VS18-M-LAS/76A/118
VS18-M-LAS/76A/118
    PEPPERL+FUCHS(倍加福)
    THRU BEAM EMITTER 0-60M
VS18-M-LAS/76A/118 数据手册
Thru-beam sensor VS18/VSE18-M-LAS/32/40a/76a/82 < < < < < < M18 threaded housing made of brass, nickel plated Detection of very small parts in the near range Visible red light, pulsed LASER light Focusable optical system Array control panel with highly visible LED display Flashing power on LED in case of short-circuit Laser thru-beam sensor Safety Information Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 800199_eng.pdf Laser Class 1 Information The irradiation can lead to irritation especially in a dark environment. Do not point at people! Maintenance and repairs should only be carried out by authorized service personnel! Attach the device so that the warning is clearly visible and readable. The warning accompanies the device and should be attached in immediate proximity to the device. Caution – Use of controls or adjustments or performance of procedures other than those specified herein may result in hazardous radiation exposure. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Thru-beam sensor VS18/VSE18-M-LAS/32/40a/76a/82 Dimensions Receiver Transmitter Focus adjustment M18 x 1 24 M18 x 1 M12 x 1 4 9 M12 x 1 4 24 2 2.3 42.8 43.8 43.6 44.6 47.1 64 77 53.9 65 78 Technical Data System components Emitter VS18-M-LAS/76a/118 Receiver VSE18-M-LAS/32/40a/82b/118 Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 800199_eng.pdf General specifications Effective detection range 0 ... 60 m Threshold detection range 85 m Light source laser diode Light type modulated visible red light Laser nominal ratings Note LASER LIGHT , DO NOT STARE INTO BEAM Laser class 1 Wave length 655 nm Beam divergence 11.7 mrad Pulse length 2 µs Repetition rate 50 kHz max. pulse energy 2.55 nJ Diameter of the light spot 100 mm x 100 mm at a distance of 85 m Angle of divergence adjustable focal point Optical face frontal Ambient light limit Hysteresis 30000 Lux H < 15 % Functional safety related parameters Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Thru-beam sensor VS18/VSE18-M-LAS/32/40a/76a/82 Technical Data MTTFd 520 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 90 % Indicators/operating means Operation indicator LED green, flashes in case of short-circuit Function indicator LED yellow, light with free light beam , flashes when falling short of the stability control , OFF when light beam is interrupted (in receiver) Control elements Sensitivity adjuster, light/dark switch (receiver) Electrical specifications Operating voltage UB 10 ... 30 V DC , class 2 No-load supply current I0 Emitter: 20 mA , Receiver: 15 mA Protection class II , rated voltage ≤ 50 V AC with pollution degree 1-2 according to IEC 60664-1 Input Test input emitter deactivation at +UB Output Pre-fault indication output 1 PNP, inactive when falling short of the stability control , max. 100 mA Switching type light/dark on, switchable Signal output 1 PNP output, short-circuit protected, reverse polarity protected, open collector Switching voltage 30 V DC Switching current max. 200 mA Voltage drop Ud ≤ 2.5 V DC Switching frequency f 5000 Hz Response time 100 µs Conformity Product standard EN 60947-5-2 Compliance with standards and directives Standard conformity Laser class IEC 60825-1:2007 Complies with 21 CFR 1040.10 and 1040.11 except for deviations pursuant to Laser Notice No. 50, dated June 24, 2007 Approvals and certificates UL approval cULus Listed, Type 1 enclosure CCC approval CCC approval / marking not required for products rated ≤36 V Ambient conditions Ambient temperature -25 ... 55 °C (-13 ... 131 °F) Storage temperature -30 ... 70 °C (-22 ... 158 °F) Shock resistance b < 30 g, T < 11 ms Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 800199_eng.pdf Mechanical specifications Degree of protection IP67 Connection 4-pin, M12 x 1 connector Material Housing brass, nickel-plated Optical face plastic Mass 60 g (device) Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Thru-beam sensor VS18/VSE18-M-LAS/32/40a/76a/82 Connection Assignment Option: 1 /32/82b /76a +UB Test 2 I/O Alarm 3 0V 4 Q = Light on = Dark on Connection Assignment 1 4 2 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) 2 1 3 4 L 1 Light/dark switch 2 Operating display green 3 Switch state yellow 4 Sensitivity adjustment D Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 800199_eng.pdf Assembly SENS. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4 Thru-beam sensor VS18/VSE18-M-LAS/32/40a/76a/82 Object detection Minimum object size [µm] (stability control = 1) 250 200 150 100 50 0 0 100 200 300 400 500 600 700 Z 800 X [mm] Z = 0.5 m Z = 1.0 m Z = 1.5 m X Accessories Mounting Bracket with swivel nut BF 18 Mounting flange, 18 mm BF 18-F Plastic mounting adapter, 18 mm BF 5-30 Universal mounting bracket for cylindrical sensors with a diameter of 5 ... 30 mm V1-G-2M-PUR Female cordset single-ended M12 straight A-coded, 4-pin, PUR cable grey V1-W-2M-PUR Female cordset single-ended M12 angled A-coded, 4-pin, PUR cable grey Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 800199_eng.pdf OMH-VL18 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 5 Thru-beam sensor VS18/VSE18-M-LAS/32/40a/76a/82 Adjustment Release date: 2021-09-29 Date of issue: 2021-09-29 Filename: 800199_eng.pdf Small object detection The focal point of the emitter can be adjusted. Very small objects are best detected at the focal point (place of smallest spot size). Whether a small object can be detected or not depends on the emitter/receiver as well as on the emitter/object distance. Please see the coresponding curves enclosed. For long distance application, you have to avoid a short focal plane setting. The maximum light spot diameter at the receivers location must not exceed 100 mm for reliable detection with 2-fold function reserve. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 6
VS18-M-LAS/76A/118 价格&库存
很抱歉,暂时无法提供与“VS18-M-LAS/76A/118”相匹配的价格&库存,您可以联系我们找货
