PH18CNT20PASA
PH18CNT20PASA
    CARLOGAVAZZI
    SENSOR THROUGH-BEAM 20M PNP
PH18CNT20PASA 数据手册
Photoelectrics Through-beam Type PH18CNT..., DC • Miniature sensor range • Range: 20 m • Sensitivity adjustment by potentiometer • Modulated, infrared light 850 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP, N.O + N.C. • Degree of protection IP67, IP69K • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable, plug and pigtail versions • Excellent EMC performance Product Description Ordering Key The PH18CNT... is part of a family of inexpensive general purpose through-beam sensors in industrial standard 18 mm cylindrical and square ABS housing. The sensors are useful in applications where high-accuracy detection as well as small size is required. Type Housing style square Housing size Housing material Housing type neutral Detection principle Sensing distance Output type Output configuration Connection type Sensitive adjustment Compact housing and high power LED for excellent performance-size ratio. The potentiometer used for adjustment of the sensitivity makes the sensors highly flexible. The output type is NPN or PNP and the output switching function is NO and NC. PH18CNT20PAM1SA Type Selection Housing type Range Connec- Ordering no. Sn tion Emitter M18 Square type M18 Square type M18 Square type 20 m 20 m 20 m Cable PH 18 CNT 20 PH 18 CNT 20 NASA Plug PH 18 CNT 20M1 PH 18 CNT 20 NAM1SA Pigtail M12 PH 18 CNT 20T1 PH 18 CNT 20 NAT1SA Specifications Receiver Rated operating distance (Sn) Blind zone Sensitivity control Electrical adjustment Mecanical adjustment Adjustable distance to target Temperature drift Hysteresis (H) (differential travel) Rated operational volt. (UB ) Ripple (Urpp ) Output current Continuous (Ie) Short-time (I) No load supply current (Io) Minimum operational current (Im) Ordering no. Receiver NPN Make or break switching Ordering no. Receiver PNP Make or break switching PH 18 CNT 20 PASA PH 18 CNT 20 PAM1SA PH 18 CNT 20 PAT1SA according to EN60947-5-2 Up to 20 m 0 mm Adjustable by potentiometer 210˚ 240˚ 1 - 20 m ≤ 0.2%/ºC ≤ 20% 10 to 30 VDC (ripple included) ≤ 10% ≤ 100 mA ≤ 100 mA (max. load capacity 100 nF) ≤ 15 mA @ 24 VDC 0.5 mA Specifications are subject to change without notice (09.06.2017) OFF-state current (Ir ) ≤ 100 µA Voltage drop (Ud ) ≤ 2.0 VDC @ 100 mA Protection Short-circuit, reverse polarity and transients Sensing angle ± 4º Ambient light 30.000 lux Incandescent lamp Operating frequency 500 Hz Response time OFF-ON (tON) ≤ 1.0 ms ON-OFF (tOFF ) ≤ 1.0 ms Power ON delay (tv) ≤ 200 ms Output function Type NPN or PNP Switching function NO and NC Indication Output ON LED, yellow Signal stability and power ON LED, green 1 PH18CNT... Specifications Emitter Rated operational volt. (UB ) Ripple (Urpp ) Supply current (Io) Light source Light type Sensing angle according to EN60947-5-2 10 to 30 VDC (ripple included) ≤ 10% ≤ 25 mA @ 24 VDC LED, 850 nm Infrared, modulated ± 4º Specifications Common Environment Installation category Pollution degree Degree of protection Ambient temperature Operating Storage Vibration Shock Rated insulation voltage Housing material Body Backpart Front material Light spot Diameter Ø 1500 mm @ 10 m Protection Reverse polarity and transients Indication function Power supply ON LED, green Signal stability and power ON LED, green Power on delay < 200 ms according to EN60947-5-2 III (IEC 60664/60664A; 60947-1) 3 (IEC 60664/60664A; 60947-1) IP 67, IP 69K* -25° to +60°C -40° to +70°C 10 to 150 Hz, 1.0 mm/15 g (IEC 60068-2-6) 30 g / 11ms, 3 pos, 3 neg per axis (IEC 60068-2-6, 60068-2-32) 500 VAC (rms) IEC protection class III ABS, grey PC-Transparent PMMA, red Cable gland POM, Black Trimmer shaft POM, Dark Grey Locknuts PP, black Mounting bracket PPA, black Connection Cable PVC, grey, 2 m Receiver 4 x 0.25 mm2, Ø = 4.5 mm Emitter 2 x 0.25 mm2, Ø = 4.5 mm Plug M12, 4-pin (CONB14NF-series) Pigtail PUR, grey, 30 cm 4 x 0.25 mm2, Ø = 4.5 mm M12, 4-pin (CONB14NF-series) Weight With cable: 85 g With Pigtail: 40 g With plug:  25 g CE-marking Yes Approvals cULus (UL508) supply class 2 * The IP69K test according to DIN 40050-9 for high-pressure, high-temperature wash-down applications. The sensor must not only be dust tight (IP6X), but also able to withstand high-pressure and steam cleaning. The sensor is exposed to high pressure water from a spray nozzle that is fed with 80°C water at 8’000– 10’000 KPa (80–100bar) and a flow rate of 14–6L/min. The nozzle is held 100 –150 mm from the sensor at angles of 0°, 30°, 60° and 90° for 30s each. The test device sits on a turntable that rotates with a speed of 5 times per minute. The sensor must not suffer any damaging effects from the high pressure water in appearance and function. 90° 60° 30° 0° Operation Diagram Operation Diagram tv = Power ON delay Power Power supply supply ON ON OFF OFF Target Target (emitter) (emitter) Present Present Not present Not Present Object Object Present Present Not present Not Present Break Break Output Output (N.C.) (N.C.) ON ON OFF OFF Make Make Output Output (N.O.) (N.O.) ON ON OFF OFF 2 Tv Tv Specifications are subject to change without notice (09.06.2017) PH18CNT... Wiring Diagrams Receiver NPN PNP V 1 BN V 1 BN 4 BK 2 WH 2 WH 4 BK 3 BU 3 BU V GND V GND Emitter V 1 BN 3 BU V GND Detection Diagram Excess Gain Emitter Y 0,0 16,4 (feet) (feet) 32,8 49,2 65,6 82,0 5,9 100 3,9 50 2,0 0 0,0 (mm) 150 0,0 -50 -2,0 -100 -3,9 -150 -5,9 0,0 5,0 10,0 15,0 20,0 16,4 32,8 49,2 65,6 82,0 10 15 20 25 1.000 25,0 Excess Gain Receiver (inch) X 100 10 1 0 5 Distance (m) Distance (m) Signal Stability Indication APH18-MB1 Excess Gain Excess Gain Operation Operation level level × x 1.1 1.1 1.0 0,9 0.9 Operation Operation level level Operation Operation level level × x 0.9 0.9 Ø 27 1.1 Time Time 6.5 Green Green LED LED ON ON Ø 27 6.5 Yellow LED LED ON ON Yellow Specifications are subject to change without notice (09.06.2017) 3 PH18CNT... Mounting Systems PH18 mounting with a combination of 1 x APH18-MB1 and 1 x M18 locknut. Maximum torque 0.9 NM m m m 0 1. .5 m in. x. 4 M a M M18 Locknut APH18-MB1 Dimensions Cable/Pigtail version 31.5 17.5 Operation Indicator (Yellow) Pigtail M12 Power and Stability Indicator (Green) 1 5.45 3.4 15 Power and Stability Indicator (Green) 1.5 10.5 Sensitivity Control 240° 35 24.1 M18 x 1 11 3 2 4 3 Receiver or Emitter 6.3 Optical Axis Ø 9.9 Ø 4.5 Plug version 31.5 15 Operation Indicator (Yellow) Power and Stability Indicator (Green) 1 11 35 M18 x 1 1.5 3.4 3 Power and Stability Indicator (Green) 5.45 17.5 24.1 10.5 Sensitivity Control 240° 2 4 3 Receiver or Emitter 10.8 Optical Axis M12 x 1 plug 4 Specifications are subject to change without notice (09.06.2017) Installation Hints To avoid interference from inductive voltage / Relief of the cable strain current peaks, separate the proximity switch cables from any other power cables. E.g. Engine, contactor or solenoid cables Protection of the sensing face Sensor mounted on a mobile carrier Incorrect Incorrect Incorrect Correct Correct > 100 mm The cable should not be pulled A proximity switch should not serve as mechanical stop Any repetitive flexing of the cable should be avoided Delivery Contents Accessories • Photoelectric switch: PH 18 CNT... • Installation instruction on plastic bag • Screwdriver • Mounting bracket APH18-MB1 • 1 M18 locknuts • Packaging: Plastic bag • Emitter and receiver is packed separately • Connector type CONG1A.. / CONB14NF.. series Specifications are subject to change without notice (09.06.2017) 5
PH18CNT20PASA 价格&库存
很抱歉,暂时无法提供与“PH18CNT20PASA”相匹配的价格&库存,您可以联系我们找货
PH18CNT20PASA
  • 1+523.789301+65.70950
  • 5+488.839985+61.32510
  • 10+459.3852810+57.63000
PH18CNT20PASA
库存:5000
