VS3AP5XLV
VS3AP5XLV
    BANNER(邦纳)
    VS3 SERIES: NON-POLARIZED RETRO
VS3AP5XLV 数据手册
VS3 Series Retroreflective Mode Sensors Miniature self-contained sensors VS3 Series Retroreflective Mode Sensor Features • Extremely compact self-contained miniature sensor • Coaxial optics eliminate “blind” area at close range • Visible red sensing beam (both polarized and non-polarized versions) • Range to supplied retroreflector is 0 to 250 mm (up to 10") • 10 to 30V dc operation • Choice of integral cable or quick-disconnect connector • 3-wire hookup; output load capacity to 50 mA • Choose models with NPN (sinking) or PNP (sourcing) output • Choose dark- or light-operate models User Application Notes: • The VS3...XLP series should be used for general sensing applications like packages, small parts, mirror-like surfaces, or documents. They are most effective when used with the supplied micro-prism reflector. • When using glass bead tape, (e.g., 3M model 6870), non-polarized models (...XLV) must be used. These models should also be considered when a glass lens (as in the LP models) is not permitted in the sensing environment. P • For non-polarized sensors, an object’s surface reflection (e.g., polished stainless steel), may be more reflective than low-grade retro-reflective tape, and “bright” object transition may never be detected by the non-polarized sensor. Visible Red, 680 nm VS3 Series Retroreflective-Mode Sensors Models Supply Voltage Cable Output Type Excess Gain Beam Pattern Non-Polarized Models 1000 VS3AN5XLV VS3AN5XLVQ VS3RN5XLV VS3RN5XLVQ VS3AP5XLV VS3AP5XLVQ 2 m (6.5') 3-Pin Pico QD 250 mm (10") using BRT32X20AM retro target (supplied) VS3RP5XLV VS3RP5XLVQ 2 m (6.5') 3-Pin Pico QD 2 m (6.5') 3-Pin Pico QD NPN Light Operate 10 to 30V dc 2 m (6.5') 3-Pin Pico QD NPN Dark Operate PNP Light Operate E X C E S S VS3XLV 100 VS3XLV 15 mm Retroreflective Mode 0.60 in 10 mm 0.40 in Retroreflective Mode 5 mm 0 5 mm G A I N with BRT32X20AM Reflector 10 10 mm with BRT32X20AM Reflector 1 1 mm 0.04 in PNP Dark Operate 0.20 in 0 15 mm 100 mm 4 in 0.40 in 0.60 in 0 10 mm 0.4 in 0.20 in 1000 mm 40 in 50 mm 100 mm 150 mm 200 mm 250 mm 2.0 in 4.0 in 6.0 in 8.0 in 10.0 in DISTANCE DISTANCE Polarized Models 1000 VS3AN5XLP VS3AN5XLPQ VS3RN5XLP VS3RN5XLPQ VS3AP5XLP VS3AP5XLPQ VS3RP5XLP VS3RP5XLPQ 2 m (6.5') 3-Pin Pico QD 250 mm (10") using BRT32X20AM retro target (supplied) 2 m (6.5') 3-Pin Pico QD 2 m (6.5') 3-Pin Pico QD 2 m (6.5') 3-Pin Pico QD NPN Light Operate 10 to 30V dc NPN Dark Operate PNP Light Operate PNP Dark Operate E X C E S S VS3XLP 100 VS3XLP 15 mm Polarized Retroreflective Mode 0.40 in Retroreflective Mode 5 mm 0.20 in 0 0 5 mm G A I N 0.60 in 10 mm with BRT32X20AM Reflector 10 10 mm with BRT32X20AM Reflector 1 1 mm 0.04 in 15 mm 100 mm 4 in 1000 mm 40 in 0.40 in 0.60 in 0 10 mm 0.4 in 0.20 in 50 mm 100 mm 150 mm 200 mm 250 mm 2.0 in 4.0 in 6.0 in 8.0 in 10.0 in DISTANCE DISTANCE See Safety Use Warning on Back Page. Printed in USA Jan07/02 2013 p/n 63226rev. Rev.AB P/N 63226 VS3 Series Retroreflective Mode VS3 Series Overview 20 mm (0.8") VS3 Series miniature self-contained sensors are designed for retroreflective sensing in small areas previously accessible only to remote or fiber optic models. Typical applications include mounting on small feeder tracks, packaging machines, and conveyors, where larger sensors will not fit. 3.0 mm (.12") 26 mm 20 mm 32 mm (1.0") (0.8") (1.1") The coaxial optics of the VS3 allow the retroreflective target to be placed as close to the sensor lens as needed – there is no “blind” response area, as is typical of most retroreflective sensors. The VS3 is supplied with a Banner model BRT32X20AM retroreflective target (see right). The specifications shown on page 1 assume use of this target. ø3.5 mm (0.14") 2.0 mm (0.08") Maximum Temperature: 65°C (150°F) Figure 1. Retroreflective target, model BRT-32X20AM (supplied with each sensor) Other retroreflective materials may be substituted. For example, using the standard BRT-3 target, the range becomes 400 mm (16"); standard BRT-THG retroreflective tape yields a 150 mm (6") range. Contact Banner Engineering for sensing performance when using other retroreflective targets. VS3 Series Specifications Supply Voltage and Current 10 to 30V dc (10% maximum ripple) at less than 25 mA (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration SPST solid-state switch Choose NPN (current sinking) or PNP (current sourcing) models Choose light operate (N.O.) or dark operate (N.C.) models Output Rating 50 mA maximum OFF-state leakage current: < 1 microamp at 24V dc ON-state saturation voltage: < 0.25V at 10 mA dc; < 0.5V at 50 mA dc Output Protection Circuitry Protected against false pulse on power-up and continuous overload or short circuit of outputs Overload trip point ≥ 100 mA Output Response Time 1 millisecond ON and OFF (NOTE: 150 millisecond delay maximum on power-up: output does not conduct during this time) Repeatability 160 microseconds Indicators Two LEDs: Green and Yellow Green ON steady: power to sensor is ON Green flashing: output overload Yellow ON steady: light is sensed Construction XLV Models: Black ABS housing with acrylic lens XLP Models: Black ABS housing with glass lens and acrylic cover Environmental Rating IEC IP67; NEMA 6 Connections 2 m (6.5') attached cable: three #28 ga stranded conductors with PE insulation; PVC outer cable jacket; or 3-pin Pico-style threaded quick-disconnect fitting. QD cables are ordered separately. Operating Conditions Temperature: -20° to +55°C (-4° to +131°F) Maximum Relative Humidity: 80% at 50°C (non-condensing) Vibration and Mechanical Shock Vibration: All models meet IEC 60068-2-6, IEC 60947-5-2, UL491 Section 40, MIL-STD-202F Method 201A; 10 to 60 Hz, 0.5 mm peak to peak Shock: All models meet IEC 60068-2-27, IEC 60947-5-2; 30g peak acceleration, 11 millisecond pulse duration, half-sine wave pulse shape Application Notes M3 stainless steel mounting hardware included. Optional mounting brackets are available (page 4). Certifications page 2 Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 VS3 Series Retroreflective Mode VS3 Series Sensor Hookups Sensors with PNP Outputs Cabled Models Sensors with NPN Outputs Cabled Models bu bn – 10-30V dc + bn bk bu bk Load bn – 10-30V dc + bn bk Load Quick-Disconnect Models Quick-Disconnect Models bu + 10-30V dc – + 10-30V dc – bu bk Load Load VS3 Series Retroreflective Mode Sensor Dimensions VS3...5XLV 4.5 mm (0.18") 16.4 mm (0.65") 9 mm (0.35") VS3...5XLVQ 15.6 mm (0.61") 12.6 mm (0.50") 14.2 mm (0.56") 25.4 mm (1.00") With Integral Cable ø3.2 mm (0.13") 35.2 mm (1.39") 30 mm (1.2") 7.3 mm (0.29") VS3...5XLPQ VS3...5XLP 4.5 mm (0.18") 16.4 mm (0.65") 9 mm (0.35") 16.6 mm (0.65") 13.6 mm (0.54") 25.4 mm (1.00") 14.2 mm (0.56") With Right-angle QD Cable With Straight QD Cable ø3.2 mm (0.13") 35.2 mm (1.39") 7.3 mm (0.29") 47 mm (1.9") 75 mm (3.0") Banner Engineering Corp. • Minneapolis, U.S.A. www.bannerengineering.com • Tel: 763.544.3164 page 3 VS3 Series Retroreflective Mode Accessories Quick-Disconnect (QD) Cables Style 3-pin Pico Style Straight Models Length PKG3M-2 2 m (6.5') PKG3M-9 For Use With Dimensions 34.7 mm (1.37") All VS3 Series sensors with model suffix “Q”. 3-pin Pico Style Right-angle 2 m (6.5') PKW3M-9 9 m (30') M8 x 1 Black Wire 9.6 mm (0.38") 9 m (30') PKW3M-2 Pinout 23.5 mm (0.93") Blue Wire Brown Wire Black Wire Blue Wire Brown Wire 16.5 mm (0.65") ø9.6 mm (0.38") M8 x 1 VS3 Series Mounting Brackets SMBVS3S • Right-angle bracket • 300 series stainless steel • Right-angle tall bracket • 300 series stainless steel SMBVS3T 2x 3.2 mm (0.13") 40° Ø13.5mm (0.53") 40° 6.0 mm (0.24") 4x 3.30 mm (0.13") 5.0 mm (0.20") 16.0 mm (0.63") 16.0 mm (0.63") Ø13.5 mm (0.53") 11.8 mm (0.46") 13.5 mm (0.53") .9 mm (0.04") 23.5 mm (0.93") 7.0 mm (0.28") 13.5 mm (0.53") 3x 3.3 mm (0.13") 51.6 mm (2.03") 5.0 mm (0.20") 0.9 mm (0.04") 13.5 mm (0.53") 20.5 mm (0.81") 18.0 mm (0.71") ! WARNING . . . Not To Be Used for Personnel Protection Never use these products as sensing devices for personnel protection. Doing so could lead to serious injury or death. These sensors do NOT include the self-checking redundant circuitry necessary to allow their use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Consult your current Banner Safety Products catalog for safety products which meet OSHA, ANSI and IEC standards for personnel protection. WARRANTY: Banner Engineering Corp. warrants its products to be free from defects for one year. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture found to be defective at the time it is returned to the factory during the warranty period. This warranty does not cover damage or liability for the improper application of Banner products. This warranty is in lieu of any other warranty either expressed or implied. Banner Engineering Corp., 9714 Tenth Ave. No., Minneapolis, MN 55441 • Phone: 763.544.3164 • www.bannerengineering.com • Email: sensors@bannerengineering.com Banner Engineering Corp Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period.This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. P/N 63226 Rev. B Banner Engineering Corp., 9714 Tenth Ave. No., Minneapolis, MN 55441 • Phone: 763.544.3164 • www.bannerengineering.com • Email: sensors@bannerengineering.com
VS3AP5XLV 价格&库存
很抱歉,暂时无法提供与“VS3AP5XLV”相匹配的价格&库存,您可以联系我们找货
