OBT350-R100-2EP-IO-V31
    PEPPERL+FUCHS(倍加福)
    PHOTO SEN 5-350MM BACK SUPPRESS
OBT350-R100-2EP-IO-V31 数据手册
Triangulation sensor (BGS) OBT350-R100-2EP-IO-V31 < < < < Miniature design with versatile mounting options Best background suppressor in its class Precision object detection, almost irrespective of the color Extended temperature range -40 °C ... 60 °C < High degree of protection IP69K < IO-Link interface for service and process data Triangulation sensor with background suppression Function Release date: 2021-09-07 Date of issue: 2021-09-07 Filename: 267075-0058_eng.pdf The R100 series miniature optical sensors are the first devices of their kind to offer an endto- end solution in a small single standard design — from thru-beam sensor through to a distance measurement device. As a result of this design, the sensors are able to perform practically all standard automation tasks. The entire series enables sensors to communicate via IO-Link. The DuraBeam laser sensors are durable and can be used in the same way as a standard sensor. The use of Multi Pixel Technology gives the standard sensors a high level of flexibility and enables them to adapt more effectively to their operating environment. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Triangulation sensor (BGS) OBT350-R100-2EP-IO-V31 Dimensions 21.5 5.5 8.7 14.5 3.2 3.2 14.2 19.95 15.9 Emitter ø 3.2 10 Reveiver 7.4 M3 (2x) 25.4 37.1 44.5 11 Technical Data Release date: 2021-09-07 Date of issue: 2021-09-07 Filename: 267075-0058_eng.pdf General specifications Detection range 5 ... 350 mm Detection range min. 5 ... 25 mm Detection range max. 5 ... 350 mm Adjustment range 25 ... 350 mm Reference target standard white, 100 mm x 100 mm Light source LED Light type modulated visible red light LED risk group labelling exempt group Black-white difference (6 %/90 %) < 15 % at 350 mm Diameter of the light spot approx. 20 mm at a distance of 350 mm Angle of divergence approx. 3 ° Ambient light limit EN 60947-5-2 : 40000 Lux Functional safety related parameters MTTFd 600 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Indicators/operating means Operation indicator LED green: constantly on - power on flashing (4Hz) - short circuit flashing with short break (1 Hz) - IO-Link mode Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Triangulation sensor (BGS) OBT350-R100-2EP-IO-V31 Technical Data Function indicator LED yellow: constantly on - object detected constantly off - object not detected Control elements Light-on/dark-on changeover switch Control elements Sensing range adjuster Electrical specifications Operating voltage UB Ripple No-load supply current 10 ... 30 V DC max. 10 % I0 Protection class < 25 mA at 24 V supply voltage III Interface Interface type IO-Link ( via C/Q = pin 4 ) IO-Link revision 1.1 Device profile Smart Sensor Device ID 0x110601 (1115649) Transfer rate COM2 (38.4 kBaud) Min. cycle time 2.3 ms Process data width Process data input 1 Bit Process data output 2 Bit SIO mode support yes Compatible master port type A Output Switching type The switching type of the sensor is adjustable. The default setting is: C/Q - Pin4: NPN normally open / light-on, PNP normally closed / dark-on, IO-Link /Q - Pin2: NPN normally closed / dark-on, PNP normally open / light-on Signal output 2 push-pull (4 in 1) outputs, short-circuit protected, reverse polarity protected, overvoltage protected Switching voltage max. 30 V DC Switching current max. 100 mA , resistive load Usage category DC-12 and DC-13 Voltage drop Ud ≤ 1.5 V DC Switching frequency f 500 Hz Response time 1 ms Conformity Communication interface IEC 61131-9 Product standard EN 60947-5-2 Release date: 2021-09-07 Date of issue: 2021-09-07 Filename: 267075-0058_eng.pdf Approvals and certificates EAC conformity TR CU 020/2011 UL approval E87056 , cULus Listed , class 2 power supply , type rating 1 Ambient conditions Ambient temperature -40 ... 60 °C (-40 ... 140 °F) Storage temperature -40 ... 70 °C (-40 ... 158 °F) Mechanical specifications Housing width 11 mm Housing height 44.5 mm Housing depth 21.5 mm Degree of protection IP67 / IP69 / IP69K Connection M8 x 1 connector, 4-pin Material Housing PC (Polycarbonate) Optical face PMMA Mass approx. 10 g Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3 Triangulation sensor (BGS) OBT350-R100-2EP-IO-V31 Connection 1 L+ 4 C/Q 2 Q 3 L- Connection Assignment 2 1 4 3 Wire colors in accordance with EN 60947-5-2 1 2 3 4 BN WH BU BK (brown) (white) (blue) (black) Assembly 2 1 3 1 Light-on / dark-on changeover switch 2 Sensing range adjuster 4 3 Operating indicator / dark on 4 Signal indicator 5 5 Operating indicator / light on Characteristic response curve Offset Y [mm] -10 -5 0 5 10 0 50 100 150 200 X Y Release date: 2021-09-07 Date of issue: 2021-09-07 Filename: 267075-0058_eng.pdf Characteristic Curve 250 300 350 Distance X [mm] white 90 % grey 18 % black 6 % Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 4 Triangulation sensor (BGS) OBT350-R100-2EP-IO-V31 Detection ranges Object colour black grey white 0 50 100 150 200 250 300 350 400 Distance X [mm] X Difference in detection distance Deviation of measured detection distance X [%] 20 18 16 14 12 10 8 6 4 2 0 0 50 100 150 200 250 300 350 400 Adjusted detection distance X [mm] X black / white grey / white Release date: 2021-09-07 Date of issue: 2021-09-07 Filename: 267075-0058_eng.pdf Accessories OMH-ML100-09 Mounting aid for round steel ø 12 mm or sheet 1.5 mm ... 3 mm IO-Link-Master02-USB IO-Link master, supply via USB port or separate power supply, LED indicators, M12 plug for sensor connection OMH-R10X-01 Mounting bracket OMH-R10X-02 Mounting bracket OMH-R10X-04 Mounting bracket OMH-R10X-10 Mounting bracket OMH-ML100-03 Mounting aid for round steel ø 12 mm or sheet 1.5 mm ... 3 mm OMH-ML100-031 Mounting aid for round steel ø 10 ... 14 mm or sheet 1 mm ... 5 mm V31-GM-2M-PUR Female cordset single-ended M8 straight A-coded, 4-pin, PUR cable grey Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 5 Triangulation sensor (BGS) OBT350-R100-2EP-IO-V31 Accessories Female cordset single-ended M8 angled A-coded, 4-pin, PUR cable grey Release date: 2021-09-07 Date of issue: 2021-09-07 Filename: 267075-0058_eng.pdf V31-WM-2M-PUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 6 Triangulation sensor (BGS) OBT350-R100-2EP-IO-V31 Configuration 1 2 1 - Light-on / dark-on changeover switch L 2 - Sensing range / sensitivity adjuster 3 - Operating indicator / dark on R100 D 4 - Signal indicator 5 - Operating indicator / light on 5 4 3 To unlock the adjustment functions turn the sensing range /sensitivity adjuster for more than 180 degrees. Sensing Range / Sensitivity Turn sensing range / sensitivity adjuster clockwise to increase sensing range / sensitivity. Turn sensing range / sensitivity adjuster counter clockwise to decrease sensing range / sensitivity. If the end of the adjustment range is reached, the signal indicator starts flashing with 8 Hz. Light-on / Dark-on Configuration Press the light-on / dark-on changeover switch for more than 1 second (less than 4 seconds). The light-on / dark-on mode changes and the operating indicators are activated accordingly. If you press the light-on / dark-on changeover switch for more than 4 seconds, the light-on /dark-on mode changes back to the original setting. On release of the light-on / dark-on changeover switch the current state is activated. Restore Factory Settings Press the light-on / dark-on changeover switch for more than 10 seconds (less than 30 seconds) until all LEDs turn off. On release of the light-on / dark-on changeover switch the signal indicator turns on. After 5 seconds the sensor resumes operation with factory default settings. Release date: 2021-09-07 Date of issue: 2021-09-07 Filename: 267075-0058_eng.pdf After 5 minutes of inactivity the sensing range / sensitivity adjustment is locked. In order to reactivate the sensing range / sensitivity adjustment, turn the sensing range /sensitivity adjuster for more than 180 degrees. Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com fa-info@de.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 7
OBT350-R100-2EP-IO-V31 价格&库存
很抱歉,暂时无法提供与“OBT350-R100-2EP-IO-V31”相匹配的价格&库存,您可以联系我们找货
  • 1+779.88185
库存:29
