PA18CAD04NAM1WS
PA18CAD04NAM1WS
    CARLOGAVAZZI
    SENSOR REFLECTIVE 200MM NPN
PA18CAD04NAM1WS 数据手册
CARLO GAVAZZI Au t o m a t i o n C o m p o n e n t s PA18 and PH18 Series - Photoelectric Sensors PA/PH18 Series Compact Photoelectric Sensors This powerful PA/PH18 sensor series, with its cost effective, compact design and robust ABS housing, offers a space saving and easy-to-clean solution for a variety of applications in e.g. material handling, textile and food & beverage industries. Due to their longer sensing distance, their highspeed detection and their improved LED diagnostics, the PA/ PH18 sensors provide an excellent price to performance ratio. Being resistant to high temperatures, high-pressure cleaning, strong cleaning agents and disinfectants, these sensors are especially well suited for reliable detection in harsh environments. The PA/PH18 series is available in a variety of versions: The PA18 comes in an axial or a radial version and the PH18 in a square version. Both PA18 and PH18 are available as diffuse reflective with narrow or wide viewing angle, diffuse reflective with background suppresion, retro-reflective, polarized retro-reflective and through-beam sensors. High Technology A built-in microprocessor guarantees advanced filtering and detection ensuring flexible customized solutions. Easy Adjustment A very precise and linear sensitivity adjustment and use of a manual potentiometer provide accurate and easy setting from close distances to full range. Easy Mounting The PA/PH18 series comes with a new mounting accessory that faci­litates fast and easy mounting. Easy to Clean Due to the smart and simple mounting accessory and the robust design of the sensors, cleaning has become more effi­ cient and easier. High Immunity The PA/PH18 sensors possess a remarkably high immunity to light and electromagnetic distur­b­ances. System maintenance is hereby reduced and the application uptime is increased. Harsh Environments The PA/PH18 sensors have been de­veloped to operate in the harshest conditions. They conform to the standards of ECOLAB, IP67 and IP69K. Approvals CE (EN60947-5-2) cULus (UL508) supply class 2 Food & Beverage: ECOLAB certified CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. Your Benefits LED indication from 3 directions Built-in hexagon for M3 nuts Potentiometer on back part LED indication Laser Printing Potentiometer Straight PA18 Axial 90º angled PA18 Radial PH18 Square PA18: M18 x 40 mm (Axial cable) PA18: M18 x 44 mm (Axial plug) PA18: M18 x 50 mm (Radial cable) PA18: M18 x 54 mm (Radial plug) PH18: 31,5 x 42,8 (Square cable) PH18: 31,5 x 47,3 (Square plug) PH18: 31,5 x 42,8 (Square pig-tail) Manual Potentiometer Clear Robust Laser Printing LED Indication The potentiometer can be left on maximum for plug & play setup, or the sensitivity level can be optimized as circumstances may require. For retro-reflective and through-beam versions this allows detection of semi­trans­parent objects. Mounting Installation of the PA/PH18 sensor is swiftly and easily carried out by means of a new mounting bracket, APA/ APH18-MB1. In addition, this simple accessory results in a smooth and neat finish and a space saving, easy-to-clean appli­ cation. Laser engraving has replaced the sensor label ensuring that the information stays intact after any cleaning process. The sensor functions are easily diagnosed by the dual LED indication in three combinations. IP69K and ECOLAB Built to withstand cleaning with water at 80°C (176°F), high pressure washing up to 100 bar (1,450 psi) and to resist alkaline and acidic cleaning agents, the PA/PH18 sensor series is an excellent solution for ap­plications where harsh cleaning methods are required. CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. Technologically Advanced The PA/PH18 photoelectric sensor is technologically advanced yet small, economical and easy to use without compromising quality and durability NO and NC in One Sensor The PA/PH18 sensors offer the freedom to choose between a normally open and normally closed output. This drastically re­duces demands on storage capacity and stock control. Efficient Lens Design The optimized aspherical lens design re­ sults in a wide sen­sing angle and a much long­er sen­­ sing range. Advanced Microprocessor The built-in microprocessor uses advanced filtering and detection principles which efficiently eliminate false de­tection caused by common light sources, flash beacon lamps or electromagnetic inter­­ference. Furthermore, this microprocessor achieves signifi­ cant­ ly faster de­tec­tion. New background suppression principle The new PA/PH18 background suppression sensor (BGS) is based on a brand-new sensing principle. This considerably increases the sensing distance (200 mm for white and grey objects, 150 mm for black objects) and improves the detection accuracy of different colours, suppressing the background even more efficiently. This revolutionary sensing technology uses an Active Pixel Sensor (APS) CMOS array of 64 x 1 sensors, where each pixel represents a specific position. It takes advantage of the fact that the reflected light hits the APS array at exactly the same position. This way, the object’s mass centre can be found regardless of the energy of the received light. Using this technology, grey, black and white objects are detected at almost exactly the same distance. Furthermore, unlike traditional CCD arrays, the CMOS array benefits from being immune to the blooming effect - not letting the light bleed onto other pixels and disturbing the detection. CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. Background area Object area PA18 and PH18 - specifications Diffuse reflective PA18 and PH18 Axial NPN Radial Cable 2m PNP Through-beam With Polarization filter Background suppression WS PA18CAB20NASA PA18CAD04NAWS PA18CAD10NASA PA18CAR65NASA PA18CAP50NASA PA18CAT20NASA PA18CAT20 - - PA18CRD08NASA PA18CRR50NASA PA18CRP40NASA PA18CRT16NASA PA18CRT16 PH18CNT20 Standard Standard Receiver Emitter Square PH18CNB20NASA - PH18CND10NASA PH18CNR65NASA PH18CNP50NASA PH18CNT20NASA Axial PA18CAB20PASA PA18CAD04PAWS PA18CAD10PASA PA18CAR65PASA PA18CAP50PASA PA18CAT20PASA PA18CAT20 Radial - - PA18CRD08PASA PA18CRR50PASA PA18CRP40PASA PA18CRT16PASA PA18CRT16 Square Axial NPN Radial PH18CNB20PASA - PH18CND10PASA PH18CNR65PASA PH18CNP50PASA PH18CNT20PASA PH18CNT20 PA18CAB20NAM1SA PA18CAD04NAM1WS PA18CAD10NAM1SA PA18CAR65NAM1SA PA18CAP50NAM1SA PA18CAT20NAM1SA PA18CAT20M1 - - PA18CRD08NAM1SA PA18CRR50NAM1SA PA18CRP40NAM1SA PA18CRT16NAM1SA PA18CRT16M1 Square PH18CNB20NAM1SA - PH18CND10NAM1SA PH18CNR65NAM1SA PH18CNP50NAM1SA PH18CNT20NAM1SA PH18CNT20M1 Axial PA18CAB20PAM1SA PA18CAD04PAM1WS PA18CAD10PAM1SA PA18CAR65PAM1SA PA18CAP50PAM1SA PA18CAT20PAM1SA PA18CAT20M1 Radial - - PA18CRD08PAM1SA PA18CRR50PAM1SA PA18CRP40PAM1SA PA18CRT16PAM1SA PA18CRT16M1 Square PH18CNB20PAM1SA - PH18CND10PAM1SA PH18CNR65PAM1SA PH18CNP50PAM1SA PH18CNT20PAM1SA PH18CNT20M1 NPN Square PH18CNB20NAT1SA - PH18CND10NAT1SA PH18CNR65NAT1SA PH18CNP50NAT1SA PH18CNT20NAT1SA PH18CNT20T1 PNP PH18CNB20PAT1SA - PH18CND10PAT1SA PH18CNR65PAT1SA PH18CNP50PAT1SA PH18CNT20PAT1SA PH18CNT20T1 Plug M12 PNP Pigtail M12 Retro-reflective Square Rated operating distance (Sn) Blind Zone Hysteresis (H) Axial 0.2 m Square 0.2 m Axial 0.4 m PA:10 mm PH: 8 mm 0 mm @ Sn max 2 mm @ Sn max Axial 20 m Radial 16 m Square 20 m 50 mm @ Sn max ≤ 10% 0 mm - ≤ 20% Rated operational voltage No load supply current (Io) Axial 1.0 m Axial 6.5 m Axial 5.0 m Radial 0.8 m Radial 5.0 m Radial 4.0 m Square 1.0 m Square 6.5 m Square 5.0 m - 10 to 30 V DC, Ripple included ≤ 20 mA @ Umax ≤ 40 mA @ Umin ≤ 15 mA @ 24 V DC Output ≤ 15 mA @ 24 V DC ≤ 25 mA @ 24 V DC ≤ 25 mA @ 24 V DC NPN or PNP - N.O. and N.C. - ≤ 100 mA (max. Load capacity 100 nF) - Minimum operational current ≤ 0,5 mA - Off-State current (Ir) ≤ 100 μA - Output function Output current (Ie) Voltage drop (Ud) ≤ 2.0 V DC @ 100 mA - Sensor protection Shortcircuit (A), reverse polarity (B) and transients (C) B+C Response time ≤ 1.0 ms Power on delay (tv) Led indications - ≤ 100 ms ≤ 200 ms Output ON (Yellow LED), Signal stability and Power ON (Green LED) Sensitivity control Power ON Adjustable by potentiometer Degree of protection IP67 and IP69K Ambient temperature Operating: -25 to +60°C (-13 to +140°F), Storage: -40 to +70°C (-40 to +158°F ) Ambient light ≤ 30.000 Lux, incandescent lamp CE marking According to EN 60947-5-2 Approvals cULus (UL508) Supply class 2 Installation category III (IEC60664/60664A; 60947-1) Pollution degree Vibration Shock Emitting light source Material Cable Connector Dimensions Weight incl. packaging 3(IEC60664/60664A; 60947-1) 10 to 150 Hz;1.0 mm/15G pr. axis (IEC 60068-2-6) 30g /11 mS. 3 positive and 3 negative pr. axis (IEC 60068-2-6) Red LED Infrared LED Red LED - Infrared LED Body: ABS grey; Front material: PMMA red PVC, grey, 2 m, 4 (2) x 0.25mm2, Ø=4.5 mm ( ) = Emitter 4-pin M12 PA18: M18 x 43.3 mm, PH18:10.8 x 20 x 30 mm PA18: Cable 85 g, Plug 25 g; PH18: Cable 85 g, Plug 25 g, Pigtail 40 g CARLO GAVAZZI Automation Components. Specifications are subject to change without notice. Illustrations are for example only. OUR SALES NETWORK IN EUROPE AUSTRIA - Carlo Gavazzi GmbH Ketzergasse 374, A-1230 Wien Tel: +43 1 888 4112 Fax: +43 1 889 10 53 office@carlogavazzi.at BELGIUM - Carlo Gavazzi NV/SA Mechelsesteenweg 311, B-1800 Vilvoorde Tel: +32 2 257 4120 Fax: +32 2 257 41 25 sales@carlogavazzi.be DENMARK - Carlo Gavazzi Handel A/S Over Hadstenvej 40, DK-8370 Hadsten Tel: +45 89 60 6100 Fax: +45 86 98 15 30 handel@gavazzi.dk FINLAND - Carlo Gavazzi OY AB Petaksentie 2-4, FI-00661 Helsinki Tel: +358 9 756 2000 Fax: +358 9 756 20010 myynti@gavazzi.fi FRANCE - Carlo Gavazzi Sarl Zac de Paris Nord II, 69, rue de la Belle Etoile, F-95956 Roissy CDG Cedex Tel: +33 1 49 38 98 60 Fax: +33 1 48 63 27 43 french.team@carlogavazzi.fr GERMANY - Carlo Gavazzi GmbH Pfnorstr. 10-14 D-64293 Darmstadt Tel: +49 6151 81000 Fax: +49 6151 81 00 40 info@gavazzi.de GREAT BRITAIN - Carlo Gavazzi UK Ltd 7 Springlakes Industrial Estate, Deadbrook Lane, Hants GU12 4UH, GB-Aldershot Tel: +44 1 252 339600 Fax: +44 1 252 326 799 sales@carlogavazzi.co.uk ITALY - Carlo Gavazzi SpA Via Milano 13, I-20020 Lainate Tel: +39 02 931 761 Fax: +39 02 931 763 01 info@gavazziacbu.it NETHERLANDS - Carlo Gavazzi BV Wijkermeerweg 23, NL-1948 NT Beverwijk Tel: +31 251 22 9345 Fax: +31 251 22 60 55 info@carlogavazzi.nl NORWAY - Carlo Gavazzi AS Melkeveien 13, N-3919 Porsgrunn Tel: +47 35 93 0800 Fax: +47 35 93 08 01 post@gavazzi.no PORTUGAL - Carlo Gavazzi Lda Rua dos Jerónimos 38-B, P-1400-212 Lisboa Tel: +351 21 361 7060 Fax: +351 21 362 13 73 carlogavazzi@carlogavazzi.pt SPAIN - Carlo Gavazzi SA Avda. Iparraguirre, 80-82, E-48940 Leioa (Bizkaia) Tel: +34 94 480 4037 Fax: +34 94 480 10 61 gavazzi@gavazzi.es SWEDEN - Carlo Gavazzi AB V:a Kyrkogatan 1, ­S-652 24 Karlstad Tel: +46 54 85 1125 Fax: +46 54 85 11 77 info@carlogavazzi.se SWITZERLAND - Carlo Gavazzi AG Verkauf Schweiz/Vente Suisse Sumpfstrasse 32, CH-6312 Steinhausen Tel: +41 41 747 4535 Fax: +41 41 740 45 40 info@carlogavazzi.ch OUR SALES NETWORK IN NORTH AMERICA USA - Carlo Gavazzi Inc. 750 Hastings Lane, Buffalo Grove, IL 60089 USA, Tel: +1 847 465 6100 Fax: +1 847 465 7373 sales@carlogavazzi.com CANADA - Carlo Gavazzi Inc. 2660 Meadowvale Boulevard, Mississauga, ON L5N 6M6 Canada, Tel: +1 905 542 0979 Fax: +1 905 542 2248 gavazzi@carlogavazzi.com MEXICO - Carlo Gavazzi Mexico S.A. de C.V. Calle La Montaña no. 28, Fracc. Los Pastores Naucalpan de Juárez, EDOMEX CP 53340 Tel & Fax: +52.55.5373.7042 mexicosales@carlogavazzi.com OUR SALES NETWORK IN ASIA AND PACIFIC SINGAPORE - Carlo Gavazzi Automation Singapore Pte. Ltd. 61 Tai Seng Avenue #05-06 UE Print Media Hub Singapore 534167 Tel: +65 67 466 990 Fax: +65 67 461 980 MALAYSIA - Carlo Gavazzi Automation (M) SDN. BHD. D12-06-G, Block D12, Pusat Perdagangan Dana 1, Jalan PJU 1A/46, 47301 Petaling Jaya, Selangor, Malaysia. Tel: +60 3 7842 7299 Fax: +60 3 7842 7399 CHINA - Carlo Gavazzi Automation (China) Co. Ltd. Unit 2308, 23/F., News Building, Block 1,1002 Middle Shennan Zhong Road, Shenzhen, China Tel: +86 755 83699500 Fax: +86 755 83699300 HONG KONG - Carlo Gavazzi Automation Hong Kong Ltd. Unit 3 12/F Crown Industrial Bldg., 106 How Ming St., Kwun Tong, Kowloon, Hong Kong Tel: +852 23041228 Fax: +852 23443689 OUR COMPETENCE CENTRES AND PRODUCTION SITES Carlo Gavazzi Ltd Zejtun - MALTA Carlo Gavazzi Controls SpA Belluno - ITALY Uab Carlo Gavazzi Industri Kaunas Kaunas - LITHUANIA Carlo Gavazzi Automation (Kunshan) Co., Ltd. Kunshan - CHINA Carlo Gavazzi Automation SpA Via Milano, 13 - I-20020 Lainate (MI) - ITALY Tel: +39 02 931 761 info@gavazziautomation.com Printed on 100% recycled paper produced using post consumer de-inked waste. www.gavazziautomation.com BRO PA18/PH18 rev. 01 - 03.2013 HEADQUARTERS Specifications are subject to change without notice. Illustrations are for example only. Carlo Gavazzi Industri A/S Hadsten - DENMARK
PA18CAD04NAM1WS 价格&库存
很抱歉,暂时无法提供与“PA18CAD04NAM1WS”相匹配的价格&库存,您可以联系我们找货
PA18CAD04NAM1WS
  • 1+856.88933
  • 5+813.96628
  • 10+788.28499
  • 25+762.60370
库存:2
