HL18L-P4A5BB
HL18L-P4A5BB
    SICK
    SENSOR RETROREFLECTIVE 10M PNP
HL18L-P4A5BB 数据手册
Product data sheet HL18L-P4A5BB SureSense HYBRID PHOTOELECTRIC SENSORS HL18L-P4A5BB | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. HL18L-P4A5BB 1075008 Other models and accessories www.sick.com/SureSense Illustration may differ Detailed technical data Features Device type Photoelectric sensors Sensor/ detection principle Photoelectric retro-reflective sensor, Dual lens Dimensions (W x H x D) 16.2 mm x 48.5 mm x 31.8 mm Housing design (light emission) Hybrid Thread diameter (housing) M18 Mounting system type M18, nose / side (24.1 … 25.4 mm) Housing color Blue Sensing range max. 0.1 m ... 12 m 1) Sensing range 0.1 m ... 10 m 1) Type of light Visible red light Light source Laser 2) 3) Light spot size (distance) 2 mm (2 m) Wave length 655 nm Laser class I Adjustment Potentiometer, right Sensitivity Potentiometer, left None Special applications Detecting small objects Special features Signal strength light bar 1) 2) 3)  Reflector PL80A.  Average service life: 50,000 h at TU = +25 °C.  CLASS 1 LASER PRODUCT EN60825-1:2014, IEC60825-1:2014, Maximum pulse power < 2,5 mW, Pulse length: 4 μs, Wavelength: 650 ... 670 nm, Complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to Laser Notice No. 50, dated June 24, 2007. 2 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HL18L-P4A5BB | SureSense HYBRID PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC Ripple –10 °C. Sensor cannot be turned on below Ta= –10 °C. Safety-related parameters MTTFD 417.2 years DCavg 0 % Classifications ECl@ss 5.0 2021-12-08 22:34:56 | Product data sheet  Subject to change without notice 27270902 PHOTOELECTRIC SENSORS | SICK 3 HL18L-P4A5BB | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F ECl@ss 5.1.4 27270902 ECl@ss 6.0 27270902 ECl@ss 6.2 27270902 ECl@ss 7.0 27270902 ECl@ss 8.0 27270902 ECl@ss 8.1 27270902 ECl@ss 9.0 27270902 ECl@ss 10.0 27270902 ECl@ss 11.0 27270902 ETIM 5.0 EC002717 ETIM 6.0 EC002717 ETIM 7.0 EC002717 ETIM 8.0 EC002717 UNSPSC 16.0901 39121528 Connection/pin assignment H I J K L M N O P Q R S T Connection type Male connector M12, 4-pin PIN assignment BN 1 + (L+) WH 2 Q2 BU 3 - (M) BK 4 Q1 4 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HL18L-P4A5BB | SureSense HYBRID PHOTOELECTRIC SENSORS Dimensional drawing (Dimensions in mm (inch)) 16.2 (0.64) 31.4 (1.24) 10.1 (0.40) D 10.5 (0.41) B 4 7.5 (0.30) 25.4 (1.00) 24.1 (0.95) 12.7 3 (0.34) 8.6 C (0.50) 48.5 (1.91) A M12 x 1 0.9 (0.04) 2 15 (0.59) 5 M18 x 1 1 ①  LED indicator yellow: Status of received light beam ②  LED indicator green: power on ③  M3 mounting hole ④  Snap Connection for flush ring (sold seperatly) ⑤  Potentiometer (if selected) or LED Indicators Dimensions in mm (inch) Receiver Sender A B C D HTB18 / HTF18 - 1.1 (0.04) 1.1 (0.04) 4.7 (0.19) 0.6 (0.02) HTE18 / HL18 / HSE18 2.5 (0.1) 0.0 (0.0) 4.0 (0.16) 0.0 (0.0) HTB18L / HTF18L / HL18L / HSE18L 2.5 (0.1) 0.0 (0.0) 3.5 (0.14) 0.0 (0.0) Connection type See table: Connection/Pin assignment 2 1 3 4 2021-12-08 22:34:56 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 HL18L-P4A5BB | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Adjustments possible 2 1 3 ①  LED indicator yellow: Status of received light beam ②  LED indicator green: power on ③  Signal strength light bar Characteristic curve Operating reserve 100 4 10 3 5 6 2 1 1 0 2 4 6 8 10 12 (6.56) (13.12) (19.67) (26.25) (32.81) (39.37) Distance in m (feet) ①  Reflector PL80A ②  Reflector P250F ③  PL10F reflector ④  Reflector PL23 FT ⑤  Reflective tape REF-AC1000 ⑥  Reflective tape IREF6000 (REF-IRF-56) 6 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice HL18L-P4A5BB | SureSense HYBRID PHOTOELECTRIC SENSORS Light spot size mm (inch) 12 Dimensions in mm (inch) (0.47) 10 (0.39) 8 (0.31) 6 (0.24) Sensing range Vertical Horizontal 0.2 m 1.2 2.65 (0.57 feet) (0.05) (0.10) 0.75 m 1.8 2.3 (2.46 feet) (0.07) (0.09) 5m 4.0 2.2 (16.40 feet) (0.16) (0.09) 12 m 10.0 5.0 (39.37 feet) (0.39) (0.20) 4 (0.16) 2 (0.08) 0 2 4 6 8 10 12 (6.56) (13.12) (19.67) (26.25) (32.81) (39.37) Distance in m (feet) Vertical Horizontal Sensing range diagram 1 2 3 4 5 6 0.1 10 0.1 8 0.1 4 6 4 6 12 10 0.1/ 2.5 1.5 0.1 0.1/ 2.5 1.5 0 2 (6.56) 4 6 8 10 12 14 (13.12) (19.69) (26.25) (32.81) (39.37) (45.93) Distance in m (feet) Sensing range Sensing range max. ①  Reflector PL80A ②  Reflector P250F ③  PL10F reflector ④  Reflector PL23 FT ⑤  Reflective tape REF-AC1000 ⑥  Reflective tape IREF6000 (REF-IRF-56) 2021-12-08 22:34:56 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 HL18L-P4A5BB | SureSense HYBRID PHOTOELECTRIC SENSORS A B C D E F Functions 100 % 100 % 100 % 100 % 100 % 0% 0% 0% 0% 0% Recommended accessories Other models and accessories www.sick.com/SureSense Brief description Type Part no. BEF-WN-REFX 2064574 YF2A14050VB3XLEAX 2096235 STE-1204-G 6009932 P250F 5308843 Mounting brackets and plates H I J K L M N O P Q R S T Universal mounting bracket for reflectors, steel, zinc coated Plug connectors and cables Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 4-pin, straight Head B: Cable: unshielded Reflectors Fine triple reflector, screw connection, suitable for laser sensors, 52 mm x 62 mm, PMMA/ABS, Screw-on, 2 hole mounting 8 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-08 22:34:56 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
HL18L-P4A5BB 价格&库存
很抱歉,暂时无法提供与“HL18L-P4A5BB”相匹配的价格&库存,您可以联系我们找货
