Q45VR3LP W/30
Q45VR3LP W/30
    BANNER(邦纳)
    Q45VR3LP W/30 12-250DC/ 24-250AC
Q45VR3LP W/30 数据手册
Q45VR3 Series Sensors Universal voltage photoelectric sensors with electromechanical relay output Q45VR3 Series Features • Advanced one-piece photoelectric sensors with outstanding optical performance and extremely rugged design • Universal supply voltage: 12 to 250V dc or 24 to 250V ac • Electromechanical relay for economical, high-capacity switching and immunity to electrical noise • Full line includes opposed, diffuse, retroreflective, convergent, and glass and plastic fiber optic sensing modes • Switchable light/dark operate • Versatile plug-in modules available for output timing logic and/or signal strength display • Highly visible Power, Signal (AID™ System), and Output indicator LEDs • Choice of prewired 2 m (6.5') or 9 m (30') unterminated cable or Mini-style quick-disconnect fitting • Versatile mounting options • Designed to withstand 1200 psi washdown; exceeds its NEMA 6P and IEC IP67 rating Because of their extremely high excess gain, these opposed-mode sensors are an excellent option for sensing in contaminated or dirty areas, and are also the best choice for long-range sensing. Infrared, 880 nm Q45VR3 Series Opposed-Mode Emitter (E) and Receiver (R) Models Models Range Cable* Supply Voltage Output Type Excess Gain Beam Pattern Effective Beam: 13 mm Q453E Emitter 2-wire 2m (6.5') Q45VR3R Receiver 5-wire 2m (6.5') 60 m (200') Q453EQ Emitter Q45VR3RQ Receiver 3-Pin Ministyle QD 1000 Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay E X C E S S G A I N Q45E/R 100 1.5 m 60 in Opposed Mode 1.0 m 40 in 0.5 m 20 in 0 10 0 0.5 m 20 in 1.0 m 40 in 1.5 m 60 in 0 1 0.1 m 0.33 ft 5-Pin Ministyle QD Q45E/R Opposed Mode 1.0 m 3.3 ft 10 m 33 ft 100 m 330 ft 12 m 40 ft 24 m 80 ft 36 m 120 ft 48 m 160 ft 60 m 200 ft DISTANCE DISTANCE * 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., Q453E W/30) A model with a QD connector requires a mating cable; see page 10. IMPORTANT: SEE SAFETY USE WARNING ON BACK PAGE Printed in USA 12/12 P/N 53997 rev. C Q45VR3 Series The visible red sensing beam of these sensors makes them very easy to align. Model Q45VR3LP polarizes the emitted light and filters out unwanted reflections, making sensing possible in applications otherwise considered unsuited to retroreflective sensing performance. Specified using the model BRT-3 3" reflector (see the Accessories section of your current Banner Photoelectric Sensors catalog for further information). P Visible red, 680 nm Non-Polarized Polarized Q45VR3 Series Retroreflective-Mode Models Models Range Cable* Supply Voltage Output Type Excess Gain Beam Pattern Non-Polarized 1000 Q45LV Q45VR3LV Q45VR3LVQ 0.08 to 9 m (3" to 30') 5-wire 2 m (6.5') 5-Pin Mini-style QD Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay E X C E S S Retroreflective Mode 100 Q45LV 75 mm 2.0 in 25 mm 1.0 in 0 G A I N 3.0 in Retroreflective Mode 50 mm With BRT-3 Reflector 1 .01 m .033 ft .10 m .33 ft 1.0 m 3.3 ft 0 With BRT-3 Reflector 10 25 mm 1.0 in 50 mm 2.0 in 75 mm 10 m 33 ft 3.0 in 0 3m 10 ft DISTANCE 6m 20 ft 9m 30 ft 12 m 40 ft 15 m 50 ft DISTANCE Polarized 1000 Q45LP Q45VR3LP Q45VR3LPQ 0.15 to 6 m (6" to 20') 5-wire 2 m (6.5') 5-Pin Mini-style QD Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay E X C E S S Retroreflective Mode 100 Q45LP 75 mm Retroreflective Mode 50 mm 25 mm G A I N With BRT-3 Reflector 1 .01 m .033 ft .10 m .33 ft 1.0 m 3.3 ft DISTANCE 10 m 33 ft 0 With BRT-3 Reflector 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 0 1.5 m 5 ft 3m 10 ft 4.5 m 15 ft 6m 20 ft DISTANCE * 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., Q45VR3LV W/30) A model with a QD connector requires a mating cable; see page 10. page 2 2.0 in 1.0 in 0 10 3.0 in Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 7.5 m 25 ft Q45VR3 Series Infrared, 880 nm These diffuse-mode models detect objects by sensing the reflection of their own emitted light. Ideal for use when the reflectivity and profile of the object to be sensed are sufficient to return a large percentage of emitted light back to the sensor. Model Q45VR3DX is the first choice for diffuse-mode applications when there are no background objects to falsely return light. Q45VR3 Series Diffuse-Mode Models Models Range Cable* Supply Voltage Output Type Excess Gain Beam Pattern Performance based on 90% reflectance white test card Short Range 1000 Q45VR3D Q45VR3DQ 45 cm (18") 5-wire 2 m (6.5') 5-Pin Mini-style QD Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay Q45D E X C E S S 15 mm Diffuse Mode 0.6 in Q45D 10 mm 100 0.4 in Diffuse Mode 5 mm 0.2 in 0 10 G A I N 0 5 mm 0.2 in 10 mm 0.4 in 15 mm 1 1.0 mm 0.04 in 0.6 in 0 10 mm 0.4 in 100 mm 4.0 in 100 mm 200mm 300 mm 400 mm 500 mm 4.0 in 8.0 in 12.0 in 16.0 in 20.0 in 1000 mm 40 in DISTANCE DISTANCE Long Range 1000 Q45DL Q45VR3DL Q45VR3DLQ 1. 8 m (6') 5-wire 2 m (6.5') 5-Pin Mini-style QD Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay E X C E S S G A I N Q45DL Diffuse Mode 75 mm Diffuse Mode 100 3.0 in 50 mm 2.0 in 25 mm 1.0 in 0 10 1 .01 m .033 ft 0 25 mm 1.0 in 50 mm 2.0 in 75 mm 3.0 in 0 .10 m .33 ft 1.0 m 3.3 ft 10 m 33 ft 0.6 m 2 ft 1.2 m 4 ft 1.8 m 6 ft 2.4 m 8 ft 3.0 m 10 ft DISTANCE DISTANCE High Power 1000 Q45VR3DX Q45VR3DXQ 3m (10') 5-wire 2 m (6.5') 5-Pin Mini-style QD Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay E X C E S S G A I N Q45DX Diffuse Mode 3.0 in Diffuse Mode 50 mm 2.0 in 25 mm 1.0 in 0 10 0 25 mm 1.0 in 50 mm 2.0 in 75 mm 1 0.01 m 0.033 ft 3.0 in 0 0.1 m 0.33 ft 1.0 m 3.3 ft DISTANCE Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Q45DX 75 mm 100 10 m 33 ft 0.6 m 2 ft 1.2 m 4 ft 1.8 m 6 ft 2.4 m 8 ft 3.0 m 10 ft DISTANCE page 3 Q45VR3 Series These sensors are ideal for reflective sensing of very small parts or profiles, and can accurately sense the position of parts approaching from the side. Will ignore all but highly reflective objects that are outside the sensing range. Visible red, 680 nm Q45VR3 Series Convergent-Mode Models Models Focus Cable* Supply Voltage Output Type Excess Gain Beam Pattern Performance based on 90% reflectance white test card 1000 Q45VR3CV Q45VR3CVQ 38 mm (1.5") Spot Size at Focus: 1.3 mm (0.05") 5-wire 2 m (6.5') 5-Pin Mini-style QD Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay E X C E S S G A I N Q45CV Convergent Mode 100 Q45CV 3.8 mm Convergent Mode 2.5 mm 1.2 mm 1 1 mm .04 in 0 1.2 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 0.15 in 0 10 mm .4 in 100 mm 4 in 0.10 in 0.05 in 0 10 0.15 in 1000 mm 40 in 38 mm 1.5 in 75 mm 113 mm 150 mm 190 mm 3.0 in 4.5 in 6.0 in 7.5 in DISTANCE DISTANCE 1000 Q45VR3CV4 Q45VR3CV4Q 100 mm (4") Spot Size at Focus: 1.5 mm (0.06") 5-wire 2 m (6.5') 5-Pin Mini-style QD Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay E X C E S S Q45CV4 Convergent Mode Q45CV4 3.8 mm 100 Convergent Mode 2.5 mm 1.2 mm 10 0 1.2 mm 0.05 in 2.5 mm 0.10 in 3.8 mm 1 1 mm .04 in 10 mm .4 in 100 mm 4 in DISTANCE 1000 mm 40 in 0.15 in 0 38 mm 1.5 in 75 mm 113 mm 150 mm 190 mm 3.0 in 4.5 in 6.0 in 7.5 in DISTANCE * 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., Q45VR3CV W/30) A model with a QD connector requires a mating cable; see page 10. page 4 0.10 in 0.05 in 0 G A I N 0.15 in Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Q45VR3 Series Infrared, 880 nm and Visible Red, 650 nm These models are an excellent choice for glass fiber optic applications where faster sensor response is not important. Their high excess gain means that opposed individual fibers can operate reliably in many very hostile environments. Also, special miniature bifurcated fiber optic assemblies with bundle sizes as small as 0.5 mm (.020") dia. may be used successfully for diffuse-mode sensing when using sensor model Q45VR3F(Q). For more information on compatible glass fiber optics, refer to your current Banner Photoelectric Sensors catalog. Q45VR3 Series Glass Fiber-Optic Models Models Range Supply Voltage Cable* Output Type Excess Gain Diffuse mode performance based on 90% reflectance white test card Infrared, 880 nm 1000 E X C E S S G A I N Q45VR3F Q45VR3FQ Range varies by sensing mode and fiber optics used 5-wire 2 m (6.5') 5-Pin Mini-style QD Beam Pattern Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay Q45F Q45F 150 mm Opposed Mode 100 IT23S Fibers 50 mm 0 IT23S fibers 10 IT13S fibers 0 50 mm 2.0 in 100 mm 4.0 in 150 mm 0.1 m 0.33 ft 1.0 m 3.3 ft 4.0 in 2.0 in IT13S Fibers 6.0 in 0 1 0.01 m 0.03 ft 6.0 in Opposed Mode 100 mm 0.4 m 15 in 0.8 m 30 in 10 m 33 ft 1.2 m 45 in 1.6 m 60 in 2.0 m 75 in DISTANCE DISTANCE 1000 E X C E S S G A I N Q45F Diffuse Mode Q45F BP Q45F opp.eps 0.15 in Diffuse Mode 0.10 in 3.8 mm 2.5 mm 100 BT13S Fiber 1.3 mm 0.05 in BT23S Fiber 0 BT23S Fiber 10 BT13S Fiber 1 1 mm 0.04 in 0.05 in 2.5 mm 0.10 in 3.8 mm 0.15 in 0 10 mm 0.4 in 100 mm 4.0 in 0 1.3 mm 25 mm 1 in 1000 mm 40 in 50 mm 2 in 75 mm 100 mm 125 mm 3 in 4 in 5 in DISTANCE DISTANCE Visible Red, 650 nm 1000 E X C E S S Q45FV Q45FV 30 mm Opposed Mode 100 Q45VR3FV Q45VR3FVQ Range varies by sensing mode and fiber optics used 5-wire 2 m (6.5') 10 mm 0.4 in 0 IT23S fibers 5-Pin Mini-style QD 10 0 SPDT Electromechanical Relay 0.8 in 30 mm 1.2 in 0 10 mm 0.4 in 100 mm 4 in 100 mm 150 mm 200 mm 250 mm 300 mm 4 in 6 in 8 in 10 in 12 in 1000 mm 40 in DISTANCE DISTANCE 1000 E X C E S S G A I N Q45FV Diffuse Mode Q45FV 3.0 mm 1.0 mm 0 1.0 mm BT13S Fiber 0.04 in BT23S Fiber 2.0 mm 0.12 in 0 10 mm 0.4 in 100 mm 4.0 in DISTANCE 0.08 in 3.0 mm BT23S Fiber 1000 mm 40 in 0.08 in 0.04 in BT13S Fiber 0 10 0.12 in Diffuse Mode 2.0 mm 100 1 1 mm 0.04 in Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 0.4 in IT13S Fibers 20 mm IT13S fibers 1 1.0 mm 0.04 in Universal 12 - 250V dc or 24 - 250V ac 0.8 in IT23S Fibers 10 mm G A I N 1.2 in Opposed Mode 20 mm 5 mm 0.2 in 10 mm 0.4 in 15 mm 0.6 in 20 mm 0.8 in 25 mm 1.0 in DISTANCE page 5 Q45VR3 Series Lower in cost than glass fiber optics, plastic fiber optics are ideal for use in situations where environmental conditions allow (for example, low levels of acids, alkalis, and solvents). Most are easily cut to length in the field, and are available in a variety of sensing end styles. For more information on compatible plastic fiber optics, refer to your current Banner Photoelectric Sensors catalog. Visible red, 660 nm Q45VR3 Series Plastic Fiber-Optic Models Models Range Cable* Supply Voltage Output Type Excess Gain Beam Pattern Diffuse mode performance based on 90% reflectance white test card 1000 E X C E S S Q45FP 100 Q45VR3FP Q45VR3FPQ Range varies by sensing mode and fiber optics used 5-wire 2 m (6.5') 5-Pin Mini-style QD Universal 12 - 250V dc or 24 - 250V ac SPDT Electromechanical Relay 1.8 in Opposed Mode 30 mm 0.6 in 0 0 PIT26U Fibers 10 15 mm 0.6 in 30 mm 1.2 in 45 mm 1.8 in PIT26U Fibers 0 1 1 mm 0.04 in 10 mm 0.4 in 100 mm 4.0 in 25 mm 1.0 in 50 mm 2.0 in 1000 mm 40 in 75 mm 100 mm 125 mm 3.0 in 4.0 in 5.0 in DISTANCE DISTANCE 1000 E X C E S S G A I N Q45FP Q45FP 18 mm Diffuse Mode 100 PBT46U Fiber 0.75 in Diffuse Mode 12 mm 0.50 in PBT46U Fiber 6 mm 0 10 PBT26U Fiber 1 mm 0.04 in 0 0.25 in 12 mm 0.50 in 0.75 in 0 10 mm 0.4 in 0.25 in 6 mm 18 mm 1 0.1 mm 0.004 in 10 mm 0.4 in 100 mm 4 in 20 mm 0.8 in 30 mm 1.2 in 40 mm 1.6 in DISTANCE * 9 m (30') cables are available by adding suffix “W/30” to the model number of any cabled sensor (e.g., Q45VR3FP W/30) A model with a QD connector requires a mating cable; see page 10. page 6 1.2 in PIT46U Fibers 15 mm PIT46U Fibers G A I N Q45FP 45 mm Opposed Mode Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 50 mm 2.0 in Q45VR3 Series Q45VR3 Series Specifications Supply Voltage and Current Universal voltage: 24 to 250V ac, 50/60 Hz or 12 to 250V dc (1.5 watts maximum) Supply Protection Circuitry Protected against transient voltages. DC hookup is without regard to polarity. Output Configuration SPDT (Single-Pole, Double-Throw) electromechanical relay output. All models except emitters. Output Rating Max. switching power (resistive load): 1250VA, 150W Max. switching voltage (resistive load): 250V ac, 125V dc Max. switching current (resistive load): 5A @ 250V ac, 5A @ 30V dc derated to 200 mA @ 125V dc Min. voltage and current: 5V dc, 10mA Mechanical life of relay: 50,000,000 operations Electrical life of relay at full resistive load: 100,000 operations Output Protection Circuitry Protected against false pulse on power-up Output Response Time 15 milliseconds ON and OFF (NOTE: 100 millisecond delay on power-up. Relay is de-energized during this time.) Repeatability Opposed mode: 0.25 milliseconds All other sensing modes: 0.5 milliseconds Response time and repeatability specifications are independent of signal strength. Adjustments Light/Dark Operate select switch; and multi-turn Sensitivity control on top of sensor beneath a transparent o-ring-sealed Lexan® cover, allows precise sensitivity setting (turn clockwise to increase gain). Optional logic and logic/display modules have adjustable timing functions (see page 10). Indicators Indicator LEDs are clearly visible beneath a raised transparent Lexan® dome on top of the sensor. Power (green) LED lights whenever 24 to 250V ac, or 12 to 250V dc power is applied Signal (red) AID™ System LED lights whenever the sensor sees its modulated light source, and pulses at a rate proportional to the strength of the received light signal Load (yellow) LED lights whenever the output relay is energized Optional 7-element LED signal strength display module Construction Molded reinforced thermoplastic polyester housing, o-ring-sealed transparent Lexan® cover, molded acrylic lenses, and stainless steel hardware. Q45s are designed to withstand 1200 psi washdown. The base of cabled models has a 1/2" NPS integral internal conduit thread. Environmental Rating NEMA 6P, IEC IP67 Connections PVC-jacketed 2 m (6.5') or 9 m (30') unterminated cables, or Mini-style quick-disconnect (QD) fittings are available (“Q”- suffix models). QD cables are ordered separately. See page 10. Operating Conditions Temperature: -25° to +55° C (-13° to +131°F) Maximum relative humidity: 90% at 50°C (non-condensing) Application Notes Transient suppression is recommended for contacts switching inductive loads. Optional output timing modules are available. See page 10 for more information. Certifications Lexan® is a registered trademark of General Electric Co. Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 page 7 Q45VR3 Series Q45VR3 Series Dimensions Q45VR3 Series Sensors – Opposed, Retro, and Diffuse Sensing Modes (model suffix E, R, D, DL, DX, LP & LV) Quick-Disconnect Cabled 54.1 mm* (2.13") *57.9 mm (2.28") for LP models 44.5 mm (1.75") Lens Centerline 50.8 mm (2.00") 69.0 mm (2.72") 87.6 mm (3.45") 6.4 mm (0.25") 87.6 mm (3.45") 4.5 mm (#10) Screw Clearance (2) 7.1 mm (0.28") 30.0 mm (1.18") Internal Thread (1/2–14NPSM) External Thread M30 X 1.5 External Thread M30 X 1.5 ø 6.1 (0.24") 2m (6.5') Cable 14 mm (0.6") Mini-style QD Connector Mounting Nut is Supplied Convergent Sensing Mode (model suffix CV & CV4) Glass Fiber Optic (model suffix F and FV) 60.5 mm (2.38") 61.7 mm (2.43") Plastic Fiber Optic (model suffix FP) 59.8 mm (2.35") Lens Centerline 50.8 mm (2.00") page 8 Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Q45VR3 Series Q45VR3 Series Indicators and Controls Status indicator LEDs for Power, Signal and Output are clearly visible beneath a raised dome in the sensor’s transparent o-ring-sealed Lexan® cover. The Power indicator lights whenever power is applied to the sensor. The Signal LED lights whenever the sensor sees its modulated light source, and pulses at a rate proportional to the strength of the received light signal; this is the AID™ Alignment Indicating Device*. The Output indicator lights whenever the sensor’s output relay is energized. This indicator is especially useful when a timing logic module is used and Signal and Output conditions are not concurrent. Also located beneath the sensor’s o-ring-sealed cover are controls for light/dark operate selection and Sensitivity adjustment. Figure 1. Indicators and controls on the Q45VR3 Series Sensors * US patent no. 4356393 Q45VR3 Series Hookups Q45VR3 Sensors with Attached Cable bn bn bu Q45VR3 Sensors with Quick-Disconnect 5-Pin Mini-Style ( model suffix Q) 24 - 250V ac or 12 - 250V dc* wh NC ye C bk NO Q453E Emitters with Attached Cable bu wh ye bk 24 - 250V ac or 12 - 250V dc* NC C NO Q453EQ Emitters with Quick-Disconnect 3-Pin Mini-Style bn bn 24-250V ac or 12-250V dc* bu bu 24-250V ac or 12-250V dc* bk *NOTE: Connection of dc power is without regard to polarity. Quick-Disconnect (QD) Option AC Q45VR3 Series sensors are sold with either a 2 m (6.5') or a 9 m (30') attached PVC-covered cable, or with a 3-pin Ministyle (opposed mode emitter) or 5-pin Mini-style Quick-Disconnect (QD) cable fitting. Mini-style QD sensors are identified by the suffix “Q” in their model number suffix. Mating cables for QD Q45VR3 sensors are specified on page 10. Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 page 9 Q45VR3 Series Accessories Mini-Style Quick-Disconnect Cables Cable: PVC jacket, polyurethane connector body, nylon coupling nut Conductors: 18 AWG high-flex stranded, PVC insulation, gold plated contacts Temperature: -40° to +80°C (-40 to +176°F) Voltage Rating: 250V ac/300V dc Style Model Length 3-Pin Female Pin-out Straight MBCC-306 MBCC-312 MBCC-330 2 m (6.5') 4 m (12') 9 m (30') 5-Pin Female Pin-out Straight MBCC-506 MBCC-512 MBCC-530 2 m (6.5') 4 m (12') 9 m (30') Dimensions Pin-Out (Female View) Black Wire 61 mm max. (2.4") 7/8-16UN-2B Blue Wire White Wire ø28 mm max. (1.1") Brown Wire Brown Wire Black Wire Blue Wire Yellow Wire Retroreflective Targets Banner offers a wide selection of high-qualitity retroreflective targets. See the Accessories section of your current Banner Photoelectric Sensors catalog for complete information. NOTE: Polarized sensors require corner cube type retroreflective targets only. Non-polarized sensors may use any retroreflective target. Output Timing Logic and Signal Strength Display Modules Q45 sensors easily accept the addition of output timing logic and signal strength display functions. Display modules have a seven-element display which gives a “finer” indication of excess gain than does the AID™ system LED that is standard on Q45 sensors. The modules listed below may be used with all Q45VR3 sensors. See the data sheet packed with the module for more information. Model 45LM58 45LM58D 45LMD page 10 Logic and/or Display Function Programmable output timing logic Programmable output timing logic plus signal strength display Signal strength display only (no timing function) Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 Q45VR3 Series Mounting Brackets Model Description Dimensions 56.0 mm (2.20") SMB30C • 30 mm split clamp, black PBT bracket 13 mm (0.5") 63.0 mm (2.48") • Stainless steel mounting hardware included 31.5 mm (1.24") 13.5 mm (0.53") Nut Plate 2.5 mm (0.10") 45.0 mm (1.77") M5 x 0.8 x 80 mm Screw (2) 25.4 mm (1.00") 6.4 mm (0.25") ø 30.15 mm (1.187" dia.) 57.0 mm (2.25") SMB30MM • 30 mm, 11-gauge, stainless steel bracket with curved mounting slots for versatility and orientation • Clearance for M6 (1/4") hardware 25.4 mm (1.00") 7.1 mm .28 x 90° (2 Slots) 34.9 mm (1.38") 25.4 mm (1.00") ø 5.1 mm (0.20" dia.) ø 6.4 mm (0.25" dia.) 57.2 mm (2.25") 25.4 mm (1.00") R 25.4 mm (1.00") 35.1 mm 57.2 mm (1.38") (2.25") 69.9 mm (2.75") 50.8 mm (2.00") SMB30SC 12.7 mm (0.50") • 30 mm swivel, black PBT bracket • Stainless steel mounting hardware included 58.7 mm (2.31") 30.0 mm (1.18") 66.5 mm (2.62") Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 29.0 mm (1.14") page 11 Q45VR3 Series :DUUDQW\ Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period.This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. ! WARNING . . . Not To Be Used for Personnel Protection Never use these products as sensing devices for personnel protection. Doing so could lead to serious injury or death. These sensors do NOT include the self-checking redundant circuitry necessary to allow their use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Consult your current Banner Safety Products catalog for safety products which meet OSHA, ANSI and IEC standards for personnel protection. Banner Engineering Corp., 9714 Tenth Ave. No., Minneapolis, MN 55441 • Phone: 763.544.3164 • www.bannerengineering.com • E-mail: sensors@baneng.com
Q45VR3LP W/30 价格&库存
很抱歉,暂时无法提供与“Q45VR3LP W/30”相匹配的价格&库存,您可以联系我们找货
