Q40SP6LP
Q40SP6LP
    BANNER(邦纳)
    EZ-BEAM Q40 SERIES: POLARIZED RE
Q40SP6LP 数据手册
Q40 Sensors dc-Voltage Series Datasheet Self-contained, dc-operated sensors WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or deenergized sensor output condition. Models Model1 Sensing Mode Range LED Output Infrared, 950 nm NPN Q406E - Q40SN6R Opposed OPPOSED Q40SP6R Q40SN6LP Q40SP6LP 60 m (200 ft) P PNP NPN Polarized Retroreflective 6 m (20 ft) Visible red, 680 nm PNP POLAR RETRO Q40SN6FF200 Q40SN6FF400 Q40SP6FF400 NPN 200 mm (8 in) cutoff Q40SP6FF200 Fixed Field 400 mm (16 in) cutoff FIXED-FIELD Q40SN6FF600 Q40SP6FF600 600 mm (24 in) cutoff PNP Infrared, 880 nm NPN PNP NPN PNP Fixed-Field Mode Overview Q40 Series self-contained fixed-field sensors are small, powerful, infrared diffuse mode sensors with far-limit cutoff. The high excess gain of these sensors makes it possible for them to detect objects of low reflectivity. The fixed-field design makes them ideal for detecting a part or surface that is directly in front of another surface, while ignoring the surface in the background. Installation In the drawings and discussion in Excess Gain on page 4 and in Background Reflectivity and Placement on page 2, the letters E, R1, and R2 identify how the sensor’s three optical elements (Emitter “E,” Near Detector “R1,” and Far Detector “R2”) line up across the face of the sensor. In Figure 1 on page 2, Figure 2 on page 2, and Figure 3 on page 2, these elements align vertically; in Figure 4 on page 2, they align horizontally. Note how the pattern on the sensor’s lens helps to define the sensing axis of the sensor (Figure 6 on page 4). The sensing axis becomes important in situations like those illustrated in Figure 3 on page 2 and Figure 4 on page 2. 1 Standard 2 m (6.5 ft) cable models are listed. • To order 9 m (30 ft) cable: add suffix "W/30" (for example, Q406E W/30). • To order 4-pin Euro-style QD models: add suffix "Q" (for example, Q406EQ). A model with a QD connector requires a mating cable. Original Document 116167 Rev. B 14 November 2016 116167 Q40 Sensors dc-Voltage Series Background Reflectivity and Placement Avoid mirror-like backgrounds that produce specular reflections. A false sensor response occurs if a background surface reflects the sensor’s light more to the near detector (R1) than to the far detector (R2). The result is a false ON condition (Figure 1 on page 2). To correct this problem, use a diffusely reflective (matte) background, or angle either the sensor or the background (in any plane) so the background does not reflect light back to the sensor (see Figure 2 on page 2). Position the background as far beyond the cutoff distance as possible. An object beyond the cutoff distance, either stationary (and when positioned as shown in Figure 3 on page 2), or moving past the face of the sensor in a direction perpendicular to the sensing axis, may cause unwanted triggering of the sensor if more light is reflected to the near detector than to the far detector. The problem is easily remedied by rotating the sensor 90° (Figure 4 on page 2) to align the sensing axis horizontally. The object then reflects the R1 and R2 fields equally, resulting in no false triggering. A better solution, if possible, may be to reposition the object or the sensor. Unwanted triggering of the sensor from an object beyond the cutoff can also be caused by attempting to sense a small object that is moving perpendicular to the sensor face, or by an object moving through the off-center position shown in Figure 3 on page 2. Making the object larger, centering the sensor relative to the object, or rotating the sensor to place the sensing axis perpendicular to the longer dimension of the object (Figure 4 on page 2) will solve the problem. Cutoff Distance Cutoff Distance Reflective Background R1 = Near Detector R2 = Far Detector E = Emitter Cutoff Reflective Background Fixed Sensing Field Q40 sensor Strong Direct Reflection to R1 R1 R2 Core of Emitted Beam E Q40 sensor R1 R2 E Core of Emitted Beam Strong Direct Reflection Away From Sensor Fixed Sensing Field Figure 1. Reflective background - problem R1 = Near Detector R2 = Far Detector E = Emitter Figure 2. Reflective background - solution Cutoff Distance Cutoff Distance Q40 sensor Q40 sensor R1 R2 E, R2, R1 E Fixed Sensing Field R1 = Near Detector R2 = Far Detector E = Emitter E = Emitter R2 = Far Detector R1 = Near Detector Reflective Background or Moving Object Fixed Sensing Field Reflective Background or Moving Object Figure 4. Object beyond cutoff - solution Figure 3. Object beyond cutoff - problem Wiring Diagrams Cabled Emitters 3 1 2 NPN (Sinking) Outputs PNP (Sourcing) Outputs Standard Hookup Standard Hookup 3 – 10-30V dc + – 10-30V dc + 1 4 2 Load Load www.bannerengineering.com - Tel: +1-763-544-3164 1 + 10-30V dc – 3 4 2 Load Load P/N 116167 Rev. B Q40 Sensors dc-Voltage Series Alarm Hookup NOTE: QD hookups are functionally identical. 1 2 3 – 10-30V dc + 3 4 Alarm Hookup + 10-30V dc – 1 4 Load 2 Alarm Load Alarm Specifications Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short circuit of outputs Supply Voltage and Current 10 to 30 V dc (10% max. ripple) Supply current (exclusive of load current): Emitters: 25 mA Receivers: 20 mA Polarized Retroreflective: 30 mA Fixed-Field: 35 mA Output Response Time Opposed mode: 3 ms ON, 1.5 ms OFF Retro and Fixed-Field: 3 ms ON and OFF NOTE: 100 ms delay on power-up; outputs do not conduct during this time. Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration SPDT solid-state dc switch; Choose NPN (current sinking) or PNP (current sourcing) models Light Operate: N.O. output conducts when sensor sees its own (or the emitter's) modulated light Dark Operate: N.C. output conducts when the sensor sees dark; the N.C. (normally closed) output may be wired as a normally open marginal signal alarm output, depending upon hookup to power supply (U.S. patent 5087838) Output Rating 150 mA maximum (each) in standard hookup. When wired for alarm output, the total load may not exceed 150 mA. OFF-state leakage current: < 1 microamp at 30 V dc ON-state saturation voltage: < 1V at 10 mA dc; < 1.5 V at 150 mA dc Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 P/N 116167 Rev. B Repeatability Opposed mode: 375 μs Retro and Fixed-Field: 750 μs Repeatability and response are independent of signal strength Indicators Two LEDs (Green and Amber) Green ON steady: power to sensor is ON Green flashing: output is overloaded Amber ON steady: N.O. output is conducting Amber flashing: excess gain marginal (1 to 1.5x) in light condition Construction PBT polyester housing; acrylic lens Environmental Rating Leakproof design rated NEMA 6P, IEC IP67. QD Models rated IEC IP69K per DIN 40050-9. Connections 2 m (6.5 ft) or 9 m (30 ft) attached cable, or 4-pin Euro-style quickdisconnect fitting Operating Conditions Temperature: −40 °C to +70 °C (−40 °F to +158 °F) 90% at +50 °C maximum relative humidity (non-condensing) Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements. Method 201A (Vibration; frequency 10 Hz to 60 Hz, max., double amplitude 0.06 inch acceleration 10G). Method 213B conditions H&I. Shock: 75G with unit operating; 100G for non-operation Certifications www.bannerengineering.com - Tel: +1-763-544-3164 3 Q40 Sensors dc-Voltage Series Dimensions Cabled Models 40.1 mm (1.58") 50.0 mm (1.97") QD Models 46.0 mm (1.81") Green LED Power Indicator Lens Centerline 50.0 mm (1.97") 20.1 mm (0.79") 19.8 mm (0.78") Yellow LED Output Indicator (Jam Nut Supplied) 19.8 mm (0.78") 82.5 mm (3.25") M30 x 1.5 Thread 2 m (6.5') Cable M30 x 1.5 Thread (Jam Nut Supplied) All measurements are listed in millimeters [inches], unless noted otherwise. Excess Gain The excess gain curves for these products are available on the Banner website. They show excess gain versus sensing distance for sensors with 200 mm, 400 mm, and 600 mm (8 in, 16 in, and 24 in) cutoffs. Maximum excess gain for all models occurs at a lens-to-object distance of about 40 mm (1.57 in). Sensing at or near this distance makes maximum use of each sensor’s available sensing power. Receiver Elements Near R1 Detector Cutoff Distance Object B or Background Object A Lenses Far R2 Detector Backgrounds and background objects must always be placed beyond the cutoff distance. The excess gain curves were generated using a white test card of 90% reflectance. Objects with reflectivity of less than 90% reflect less light back to the sensor, and thus require proportionately more excess gain in order to be sensed with the same reliability as more reflective objects. When sensing an object of very low reflectivity, it may be especially important to sense it at or near the distance of maximum excess gain. Emitter Sensing Range Object is sensed if amount of light at R1 is greater than the amount of light at R2 Figure 5. Fixed-field Concept The effects of object reflectivity on cutoff distance, though small, may be important for some applications. Sensing of objects of less than 90% reflectivity causes the cutoff distances to be “pulled” slightly closer to the sensor. For example, an excess gain of 1 for an object that reflects 1/10 as much light as the 90% white card is represented by the heavy horizontal graph line at excess gain = 10. An object of this reflectivity results in far limit cutoffs of approximately 190 mm, 250 mm, and 390 mm (7.48 in, 9.84 in, and 15.4 in) for the 200 mm, 400 mm, and 600 mm (8 in, 16 in, and 24 in) cutoff models, respectively. For highest sensitivity, the sensor-to-object distance should be such that the object will be sensed at or near the point of maximum excess gain. The background must be placed beyond the cutoff distance. Following these two guidelines makes it possible to detect objects of low reflectivity, even against close-in reflective backgrounds. 4 E R1 R2 Sensing Axis E As a general rule, the most reliable sensing of an object approaching from the side occurs when the line of approach is parallel to the sensing axis. Figure 6. Fixed-field sensing axis www.bannerengineering.com - Tel: +1-763-544-3164 P/N 116167 Rev. B Q40 Sensors dc-Voltage Series Quick-Disconnect (QD) Cables 4-Pin Threaded M12/Euro-Style Cordsets Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 15.2 m (50 ft) 2 1 3 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC-450RA Pinout (Female) 1 2 3 4 = = = = Brown White Blue Black M12 x 1 ø 14.5 [0.57"] Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
Q40SP6LP 价格&库存
很抱歉,暂时无法提供与“Q40SP6LP”相匹配的价格&库存,您可以联系我们找货
