Installation
Guide
Q25 Sensors – ac-Voltage Series
Self-contained, ac-operated sensors
Additional information on this product is immediately available online at www.bannerengineering.com/116166
View or download additional information, including excess gain curves, beam patterns and accessories.
For further assistance, contact a Banner Engineering Applications Engineer at (763) 544-3164 or (888) 373-6767.
Sensing Mode
Range
LED
20 m (66')
Infrared
950 nm
Output
Opposed
Polarized
Retroreflective
P
Visible
Red
680 nm
2 m (79")
25 mm (1")
cutoff
R
50 mm (2")
cutoff
Fixed
Field
LISTED
Cabled Emitters
Infrared
880 nm
bn
20-250V ac
bu
100 mm (4")
cutoff
QD Emitters
(4-pin Micro-Style)
20-250V ac
rd
20-250V ac
30.0 mm*
(1.18")
35.0 mm
(1.38")
All Other QD Models
(4-pin Micro-Style)
rd/bk
rd
gn
Q25RW3R
LO
Q25AW3LP
DO
Q25RW3LP
LO
Q25AW3FF25
DO
Q25RW3FF25
LO
Q25AW3FF50
DO
Q25RW3FF50
LO
Q25AW3FF100
DO
Q25RW3FF100
Green LED
Power Indicator
25.0 mm
(0.98")
Load
rd/wh
DO
Yellow LED
Output Indicator
bn
bk
Q25AW3R
QD Models
Cabled Models
All Other Cabled Models
bu
LO
Dimensions
No Connection
gn
Q253E
* Standard 2 m (6.5') cable models are listed.
• 9 m (30') cable: add suffix “W/30” (e.g., Q253E W/30).
• 4-pin Micro-style QD models: add suffix “Q1” (e.g., Q253EQ1). A model with a QD connector
requires a mating cable.
rd/bk
rd/wh
Model*
20-250V ac
Load
No Connection
Lens Centerline
12.4 mm
(0.49")
15.2 mm
(0.60")
*Fixed-field models = 31.0 mm (1.22")
M18 x 1 Thread
(Jam Nut Supplied)
12.7 mm
(0.50")
2 m (6.5') Cable
Printed in USA
WARNING . . .
Not To Be Used for Personnel Protection
Never use these products as sensing devices for personnel protection. Doing so could lead to serious injury or death.
These sensors do NOT include the self-checking redundant circuitry necessary to allow their use in personnel safety
applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition.
Consult your current Banner Safety Products catalog for safety products which meet OSHA, ANSI and IEC standards for
01/12
P/N 116166 rev. B
Specifications
Supply Voltage and Current
20 to 250V ac (50/60 Hz). Average current: 20 mA
Peak current: 200 mA at 20V ac, 500 mA at 120V ac, 750 mA at 250V ac
Supply Protection Circuitry
Protected against transient voltages
Output Configuration
SPST solid-state ac switch; Three-wire hookup; Choose light operate or dark
operate models
Light Operate: Output conducts when sensor sees its own (or the emitter’s)
modulated light
Dark Operate: Output conducts when the sensor sees dark
Output Rating
300 mA maximum (continuous);
Fixed-Field Models: derate 5 mA/°C above +50°C (+122°F)
Inrush Capability 1 amp for 20 milliseconds, non-repetitive
OFF-state leakage current: < 100 microamps
ON-state saturation voltage: 3V at 300 mA ac; 2V at 15 mA ac
Output Protection Circuitry
Protected against false pulse on power-up
Output Response Time
Opposed Mode: 16 milliseconds ON, 8 milliseconds OFF
Other Models: 16 milliseconds ON and OFF
NOTE: 100 millisecond delay on power-up
Repeatability
Opposed Mode: 2 milliseconds
Other Models: 4 milliseconds
Repeatability and response are independent of signal strength.
Indicators
Two LEDs (Green and Yellow)
Green ON steady: power to sensor is ON
Yellow ON steady: sensor sees light
Yellow flashing: excess gain marginal (1 to 1.5x) in light condition
Construction
PBT polyester housing; polycarbonate (opposed-mode) or acrylic lens
Environmental Rating
Leakproof design rated NEMA 6P, DIN 40050 (IP69K)
Connections
2 m (6.5') attached cable, or 4-pin Micro-style quick-disconnect fitting
Operating Conditions
Temperature: -40° to +70°C (-40° to +158°F);
Maximum relative humidity: 90% at 50°C (non-condensing)
Vibration and Mechanical Shock
All models meet Mil. Std. 202F requirements. Method 201A (Vibration;
frequency 10 to 60 Hz, max., double amplitude 0.06" acceleration 10G).
Method 213B conditions H&I (Shock: 75G with unit operating; 100G for
non-operation)
Certifications
R
LISTED
Quick-Disconnect (QD) Cables
Style
4-pin
Micro-style
Straight
Model
MQAC-406
MQAC-415
MQAC-430
Length
2 m (6.5')
5 m (15')
9 m (30')
Dimensions
Pinout
38 mm max.
(1.5")
4-pin
Micro-style
Right-angle
MQAC-406RA
MQAC-415RA
MQAC-430RA
2 m (6.5')
5 m (15')
9 m (30')
Green Wire
Red Wire
Red/White
Wire
Red/Black
Wire
38 mm max.
(1.5")
1/2-20UNF-2B
ø 15 mm
(0.6")
Banner Engineering Corp Limited Warranty
Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective
during the warranty period.This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product.
THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF
PERFORMANCE, COURSE OF DEALING OR TRADE USAGE.
This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING
CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY
INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE
PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE.
Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any
product previously manufactured by Banner Engineering Corp.
P/N 116166 rev. B
Banner Engineering Corp., 9714 Tenth Ave. No., Minneapolis, MN USA 55441 • Phone: 763.544.3164 • www.bannerengineering.com • Email: sensors@bannerengineering.com
很抱歉,暂时无法提供与“Q25RW3LP W/15”相匹配的价格&库存,您可以联系我们找货
