WSE9L-3P2437
WSE9L-3P2437
    SICK
    SENSOR THROUGH-BEAM 50M PNP
WSE9L-3P2437 数据手册
Product data sheet WSE9L-3P2437 W9 SMALL PHOTOELECTRIC SENSORS WSE9L-3P2437 | W9 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. WSE9L-3P2437 1058181 Other models and accessories www.sick.com/W9 Illustration may differ Detailed technical data Features Device type Photoelectric sensors Sensor/ detection principle Through-beam photoelectric sensor Dimensions (W x H x D) 12.2 mm x 52.2 mm x 23.6 mm Housing design (light emission) Rectangular Mounting hole M3 Sensing range max. 0 m ... 60 m Sensing range 0 m ... 50 m Type of light Visible red light Light source Laser 1) Light spot size (distance) Ø 1 mm (500 mm) Wave length 650 nm Laser class 1 (IEC 60825-1 / CDRH 21 CFR 1040.10 & 1040.11) Adjustment Single teach-in button Special applications Detecting small objects 1) 2  Average service life: 50,000 h at TU = +25 °C. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-22 19:19:46 Subject to change without notice WSE9L-3P2437 | W9 SMALL PHOTOELECTRIC SENSORS Mechanics/electronics Supply voltage 10 V DC ... 30 V DC 1) Ripple –10 °C, then cools down, and the supply voltage is subsequently not switched off. Switching on below Tu –10 °C is not permissible. Safety-related parameters MTTFD 355 years (EN ISO 13849-1) 1) DCavg 0 % 1)  Mode of calculation: Parts-Count-calculation. Classifications ECl@ss 5.0 2021-10-22 19:19:46 | Product data sheet  Subject to change without notice 27270901 PHOTOELECTRIC SENSORS | SICK 3 WSE9L-3P2437 | W9 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T ECl@ss 5.1.4 27270901 ECl@ss 6.0 27270901 ECl@ss 6.2 27270901 ECl@ss 7.0 27270901 ECl@ss 8.0 27270901 ECl@ss 8.1 27270901 ECl@ss 9.0 27270901 ECl@ss 10.0 27270901 ECl@ss 11.0 27270901 ETIM 5.0 EC002716 ETIM 6.0 EC002716 ETIM 7.0 EC002716 ETIM 8.0 EC002716 UNSPSC 16.0901 39121528 Connection diagram Cd-232 2 1 BN 1 + (L+) BU 3 - (M) BK 4 Not connected WH 2 Not connected BN 1 BK 4 WH 2 BU 3 + (L+) Q Q - (M) ①  Sender ②  Receiver 4 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-22 19:19:46 Subject to change without notice WSE9L-3P2437 | W9 SMALL PHOTOELECTRIC SENSORS Characteristic curve 10000 1000 100 10 Sensing range 1 m Sensing range typ. max. 10 20 30 (feet) (32.81) (65.62) 40 50 60 (98.43) (131.23) (164.04) (196.85) Distance in m (feet) Light spot size Radius in mm (inch) 200 Dimensions in mm (inch) (7.87) 150 (5.91) 100 (3.94) 50 (1.97) 0 –50 (–1.97) –100 Sensing range Vertical Horizontal 0.5 m < 1.0 < 1.0 (1.64 feet) (0.04) (0.04) 1m 1.5 1.2 (3.28 feet) (0.06) (0.05) 5m 15 11 (16.40 feet) (0.59) (0.43) 10 m 45 28 (32.81 feet) (1.77) (1.10) 60 m 336 200 (196.85 feet) (13.23) (7.87) (–3.94) –150 (–5.91) –200 (–7.87) 10 20 (32.81) (65.62) 30 40 50 60 (98.43) (131.23) (164.04) (196.85) Distance in m (feet) 2021-10-22 19:19:46 | Product data sheet  Subject to change without notice Vertical Horizontal PHOTOELECTRIC SENSORS | SICK 5 WSE9L-3P2437 | W9 SMALL PHOTOELECTRIC SENSORS A B C D E F Light spot size (detailed view) Detailed view close range Radius in mm (inch) 10 (0.39) 8 (0.31) 6 (0.24) 4 (0.16) 2 (0.08) 0 –2 (–0.08) –4 (–0.16) –6 (–0.24) –8 (–0.31) –10 1 2 3 4 5 (3.28) (6.56) (9.84) (13.12) (16.40) (–0.39) H I J K L M N O P Q R S T Distance in m (feet) Vertical Horizontal Sensing range diagram 0 0 50 10 20 30 40 50 60 60 (32.81) (65.62) (98.43) (131.23) (164.04) (196.85) Distance in m (feet) Sensing range 6 Sensing range typ. max. PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-22 19:19:46 Subject to change without notice WSE9L-3P2437 | W9 SMALL PHOTOELECTRIC SENSORS Adjustments Single teach-in button 3 4 8 ③  LED indicator yellow: Status of received light beam ④  LED indicator green: power on ⑧  Teach-in button Dimensional drawing (Dimensions in mm (inch)) WSE9L-3 5 (0.01) 0.2 6 52.5 (2.07) 22.1 (0.87) 49.8 (1.96) 8.5 8.5 19.2 (0.76) (0.33) (0.33) 2 1 5.2 (0.2) 3 4 50 (1.97) 5.2 (0.2) 23.6 (0.93) 3.7 (0.15) 19.6 (0.77) 18.2 (0.72) 3 (0.12) 12.2 (0.48) 7 ①  Sender and receiver optical axis center ②  Mounting hole M3 (Ø 3.1 mm) ③  LED indicator yellow: Status of received light beam ④  LED indicator green: power on ⑤  Connecting cable or connecting cable with connector ⑥  Male connector M8, 4-pin ⑦  Male connector M12, 4-pin Recommended accessories Other models and accessories www.sick.com/W9 Brief description Type Part no. BEF-WN-W9-2 2022855 Mounting brackets and plates Mounting bracket, steel, zinc coated, mounting hardware included 2021-10-22 19:19:46 | Product data sheet  Subject to change without notice PHOTOELECTRIC SENSORS | SICK 7 WSE9L-3P2437 | W9 SMALL PHOTOELECTRIC SENSORS A B C D E F H I J K L M N O P Q R S T Brief description Type Part no. YF2A14050VB3XLEAX 2096235 STE-1204-G 6009932 Plug connectors and cables Head A: female connector, M12, 4-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PVC, unshielded, 5 m Head A: male connector, M12, 4-pin, straight Head B: Cable: unshielded 8 PHOTOELECTRIC SENSORS | SICK Product data sheet | 2021-10-22 19:19:46 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
WSE9L-3P2437
物料型号:WSE9L-3P2437,型号编号为1058181。
器件简介:SICK W9系列小型光电传感器,采用透射式光电检测原理,适用于检测小型物体。
引脚分配:4针M12公头连接器,包括正极(L+)、负极(M)、接收器(BU)和发射器(BK)。
参数特性: - 供电电压:10V DC至30V DC。 - 电流消耗:30mA(无负载)。 - 输出类型:PNP,互补输出。 - 响应时间:0.5毫秒。 - 工作频率:1000Hz。 - 连接类型:M12 4针公头连接器。 - 保护等级:IP66、IP67、IP69K。 - 环境工作温度:-10°C至+50°C。
功能详解: - 传感器类型:光电传感器。 - 检测原理:透射式。 - 尺寸:12.2 mm x 52.2 mm x 23.6 mm。 - 发光类型:可见红光,激光。 - 光斑大小:在500mm处为1mm。 - 波长:650nm。 - 激光类别:1(符合IEC 60825-1/CDRH 21 CFR 1040.10 & 1040.11)。
应用信息:适用于检测小型物体。
封装信息: - 外壳材料:塑料,VISTAL。 - 光学材料:塑料,PMMA。 - 重量:13g。
WSE9L-3P2437 价格&库存
很抱歉,暂时无法提供与“WSE9L-3P2437”相匹配的价格&库存,您可以联系我们找货
