GTB6-P4212
GTB6-P4212
    SICK
    SENSOR 140MM PNP LO/DO M8 BKT
GTB6-P4212 数据手册
Product data sheet GTB6-P4212 G6 MINIATURE PHOTOELECTRIC SENSORS GTB6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. GTB6-P4212 1052442 Included in delivery: BEF-W100-A (1) Other models and accessories www.sick.com/G6 Illustration may differ Detailed technical data Features Device type Photoelectric sensors Functional principle Photoelectric proximity sensor Functional principle detail Background suppression Sensing range max. 5 mm ... 250 mm 1) Sensing range 35 mm ... 140 mm Polarisation filters No Emitted beam Light source PinPoint LED 2) Type of light Visible red light Light spot size (distance) Ø 6 mm (100 mm) Key LED figures Wave length 650 nm Adjustment 1) 2) Mechanical spindle, 5 turns  Object with 90 % reflectance (referred to standard white, DIN 5033).  Average service life: 100,000 h at TU = +25 °C. Safety-related parameters MTTFD 1,886 years DCavg 0 % 2 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-07 22:21:40 Subject to change without notice GTB6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS Electrical data Supply voltage UB 10 V DC ... 30 V DC 1) Ripple ± 10 % 2) Power consumption 30 mA 3) Protection class III Digital output Type PNP Signal voltage PNP HIGH/LOW VS - (≤ 3 V) / approx. 0 V Output current Imax. ≤ 100 mA 4) Response time 24 V, IA max. = 50 mA.  Signal transit time with resistive load.  With light/dark ratio 1:1.  A = VS connections reverse-polarity protected.  B = inputs and output reverse-polarity protected.  D = outputs overcurrent and short-circuit protected. Mechanical data Housing Rectangular Dimensions (W x H x D) 12 mm x 31.5 mm x 21 mm Connection Male connector M8, 4-pin Material Housing Plastic, ABS/PC Front screen Plastic, PMMA Weight 20 g Items supplied Stainless steel mounting bracket (1.4301/304) BEF-W100-A Ambient data Enclosure rating IP67 Ambient operating temperature –25 °C ... +55 °C 1) Ambient temperature, storage –40 °C ... +70 °C UL File No. NRKH.E348498 & NRKH7.E348498 1)  Temperature stability following adjustment +/-10 °C. Classifications ECl@ss 5.0 2021-12-07 22:21:40 | Product data sheet  Subject to change without notice 27270904 PHOTOELECTRIC SENSORS | SICK 3 GTB6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T ECl@ss 5.1.4 27270904 ECl@ss 6.0 27270904 ECl@ss 6.2 27270904 ECl@ss 7.0 27270904 ECl@ss 8.0 27270904 ECl@ss 8.1 27270904 ECl@ss 9.0 27270904 ECl@ss 10.0 27270904 ECl@ss 11.0 27270904 ETIM 5.0 EC002719 ETIM 6.0 EC002719 ETIM 7.0 EC002719 ETIM 8.0 EC002719 UNSPSC 16.0901 39121528 Connection type Connection diagram Cd-066 BN 1 WH 2 BU 3 BK 4 4 + (L+) not connected - (M) Q PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-07 22:21:40 Subject to change without notice GTB6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS Characteristic curve GTB6 % of sensing distance 25 20 6%/90% 15 18%/90% 10 3 2 1 5 90%/90% 0 50 100 150 200 250 300 (1.97) (3.94) (5.91) (7.87) (9.84) (11.81) 0 Distance in mm (inch) ①  Object with 90% remission (based on standard white DIN 5033) ②  Sensing range on gray, 18 % remission ③  Sensing range on black, 6% remission Light spot size GTB6 Ø 5.6 Ø 5.3 (0.22) (0.21) Sensor Ø 6.6 (0.26) 50 150 250 (1.97) (5.91) (9.84) Distance All dimensions in mm (inch) 2021-12-07 22:21:40 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 5 GTB6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS GTB6 5 35 140 7 35 140 10 35 140 0 250 200 100 (3.94) 200 300 (7.87) (11.81) Distance in mm (inch) Sensing range max. Sensing range ①  Object with 90% remission (based on standard white DIN 5033) ②  Sensing range on gray, 18 % remission ③  Sensing range on black, 6% remission Adjustments Adjustment possibility 5 4 + – 7 ④  LED indicator green: Supply voltage active ⑤  LED indicator yellow: Status of received light beam ⑦  Sensitivity control: potentiometer 0.5 (0.02) 4 9.7 (0.38) 6 31.5 (1.24) 11.4 3 (0.12) 5 L D (0.45) 3 28.5 (1.12) 3 25.4 (1.00) 7.6 1 2 21 (0.83) (0.30) 0.5 (0.02) Dimensional drawing (Dimensions in mm (inch)) 9.7 H I J K L M N O P Q R S T Sensing range diagram (0.38) A B C D E F 18.3 12 (0.72) (0.47) ①  Optical axis, receiver ②  Optical axis, sender ③  Mounting holes M3 ④  LED indicator green: Supply voltage active ⑤  LED indicator yellow: Status of received light beam ⑥  Light/ dark rotary switch: L = light switching, D = dark switching 6 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-12-07 22:21:40 Subject to change without notice GTB6-P4212 | G6 MINIATURE PHOTOELECTRIC SENSORS Recommended accessories Other models and accessories www.sick.com/G6 Brief description Type Part no. BEF-WN-G6 2062909 YF8U14050VA3XLEAX 2095889 STE-0804-G 6037323 Mounting brackets and plates Stainless steel (1.4301) Plug connectors and cables Head A: female connector, M8, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M8, 4-pin, straight Head B: Cable: unshielded 2021-12-07 22:21:40 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
GTB6-P4212
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
GTB6-P4212 价格&库存
很抱歉,暂时无法提供与“GTB6-P4212”相匹配的价格&库存,您可以联系我们找货
