SM2A30SRLQD
SM2A30SRLQD
    BANNER(邦纳)
    PHOTO SEN RECEIVER 150M SPST
SM2A30SRLQD 数据手册
SM30 Series 30 mm Barrel Sensors Datasheet Opposed-Mode Infrared Photoelectric Sensors for Especially Demanding Applications • • • • • • • Stainless steel or plastic barrel models Very high excess gain; 150 m (500 ft) sensing range; 880 nm Infrared LED Positive sealing eliminates even capillary leakage; lens is quad-ring sealed; exceeds NEMA 6P (IP67) ratings – ideal for equipment wash-down environments EZ-BEAM® technology provides reliable sensing without the need for adjustment Modulation frequency “A” is standard; frequencies “B” and “C” also available for preventing crosstalk in multiple-sensor applications (emitter and opposed receiver frequencies must match) AC- and DC-operated receiver models available; emitters feature Universal voltage Range for all models: 150 m (500 ft) WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Modulation Frequency1 A Housing B C SMA30PEL SMA30PELB SMA30PELC SMA30PELQD SMA30PELQDB SMA30PELQDC SMA30SEL SMA30SELB SMA30SELC SMA30SELQD SMA30SELQDB SMA30SELQDC SM30PRL SM30PRLB SM30PRLC SM30PRLQD SM30PRLQDB SM30PRLQDC SM30SRL SM30SRLB SM30SRLC SM30SRLQD SM30SRLQDB SM30SRLQDC SM2A30PRL SM2A30PRLB SM2A30PRLC SM2A30PRLQD SM2A30PRLQDB SM2A30PRLQDC SM2A30SRL SM2A30SRLB SM2A30SRLC SM2A30SRLQD SM2A30SRLQDB SM2A30SRLQDC SM2A30PRLNC SM2A30PRLNCB SM2A30PRLNCC SM2A30PRLNCQD SM2A30PRLNCQDB SM2A30PRLNCQDC SM2A30SRLNC SM2A30SRLNCB SM2A30SRLNCC SM2A30SRLNCQD SM2A30SRLNCQDB SM2A30SRLNCQDC Cable2 Power Supply Output Type Emitter Models Plastic Stainless Steel 2 m (6.5 ft) 2-wire Cable 3-pin Mini-style QD3 2 m (6.5 ft) 3-wire Cable Universal: 12 to 240 V ac, 10 to 30 V dc – 10 to 30 V dc Bi-Modal™ NPN or PNP 3-pin Mini-style QD3 DC Receivers Plastic Stainless Steel 2 m (6.5 ft) 4-wire Cable 4-pin Mini-style QD 2 m (6.5 ft) 4-wire Cable 4-pin Mini-style QD AC Receivers Plastic Stainless Steel Plastic Stainless Steel 2 m (6.5 ft) 2-wire Cable 3-pin Mini-style QD3 SPST Solid-state, L.O. 2 m (6.5 ft) 3-wire Cable 3-pin Mini-style QD3 2 m (6.5 ft) 2-wire Cable 3-pin Mini-style QD3 2 m (6.5 ft) 3-wire Cable 24 to 240 V ac SPST Solid-state, D.O. 3-pin Mini-style QD3 1 Any emitter and receiver shown here can be used together, if they have the same modulation frequency. 2 Standard 2 m (6.5 ft) cable and integral QD models are listed. Models with a quick disconnect require a mating cordset. To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. For example, SM30PRLBW/30. 3 AC models with QD require SM30CC model cables. Original Document 03541 Rev. G 25 May 2017 03541 SM30 Series 30 mm Barrel Sensors Wiring Diagrams Key 1 = Brown (red/black for QD emitters/receivers) 3 = Blue (red/white for QD emitters/receivers) 4 = Green (green for QD emitters/receivers) Emitters—Cabled Emitters—QD AC Receivers—Cabled AC Receivers—QD 1 1 10-30V dc or 12-240V ac 3 1 10-30V dc or 12-240V ac 3 1 4 4* 24-240V ac 3 Load 24-240V ac 3 4 Load 4* Note: AC emitters are not polarity-sensitive when powered by dc voltage. For QD emitters, use a SM30CC model cordset to match cable colors. *Connect the green wire to earth ground whenever a stainless steel model is powered by ac voltage. (Cabled plastic models have no green wire.) Key 1 = Brown 2 = White 3 = Blue 4 = Black DC Receivers—NPN DC Receivers—PNP 3 4 3 – 10-30V dc + 1 4 Load 2 Light Operate 3 – 10-30V dc + 1 4 Load 2 Dark Operate 3 + 10-30V dc – 1 4 Load 2 Light Operate + 10-30V dc – 1 Load 2 Dark Operate Cabled wiring diagrams are functionally identical. 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 03541 Rev. G SM30 Series 30 mm Barrel Sensors Specifications Supply Voltage and Current Emitters: 12 to 240V ac (50/60 Hz) or 10-30V dc at 20 mA, 10% maximum ripple DC Receivers: 10 to 30V dc at 10 mA maximum (exclusive of load); 10% maximum ripple AC Receivers: 24 to 240V ac (50/60 Hz) Environmental Rating Exceeds NEMA 6P and IEC IP67 Supply Protection Circuitry Protected against reverse polarity and transient voltages Operating Conditions Temperature: −40 °C to +70 °C (−40 °F to +158 °F) 90% at +50 °C maximum relative humidity (non-condensing) Connections PVC-jacketed 2 m or 9 m cables or Mini-style quick-disconnect (QD) fitting are available. QD cables are ordered separately. Output Configuration Required Overcurrent Protection DC Receivers: Bi-Modal™ output (PNP sourcing or NPN sinking). Selection of light/dark operate and sourcing or sinking configuration dependent on hookup. WARNING: Electrical connections must be made AC Receivers: SPST solid-state switch; light operate (LO) or dark operate (DO) by qualified personnel in accordance with local dependent on model. and national electrical codes and regulations. Output Rating Overcurrent protection is required to be provided by end product application DC Receivers: 250 mA continuous per the supplied table. Output saturation voltage (PNP & NPN configuration) < 1 volt at 10 mA and < 2 Overcurrent protection may be provided with external fusing or via Current volts at 250 mA Limiting, Class 2 Power Supply. Off-state leakage current < 10 microamps Supply wiring leads < 24 AWG shall not be spliced. AC Receivers: Maximum steady-state load capability is 500 mA For additional product support, go to www.bannerengineering.com. Inrush capability: 10 amps for 1 second (non-repeating) Off-state leakage: current < 1.7 mA rms Supply Wiring (AWG) Required Overcurrent Protection (Amps) On-state voltage drop: < 3.5 volts rms across a 500 mA load; < 5 volts rms across a 15 mA load 20 5.0 Output Protection Circuitry Outputs of dc receivers are short circuit protected Output Response Time 10 milliseconds on/off Repeatability “A” frequency models: 1 ms “B” frequency models: 1.5 ms “C” frequency models: 2.3 ms Indicators Internal red LED, visible through the lens or from side of the sensor. Emitters: Red “Power ON” indicator LED DC Receivers: Lights whenever receiver sees its modulated light source AC Receivers: Lights whenever receiver’s output is conducting 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Certifications Construction Fully epoxy-encapsulated tubular threaded housing, positive sealed at both ends, quad-ring sealed acrylic lens. Plastic models: 30 mm diameter thermoplastic polyester housing and jam nuts. Stainless Steel models: 30 mm diameter 303 stainless steel housing and jam nuts. Dimensions All measurements are listed in millimeters [inches], unless noted otherwise. Cabled Models QD Models Jam Nuts (2 Provided) Jam Nuts (2 Provided) Alignment Indicator (Receivers) Alignment Indicator (Receivers) M30 x 1.5 Thread 102 mm (4.0") P/N 03541 Rev. G M30 x 1.5 Thread 114 mm (4.5") www.bannerengineering.com - Tel: +1-763-544-3164 3 SM30 Series 30 mm Barrel Sensors Performance Curves Excess Gain Curve Beam Pattern 100000 SM30 Series Opposed Mode 10000 E X C E S S G A I N 1500 mm SM30 Series 60 in 1000 mm Opposed Mode 40 in 500 mm 20 in 0 0 1000 100 500 mm 20 in 1000 mm 40 in 1500 mm 60 in 0 10 45 m 150 ft 90 m 300 ft 135 m 450 ft 180 m 600 ft 225 m 750 ft DISTANCE 1 1m 3.3 ft 10 m 33 ft 100 m 330 ft 1000 m 3300 ft DISTANCE Accessories Cordsets 3-Pin Mini-Style Cordsets Model Length SM30CC-306 Style Dimensions 1.83 m (6 ft) 52 Typ. SM30CC-312 Pinout (Female) 3.66 m (12 ft) 4 7/8-16UN-2B 1 3 Straight ø 25.5 1 = Red/Black 3 = Red/White 4 = Green 4-Pin Mini-Style Cordsets Model Length MBCC-406 1.83 m (6 ft) MBCC-412 3.66 m (12 ft) Style Dimensions 52 Typ. Pinout (Female) 7/8-16UN-2B Straight MBCC-430 ø 25.5 9.14 m (30 ft) 2 4 1 3 1 = Brown 2 = White 3 = Blue 4 = Black Apertures APG30S Kit includes round apertures of 0.05 in, 0.12 in, and 0.70 in diameter; slotted widths of 1 mm (0.04 in), 0.10 in and 0.20 in. Used with SM30 and SMI30 models. 4 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 03541 Rev. G SM30 Series 30 mm Barrel Sensors Brackets SMB30A • Right-angle bracket with curved slot for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor • 12-ga. stainless steel 45 C 61 B A 69 Hole center spacing: A to B=40 Hole size: A=ø 6.3, B= 27.1 x 6.3, C=ø 30.5 SMB30MM • 12-ga. stainless steel bracket with curved mounting slots for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor SMB30C • 30 mm split clamp, black PBT bracket • Stainless steel mounting hardware included • Mounting hole for 30 mm sensor 56 A 66 B 13 Hole center spacing: A=ø 45 Hole size: B=ø 27.2 57 70 C 57 B A Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 67 B 58 29 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
SM2A30SRLQD 价格&库存
很抱歉,暂时无法提供与“SM2A30SRLQD”相匹配的价格&库存,您可以联系我们找货
SM2A30SRLQD
  • 1+3302.502511+427.22912
