Q12AB6FF15 W/30
Q12AB6FF15 W/30
    BANNER(邦纳)
    WORLD-BEAM Q12 SERIES: FIXED-FIE
Q12AB6FF15 W/30 数据手册
WORLD-BEAM® Q12 Miniature self-contained photoelectric sensors in universal housing Features • Bright, visible red (640 nm) light source • 10 to 30V dc operation • Solid-state, bipolar outputs: one current sourcing (PNP) and one current sinking (NPN) • Light Operate (L.O.) or Dark Operate (D.O.), depending on model • Models available with PFA chemical-resistant jacket (1200 psi washdown rated) for use in harsh environments (see page 2). Standard Model Chemical-Resistant Model • Standard models available with 4-wire, 2 m (6.5') or 9 m (30') cable or 150 mm (6") pigtail with Pico-style M8 threaded connector • Compact 8 mm (0.31") housing mounts almost anywhere • Crosstalk-avoidance circuitry for multiple-sensor applications • LED status indicators for Power ON, Output Overload, Signal Received, and Marginal Signal Standard Models Opposed 640 nm Visible Red Effective Beam: 5.7 mm (0.22") Model* Range Q126E Sensing Mode Model* 640 nm Visible Red Bipolar L.O. Q12AB6FF30 30 mm (1.2") cutoff; Bipolar L.O. Q12RB6FF30 16 mm (0.63") focus Bipolar D.O. Bipolar L.O. Q12AB6FF50 50 mm (2") cutoff; Bipolar L.O. Bipolar D.O. Q12RB6FF50 16 mm (0.63") focus Bipolar D.O. Q12AB6FF15 Q12RB6R Bipolar D.O. Q12RB6FF15 Q12AB6LP Bipolar L.O. 2m (6.5') Q12RB6LP 1 m† (40") 640 nm Visible Red Retro Q12AB6LV Q12RB6LV 1.5 m† (59") Output 15 mm (0.6") cutoff; 10 mm (0.4") focus Bipolar L.O. Q12AB6R Range Performance based on use of 90% reflectance white test card. N/A 640 nm Visible Red Polarized Retro Output Bipolar D.O. Fixed-Field Sensing Mode Bipolar D.O. *Only standard 2 m (6.5') cable models are listed. For 9 m (30') cable, add suffix “W/30” to the model number (e.g., Q126E W/30). QD models: For 4-pin 150 mm (6") pigtail with threaded Pico-style M8 connector, add suffix “Q” (e.g. Q126EQ). †Retroreflective range is specified using one model BRT-60X40C retroreflector. Actual sensing range may be more or less than specified, depending upon efficiency and reflective area of the retroreflector(s) used. WORLD-BEAM® Q12 Specifications Sensing Beam 640 nm visible red Supply Voltage and Current Supply Protection Circuitry 10 to 30V dc (10% max. ripple) @ 20 mA max current Output Configuration Bipolar (1 NPN and 1 PNP) solid-state, L.O. or D.O. depending on model Output Ratings Output Protection Circuitry Protected against reverse polarity and transient voltages 50 mA total across both outputs with overload and short circuit protection OFF-state leakage current: ON-state saturation voltage: NPN: 200 µA NPN: 1.25V @ 50 mA PNP: 10 µA PNP: 1.45V @ 50 mA Protected against false pulse on power-up, short-circuit protected Output Response Time Opposed Mode: 1.3 ms ON; 900 µs OFF All Other Modes: 700 µs ON/OFF NOTE: 120 ms delay on power-up; outputs do not conduct during this time. Repeatability 175 microseconds Switching Frequency Opposed Mode: 385 Hz All Other Modes: 715 Hz Indicators One Yellow and one Green LED (see Figure 1) Construction Environmental Rating Connections Operating Conditions Certifications Polarized Retro Models: Thermoplastic elastomer housing with glass lens All Other Standard Models: Thermoplastic elastomer housing with polycarbonate lens Chemical-Resistant Models: Housing encased in PFA jacket; cable encased in 3/16" O.D. PFA tubing Standard Models: IEC IP67 Chemical-Resistant Models: IEC IP67 and 1200 PSI Washdown NEMA ICS 5, Annex F-2002 Standard Models: 2 m (6.5') or 9 m (30') attached PVC cable, or 150 mm (6") pigtail with M8 threaded connection Chemical-Resistant Models: 2 m (6.5') cable encased in 3/16" O.D. PFA tubing Operating temperature: -20° to +55° C (-4° to +131° F) Storage temperature: -30° to +75° C (-22° to +167° F) Relative humidity: 90% max @ +50° C (+122° F) non-condensing WORLD-BEAM® Q12 Dimensions Standard Models Chemical-Resistant Models 22.6 mm (0.89") 12.4 mm (0.49") 12.5 mm (0.49") 8.1 mm (0.32") Mounting hardware not included M3 mounting screws included 8.0 mm (0.31") 5.9 mm (0.23") 15.0 mm (0.59") 5.1 mm (0.20") 23.1 mm (0.91") 22 mm (0.86") 4.7 mm (0.19") Polarized Retro Models Ø 3.4 mm (0.13") max. torque* 0.9 Nm (8 in-lbf) 15.0 mm (0.59") 3.2 mm (0.13") Emitter 28.8 mm (1.13") 10.7 mm (0.42") 8.6 mm (0.34") 3.5 mm (0.14") 6.2 mm (0.25") 3.4 mm (0.13") Ø 3 mm (0.12") max. torque 0.9 Nm (8 in-lbf) 5.5 mm (0.22") Ø12.5 mm (0.49") * When mounting by running a screw through both flanges without support between the flanges, the max. torque applied should be 0.1 Nm (1 in-lbf). 4.7 mm (0.18") 4.8 mm (0.19") O.D. PFA Tube 2 m (6.5')
Q12AB6FF15 W/30 价格&库存
很抱歉,暂时无法提供与“Q12AB6FF15 W/30”相匹配的价格&库存,您可以联系我们找货
