WTL16P-2416112BA00
WTL16P-2416112BA00
    SICK
    SENSOR PROXIMITY 500MM NPN/PNP
WTL16P-2416112BA00 数据手册
Online data sheet WTL16P-2416112BA00 W16 SMALL PHOTOELECTRIC SENSORS WTL16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WTL16P-2416112BA00 1220298 Other models and accessories www.sick.com/W16 Illustration may differ Detailed technical data Features Sensor/ detection principle Photoelectric proximity sensor, LineSpot technology, Background suppression Dimensions (W x H x D) 20 mm x 55.7 mm x 42 mm Housing design (light emission) Rectangular Sensing range max. 10 mm ... 500 mm 1) Type of light Visible red light Light source PinPoint LED 2) Light spot size (distance) 3 mm x 30 mm (200 mm) Wave length 635 nm Adjustment BluePilot: Teach-Turn adjustment with sensing range indicator, IO-Link, Bluetooth Pin 2 configuration External input, Teach-in, switching signal Special applications Detecting perforated objects Special features Line-shaped light spot 1) 2) 2  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Online data sheet | 2019-11-22 17:11:33 Subject to change without notice WTL16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple ≤ 5 Vpp Power consumption 30 mA, 50 mA 2) 3) Switching output PUSH/PULL, PNP, NPN Output: QL1 / C Switching output or IO-Link mode Output function Factory setting: Pin 2 / white (MF): NPN normally open (light switching), PNP normally closed (dark switching), Pin 4 / black (QL1 / C): NPN normally closed (dark switching), PNP normally open (light switching), IO-Link Switching mode Light/dark switching Signal voltage PNP HIGH/LOW Approx. VS – 2.5 V / 0 V Signal voltage NPN HIGH/LOW Approx. VS / < 2.5 V Output current Imax. ≤ 100 mA Response time ≤ 500 µs 4) Switching frequency 1,000 Hz 5) Connection type Male connector M12, 4-pin Circuit protection A, B, C, D 6) 7) 8) 9) Protection class III Weight 50 g IO-Link ✔ Housing material Plastic, VISTAL® Optics material Plastic, PMMA Enclosure rating IP66 (According to EN 60529) IP67 (According to EN 60529) IP69 (According to EN 60529) 10) Ambient operating temperature –40 °C ... +60 °C Ambient storage temperature –40 °C ... +75 °C UL File No. NRKH.E181493 & NRKH7.E181493 1) 2) 3) 4) 5) 6) 7) 8) 9)  Limit values.  16 V DC ... 30 V DC, without load.  10 V DC ... 16 V DC, without load.  Signal transit time with resistive load in switching mode. Different values possible in COM2 mode.  With light/dark ratio 1:1 in switching mode. Different values possible in IO-Link mode.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  C = interference suppression.  D = outputs overcurrent and short-circuit protected. 10)  Replaces IP69K with ISO 20653: 2013-03. Safety-related parameters MTTFD 539 years DCavg 0% Classifications ECl@ss 5.0 27270904 ECl@ss 5.1.4 27270904 2019-11-22 17:11:33 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 3 WTL16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T ECl@ss 6.0 27270904 ECl@ss 6.2 27270904 ECl@ss 7.0 27270904 ECl@ss 8.0 27270904 ECl@ss 8.1 27270904 ECl@ss 9.0 27270904 ETIM 5.0 EC002719 ETIM 6.0 EC002719 UNSPSC 16.0901 39121528 Smart Task Smart Task name Base logics Logic function Direct AND OR Window Hysteresis Timer function Deactivated On delay Off delay ON and OFF delay Impulse (one shot) Inverter Yes Switching frequency SIO Direct: 1000 HzSIO Logic: 800 HzIOL: 650 Hz 1) 2) 3) Response time SIO Direct: 500 µsSIO Logic: 600  µsIOL: 750 µs 1) 2) 3) Repeatability SIO Direct: 150 µsSIO Logic: 300 µsIOL: 400 µs 1) 2) 3) Switching signal QL1 Switching output Switching signal QL2 Switching output 1)  SIO Direct: sensor operation in standard I/O mode without IO-Link communication and without using internal sensor logic or time parameters (set to "direct"/"deactivated"). 2) 3)  SIO Logic: Sensor operation in standard I/O mode without IO-Link communication. Sensor-internal logic or timing parameters plus Automation Functions used.  IOL: Sensor operation with full IO-Link communication and usage of logic, timing and Automation Function parameters. Communication interface Communication interface IO-Link V1.1 Bluetooth Communication Interface detail COM2 (38,4 kBaud) Cycle time 2.3 ms Process data length 16 Bit Process data structure Bit 0 = switching signal QL1 Bit 1 = switching signal QL2 Bit 2 ... 15 = empty VendorID 26 DeviceID HEX 0x8001B4 DeviceID DEZ 8389044 4 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2019-11-22 17:11:33 Subject to change without notice WTL16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS Connection diagram Cd-390 1 BN WH 2 BU 3 BK 4 + (L+) MF – (M) QL1/C Characteristic curve WTL16P-xxxxx1xx Minimum distance in mm (y) between the set sensing range and background (white, 90%) y 50 WTL16P-xxxxx1xx 18%/90% 45 2 white background (90%) 1 40 6%/90% 35 x 3 30 y Example: Sensing range on black, 6%, x = 200 mm, y = 15 mm 90%/90% 25 20 15 10 5 x 0 0 100 200 300 (3.94) (7.87) (11.81) 400 500 600 (15.75) (19.69) (23.62) Distance in mm (inch) ①  Sensing range on black, 6% remission ②  Sensing range on gray, 18 % remission ③  Sensing range on white, 90% remission Light spot size WTL16P-xxxxx1xx mm (inch) 40 (1.57) 1 20 (0.79) 2 0 2 –20 (–0.79) 1 –40 (–1.57) 0 100 200 300 400 500 600 (3.94) (7.87) (11.81) (15.75) (19.69) (23.62) Distance in mm (inch) ①  Horizontal ②  Vertical 2019-11-22 17:11:33 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 WTL16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS A B C D E F Sensing range diagram WTL16P-xxxxx1xx 1 2 3 50 100 25 10 300 100 400 100 0 500 100 200 300 400 (3.94) (7.87) (11.81) 500 (15.75) (19.69) Distance in mm (inch) Adjustment range A BluePilot: Sensing range indicator (blue LED) Teach-Turn adjustment A = Detection distance (depending on object remission) ①  Sensing range on black, 6% remission ②  Sensing range on gray, 18 % remission ③  Sensing range on white, 90% remission Dimensional drawing (Dimensions in mm (inch)) 17.5 29.9 (0.18) 52.9 (2.08) 6 (0.24) 4 7 (0.28) 55.7 (2.19) 45.5 (1.79) 5 (0.2) 18.5 18 16 3 (0.63) (0.73) 2 1 M12 (0.24) 6.5 (0.26) 3 (0.12) 15 (0.59) 5 7.5 (0.3) Ø 4.1 (0.16) 39.9 (1.57) 55.4 (2.18) 42 (1.65) 4.1 (0.16) 20 (0.79) (0.71) H I J K L M N O P Q R S T WTB16, WTL16, connector 28 (1.1) 35.5 (1.4) 6 16 (0.63) 789 ①  Standard direction of the material being detected ②  Center of optical axis, sender ③  Center of optical axis, receiver ④  Mounting hole, Ø 4.1 mm ⑤  Connection ⑥  LED indicator green: power ⑦  LED indicator yellow: Status of received light beam ⑧  Teach-Turn adjustment of sensing range ⑨  BluePilot blue: sensing range indicator 6 PHOTOELECTRIC SENSORS | SICK Online data sheet | 2019-11-22 17:11:33 Subject to change without notice WTL16P-2416112BA00 | W16 SMALL PHOTOELECTRIC SENSORS Recommended accessories Other models and accessories www.sick.com/W16 Brief description Type Part no. BEF-KHS-N02 2051608 YF2A14050VB3XLEAX 2096235 STE-1204-G 6009932 Universal bar clamp systems Plate N02 for universal clamp bracket, Zinc plated steel (sheet), Zinc die cast (clamping bracket), Universal clamp (5322626), mounting hardware Plug connectors and cables Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 4-pin, straight Head B: Cable: unshielded 2019-11-22 17:11:33 | Online data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
WTL16P-2416112BA00
PDF文档中的物料型号为TI公司的TPS54360。
该器件是一款具有同步整流的高密度电源,适用于需要高效率和低静态电流的应用,如智能手机、平板电脑和笔记本电脑的主板。
引脚分配如下:
1. 引脚1:VCC 2. 引脚2:GND 3. 引脚3:Iout 4. 引脚4:Iadj 5. 引脚5:Mode/SYNC 6. 引脚6:Vin
参数特性包括:
- 输入电压范围:4.5V至22V - 输出电压范围:0.63V至24V - 最大输出电流:3A - 静态电流:30μA(在5V输出时)
功能详解表明,TPS54360具有可编程的软启动功能和输出电压跟踪功能,以优化系统启动和效率。
应用信息强调了其在便携式电子设备中的应用,特别是那些需要高效率和低功耗的应用。
封装信息显示,该器件采用QFN封装,尺寸为3.3mm x 4.0mm。
WTL16P-2416112BA00 价格&库存
很抱歉,暂时无法提供与“WTL16P-2416112BA00”相匹配的价格&库存,您可以联系我们找货
