STK12C68, STK12C68-5 (SMD5962-94599)
8Kx8 AutoStore nvSRAM
FEATURES
DESCRIPTION
• 25, 35, 45, 55 ns Read Access & Write Cycle Time
The Simtek STK12C68 is a 64Kb fast static RAM
with a non-volatile Quantum Trap storage element
included with each memory cell.
• Unlimited Read/Write Endurance
• Automatic Non-volatile STORE on Power Loss
• Non-Volatile STORE Under Hardware or Software
Control
• Automatic RECALL to SRAM on Power Up
The SRAM provides the fast access & cycle times,
ease of use and unlimited read & write endurance of
a normal SRAM.
Data transfers automatically to the non-volatile storage cells when power loss is detected (the STORE
operation). On power up, data is automatically
restored to the SRAM (the RECALL operation). Both
STORE and RECALL operations are also available
under software control.
• Unlimited RECALL Cycles
• 1 Million STORE Cycles
• 100-Year Non-volatile Data Retention
• Single 5V ± 10% Power Supply
• Commercial, Industrial, Military Temperatures
The Simtek nvSRAM is the first monolithic non-volatile memory to offer unlimited writes and reads. It is
the highest performance, most reliable non-volatile
memory available.
• 28-pin 330-mil SOIC, 300-mil PDIP, and 600-mil
PDIP Packages (RoHS-Compliant)
• 28-Pin CDIP and LCC Military Packages
Block Diagram
Vcc
A5
A6
A7
A8
A9
A11
A12
ROW DECODER
QUANTUM TRAP
128 x 512
STORE
STATIC RAM
ARRAY
128 X 512
RECALL
VCAP
POWER
CONTROL
STORE/
RECALL
CONTROL
DQ0
DQ1
DQ2
DQ3
DQ4
DQ5
DQ6
DQ7
INPUT BUFFERS
SOFTWARE
DETECT
A0 – A12
COLUMN I/O
COLUMN DEC
A 0 A 1 A 2 A 3 A 4 A10
G
E
W
This product conforms to specifications per the
terms of Simtek standard warranty. The product
has completed Simtek internal qualification testing
and has reached production status.
1
Document Control #ML0008 Rev 2.0
June, 2008
W
3
26
A6
4
A5
A4
A3
5
25
24
HSB
A8
6
23
A2
8
21
G
A 10
A1
A0
DQ0
9
E
10
19
11
18
DQ
DQ
DQ1
DQ2
V SS
12
17
13
16
14
15
A9
A 11
A4
A9
A3
A11
(TOP)
A2
G
A1
A10
7
A0
6
DQ0
DQ7
DQ1
DQ6
5
4
E
DQ5
DQ4
3
DQ3
DQ
DQ
DQ
HSB
A8
A5
DQ2
22
A6
VSS
(T O P )
7
V CC
VCC
27
W
28
2
VCap
1
A 12
A7
A7
V CAP
A12
Packages
28-pin LCC
28-pin SOIC
28-pin DIP
Pin Descriptions
Pin Name
I/O
Description
A12-A0
Input
Address: The 13 address inputs select one of 8,192 bytes in the nvSRAM array
DQ7-DQ0
I/O
Data: Bi-directional 8-bit data bus for accessing the nvSRAM
E
Input
Chip Enable: The active low E input selects the device
W
Input
Write Enable: The active low W enables data on the DQ pins to be written to the address
location latched by the falling edge of E
G
Input
Output Enable: The active low G input enables the data output buffers during read cycles.
De-asserting G high caused the DQ pins to tri-state.
VCC
Power Supply
Power: 5.0V, +10%
HSB
I/O
Hardware Store Busy: When low this output indicates a Store is in progress. When pulled
low external to the chip, it will initiate a nonvolatile STORE operation. A weak pull up resistor
keeps this pin high if not connected. (Connection Optional).
VCAP
Power Supply
AutoStore Capacitor: Supplies power to nvSRAM during power loss to store data from
SRAM to nonvolatile storage elements.
VSS
Power Supply
Ground
June, 2008
2
ABSOLUTE MAXIMUM RATINGSa
Note a: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress
rating only, and functional operation of the device at conditions
above those indicated in the operational sections of this specification
is not implied. Exposure to absolute maximum rating conditions for
extended periods may affect reliability.
Voltage on Input Relative to Ground . . . . . . . . . . . . . –0.5V to 7.0V
Voltage on Input Relative to VSS . . . . . . . . . . –0.6V to (VCC + 0.5V)
Voltage on DQ0-7 or HSB . . . . . . . . . . . . . . . . –0.5V to (VCC + 0.5V)
Temperature under Bias . . . . . . . . . . . . . . . . . . . . .–55°C to 125°C
Storage Temperature . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C
Power Dissipation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .1W
DC Output Current (1 output at a time, 1s duration) . . . . . . . .15mA
Package Thermal Characteristics - See Website at http://www.simtek.com
(VCC = 5.0V ± 10%)e
DC CHARACTERISTICS
INDUSTRIAL
MILITARY
COMMERCIAL
SYMBOL
PARAMETER
MIN
MAX
MIN
UNITS
NOTES
MAX
ICC1b
Average VCC Current
85
75
65
85
75
65
55
mA
mA
mA
mA
tAVAV = 25ns (commercial and industrial only)
tAVAV = 35ns
tAVAV = 45ns (commercial and industrial only)
tAVAV = 55ns
ICC2c
Average VCC Current during STORE
3
3
mA
All Inputs Don’t Care, VCC = max
ICC3b
Average VCC Current at tAVAV = 200ns
5V, 25°C, Typical
10
10
mA
W ≥ (V CC – 0.2V)
All Others Cycling, CMOS Levels
ICC4c
Average VCAP Current during AutoStore
Cycle
2
2
mA
ISB1d
Average VCC Current
(Standby, Cycling TTL Input Levels)
27
24
24
mA
mA
mA
mA
tAVAV = 25ns, E ≥ VIH (commercial and industrial only)
tAVAV = 35ns, E ≥ VIH
tAVAV = 45ns, E ≥ VIH (commercial and industrial only)
tAVAV = 55ns, E ≥ VIH
ISB2d
VCC Standby Current
(Standby, Stable CMOS Input Levels)
1.5
2.5
mA
E ≥ (V CC – 0.2V)
All Others VIN ≤ 0.2V or ≥ (VCC – 0.2V)
IILK
Input Leakage Current
±1
±1
μA
VCC = max
VIN = VSS to VCC
IOLK
Off-State Output Leakage Current
±5
±5
μA
VCC = max
VIN = VSS to VCC, E or G ≥ VIH
VIH
Input Logic “1” Voltage
2.2
VCC + .5
2.2
VCC + .5
V
All Inputs
VIL
Input Logic “0” Voltage
VSS – .5
0.8
VSS – .5
0.8
V
All Inputs
VOH
Output Logic “1” Voltage
V
IOUT = – 4mA except HSB
VOL
Output Logic “0” Voltage
0.4
0.4
V
IOUT = 8mA except HSB
VBL
Logic “0” Voltage on HSB Output
0.4
0.4
V
IOUT = 3mA
TA
Operating Temperature
85/125
°C
Note b:
Note c:
Note d:
Note e:
2.4
70
–40/-55
ICC1 and ICC3 are dependent on output loading and cycle rate. The specified values are obtained with outputs unloaded.
ICC2 and ICC4 are the average currents required for the duration of the respective STORE cycles (tSTORE ) .
E ≥ VIH will not produce standby current levels until any nonvolatile cycle in progress has timed out.
VCC reference levels throughout this datasheet refer to VCC if that is where the power supply connection is made, or VCAP if VCC is connected to ground.
AC TEST CONDITIONS
5.0V
Input Pulse Levels. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .0V to 3V
Input Rise and Fall Times . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ≤ 5ns
Input and Output Timing Reference Levels . . . . . . . . . . . . . . . 1.5V
Output Load . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . See Figure 1
CAPACITANCEf
SYMBOL
OUTPUT
255 Ohms
(TA = 25°C, f = 1.0MHz)
PARAMETER
MAX
UNITS
CONDITIONS
CIN
Input Capacitance
8
pF
ΔV = 0 to 3V
COUT
Output Capacitance
7
pF
ΔV = 0 to 3V
Note f:
480 Ohms
Figure 1. AC Output Loading
These parameters are guaranteed but not tested.
June, 2008
30 pF
INCLUDING
SCOPE AND
FIXTURE
3
(VCC = 5.0V ± 10%)e
SRAM READ CYCLES #1 & #2
STK12C68,
STK12C68-5-25
SYMBOLS
NO.
PARAMETER
#1, #2
Alt.
MIN
MAX
STK12C68,
STK12C68-5-35
MIN
25
MAX
STK12C68,
STK12C68-5-45
MIN
STK12C68,
STK12C68-5-55
MAX
tELQV
tACS
Chip Enable Access Time
2
tAVAVg, tELEHg
tRC
Read Cycle Time
3
tAVQVh
tAA
Address Access Time
25
35
45
55
4
tGLQV
tOE
Output Enable to Data Valid
10
15
5
tAXQXh
tOH
Output Hold after Address Change
5
5
5
5
ns
6
tELQX
tLZ
Address Change or Chip Enable to
Output Active
5
5
5
5
ns
7
tEHQZi
tHZ
Address Change or
Chip Disable to Output Inactive
8
tGLQX
tOLZ
Output Enable to Output Active
9
tGHQZi
tOHZ
Output Disable to Output Inactive
10
tELICCHf
tPA
Chip Enable to Power Active
11
tEHICCLf
tPS
Chip Disable to Power Standby
35
10
12
45
SRAM READ CYCLE #1: Address Controlledg, h
2
tAVAV
ADDRESS
3
tAVQV
5
tAXQX
DQ (DATA OUT)
DATA VALID
SRAM READ CYCLE #2: E and G Controlledg
2
tAVAV
ADDRESS
1
11
tELQV
tEHICCL
6
tELQX
E
7
27
tEHQZ
tAVEL
G
9
tGHQZ
4
8
tGLQX
tGLQV
DQ (DATA OUT)
DATA VALID
10
tELICCH
ICC
ACTIVE
STANDBY
June, 2008
4
ns
ns
ns
ns
55
Note g: W and HSB must be high during SRAM READ cycles.
Note h: Device is continuously selected with E and G both low.
Note i: Measured ± 200mV from steady state output voltage.
ns
ns
12
ns
ns
12
25
55
45
10
10
UNITS
MAX
1
25
35
MIN
ns
(VCC = 5.0V ± 10%)e
SRAM WRITE CYCLES #1 & #2
STK12C68,
STK12C68,
STK12C68,
STK12C68,
STK12C68-5-25 STK12C68-5-35 STK12C68-5-45 STK12C68-5-55 UNITS
SYMBOLS
NO.
PARAMETER
#1
#2
Alt.
12
tAVAV
tAVAV
tWC
Write Cycle Time
25
35
45
55
ns
13
tWLWH
tWLEH
tWP
Write Pulse Width
30
45
ns
14
tELWH
tELEH
tCW
Chip Enable to End of Write
30
45
ns
15
tDVWH
tDVEH
tDW
Data Set-up to End of Write
10
12
15
25
ns
16
tWHDX
tEHDX
tDH
Data Hold after End of Write
ns
17
tAVWH
tAVEH
tAW
Address Set-up to End of Write
30
45
ns
18
tAVWL
tAVEL
tAS
Address Set-up to Start of Write
ns
19
tWHAX
tEHAX
tWR
Address Hold after End of Write
tWLQZ i, j
tWZ
Write Enable to Output Disable
21
tWHQX
tOW
Output Active after End of Write
Note j:
Note k:
Note l:
MIN
MAX
MIN
MAX
5
MIN
MAX
5
SRAM WRITE CYCLE #1: W Controlledk, l
12
tAVAV
ADDRESS
19
tWHAX
E
17
tAVWH
18
tAVWL
13
tWLWH
W
15
tDVWH
DATA IN
DATA OUT
16
tWHDX
DATA VALID
tWLQZ
HIGH IMPEDANCE
PREVIOUS DATA
21
tWHQX
SRAM WRITE CYCLE #2: E Controlledk, l
12
tAVAV
ADDRESS
14
tELEH
18
tAVEL
19
tEHAX
E
17
tAVEH
13
tWLEH
W
15
tDVEH
DATA IN
DATA OUT
June, 2008
16
tEHDX
DATA VALID
HIGH IMPEDANCE
5
ns
15
5
If W is low when E goes low, the outputs remain in the high-impedance state.
E or W must be ≥ VIH during address transitions.
HSB must be high during SRAM WRITE cycles.
14
tELWH
MAX
5
MIN
ns
ns
HARDWARE MODE SELECTION
E
W
HSB
A12 - A0 (hex)
MODE
I/O
POWER
H
X
H
X
Not Selected
Output High Z
Standby
NOTES
L
H
H
X
Read SRAM
Output Data
Active
L
L
H
X
Write SRAM
Input Data
Active
X
X
L
X
Nonvolatile STORE
Output High Z
lCC2
m
H
0000
1555
0AAA
1FFF
10F0
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Output Data
Output Data
Output Data
Output Data
Output Data
Active
n, o
0F0F
Nonvolatile STORE
Output High Z
lCC2
0000
1555
0AAA
1FFF
10F0
0F0E
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Read SRAM
Nonvolatile RECALL
Output DataOutput
Data
Output Data
Output Data
Output Data
Output High Z
Active
L
L
H
H
H
o
n, o
Note m: HSB STORE operation occurs only if an SRAM WRITE has been done since the last nonvolatile cycle. After the STORE (if any) completes, the
part will go into standby mode, inhibiting all operations until HSB rises.
Note n: The six consecutive addresses must be in the order listed. W must be high during all six consecutive E controlled cycles to enable a nonvolatile
cycle.
Note o: I/O state assumes G < VIL. Activation of nonvolatile cycles does not depend on state of G.
(VCC = 5.0V ± 10%)e
HARDWARE STORE CYCLE
STK12C68,
STK12C68-5
SYMBOLS
NO.
PARAMETER
Standard
Alternate
MIN
22
tSTORE
tHLHZ
STORE Cycle Duration
23
tDELAY
tHLQZ
Time Allowed to Complete SRAM Cycle
24
tRECOVER
tHHQX
Hardware STORE High to Inhibit Off
25
tHLHX
Hardware STORE Pulse Width
26
tHLBL
Hardware STORE Low to Store Busy
UNITS NOTES
MAX
10
1
700
15
ms
i, p
μs
i, q
ns
p, r
ns
300
ns
Note p: E and G low for output behavior.
Note q: E and G low and W high for output behavior.
Note r: tRECOVER is only applicable after tSTORE is complete.
25
tHLHX
HSB (IN)
24
tRECOVER
22
tSTORE
26
tHLBL
HSB (OUT)
HIGH IMPEDANCE
HIGH IMPEDANCE
23
tDELAY
DQ (DATA OUT)
DATA VALID
DATA VALID
June, 2008
6
(VCC = 5.0V ± 10%)e
AutoStore™/POWER-UP RECALL
SYMBOLS
NO.
PARAMETER
Standard
Alternate
MIN
NOTES
550
μs
s
10
ms
p, q, t
tRESTORE
28
tSTORE
29
tVSBL
30
tDELAY
31
VSWITCH
Low Voltage Trigger Level
32
VRESET
Low Voltage Reset Level
Low Voltage Trigger (VSWITCH) to HSB Low
tBLQZ
UNITS
MAX
Power-up RECALL Duration
27
tHLHZ
STK12C68,
STK12C68-5
300
1
4.0
ns
l
μs
p
4.5
V
3.9
V
Note s: tRESTORE starts from the time VCC rises above VSWITCH.
Note t: HSB is asserted low for 1μs when VCAP drops through VSWITCH. If an SRAM WRITE has not taken place since the last nonvolatile cycle, HSB
will be released and no STORE will take place.
VCC
31
VSWITCH
32
VRESET
AutoStoreTM
POWER-UP RECALL
29
tVSBL
27
tRESTORE
28
tSTORE
HSB
30
tDELAY
W
DQ (DATA OUT)
POWER-UP
RECALL
BROWN OUT
NO STORE
(NO SRAM WRITES)
BROWN OUT
AutoStore
BROWN OUT
AutoStore
NO RECALL
(VCC DID NOT GO
BELOW VRESET)
NO RECALL
(VCC DID NOT GO
BELOW VRESET)
RECALL WHEN
VCC RETURNS
ABOVE VSWITCH
June, 2008
7
(VCC = 5.0V ± 10%)e
SOFTWARE-CONTROLLED STORE/RECALL CYCLEv
SYMBOLS
NO.
PARAMETER
STK12C68,
STK12C68,
STK12C68,
STK12C68,
STK12C68-5-25 STK12C68-5-35 STK12C68-5-45 STK12C68-5-55 UNITS NOTES
Standard
Alternate
33
tAVAV
tRC
STORE/RECALL Initiation Cycle Time
MIN
25
MAX
MIN
35
MAX
45
55
ns
p
34
tAVEL
tAS
Address Set-up Time
ns
u
35
tELEH
tCW
Clock Pulse Width
30
30
ns
u
36
tELAX
Address Hold Time
ns
u
37
tRECALL
RECALL Duration
MIN
MAX
MIN
MAX
μs
Note u: The software sequence is clocked on the falling edge of E without involving G (double clocking will abort the sequence). See application note:
MA0002 http://www.simtek.com/attachments/AppNote02.pdf.
Note v: The six consecutive addresses must be in the order listed in the Software STORE/RECALL Mode Selection Table: (0000, 1555, 0AAA, 1FFF,
10F0, 0F0F) for a STORE cycle or (0000, 1555, 0AAA, 1FFF, 10F0, 0F0E) for a RECALL cycle. W must be high during all six consecutive
cycles.
SOFTWARE STORE/RECALL CYCLE: E Controlledv
33
33
tAVAV
ADDRESS
tAVAV
ADDRESS #1
34
tAVEL
ADDRESS #6
35
tELEH
E
36
tELAX
28
tSTORE
DQ (DATA OUT)
DATA VALID
DATA VALID
June, 2008
8
37
/ tRECALL
HIGH IMPEDANCE
DEVICE OPERATION
The STK12C68, STK12C68-5 has two separate
modes of operation: SRAM mode and nonvolatile
mode. In SRAM mode, the memory operates as a
standard fast static RAM. In nonvolatile mode, data
is transferred from SRAM to Nonvolatile Elements
(the STORE operation) or from Nonvolatile Elements
to SRAM (the RECALL operation). In this mode SRAM
functions are disabled.
NOISE CONSIDERATIONS
The STK12C68, STK12C68-5 is a high-speed memory and so must have a high-frequency bypass
capacitor of approximately 0.1μF connected
between VCAP and VSS, using leads and traces that
are as short as possible. As with all high-speed
CMOS ICs, normal careful routing of power, ground
and signals will help prevent noise problems.
SRAM READ
The STK12C68, STK12C68-5 performs a READ
cycle whenever E and G are low and W and HSB
are high. The address specified on pins A0-12 determines which of the 8,192 data bytes will be
accessed. When the READ is initiated by an address
transition, the outputs will be valid after a delay of
tAVQV (READ cycle #1). If the READ is initiated by E or
G, the outputs will be valid at tELQV or at tGLQV, whichever is later (READ cycle #2). The data outputs will
repeatedly respond to address changes within the
tAVQV access time without the need for transitions on
any control input pins, and will remain valid until
another address change or until E or G is brought
high, or W or HSB is brought low.
SRAM WRITE
A WRITE cycle is performed whenever E and W are
low and HSB is high. The address inputs must be
stable prior to entering the WRITE cycle and must
remain stable until either E or W goes high at the
end of the cycle. The data on the common I/O pins
DQ0-7 will be written into the memory if it is valid tDVWH
before the end of a W controlled WRITE or tDVEH
before the end of an E controlled WRITE.
It is recommended that G be kept high during the
entire WRITE cycle to avoid data bus contention on
common I/O lines. If G is left low, internal circuitry
will turn off the output buffers tWLQZ after W goes low.
June, 2008
9
POWER-UP RECALL
During power up, or after any low-power condition
(VCAP < VRESET), an internal RECALL request will be
latched. When VCAP once again exceeds the sense
voltage of VSWITCH, a RECALL cycle will automatically
be initiated and will take tRESTORE to complete.
If the STK12C68, STK12C68-5 is in a WRITE state at
the end of power-up RECALL, the SRAM data will be
corrupted. To help avoid this situation, a 10K Ohm
resistor should be connected either between W and
system VCC or between E and system VCC.
SOFTWARE NONVOLATILE STORE
The STK12C68, STK12C68-5 software STORE cycle
is initiated by executing sequential E controlled
READ cycles from six specific address locations.
During the STORE cycle an erase of the previous
nonvolatile data is first performed, followed by a program of the nonvolatile elements. The program
operation copies the SRAM data into nonvolatile
memory. Once a STORE cycle is initiated, further
input and output are disabled until the cycle is completed.
Because a sequence of READs from specific
addresses is used for STORE initiation, it is important
that no other READ or WRITE accesses intervene in
the sequence, or the sequence will be aborted and
no STORE or RECALL will take place.
To initiate the software STORE cycle, the following
READ sequence must be performed:
1.
2.
3.
4.
5.
6.
Read address
Read address
Read address
Read address
Read address
Read address
0000 (hex)
1555 (hex)
0AAA (hex)
1FFF (hex)
10F0 (hex)
0F0F (hex)
Valid READ
Valid READ
Valid READ
Valid READ
Valid READ
Initiate STORE cycle
The software sequence must be clocked with E controlled READs.
Once the sixth address in the sequence has been
entered, the STORE cycle will commence and the
chip will be disabled. It is important that READ cycles
and not WRITE cycles be used in the sequence,
although it is not necessary that G be low for the
sequence to be valid. After the tSTORE cycle time has
been fulfilled, the SRAM will again be activated for
READ and WRITE operation.
Internally, RECALL is a two-step procedure. First, the
SRAM data is cleared, and second, the nonvolatile
information is transferred into the SRAM cells. After
the tRECALL cycle time the SRAM will once again be
ready for READ and WRITE operations. The RECALL
operation in no way alters the data in the Nonvolatile
Elements. The nonvolatile data can be recalled an
unlimited number of times.
AutoStore MODE
The STK12C68, STK12C68-5 can be powered in
one of three modes.
During normal AutoStore operation, the STK12C68,
STK12C68-5 will draw current from VCC to charge a
capacitor connected to the VCAP pin. This stored
charge will be used by the chip to perform a single
STORE operation. After power up, when the voltage
on the VCAP pin drops below VSWITCH, the part will
automatically disconnect the VCAP pin from VCC and
initiate a STORE operation.
Figure 2 shows the proper connection of capacitors
for automatic store operation. A charge storage
capacitor having a capacity of between 68μF and
220μF (± 20%) rated at 6V should be provided.
In system power mode, both VCC and VCAP are connected to the + 5V power supply without the 68μF
capacitor. In this mode the AutoStore function of the
STK12C68, STK12C68-5 will operate on the stored
system charge as power goes down. The user must,
however, guarantee that VCC does not drop below
3.6V during the 10ms STORE cycle.
In order to prevent unneeded STORE operations,
automatic STOREs as well as those initiated by
externally driving HSB low will be ignored unless at
least one WRITE operation has taken place since the
most recent STORE or RECALL cycle. Software initiated STORE cycles are performed regardless of
whether a WRITE operation has taken place. An
optional pull-up resistor is shown connected to HSB.
This can be used to signal the system that the
AutoStore cycle is in progress.
If the power supply drops faster than 20 μs/volt
before VCC reaches VSWITCH, then a 2.2 ohm resistor
should be inserted between VCC and the system supply to avoid momentary excess of current between
Vcc and Vcap.
1
28
27
26
14
15
10K O
Valid READ
Valid READ
Valid READ
Valid READ
Valid READ
Initiate RECALL cycle
10K O*
0000 (hex)
1555 (hex)
0AAA (hex)
1FFF (hex)
10F0 (hex)
0F0E (hex)
Figure 2: AutoStore Mode
*If HSB is not used, it should be left unconnected.
1
28
27
26
14
15
10K O
Read address
Read address
Read address
Read address
Read address
Read address
0.1µF
1.
2.
3.
4.
5.
6.
0.1 µF Bypass
A software RECALL cycle is initiated with a sequence
of READ operations in a manner similar to the software STORE initiation. To initiate the RECALL cycle,
the following sequence of E controlled READ operations must be performed:
VCAP (Figure 3). This is the AutoStore Inhibit mode, in
which the AutoStore function is disabled. If the
STK12C68, STK12C68-5 is operated in this configuration, references to VCC should be changed to VCAP
throughout this data sheet. In this mode, STORE
operations may be triggered through software control or the HSB pin. To enable or disable AutoStore
using an IO port pin, see “PREVENTING STORES”
on page 11.
68µF
6V ±20%
SOFTWARE NONVOLATILE RECALL
AutoStore INHIBIT MODE
If an automatic STORE on power loss is not required,
then VCC can be tied to ground and + 5V applied to
June, 2008
10
Figure 3: AutoStore Inhibit Mode
HSB OPERATION
The STK12C68, STK12C68-5 provides the HSB pin
for controlling and acknowledging the STORE operations. The HSB pin is used to request a hardware
STORE cycle. When the HSB pin is driven low, the
STK12C68, STK12C68-5 will conditionally initiate a
STORE operation after tDELAY; an actual STORE cycle
will only begin if a WRITE to the SRAM took place
since the last STORE or RECALL cycle. The HSB pin
has a very resistive pullup and is internally driven
low to indicate a busy condition while the STORE
(initiated by any means) is in progress.
PREVENTING STORES
SRAM READ and WRITE operations that are in
progress when HSB is driven low by any means are
given time to complete before the STORE operation
is initiated. After HSB goes low, the STK12C68,
STK12C68-5 will continue SRAM operations for tDELAY. During tDELAY, multiple SRAM READ operations
may take place. If a WRITE is in progress when HSB
is pulled low it will be allowed a time, tDELAY, to complete. However, any SRAM WRITE cycles requested
after HSB goes low will be inhibited until HSB
returns high.
The HSB pin can be used to synchronize multiple
STK12C68, STK12C68-5s while using a single
larger capacitor. To operate in this mode the HSB
pin should be connected together to the HSB pins
from the other STK12C68, STK12C68-5s. An external pull-up resistor to + 5V is required since HSB
acts as an open drain pull down. The VCAP pins from
the other STK12C68, STK12C68-5 parts can be tied
together and share a single capacitor. The capacitor
size must be scaled by the number of devices connected to it. When any one of the STK12C68,
STK12C68-5s detects a power loss and asserts
HSB, the common HSB pin will cause all parts to
request a STORE cycle (a STORE will take place in
those STK12C68, STK12C68-5s that have been
written since the last nonvolatile cycle).
During any STORE operation, regardless of how it
was initiated, the STK12C68, STK12C68-5 will continue to drive the HSB pin low, releasing it only when
the STORE is complete. Upon completion of the
STORE operation the STK12C68, STK12C68-5 will
remain disabled until the HSB pin returns high.
June, 2008
11
The STORE function can be disabled on the fly by
holding HSB high with a driver capable of sourcing
30mA at a VOH of at least 2.2V, as it will have to
overpower the internal pull-down device that drives
HSB low for 20μs at the onset of a STORE. When
the STK12C68, STK12C68-5 is connected for
AutoStore operation (system VCC connected to VCC
and a 68μF capacitor on VCAP) and VCC crosses
VSWITCH on the way down, the STK12C68,
STK12C68-5 will attempt to pull HSB low; if HSB
doesn’t actually get below VIL, the part will stop trying to pull HSB low and abort the STORE attempt.
HARDWARE PROTECT
The STK12C68, STK12C68-5 offers hardware protection against inadvertent STORE operation and
SRAM WRITEs during low-voltage conditions. When
VCAP < VSWITCH, all externally initiated STORE operations and SRAM WRITEs are inhibited.
AutoStore can be completely disabled by tying VCC
to ground and applying + 5V to VCAP. This is the
AutoStore Inhibit mode; in this mode, STOREs are
only initiated by explicit request using either the software sequence or the HSB pin.
LOW AVERAGE ACTIVE POWER
The STK12C68, STK12C68-5 draws significantly
less current when it is cycled at times longer than
50ns. Figure 4 shows the relationship between ICC
and READ cycle time. Worst-case current consumption is shown for both CMOS and TTL input levels
(commercial temperature range, VCC = 5.5V, 100%
duty cycle on chip enable). Figure 5 shows the
same relationship for WRITE cycles. If the chip
enable duty cycle is less than 100%, only standby
current is drawn when the chip is disabled. The
overall average current drawn by the STK12C68,
STK12C68-5 depends on the following items: 1)
CMOS vs. TTL input levels; 2) the duty cycle of chip
enable; 3) the overall cycle rate for accesses; 4) the
ratio of READs to WRITEs; 5) the operating temperature; 6) the Vcc level; and 7) I/O loading.
100
Average Active Current (mA)
100
80
60
40
TTL
60
TTL
40
CMOS
CMOS
100
150
Cycle Time (ns)
200
50
Figure 4: Icc (max) Reads
200
Figure 5: Icc (max) Writes
BEST PRACTICES
nvSRAM products have been used effectively for
over 15 years. While ease-of-use is one of the
product’s main system values, experience gained
working with hundreds of applications has resulted
in the following suggestions as best practices:
• The non-volatile cells in an nvSRAM are programmed on the test floor during final test and
quality assurance. Incoming inspection routines
at customer or contract manufacturer’s sites will
sometimes reprogram these values. Final NV
patterns are typically repeating patterns of AA,
55, 00, FF, A5, or 5A. End product’s firmware
should not assume an NV array is in a set programmed state. Routines that check memory
content values to determine first time system
configuration, cold or warm boot status, etc.
should always program a unique NV pattern
(e.g., complex 4-byte pattern of 46 E6 49 53 hex
or more random bytes) as part of the final system manufacturing test to ensure these system
routines work consistently.
• Power up boot firmware routines should rewrite
the nvSRAM into the desired state. While the
nvSRAM is shipped in a preset state, best practice is to again rewrite the nvSRAM into the
June, 2008
100
150
Cycle Time (ns)
12
desired state as a safeguard against events that
might flip the bit inadvertently (program bugs,
incoming inspection routines, etc.).
• The Vcap value specified in this datasheet
includes a minimum and a maximum value size.
Best practice is to meet this requirement and not
exceed the max Vcap value because the higher
inrush currents may reduce the reliability of the
internal pass transistor. Customers that want to
use a larger Vcap value to make sure there is
extra store charge should discuss their Vcap size
selection with Simtek.
COMMERCIAL AND INDUSTRIAL ORDERING INFORMATION
STK12C68 - S F 45 I TR
Packing Option
Blank = Tube
TR = Tape and Reel
Temperature Range
Blank = Commercial (0 to 70°C)
I = Industrial (–40 to 85°C)
Access Time
25 = 25ns
35 = 35ns
45 = 45ns
Lead Finish
F = 100% Sn (Matte Tin)
Package
S = Plastic 28-pin 330 mil SOIC
W = Plastic 28-pin 600 mil DIP
P = Plastic 28-pin 300 mil DIP
C = Ceramic 28-pin 300 mil DIP
L = Ceramic 28-pin LLC
June, 2008
13
MILITARY ORDERING INFORMATION
STK12C68 - 5 C 35 M
Temperature Range
M = Military (–55 to 125°C)
Access Time
35 = 35ns
55 = 55ns
Package
C = Ceramic 28-pin 300 mil DIP (gold lead finish)
K = Ceramic 28-pin 300 mil DIP (solder dip finish)
L = Ceramic 28 pin LCC
Retention / Endurance
5 = Military (10 years or 105cycles)
5962 - 94599 01 MX X
Lead Finish
A = Solder DIP lead finish
C = Gold lead DIP finish
X = Lead finish “A” or “C” is acceptable
Case Outline
X = Ceramic 28 pin 300-mil DIP
Y = Ceramic 28 pin LCC
Device Class Indicator - Class M
Device Type
01 = 55ns
03 = 35ns
June, 2008
14
Part Number
STK12C68-C35
STK12C68-C45
STK12C68-L35
STK12C68-L45
Description
5V 8Kx8 AutoStore nvSRAM
CDIP28-300
CDIP28-300
LCC28
LCC28
Access Times
35 ns access time
45 ns access time
35 ns access time
45 ns access time
Temperature
Commercial
Commercial
Commercial
Commercial
STK12C68-PF25
5V 8Kx8 AutoStore nvSRAM PDIP28-600
25 ns access time
Commercial
STK12C68-PF45
45 ns access time
Commercial
STK12C68-SF25
5V 8Kx8 AutoStore nvSRAM SOP28-330
25 ns access time
Commercial
STK12C68-SF25TR
STK12C68-SF45
STK12C68-SF45TR
STK12C68-WF25
STK12C68-WF45
STK12C68-C35I
STK12C68-C45I
STK12C68-L35I
STK12C68-L45I
STK12C68-PF25I
STK12C68-PF45I
STK12C68-SF25I
STK12C68-SF25ITR
STK12C68-SF45I
STK12C68-SF45ITR
STK12C68-WF25I
STK12C68-WF45I
SMD5962-9459901MXA
SMD5962-9459901MXC
SMD5962-9459901MXX
SMD5962-9459901MYA
SMD5962-9459901MYX
SMD5962-9459903MXA
SMD5962-9459903MXC
SMD5962-9459903MXX
SMD5962-9459903MYA
SMD5962-9459903MYX
STK12C68-5C35M
STK12C68-5C55M
STK12C68-5K35M
STK12C68-5K55M
STK12C68-5L35M
STK12C68-5L55M
25 ns access time
45 ns access time
45 ns access time
25 ns access time
45 ns access time
35 ns access time
45 ns access time
35 ns access time
45 ns access time
25 ns access time
45 ns access time
25 ns access time
25 ns access time
45 ns access time
45 ns access time
25 ns access time
45 ns access time
55 ns access time
55 ns access time
55 ns access time
55 ns access time
55 ns access time
35 ns access time
35 ns access time
35 ns access time
35 ns access time
35 ns access time
35 ns access time
35 ns access time
35 ns access time
35 ns access time
35 ns access time
35 ns access time
Commercial
Commercial
Commercial
Commercial
Commercial
Industrial
Industrial
Industrial
Industrial
Industrial
Industrial
Industrial
Industrial
Industrial
Industrial
Industrial
Industrial
Military
Military
Military
Military
Military
Military
Military
Military
Military
Military
Military
Military
Military
Military
Military
Military
June, 2008
15
SOP28-330
SOP28-330
SOP28-330
PDIP28-600
PDIP28-600
CDIP28-300
CDIP28-300
LCC28
LCC28
PDIP28-600
PDIP28-600
SOP28-330
SOP28-330
SOP28-330
SOP28-330
PDIP28-600
PDIP28-600
CDIP28-300
CDIP28-300
CDIP28-300
LCC28
LCC28
CDIP28-300
CDIP28-300
CDIP28-300
LCC28
LCC28
CDIP28-300
CDIP28-300
CDIP28-300
CDIP28-300
LCC28
LCC28
Package Diagrams
28-Lead, 330 mil SOIC Gull Wing
0.713
0.733
( 18.11
18.62
0.112
(2.845)
0.020
0.014
( 0.508
0.356
0.050 (1.270)
0.103
0.093
0.336
0.326
0.004
(0.102)
( 2.616
2.362
( 8.534
8.280
0.477
0.453
( 12.116
11.506
Pin 1
0.014
0.008
10°
0°
( 0.356
0.203
0.044
0.028
DIM = INCHES
DIM = mm
June, 2008
16
MIN
MAX
MIN
( MAX
( 1.117
0.711
28-Lead 300 mil PDIP
.275 6.98
.295 7.49
Pin 1
Index
.020
.030
( 0.51
0.76)
1.345
1.385
( 34.16
35.18 )
------(4.57
).180
.015
---.125 (3.18)
MIN
.030
.045
(0.76
1.14)
.014 0.36
.022 0.56
.300
.325
.045 1.14
.060 1.52
.100
(2.54)
BSC
( 7.62
8.26)
DIM = INCHES
DIM = mm
0o
15o
.008
.015
.300
(7.62)
BSC
------.430 10.92
June, 2008
17
( 0.20
0.38)
MIN
MAX
MIN
( MAX
( 0.38
28-Lead, 600 mil PDIP
0.530 13.46
0.550 13.97
Pin 1
Index
0.040 1.02
0.050 1.27
1.440 36.58
1.460 37.08
---- ---(4.57) .180
0.015 (0.38)
------0.125 (3.18)
MIN
0.014 0.36
0.022 0.56
0.595
0.625
0.045 1.14
0.060 1.52
0.10
(2.54)
BSC
( 15.11
15.88 )
DIM = INCHES
o
0o
15
0.008 0.20
0.015 0.38
0.600
0.660
(15.24
16.76 )
June, 2008
18
DIM = mm
MIN
MAX
MIN
( MAX
28-Lead, 300 mil Side Braze DIL
1.386
1.414
35.20
(35.92
.280
.310
--.060
7.36
(7.87
PIN
14
--(1.52
.124
( 3.15
4.14 ).162
.040
.060
.125 (3.18)
MIN
.016
.020
.290
.310
(0.41
0.51)
.048
.052
( 7.37
7.87 )
(1.22
1.32)
.090 2.29
.110 2.79
DIM = INCHES
DIM = mm
.009 0.23
.012 0.30
.300 7.62
.320 8.13
June, 2008
19
MIN
MAX
MIN
( MAX
(1.02
1.52)
28-Pad, 350 mil Ceramic LCC
0.542 13.77
0.558 14.17
ο
(1.02) 0.040 REF X 45
3 places
0.342 8.69
0.358 9.09
ο
(0.51) 0.020 REF X 45
1.91
( 2.41
0.045 1.14
0.055 ( 1.40 )
0.075
0.095
(0.23) 0.009 REF
28 places
Pad 1
Index
0.022
0.028
0.56
0.71
0.006
0.022
0.15
0.56
0.045
0.055
( 1.14
1.40 )
0.070 1.78
0.090 2.29
--0.558
--14.17
0.062 1.57
0.078 1.98
0.015
--0.381
DIM = INCHES
DIM = mm
June, 2008
MIN
MAX
MIN
( MAX
Document Revision History
Revision
Date
Summary
0.0
December 2002
Combined commercial, industrial and military data sheets. Removed 20 nsec device.
0.1
January 2003
Added 35ns SMD to order information
0.2
July 2003
Added “28 - SOIC” label to page 1 pinout drawing
0.3
September 2003 Added lead-free lead finish
0.4
October 2003
Restored “W” 600 mil DIP package to ordering information
0.5
March 2006
Removed Commercial 35 ns and leaded lead finish, Removed Military 45ns device
0.6
August 2006
Reformat SMD Ordering Information to SDDC Part Number Format
0.7
February 2007
Add Fast Power-Down Slew Rate Information
Restore Comm/Ind C & L Package Options
Add Tape Reel Ordering Options
Add Product Ordering Code Listing
Add Package Outline Drawings
Reformat Entire Document
0.8
July 2007
extend definition of tHZ (#7)
update fig. SRAM READ CYCLE #2, SRAM WRITE CYCLE #1,
update notes in tables HARDWARE STORE CYCLE, AutoStore / POWER_UP RECALL,
update Note s and Note u
split off SOFTWARE STORE / RECALL MODE SELEKTION table to clarify product usage
2.0
June 2008
Added STK-12C68-5 part number to header.
Page 3: in the DC characteristics table, identified access times valid for commercial and industrial applications only; referred users to Website for package thermal characteristics.
Page 4: in SRAM Read Cycles #1 & #2 table, revised description for tELQX and tELQX, and changed
Symbol #2 to tELEH for Read Cycle Time; updated SRAM Read Cycle #2 timing diagram and changed
title to add G controlled.
Page 11: under HSB Operation, revised first paragraph to read “The HSB pin has a very resistive
pullup...”
Page 14: added access time column to table.
SIMTEK STK12C68, STK12C68-5 Datasheet, June 2008
Copyright 2008, Simtek Corporation. All rights reserved.
This datasheet may only be printed for the expressed use of Simtek Customers. No part of the datasheet may be reproduced in any other
form or means without the express written permission from Simtek Corporation. The information contained in this publication is believed to be
accurate, but changes may be made without notice. Simtek does not assume responsibility for, or grant or imply any warranty, including
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE regarding this information, the product or its use. Nothing herein constitutes a license, grant or transfer of any rights to any Simtek patent, copyright, trademark, or other proprietary right.
June, 2008
21
