A/95/136
    PEPPERL+FUCHS(倍加福)
    PHOTO SEN 120MM BACK SUPPRESS
ML6-8-H-120-RT/59/65A/95/136 数据手册
Background suppression sensor ML6-8-H-120-RT/59/65a/95/136 < < < < < Precise background suppression Adjustable background suppression Small, sharp light spot Very small black-white difference Highly visible LEDs for Power-On, switching status, short-circuit, and undervoltage < Metal-reinforced fastening holes < Push-pull output Triangulation sensor with background suppression for standard applications, miniature design, 120 mm adjustable detection range, light/dark on, red light, two push-pull outputs, M8 plug Function Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 182444_eng.pdf The ML6 series is characterized by a robust, powerful and standard design in a miniature housing. The housing offers IP67/IP69K degree of protection, a food-grade lens, highly visible LEDs and robust all-metal bushings for mounting. Adjustable and tamper-proof sensors with a double push-pull output are available. The sensors have a high ambient light limit. Reflections from the background are suppressed. The unusually small, sharp light spot and the quick response time offer maximum switching precision on object edges. Clearly visible red light sources facilitates alignment. A high-performance fixed focus background suppressor is a useful feature. The sensors are suitable for precise object detection and open up a wide range of application fields. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Background suppression sensor ML6-8-H-120-RT/59/65a/95/136 Dimensions 18 Fixing screw M2 x 5 8 3 13.9 6.8 M8 x 1 7.9 ± 0.3 31.4 39.5 15 26.6 25.4 9.9 7.2 3 ø 3.2 Technical Data Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 182444_eng.pdf General specifications Detection range 15 ... 120 mm Detection range min. 10 ... 30 mm Detection range max. 18 ... 120 mm Adjustment range 30 ... 120 mm Reference target standard white, 100 mm x 100 mm Light source LED Light type modulated visible red light , 660 nm Black-white difference (6 %/90 %) < 10 % Diameter of the light spot approx. 5 mm at detection range 120 mm Ambient light limit Continuous light 40000 Lux Modulated light 5000 Lux Functional safety related parameters MTTFd 1940 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means Operation indicator LED green, statically lit Power on , Undervoltage indicator: Green LED, pulsing (approx. 0.8 Hz) , short-circuit : LED green flashing (approx. 4 Hz) Function indicator LED yellow: lights when object is detected Control elements Sensing range adjuster Electrical specifications Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Background suppression sensor ML6-8-H-120-RT/59/65a/95/136 Technical Data Operating voltage UB Ripple 10 ... 30 V DC , class 2 max. 10 % No-load supply current I0 < 25 mA Output Switching type light/dark on, programmable Signal output 2 push-pull (4 in 1) outputs, complementary, short-circuit proof, reverse polarity protected Switching voltage max. 30 V DC Switching current max. 100 mA Voltage drop Ud ≤ 2.5 V DC Switching frequency f 1000 Hz Response time 500 µs Conformity Product standard EN 60947-5-2 Compliance with standards and directives Standard conformity Shock and impact resistance IEC / EN 60068. half-sine, 40 g in each X, Y and Z directions Vibration resistance IEC / EN 60068-2-6. Sinus. 10 -150 Hz, 5 g in each X, Y and Z directions Approvals and certificates UL approval cULus Listed CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -20 ... 60 °C (-4 ... 140 °F) Storage temperature -40 ... 75 °C (-40 ... 167 °F) Mechanical specifications Housing width 13.9 mm Housing height 31.4 mm Housing depth 18 mm Degree of protection IP67 / IP69K Connection M8 x 1 connector, 4-pin Material Housing ABS Optical face PMMA Mass approx. 10 g Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 182444_eng.pdf Connection Assignment Option: 1 +UB 2 Q2 3 0V 4 Q1 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Background suppression sensor ML6-8-H-120-RT/59/65a/95/136 = Light on = Dark on Connection Assignment 2 1 4 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Assembly 1 2 3 1 4 5 1 2 3 4 5 operating display green indication of the switching state yellow receiver axis emitter axis detection range adjuster 2 Characteristic Curve Characteristic response curve ML6-8-H-120... Offset Y [mm] 3 2 1 0 -2 -3 0 20 40 60 80 100 120 140 160 Distance X [mm] x y Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 182444_eng.pdf -1 white 90 % grey 18 % black 6 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4 Background suppression sensor ML6-8-H-120-RT/59/65a/95/136 ML6-8-H-120... Difference in detection distance Deviation of measured detection distance X [%] 20 15 10 5 0 0 20 40 60 80 100 120 140 Adjusted detection distance (white) X [mm] x grey 18 % black 6 % Accessories Mounting Clamp OMH-ML6 Mounting bracket OMH-ML6-U Mounting bracket OMH-ML6-Z Mounting bracket V31-GM-5M-PUR Female cordset single-ended M8 straight A-coded, 4-pin, PUR cable grey V31-WM-5M-PUR Female cordset single-ended M8 angled A-coded, 4-pin, PUR cable grey Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 182444_eng.pdf OMH-4.1 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 5
ML6-8-H-120-RT/59/65A/95/136 价格&库存
很抱歉,暂时无法提供与“ML6-8-H-120-RT/59/65A/95/136”相匹配的价格&库存,您可以联系我们找货
