GL50-RT/32/40A/98A
GL50-RT/32/40A/98A
    PEPPERL+FUCHS(倍加福)
    PHOTO SEN 50MM SLOT PNP
GL50-RT/32/40A/98A 数据手册
Photoelectric slot sensor GL50-RT/32/40a/98a Dimensions 10.5 10 10.5 D+ - 10 H L2 5 L1 5 L1 L2 L3 L4 L5 GL30... 30 50 35 60 33 GL50... 50 70 55 80 53 9 L5 8 4.5 5 R L4 L3 GL80... 80 100 55 80 83 3 x ø 4.3 M8 x 1 4.5 Model Number GL50-RT/32/40a/98a Photoelectric slot sensor Electrical connection /98a with 3-pin, M8 x 1 connector Features 1 +UB 4 Q 3 0V • Optimized for the detection of small parts • High switching frequency • Multiple device installation possible, no mutual interference (no cross-talk) • Sensitivity adjuster and light/dark switch as standard features of this series • Visible red light • Degree of protection IP67 • cULus approval = Light on = Dark on Pinout • Diecast zinc housing, powder coated Wire colors in accordance with EN 60947-5-2 Product information 1 3 4 4 (brown) (blue) (black) 3 Indicators/operating means 1 2 3 1 Functional display red 2 Light-/dark switch H D+ - 3 Sensitivity adjuster Release date: 2019-11-26 15:14 Date of issue: 2019-11-26 199990_eng.xml 1 Photoelectric slot sensors offer vast installation benefits thanks to their housing design. When it comes to operation, these new generation devices boast features such as high resolution, high repeatability, automatic signal threshold adjustment, ambient light resistance, and detection of and/or light transmission through transparent objects. Cross-talk protection enables parallel installation of devices despite extremely high switching frequency. These characteristics guarantee reliable detection of small parts, from 0.3 mm, across the entire detection range, even in very fast moving applications. BN BU BK Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Photoelectric slot sensor GL50-RT/32/40a/98a Technical data Accessories General specifications Light source Light type Tests Target size Slot width Slot depth Ambient light limit LED modulated visible red light EN 60947-5-2 0.3 mm 50 mm 55 mm 100000 Lux Functional safety related parameters MTTFd Mission Time (TM) Diagnostic Coverage (DC) 1290 a 20 a 0% Indicators/operating means Function indicator Control elements LED red in connector Sensitivity adjuster, light/dark switch Electrical specifications Operating voltage Ripple No-load supply current Output Switching type Signal output Switching voltage Switching current Repeat accuracy Switching frequency Response time UB I0 f light/dark on 1 PNP, short-circuit protected, open collector max. 30 V DC max. 100 mA 0.05 mm 3 kHz ≤ 160 µs EN 60947-5-2 Ambient conditions Ambient temperature Storage temperature -20 ... 60 °C (-4 ... 140 °F) -20 ... 75 °C (-4 ... 167 °F) Approvals and certificates CE conformity UL approval CCC approval Other suitable accessories can be found at www.pepperl-fuchs.com 10 ... 30 V DC, class 2 10 % ≤ 15 mA Conformity Product standard Mechanical specifications Degree of protection Connection Material Housing Optical face Mass V3-WM-2M-PUR Female cordset single-ended, M8, 3-pin, PUR cable IP67 M8 connector, 3-pin powder coated diecast zinc glass 90 g CE cULus CCC approval / marking not required for products rated ≤36 V Release date: 2019-11-26 15:14 Date of issue: 2019-11-26 Photoelectric slot sensors are photoelectric sensors that operate according to the thru-beam sensor principle. The transmitter sends signals directly to the receiver. If an object breaks the light beam, the switching element function is triggered. The special U-shaped design means the transmitter and receiver can be accommodated in one housing, which ensures high resistance to vibrations. In contrast to standard thru-beam sensors, photoelectric slot sensors have the added advantage of not requiring complex electrical installation, as only one device needs to be connected. Also, adjustment of the optical axes is not necessary. 199990_eng.xml Operating principle 2 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com
GL50-RT/32/40A/98A 价格&库存
很抱歉,暂时无法提供与“GL50-RT/32/40A/98A”相匹配的价格&库存,您可以联系我们找货
GL50-RT/32/40A/98A
  • 1+1617.51883
库存:17
