Photoelectrics
Background Suppression
Type PD112CNB25BP..
• Range: 2500 mm
• Accurate & stable distance adjustment
• Modulated, infrared light 850 nm
• Supply voltage: 10 to 30 VDC
• Output: 200 mA, NPN or PNP preset
• Make or break switching function selectable
• Adjustable ON- / OFF delay, 1 – 16 sec.
• LED indication for output and power ON
• Protection: reverse polarity, short circuit and transients
• Cable and plug versions
• Excellent EMC performance
• Remote test feature (mute)
Product Description
Ordering Key
The PD112CNB25 sensor
comes in a 112 x 45 x 25 mm
strong polycarbonate (PC)
housing. The sensors are
useful in applications where
long range and high accuracy
detection is required.
Robust housing, a sophisticated mechanical design and
high power LED for excellent
performance in harsh environments.
The sensor has a test input,
for door mode, designed to
Type
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
Connection type
remotely disable (mute) the
emitter and thereby evaluate
the sensor function from a
door controller or e.g. a PLC.
The output type is preset
(NPN and PNP) with selectable switching function NO/
NC.
2 selectable modes are built
in: ”Industrial” for general
automation and ”Door” specifically for control of doors &
gates.
PD112CNB25BPM1
Type Selection
Housing
Range
Connection
WxHxD
Sn
Ordering no.
NPN and PNP
25 x 107.5 x45 mm
25 x 107.5 x45 mm
PD 112 CNB 25 BP
PD 112 CNB 25 BPM1
500 - 2500 mm
500 - 2500 mm
Cable
Plug
Specifications
Rated operating distance (Sn) 50 to 2500 mm,
referece target Kodak
test card R27, white, 90%
reflective, 200 x 200 mm
Background adjustment
500 to 2500 mm
(28 turns calibration screw)
Blind zone
50 mm
Temperature drift
≤ 0.2%/ºC
Rated operational volt. (UB )
10 to 30 VDC
(ripple included)
Ripple (Urpp )
≤ 10%
Output current
Continuous (Ie)
≤ 200 mA
(max. load capacity 100 nF)
No load supply current (Io)
≤ 40 mA @ 24 VDC
Minimum operational current (Im) 0.5 mA
OFF-state current (Ir )
≤ 100 µA
Voltage drop (Ud )
≤ 2.5VDC @ 200 mA
Protection
Short-circuit, reverse polarity
and transients
Light source
GaAlAs, LED, 850 nm
Specifications are subject to change without notice (13.06.2017)
Light type
Infrared, modulated
Sensing angle
Industry
± 1.9º
Door
± 2.6º
Ambient light
10,000 lux
Light spot
60 mm @ 1.5 m
Operating frequency
Industry
250 Hz
Door
16.7 Hz
Response time
OFF-ON (tON)
Industry
≤ 2 ms
ON-OFF (tOFF )
Industry
≤ 2 ms
OFF-ON (tON)
Door
≤ 30 ms
ON-OFF (tOFF )
Door
≤ 30 ms
Power ON delay (tv)
≤ 50 ms
Output delay
ON-delay
1-16 s
OFF-delay
1-16 s
Output function
NPN and PNP
Preset
NO/NC switching function
Selectable by DIP switch
1
PD112CNB25BP..
Specifications (cont.)
Vibration
10 to 150 Hz, 0.5 mm/7.5 g
(IEC 60068-2-6)
Shock
2 x 1 m, 100 x 500 mm
(IEC 60068-2-32)
Rated insulation voltage
2 kV (rms)
Housing material
Body
PC (polycarbonate), black
Cover
PC (polycarbonate), clear
Connection
Cable
PVC, black, 2 m
5 x 0.34 mm2, Ø = 5.2 mm
Plug
M12, 5-pin (CONB15-series)
Weight
With cable: 160 g
With plug: 80 g
CE-marking Yes
Approvals
cULus (UL508)
Test input
Door mode
Emitter off (voltagelevel)
< 1 VDC, NPN
(No pull-up resistor) or
> 9 VDC PNP
(No pull-down resistor)
Input current
< 3 mA DC
Industrial mode
Not avaliable
Indication
Output ON
LED, yellow
Power ON
LED, green
Environment
Installation category
III (IEC 60664/60664A;
60947-1)
Pollution degree
3 (IEC 60664/60664A;
60947-1)
Degree of protection
IP 67 (IEC 60529; 60947-1)
Ambient temperature
Operating -25° to +55°C (-13° to +131°F)
Storage -25° to +80°C (-13° to +176°F)
Operation Diagram
With time delay
Power supply
ON
OFF
Background
Present
Not Present
Object/Target
Present
Not Present
Make Output (NO)
ON
OFF
Break Output (NC)
ON
OFF
Yellow LED
ON
OFF
Test input*
ON
OFF
Without time delay
Dont care
tv
t
t
t
t
t
t
t
t
tv = Power on delay, t = Time delay (delay on operate and delay on release)
* Only active in Door Mode
Detection Diagram
Wiring Diagrams
Detection diagram PD112 BGU white
BN
50
40
30
BK
(mm)
Door
Industry
-20
BU
GY (test input)
-30
-40
-50
1000
1500
2000
Sensing range (mm)
2
WH
2500
3000
PNP*
NPN*
* or potential free contact
PD112CNB25BP..
Sensing Conditions “Industrial” mode
In this mode the maximum operating frequency is set to 250
Hz and detection is optimized for objects close to the background for top performance in general industry automation
applications such as pallet wrapping machines, airport baggage
conveyors,
White
object (90%) wood planks handling/stacking.
White background (90%)
30
1625
1420
1215
1010
85
60
4 0
2
Grey object (18%)
Black object (6%)
White object (90%)
Grey object (18%)
Black object (6%)
50
100
150
200
250
300
Distance cm
50
100
150
200
250
300
Sensing Conditions
“Door”
mode
Distance
cm
In this mode various parameters are optimized for monitoring and control of doors, from a position above the door/in
the ceiling. Maximum operating frequency is set to 16.7 Hz,
adapting to moving persons, and the test input – for evaluation
(90%)functioning through muting of the emitter – is
ofWhite
theobject
sensor
Grey object
(18%)
enabled
for
use by a door controller or e.g. a PLC.
Black background (6%)
background (cm)
Object distance from
Object
background
(cm)distance from
60
50
40
background (cm)
1630
1420
12
10
10
80
4
2
140
Black object (6%)
50
100
150
200
250
300
Distance cm
50
100
150
Grey background (18%)
200
250
50
100
150
200
60
300
Distance cm
12
10
8
6
4
2
White object (90%)
Grey object (18%)
Black object (6%)
background (cm)
background (cm)
Object (cm)
distance from
background
35
40
White object (90%)
30
Grey object (18%)
Black object20
(6%)
250
Door
NO
Industrial
DIST.
Door
NO
Industrial
ON
DIST.
PD112 Sensor
OFF
150
200
250
300
Distance cm
Detectable area
NC
NC
DELAY
50
Detection Principle
PD112 Detection Principle
ON
10
300
Distance cm
DELAY
50
PD112 Sensor
OFF
50 mm
Object direction
Detectable area
X = Distance to background
Y = Object distance (min.) from background
X
= Detectable objects
= Not detectable objects
Y
Object direction
3
PD112CNB25BP..
Adjustment
Background suppression adjustment*
1. Align the sensor at the background
2. Turn distance calibration screw (28 turns) counter clockwise until
2. Turn distance calibration screw (28 turns) clockwise until yellow
yellow led turns OFF
led is ON
3. Turn distance calibration screw (28 turns) clockwise until yellow
3. Turn distance calibration screw (28 turns) counter clockwise until led turns ON
4. The object can now be detected
4. Background is now neglected
Object detection adjustment
*If no background exists a white cardboard can be used as background.
Dimensions (mm)
Plug version
Cable version
Sensor top 1:1
25
25
2.5
2.5
Door
NO
Industrial
DELAY
ON
112.5
112.5
NC
DIST.
OFF
2 x Ø5.2
2 x Ø5.2
Incorrect
Correct
7.5
5
5
7.5
30
30
Output
45
Power
45
OFF
ON
Door
DIST.
NC
Industrial
Door
DIST.
NC
Industrial
NO
NO
DELAY
OFF
ON
DELAY
> 100 mm
Installation Hints
To avoid interference from inductive voltage / Relief of the cable strain
current peaks, separate the proximity switch
cables from any other power cables. E.g.
Engine, contactor or solenoid cables
Protection of the sensing face
Sensor mounted on a mobile carrier
Incorrect
Incorrect
Incorrect
Correct
Correct
> 100 mm
The cable should not be pulled
A proximity switch should not serve
as mechanical stop
Any repetitive flexing of the
cable should be avoided
Delivery Contents
Accessories
• Photoelectric switch: PD 112 CNB 25 BP..
• Screwdriver for adjustment: 77-005
• Installation instruction
• Packaging: Cardboard box
• Connector type CONB15NF... series
4
很抱歉,暂时无法提供与“PD112CNB25BP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2267.572021+293.34506
