QS18AB6AF300
QS18AB6AF300
    BANNER(邦纳)
    PHOTO SEN BACK SUPP 30-300MM
QS18AB6AF300 数据手册
WORLD-BEAM® QS18AF Mechanically Adjustable Background Suppression Sensor (30-300mm) Datasheet Compact sensors featuring extended range and background suppression mode • • • • • • Exceptional optical performance; up to 300 mm sensing range in compact QS18 housing Background suppression models for reliable detection of objects when the background condition is not controlled or fixed Simple multi-turn screw adjustment of cutoff distance Enhanced immunity to fluorescent lights Crosstalk immunity algorithm allows two sensors to be used in close proximity Visible red emitter WARNING: Not To Be Used for Personnel Protection Never use this device as a sensing device for personnel protection. Doing so could lead to serious injury or death. This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A sensor failure or malfunction can cause either an energized or de-energized sensor output condition. Models Models1 Supply Voltage QS18VN6AF300 Sensing Range Adjustable Cutoff: 30 to 300 mm QS18VP6AF300 10 to 30 V dc QS18AB6AF300 Minimum sensing range 4 to 10 mm depending on cutoff Output Type NPN PNP Bipolar (1 NPN & 1 PNP) Overview WORLD-BEAM® QS18 Adjustable-Field Sensors with Background Suppression ignore objects beyond the set cutoff distance. Background suppression mode can be used in most situations with varying object color and position or with varying background conditions. 2 3 1 1 Green: Power Indicator 2 Yellow: Light Sensed Indicator (Flashes for Marginal Conditions) 3 Cutoff Point Adjustment Screw Figure 1. Sensor features 1 Only standard 2 m (6.5 ft) cable models are listed. • To order 9 m (30 ft) cable models: add suffix “W/30” to the model number (for example, QS18VN6AF300 W/30). • To order 150 mm (6 in) pigtail with a 4-pin Pico-style connector models, add suffix “Q” to the model number (for example, QS18VN6AF300Q) • To order 150 mm (6 in) pigtail with a 4-pin Euro-style connector models, add suffix “Q5” to the model number (for example,QS18VN6AF300Q5) Original Document 146923 Rev. G 11 September 2018 146923 WORLD-BEAM® QS18AF Mechanically Adjustable Background Suppression Sensor (30-300mm) Sensor Orientation To ensure reliable detection, orient the sensor as shown in relation to the target to be detected. Figure 2. Optimal Orientation of Target to Sensor Wiring Diagrams Cabled wiring diagrams are shown.Quick disconnect (QD) wiring diagrams are functionally identical. NPN (Sinking) Outputs 3 – 10-30V dc + 1 4 2 PNP (Sourcing) Outputs 1 4 Load 2 Load + 10-30V dc – 3 Wiring Key 1 = Brown 2 = White 3 = Blue 4 = Black Load Load Bipolar Outputs 1 + 10-30V dc – 3 2 4 Load Load Sensor Setup - Background Suppression Background Suppression Mode: Objects beyond the set cutoff distance will not be detected. Background suppression mode can be used in most situations with varying object colors and positions or with varying background conditions. To ensure reliable background suppression, a minimum separation distance between the object and the background is necessary. See Figure 7 on page 5 to determine the minimum separation distance. 2 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 146923 Rev. G WORLD-BEAM® QS18AF Mechanically Adjustable Background Suppression Sensor (30-300mm) 1. Mount the sensor with the darkest object at the longest application distance. The distance to the object must be less than shown in Figure 7 on page 5 for your object color. 2. Turn the adjustment potentiometer counter-clockwise until the yellow indicator turns off (5 turns maximum). 3. Turn the adjustment potentiometer clockwise until the yellow indicator turns on. 4. Replace the darkest object with the brightest background at the closest application distance. 5. Turn the adjustment potentiometer clockwise, counting the revolutions, until the yellow indicator turns on. 6. Turn the adjustment potentiometer counter-clockwise half of the number of turns from step 5. This places the cutoff distance midway between the object and the background switchpoints (see Figure 3 on page 3). Object Background Y X Cutoff Distance X: Distance to the Object Y: Minimum Separation Between the Object and the Background The sensor is ready for operation. Figure 3. Set the cutoff distance approximately midway between the farthest object and the closest background Setup Example An object with a reflectivity similar to black paper is set 150 mm away from the sensor. A background with a reflectivity similar to white paper is set 200 mm away from the sensor. According to Figure 7 on page 5 , the minimum separation distance between the object and the background is 12 mm. In this application, reliable detection is achieved when set up according to the procedure outlined in Sensor Setup - Background Suppression on page 2. 1. Object 2. Conveyor 3. Background X: Distance to the Object = 150 mm Y: Minimum Separation Between the Object and the Background > 12 mm Y X Figure 4. Background Suppression Mode Application Example Output States Background Suppression Mode Sensor Model Type Output Object Inside Minimum Sensing Range Object Between Minimum Sensing Range and Cutoff Distance Object Beyond Cutoff Distance All Models Yellow Indicator Light Undefined ON OFF Black Wire (Pin 4) Undefined ON OFF White Wire (Pin 2) Undefined OFF ON Black Wire (Pin 4) Undefined ON OFF White Wire (Pin 2) Undefined ON OFF Complementary Models Bipolar Models P/N 146923 Rev. G www.bannerengineering.com - Tel: +1-763-544-3164 3 WORLD-BEAM® QS18AF Mechanically Adjustable Background Suppression Sensor (30-300mm) Specifications Supply Voltage 10 to 30 V dc (10% maximum ripple within specified limits) at less than 16 mA, exclusive of load Sensing Beam Visible red LED, 640 nm Output Response 2.8 millisecond ON/OFF Note: 200 millisecond delay on power-up; outputs do not conduct during this time Adjustments Five-turn adjustment screw sets cutoff distance between min. and max. positions, clutched at both ends of travel Supply Protection Circuitry Protected against reverse polarity and transient voltages Output Configuration Solid-state complementary: NPN or PNP (current sinking or sourcing), or bipolar (both sinking and sourcing) depending on model; Rating: 100 mA total output current Off-state leakage current: < 50 µA at 30 V dc ON-state saturation voltage: < 1.5 V at 10 mA; < 3.0 V at 100 mA Protected against false pulse on power-up and continuous overload or short circuit of outputs Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Indicators 2 LED indicators on sensor top: Green solid: Power on Amber solid: Light sensed Amber flashing: Marginal sensing condition Construction ABS housing, acrylic lens cover; PVC cable, nickel-plated brass connector, acetal adjustment pot Environmental Rating IEC IP67; NEMA 6; UL Type 1 Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Repeatability 250 µs Connections 2 m (6.5 ft) 4-wire PVC cable, 9 m (30 ft) PVC cable, or 4-pin Pico-style or Eurostyle 150 mm (6 in) pigtail QD, depending on model Operating Conditions Relative Humidity: 95% relative humidity at 50 °C (non-condensing) Temperature: –20 °C to 55 °C (–4 °F to 131 °F) Application Notes For mirror-like objects, minimize the sensor to object mounting distance and tilt the sensor so reflected light is directed away from the sensor when the object is present. Certifications Performance Curves 25 15 Emitter Spot Diameter (mm) Minimum Sensing Range (mm) for 6% Blk QS18AF300 Minimum Sensing Range vs. 90% White Cuttoff Setting 10 5 20 15 10 5 0 0 0 50 100 150 200 250 300 350 0 50 4 150 200 250 300 350 Range (mm) 90% White Card Cutoff Setting (mm) Figure 5. Minimum Sensing Range (Dead Zone) vs. 90% White Cutoff Setting 100 Figure 6. Typical Emitter Spot Diameter vs. Distance www.bannerengineering.com - Tel: +1-763-544-3164 P/N 146923 Rev. G WORLD-BEAM® QS18AF Mechanically Adjustable Background Suppression Sensor (30-300mm) Object QS18AF300 Minimum Separation Between Object to Background (Background Suppression Mode) Background 30 Minimum Sepparation Object to Background Dimension "Y" (mm) Object/Background black/white 25 gray/white Y 20 X 15 white/white 10 Cutoff Distance 5 X: Distance to Object (mm) 0 0 50 100 150 200 250 300 350 Distance to Object, Dimension "X" (mm) Figure 7. Minimum Separation Distance Between Object and Background: Background Suppression Mode Y: Minimum Separation Between Object and Background (mm) Excess Gain Curves 1000 EXCESS GAIN EXCESS GAIN 1000 100 10 1 100 10 1 1 10 100 1000 1 DISTANCE (mm) Figure 8. Excess Gain Curve with 30 mm Cutoff (based on 90% White Card) P/N 146923 Rev. G 10 100 1000 DISTANCE (mm) Figure 9. Excess Gain Curve with 300 mm Cutoff (based on 90% White Card) www.bannerengineering.com - Tel: +1-763-544-3164 5 WORLD-BEAM® QS18AF Mechanically Adjustable Background Suppression Sensor (30-300mm) Dimensions All measurements are listed in millimeters [inches], unless noted otherwise. 5.5 mm (0.22") 7.5 mm (0.30") 15.0 mm (0.59") 21.0 mm (0.83") 3.8 mm (0.15") 34.5 mm (1.36") 5.2 mm (0.20") 9.0 mm (0.35") 3.0 mm (0.12") 24.1 mm (0.95") 12.0 mm (0.47") M2.5 Hardware Included* M3 Hardware Included* 3.8 mm (0.15") 13.4 mm (0.53") *M3 Hardware for Sidemount M2.5 Hardware for Mounting to Threaded Inserts Max. torque 0.6 nm (5 in. lbs) (2) M3 x 0.5 x 20 mm ss screw (2) M3 x 0.5 ss hex nut (2) M3 ss washer (2) M2.5 x 0.45 x 5 mm ss screw (2) M2.5 ss washer Accessories Quick-Disconnect (QD) Cordsets 4-Pin Snap-on M8/Pico-Style Cordsets Model Length Style Dimensions Pinout (Female) 4 32 Typ. PKG4-2 2 m (6.56 ft) 2 1 3 Straight ø 9.0 1 = Brown 2 = White 3 = Blue 4 = Black 6 www.bannerengineering.com - Tel: +1-763-544-3164 P/N 146923 Rev. G WORLD-BEAM® QS18AF Mechanically Adjustable Background Suppression Sensor (30-300mm) 4-Pin Threaded M12/Euro-Style Cordsets Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 Style Dimensions Pinout (Female) 9.14 m (30 ft) 3 4 Straight MQDC-450 2 1 44 Typ. M12 x 1 ø 14.5 15.2 m (50 ft) 1 = Brown 2 = White 3 = Blue 4 = Black Mounting Brackets All measurements are listed in millimeters, unless noted otherwise. SMBQS18A • Wrap-around protection bracket • Die-cast bracket • Base fits 18 mm threaded hole • Metal hex nut, lock washer and grommet included • Mounting holes specially designed for QS18AF sensors 19 62 25 A SMBQS18AF • Right-angle mounting bracket • 14-ga. 304 stainless steel Hole center spacing: A to B = 20.3 Hole size: A = 4.3 × 9.4, B = ø 4.3 44 A B 15 32 Hole size: A = ø 15.3 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. © Banner Engineering Corp. All rights reserved
QS18AB6AF300 价格&库存
很抱歉,暂时无法提供与“QS18AB6AF300”相匹配的价格&库存,您可以联系我们找货
QS18AB6AF300
  • 1+1131.577961+145.31943
库存:1
