QCM50 Color Sensor
Datasheet
High-performance color sensor with IO-Link
Reliable color detection across the entire range of the sensor
Up to 12 colors can be detected with one sensor, which saves inventory costs and enables
faster changeover
Available in anti-glare models to reliably detect reflective targets
Intuitive configuration with integrated digital display and on-board buttons
IO-Link communication for remote configuration and monitoring
WARNING:
• Do not use this device for personnel protection
• Using this device for personnel protection could result in serious injury or
death.
• This device does not include the self-checking redundant circuitry
necessary to allow its use in personnel safety applications. A device
failure or malfunction can cause either an energized (on) or de-energized
(off) output condition.
Models
Feature
Range (mm)
Spot Size
(mm)
Outputs 1
Stored
Colors
Glare suppression
18 to 32
6 × 6 at 25 mm
3 Discrete
7
Integral 5-pin M12/Euro-style quick disconnect
4 × 4 at 40 mm
1 Discrete
1
Integral 4-pin M12/Euro-style quick disconnect
4 × 4 at 40 mm
3 Discrete
7
QCM50-K5D40-Q8-8
4 × 4 at 40 mm
5 Discrete
12
Integral 8-pin M12/Euro-style quick disconnect
QCM50-K1D60-Q8-4
8 × 8 at 60 mm
1 Discrete
1
8 × 8 at 60 mm
3 Discrete
7
8 × 8 at 60 mm
5 Discrete
12
Models
QCM50-K3D25-Q8-5 2
QCM50-K1D40-Q8-4
QCM50-K3D40-Q8-5
Small spot size
QCM50-K3D60-Q8-5
18 to 60
Long range
20 to 150
QCM50-K5D60-Q8-8
Connection
Wiring Diagrams
4 bk
5 gy
Q2 / Trig
Q1 / IO-Link
Q3
Auto
Detect
3 bu
2 wh
4 bk
5 gy
6 pk
7 vt
Q2 / Trig
Q1 / IO-Link
NPN
2 wh
1 bn
Auto
Detect
Load
3 bu
NPN
NPN
PNP
Trig
Q1 / IO-Link
Auto
Detect
Load
4 bk
Load
2 wh
Load
3 bu
1 bn
PNP
Load
1 bn
PNP
Load
Q5
Q3
Q4 / Lock
8 og
The QCM50 Color Sensor requires a shielded cable. Refer to the Accessories list in the QCM50 Color Sensor Instruction Manual
(p/n 209633) for a list of recommended cables.
1 PNP/NPN Auto-Detect based on output connection.
2 Polarized optics (anti-glare). Not for use with black objects.
Original Document
209634 Rev. A (068-14865)
15 April 2019
209634
QCM50 Color Sensor
Menu System
The following functions are available using the sensor's menu system.
Teaching the Sensor
Sub-Menu
Options
Description
Navigate
Color
The output is only active when the sensor sees a target color that matches a
taught color.
Menu > Sensor Mode > Color
Best Fit
The output that matches the target color best is active (at least two colors must
be taught to use this mode). One output will always be active when a color
target is present in this mode. (Not available on 1 output models.)
Menu > Sensor Mode > Best Fit
Color
The sensor is taught a single static color point.
Menu > Teach Q/C > Color
Color Scan
The sensor is taught a color space. The sensor will learn multiple color points
until Stop is pressed.
Menu > Teach Q/C > Color Scan
Sensor mode
Teach
Methods
The tolerance adjustment populates after teaching in Color Mode.
Tolerance
Adjustable 1 to 9
The tolerance adjustment can also be accessed any time through the menu
system after a Color Mode teach has been completed.
Menu > Config Q > Tolerance
Higher tolerance number results in more color variations accepted (Tolerance
levels range from 1-9). Tolerance is not available when using Best Fit Mode.
Output Configuration and Sensor Settings
Sub-Menu
Description
Navigate
Smart Functions
The Smart Functions menu options set the delays and timers. On/Off Delays can be
programmed between 0 to 100 ms.
Menu > Config Q > SmartFunc
Turn off Impulse if a one-shot is needed.
Outputs
Program the outputs individually to be normally open or normally closed.
Menu > Config Q > NO/NC
Program the outputs as a group to be normally open or normally closed, to be PNP or
NPN, and to define the output speed.
Menu > Config Q All
PNP/NPN and speed are not configurable on an individual output.
Sensor Settings
Restores the sensor to factory default settings.
Menu > Settings > Factory Reset
Specifications
Supply Voltage and Current
18 to 30 V dc
Less than 60 mA, exclusive of load
Supply Protective Circuitry
Reverse polarity protection UB / short-circuit
protection (Q)
Power On Delay
< 150 ms
Warm-up Time
5 minutes
Vibration and Mechanical Shock
EN 60947-5-2
Certifications
Light Used
LED, white
Response Time Q
180 μs
LED class
LED risk group 2
(EN 62471:2008)
Maximum Capacitive Load
< 100 nF
Control Input
Trigger; keylock
Construction
Materials: Zinc die-cast, matt chrome housing;
PMMA front screen and display
Indicators
LED 1 (amber): output indicator
LED 2 (green): power indicator, IO-Link
LED 2 (red): status/error indicator
3
2
IO-Link
Communication mode: COM 2
Minimum cycle time: 4 ms
SIO mode: Compatible
Length of process data: 2 bytes / 6 bytes
Specification: 1.1
Output Ratings
N.O. / N.C.
Output current, Ie: < 100 mA
Switching output (Q): Auto-detect (Q1)1 / NPN /
PNP
Environmental Conditions
Operating: –20 °C to +55 °C (–4 °F to +131°F)
Storage: –20 °C to +80 °C (–4 °F to +176 °F)
Environmental Rating3
IEC IP67, IEC IP69
With connected IP 67 / IP 69 plug
www.bannerengineering.com - Tel: + 1 888 373 6767
P/N 209634 Rev. A (068-14865)
QCM50 Color Sensor
Required Overcurrent Protection
WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes
and regulations.
Overcurrent protection is required to be provided by end product application per the supplied table.
Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply.
Supply wiring leads < 24 AWG shall not be spliced.
For additional product support, go to www.bannerengineering.com.
Supply Wiring (AWG)
Required Overcurrent Protection (Amps)
22
3.0
24
2.0
26
1.0
28
0.8
30
0.5
Dimensions
50
4.3
46
44
16
Emitter
16.4
Receiver
4
16.97
11.6
50.5
25
M12 x 1
All measurements are listed in millimeters, unless noted otherwise.
Banner Engineering Corp. Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or
replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not
cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO
BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES
RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT,
STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously
manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the
product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will
void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at
any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to:
For patent information, see www.bannerengineering.com/patents.
© Banner Engineering Corp. All rights reserved
很抱歉,暂时无法提供与“QCM50-K3D25-Q8-5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10048.825291+1299.58634
