Q4XTULAF600-Q8
Q4XTULAF600-Q8
    BANNER(邦纳)
    PHOTO SEN 600MM 0-10V
Q4XTULAF600-Q8 数据手册
Q4X Stainless Steel Analog Laser Sensor Quick Start Guide Class 1 laser CMOS analog sensor with an analog output. Patent pending. This guide is designed to help you set up and install the Q4X Analog Sensor. For complete information on programming, performance, troubleshooting, dimensions, and accessories, please refer to the Instruction Manual at www.bannerengineering.com. Search for p/n 185624 to view the Instruction Manual. Use of this document assumes familiarity with pertinent industry standards and practices. For illustration purposes, the threaded barrel model Q4X images are used throughout this document. WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Features Figure 2. Sensor Features—Flush Mount Models Figure 1. Sensor Features—Threaded Barrel Models 1 1 2 3 1. Output Indicator (Amber) 2. Display 3. Buttons 2 3 Display and Indicators The display is a 4-digit, 7-segment LED. The main screen is the Run Mode screen, which shows the current distance to the target in millimeters. Figure 3. Display in Run Mode 1. Stability Indicator (STB = Green) 2. Active TEACH Indicators • 2-PT = Two-Point TEACH (Amber) • 1-PT = One-Point TEACH (Amber) 3. Display Value Indicator (MM = Amber) Output Indicator • On—Displayed distance is within the taught analog output window • Off—Displayed distance is outside of the taught analog output window Stability Indicator (STB) • On—Stable signal within the specified sensing range • Flashing—Marginal signal, the target is outside of the limits of the specified sensing range, or a multiple peak condition exists • Off—No target detected within the specified sensing range Active TEACH Indicators (2PT and 1PT) • 2-PT on—Two-point TEACH mode selected (default) • 1-PT on—One-point TEACH mode selected Display Value Indicator (MM) • On—Display shows the distance in millimeters (default) • Off—Display shows the analog output value Buttons Use the sensor buttons (SELECT)(TEACH), (+)(DISP), and (-)(MODE) to program the sensor. Original Document 185623 Rev. F 11 November 2020 185623 Q4X Stainless Steel Analog Laser Sensor (SELECT)(TEACH) (+)(DISP) • Press and hold for longer than 2 seconds to start the • Press to change the distance setting for the 10 V (20 currently selected TEACH mode (the default is two-point mA) point; press and hold to increase numeric values TEACH) • Press and hold for longer than 2 seconds to toggle the • Press to select menu items in Setup mode display value between the distance and the analog output (-)(MODE) • Press to navigate the sensor menu in Setup mode • Press to change the distance setting for the 0 V (4 mA ) point; press and hold to decrease numeric values Note: When navigating the menu, the menu • Press and hold for longer than 2 seconds to enter Setup items loop. mode • Press to navigate the sensor menu in Setup mode Laser Description and Safety Information CAUTION: Use of controls or adjustments or performance of procedures other than those specified herein may result in hazardous radiation exposure. Do not attempt to disassemble this sensor for repair. A defective unit must be returned to the manufacturer. ≤ 510 mm Models - IEC 60825-1:2007 Class 1 Laser Class 1 lasers are lasers that are safe under reasonably foreseeable conditions of operation, including the use of optical instruments for intrabeam viewing. Laser wavelength: 655 nm Output: < 0.20 mW Pulse Duration: 7 µs to 2 ms > 510 mm Models - IEC 60825-1:2014 Class 1 Laser Class 1 lasers are lasers that are safe under reasonably foreseeable conditions of operation, including the use of optical instruments for intrabeam viewing. COMPLIES WITH 21 CFR 1040.10 AND 1040.11 EXCEPT FOR CONFORMANCE WITH IEC 60825-1:2014, AS DESCRIBED IN LASER NOTICE No. 56, DATED MAY 8, 2019. BANNER ENGINEERING CORP. 9714 10TH AVENUE NORTH MINNEAPOLIS, MN 55441 CLASS 1 LASER PRODUCT COMPLIES WITH IEC 60825-1:2014 Laser wavelength: 655 nm Output: < 0.39 mW 2 www.bannerengineering.com - Tel: + 1 888 373 6767 Pulse Duration: 7 µs to 2 ms P/N 185623 Rev. F Q4X Stainless Steel Analog Laser Sensor Installation Install the Safety Label 1. Remove the protective cover from the adhesive on the label. 2. Wrap the label around the Q4X cable, as shown. 3. Press the two halves of the label together. CLASS 1 LASER PRODUCT Note: Position the label on the cable in a location that has minimal chemical exposure. Figure 4. Safety Label Installation COMPLIES WITH IEC 60825-1:2007 The safety label must be installed on Q4X sensors that are used in the United States. COMPLIES WITH 21 CFR 1040.10 AND 1040.11 EXCEPT FOR DEVIATIONS PURSUANT TO LASER NOTICE No. 50, DATED JUNE 24, 2007. BANNER ENGINEERING CORP. 9714 10TH AVENUE NORTH MINNEAPOLIS, MN 55441 CLASS 1 LASER PRODUCT COMPLIES WITH IEC 60825-1:2007 Sensor Orientation Optimize detection reliability and performance with correct sensor-to-target orientation. To ensure reliable detection, orient the sensor as shown in relation to the target to be detected. Figure 5. Optimal Orientation of Target to Sensor See the following figures for examples of correct and incorrect sensor-to-target orientation as certain placements may pose problems for sensing some targets. Figure 6. Orientation by a wall Correct Incorrect Figure 9. Orientation for a color or luster difference (Optimal) Horizontal Orientation Vertical Orientation Figure 7. Orientation for a turning object Correct Incorrect Figure 8. Orientation for a height difference Correct Incorrect Figure 10. Orientation for highly reflective target1 Reflective Surface (optional) Mount the Device 1. If a bracket is needed, mount the device onto the bracket. 2. Mount the device (or the device and the bracket) to the machine or equipment at the desired location. Do not tighten the mounting screws at this time. 3. Check the device alignment. 4. Tighten the mounting screws to secure the device (or the device and the bracket) in the aligned position. 1 Applying tilt to sensor may improve performance on reflective targets. The direction and magnitude of the tilt depends on the application, but a 15° tilt is often sufficient. P/N 185623 Rev. F www.bannerengineering.com - Tel: + 1 888 373 6767 3 Q4X Stainless Steel Analog Laser Sensor Wiring Diagram 1 3 2 4 1 + 12-30V dc – 2 3 Analog Out Load Key 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray Analog Gnd 5 4 5 Remote Teach Shield Note: Open lead wires must be connected to a terminal block. Note: The input wire function is user-selectable; see the Instruction Manual for details. The default for the input wire function is off (disabled). Note: Shielded cordsets are recommended for all models with quick disconnect fittings. It is recommended that the shield wire be connected to -V dc (the blue wire). Cleaning and Maintenance Handle the sensor with care during installation and operation. Sensor windows soiled by fingerprints, dust, water, oil, etc. may create stray light that may degrade the peak performance of the sensor. Blow the window clear using filtered, compressed air, then clean as necessary using only water and a lint-free cloth. Connecting to RSD1 The following diagram depicts the connection of the Q4XTULAF600, Q4XTILAF600, Q4XTULAF610, or Q4XTILAF610 to the optional RSD1 accessory. Figure 11. Q4X to RSD1 RSD1 MQDC-540..SS* Q4X *Optional Extension Cordset: MQDEC3-5..SS Sensor Programming Program the sensor using the buttons on the sensor or the remote input (limited programming options). In addition to programming the sensor, use the remote input to disable the buttons for security, preventing unauthorized or accidental programming changes. See the Instruction Manual, p/n 185624 for more information. Setup Mode 1. Access Setup mode and the sensor menu from Run mode by pressing and holding MODE for longer than 2 seconds. and to navigate through the menu. 2. Use 3. Press SELECT to select a menu option and access the submenus. 4. Use and to navigate through the submenus. 5. Select a submenu option. • Press SELECT to select a submenu option and return to the top menu. • Press and hold SELECT for longer than 2 seconds to select a submenu option and return immediately to Run mode. To exit Setup mode and return to Run mode, navigate to 4 and press SELECT. www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 185623 Rev. F Q4X Stainless Steel Analog Laser Sensor Figure 12. Sensor Menu Map Top Menu Sub Menus Teach Process Selection two-point teach one-point teach Base Measurement Rate Averaging Slope ( default setting) 100/110, 300/310, & 500/510 mm Model Response Speeds set Base Measurement Rate to 0.3 ms set Base Measurement Rate to 0.5 ms set Base Measurement Rate to 1.0 ms set Base Measurement Rate to 2.5 ms set Base Measurement Rate to 5.0 ms or 600/610 mm Model Response Speeds set Base Measurement Rate to 0.4 ms set Base Measurement Rate to 0.8 ms set Base Measurement Rate to 1.5 ms set Base Measurement Rate to 2.5 ms set Base Measurement Rate to 5.0 ms average 1 measurement for analog output average 2 measurements for analog output average 4 measurements for analog output average 8 measurements for analog output average 16 measurements for analog output average 32 measurements for analog output average 64 measurements for analog output average 128 measurements for analog output average 256 measurements for analog output average 512 measurements for analog output positive slope negative slope Select Zero Reference Location near: set zero displayed value to end of 18 mm barrel far: set zero displayed value to maximum detection range Shift Zero Reference after Teach on: move the zero point after each teach off: zero point is either at end of barrel or maximum detection range Loss of Signal current models (3.5 mA) (20.5 mA) hold voltage models (0 V) (10.5 V) hold Input Wire Function Trigger Mode off: remote teach input is not active set: Remote Teach input laser off when pulled low laser on when pulled low master slave trigger average measurement range (max. dist - min. dist) max. distance min. distance track max. distance track min. distance sample measurement Display Read Exit Setup Trigger Mode appears when Input Wire Function is set to “trigger” display on display on, inverted display off (enters sleep mode after 60 seconds) display off, inverted (enters sleep mode after 60 seconds) end: select to exit setup Reset to Factory Defaults no: do not reset to factory defaults yes: reset to factory defaults P/N 185623 Rev. F www.bannerengineering.com - Tel: + 1 888 373 6767 5 Q4X Stainless Steel Analog Laser Sensor Basic TEACH Instructions Use the following instructions to teach the Q4X sensor. The instructions provided on the sensor display vary depending on the type of TEACH mode selected. Two-point TEACH is the default TEACH mode. 1. Press and hold TEACH for longer than 2 seconds to start the selected TEACH mode. 2. Present the target. 3. Press TEACH to teach the target. The target is taught and the sensor waits for the second target, if required by the selected TEACH mode, or returns to Run mode. Complete steps 4 and 5 only if required for the selected TEACH mode: 4. Present the second target. 5. Press TEACH to teach the target. The target is taught and the sensor returns to Run mode. Manual Adjustments Manually adjust the distance set for the 0 V (4 mA) and 10 V (20 mA) values using the adjustments vary depending on the TEACH mode selected. and buttons. The available Locking and Unlocking the Sensor Buttons Use the lock and unlock feature to prevent unauthorized or accidental programming changes. Three settings are available: • —The sensor is unlocked and all settings can be modified (default). • — The sensor is locked and no changes can be made. • —The value associated with 0 V (4 mA) and 10 V (20 mA ) can be changed by teaching or manual adjustment, but no sensor settings can be changed through the menu. When in mode, (-)(MODE) are pressed, but displays when the (SELECT)(TEACH) button is pressed. The analog point displays when (+)(DISP) or displays if the buttons are pressed and held. When in mode, displays when (+)(DISP) or (-)(MODE) are pressed and held. To access the manual adjust options, briefly press and release (+)(DISP) or (-)(MODE). To enter TEACH mode, press the (SELECT)(TEACH) button and hold for longer than 2 seconds. To enter mode, hold and pressing 6 and press four times. To enter mode, hold and press four times unlocks the sensor from either lock mode and the sensor displays www.bannerengineering.com - Tel: + 1 888 373 6767 seven times. Holding . P/N 185623 Rev. F Q4X Stainless Steel Analog Laser Sensor Specifications Sensing Beam using Visible red Class 1 laser, 655 nm ≤ 510 mm models: IEC 60825-1:2007 Class 1 > 510 mm models: IEC 60825-1:2014 Class 1 Analog Linearity Analog linearity performance matches accuracy performance curve (see Performance Curves—Threaded Barrel Models on p. 9 and Performance Curves—Flush Mount Models on p. 10). On 600 mm and 610 mm models, linearity is the lesser of accuracy or 2.5% of full scale range Supply Voltage (Vcc) 12 to 30 V dc Power and Current Consumption, exclusive of load < 675 mW Response Speed Total response speed varies from 0.5 ms to 2560 ms, depending on base measurement rate and averaging settings. See Instruction Manual for more information. Sensing Range—Threaded Barrel Models 600 mm models: 25 mm to 600 mm (0.98 in to 23.62 in) 500 mm models: 25 mm to 500 mm (0.98 in to 19.68 in) 300 mm models: 25 mm to 300 mm (0.98 in to 11.81 in) 100 mm models: 25 mm to 100 mm (0.98 in to 3.94 in) Delay at Power Up < 750 ms Ambient Light Immunity > 5,000 lux at 300 mm > 2,000 lux at 500 mm Sensing Range—Flush Mount Models 610 mm models: 35 mm to 610 mm (1.38 in to 24.02 in) 310 mm models: 35 mm to 310 mm (1.38 in to 12.20 in) 110 mm models: 35 mm to 110 mm (1.38 in to 4.33 in) Maximum Torque Side mounting: 1 N·m (9 in·lbs) Nose mounting: 20 N·m (177 in·lbs) Analog Output Configuration 0 to 10 V or 4 to 20 mA, depending on model Output Rating Analog Voltage Outputs (Q4X..U Models): 2.5 kOhm minimum load resistance Analog Current Outputs (Q4X..I Models): 1 kΩ maximum load resistence at 24 V; maximum load resistance = [(Vcc – 4.5)/0.02 Ω] Remote Input Allowable Input Voltage Range: 0 to Vcc Active Low (internal weak pullup—sinking current): Low State < 2.0 V at 1 mA max. Supply Protection Circuitry Protected against reverse polarity and transient overvoltages Analog Resolution—Threaded Barrel Models 300 mm and 600 mm models: 25 mm to 100 mm: < 0.3 mm 100 mm to 300 mm: < 1 mm 500 mm models only: 300 to 500 mm: < 1.75 mm 600 mm models only: 300 to 600 mm: < 2 mm 100 mm models: 25 mm to 100 mm: < 0.15 mm Connector Integral 5-pin M12/Euro-style male quick disconnect Construction Housing: 316 L stainless steel Lens cover: PMMA acrylic Lightpipe and display window: polysulfone Chemical Compatibility Compatible with commonly used acidic or caustic cleaning and disinfecting chemicals used in equipment cleaning and sanitation. ECOLAB® certified. Compatible with typical cutting fluids and lubricating fluids used in machining centers Application Note For optimum performance, allow 10 minutes for the sensor to warm up Analog Resolution—Flush Mount Models 610 mm models: 310 to 610 mm: < 2 mm 310 mm models: 35 mm to 110 mm: < 0.3 mm 110 mm to 310 mm: < 1 mm 110 mm models: 35 mm to 110 mm: < 0.15 mm Beam Spot Size—300/310 mm, 500 mm, and 600/610 Models Table 1: Beam Spot Size—300/310 mm, 500 mm, and 600/610 mm Models Distance (mm) Beam Spot Size—100/110 mm Models Table 2: Beam Spot Size—100/110 mm Models Distance (mm) Size (Horizontal × Vertical) Size (Horizontal × Vertical) Threaded Barrel Models Flush Mount Models Threaded Barrel Models Flush Mount Models 25 35 2.6 mm × 1.0 mm 25 35 2.4 mm × 1.0 mm 150 160 2.3 mm × 0.9 mm 50 60 2.2 mm × 0.9 mm 300 310 2.0 mm × 0.8 mm 100 110 1.8 mm × 0.7 mm 500 - 1.9 mm × 1.0 mm 600 610 1.9 mm × 1.0 mm P/N 185623 Rev. F www.bannerengineering.com - Tel: + 1 888 373 6767 7 Q4X Stainless Steel Analog Laser Sensor Excess Gain using a 90% White Card—600/610 mm Models Table 3: Excess Gain2) Excess Gain ( Response Speed (ms) · at 25 mm (600 mm models) · at 100 mm (600 mm models) · at 300 mm (600 mm models) · at 600 mm (600 mm models) · at 35 mm (610 mm models) · at 110 mm (610 mm models) · at 310 mm (610 mm models) · at 610 mm (610 mm models) 2 280 110 25 6 5 280 110 25 6 15 1000 (360) 400 (150) 80 (30) 20 (7) 25 2000 (1000) 800 (400) 160 (80) 40 (20) 50 4000 (2000) 1600 (800) 320 (160) 80 (40) Environmental Rating IEC IP67 per IEC60529 IEC IP68 per IEC60529 IP69K per DIN 40050-9 per DIN40050-9 Operating Conditions 35% to 95% relative humidity Shock MIL-STD-202G, Method 213B, Condition I (100G 6x along X, Y, and Z axes, 18 shocks), with device operating Vibration MIL-STD-202G, Method 201A (Vibration: 10 Hz to 60 Hz, 0.06 inch (1.52 mm) double amplitude, 2 hours each along X, Y and Z axes), with device operating Storage Temperature –25 °C to +75 °C (–13 °F to +167 °F) Min. Ambient Temp (°C) Vcc Max. Ambient Temp (°C) All Models Q4X…U (0–10V) –10 50 12 Q4X..I (4–20 mA)* 50 24 30 45 40 * For 4–20 mA models only: Max. Ambient Sensor Temp (°C) = 50 – (Vcc – 12)/2 Certifications Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Industrial Control Equipment Class 2 power UL Environmental Rating: Type 1 3TJJ chemical compatibility certified ECOLAB is a registered trademark of Ecolab USA Inc. All rights reserved. 2 8 • excess gain available in 15 ms response speed only • excess gain provides increased noise immunity www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 185623 Rev. F Q4X Stainless Steel Analog Laser Sensor Performance Curves—Threaded Barrel Models Accuracy (90% to 6% reflectance) Figure 13. 100 mm Models Figure 14. 300 mm Models 1.25 10 Accuracy ( ± mm) Accuracy ( ± mm) 9 1.00 0.75 0.50 8 7 6 5 4 3 2 0.25 1 0 0 0 25 75 50 100 0 50 100 150 200 250 DISTANCE (mm) DISTANCE (mm) Figure 15. 500 mm Models Figure 16. 600 mm Models 300 35 25 Accuracy ( ± mm) Accuracy ( ± mm) 30 20 15 10 5 0 25 20 15 10 5 0 0 100 200 300 400 500 0 100 200 300 400 500 600 700 DISTANCE (mm) DISTANCE (mm) Repeatability (90% to 6% reflectance) Figure 18. 300 mm Models 0.35 3.5 0.30 3.0 Averaging = 1 Averaging = 512 0.25 0.20 0.15 0.10 0.075 0.05 0 0 25 50 100 Repeatability ( ± mm) Repeatability ( ± mm) Figure 17. 100 mm Models Averaging = 1 Averaging = 512 2.5 2.0 1.5 1.0 0.5 0 0 DISTANCE (mm) P/N 185623 Rev. F 50 100 150 200 250 300 DISTANCE (mm) www.bannerengineering.com - Tel: + 1 888 373 6767 9 Q4X Stainless Steel Analog Laser Sensor Repeatability (90% to 6% reflectance) Figure 19. 500 mm Models Figure 20. 600 mm Models 1.4 5.0 4.0 3.0 2.0 1.0 0 Filter = 1 Filter = 512 1.2 Repeatability ( ± mm) Repeatability ( ± mm) Averaging = 1 Averaging = 512 1.0 0.8 0.6 0.4 0.2 0 0 100 200 300 400 0 500 100 200 300 400 500 600 700 DISTANCE (mm) DISTANCE (mm) Temperature Effects Figure 21. 100 mm and 300 mm Models Figure 22. 500 mm Models 1.0 0.30 0.25 0.20 0.15 0.10 0.05 0 50 100 150 200 250 300 1.2 Temperature Effect (± mm / °C) Temperature Effect (± mm / °C) Temperature Effect (± mm / °C) 0.35 0 Figure 23. 600 mm Models 0.8 0.6 0.4 0.2 0.05 0 0 100 200 300 400 500 1.0 0.8 0.6 0.4 0.2 0.05 0 0 DISTANCE (mm) DISTANCE (mm) 100 200 300 400 500 600 700 DISTANCE (mm) Performance Curves—Flush Mount Models Accuracy (90% to 6% reflectance) Figure 24. 110 mm Models Figure 25. 310 mm Models 0.75 0.50 10 35 9 30 8 Accuracy ( ± mm) 1.00 Accuracy ( ± mm) Accuracy ( ± mm) 1.25 Figure 26. 610 mm Models 7 6 5 4 3 2 0.25 25 20 15 10 5 1 0 0 35 50 DISTANCE (mm) 10 100 110 0 310 35 0 50 100 150 200 250 300 DISTANCE (mm) www.bannerengineering.com - Tel: + 1 888 373 6767 0 0 100 200 300 400 500 600 700 DISTANCE (mm) P/N 185623 Rev. F Q4X Stainless Steel Analog Laser Sensor Repeatability (90% to 6% reflectance) Figure 28. 310 mm Models 3.5 0.30 3.0 Averaging = 1 Averaging = 512 0.25 0.20 0.15 0.10 0.075 0.05 0 35 0 50 100 Figure 29. 610 mm Models 1.4 Averaging = 1 Averaging = 512 2.5 2.0 1.5 1.0 0.5 0 110 DISTANCE (mm) 0 35 310 50 100 150 200 250 Filter = 1 Filter = 512 1.2 Repeatability ( ± mm) 0.35 Repeatability ( ± mm) Repeatability ( ± mm) Figure 27. 110 mm Models 1.0 0.8 0.6 0.4 0.2 0 300 0 DISTANCE (mm) 100 200 300 400 500 600 700 DISTANCE (mm) Temperature Effects Figure 30. 110 mm and 310 mm Models Figure 31. 610 mm Models 1.2 0.30 0.25 0.20 0.15 0.10 0.05 0 310 35 0 50 100 150 200 250 300 Temperature Effect (± mm / °C) Temperature Effect (± mm / °C) 0.35 1.0 0.8 0.6 0.4 0.2 0.05 0 0 100 200 300 400 500 600 700 DISTANCE (mm) DISTANCE (mm) Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
Q4XTULAF600-Q8 价格&库存
很抱歉,暂时无法提供与“Q4XTULAF600-Q8”相匹配的价格&库存,您可以联系我们找货
Q4XTULAF600-Q8
  • 1+6506.311291+844.81217
库存:6
