PD30CNB25PAPS
PD30CNB25PAPS
    CARLOGAVAZZI
    SENSOR REFLECTIVE 250MM PNP
PD30CNB25PAPS 数据手册
 PD30CNB25xxPS Photoelectrics, Background suppression reflective - PointSpot Main features • Miniature sensor range • The visible red PointSpot light makes alignment very easy • Range: 250 mm • Sensitivity adjustment by potentiometer • Modulated, red light 617 nm • Supply voltage: 10 to 30 VDC • Output: 100 mA, NPN or PNP preset • Make and break switching function • LED indication for output, stability and power ON • Protection: reverse polarity, short circuit and transients • Cable and plug versions • Excellent EMC performance • Power supply necessary only on one side of the application Main functions Description The PD30CNB25... sensor family comes in a compact 10 x 30 x 20 mm ABS housing. They are designed for use in applications where a compact lightbeam without "halo" light is required to assure a high sensing performance. The potentiometer function for adjustment of the sensitivity makes the sensors highly flexible. The output types NPN or PNP feature both N.O. and N.C. output. Element A B C Component Potentiometer 2 LEDs 2 M3 06/03/2017 PD30CNB25xxPS ENG • Detects presence or absence of objects by cutting off the background information. • The detection distance is very independent of the colour of the object to detect. • The PointSpot light source removes halo light and increases detection reliability. Function Adjustment Green LED: Power ON / Signal stability.Yellow LED: Output Fixing holes for sensor mounting Carlo Gavazzi Industri A/S 1 PD30CNB25xxPS  References Product selection key PD30CNB25 A PS Enter the code entering the corresponding option instead of Code P D 30 C N B 25 A PS Option N P M5 - Description Photoelectric sensor Rectangular housing Length of housing Plastic housing Normal trimmer (back trimmer) Diffuse reflective, Background suppression Distance [cm] NPN PNP Output: N.O. and N.C. Cable, 2 m Connector M8 PointSpot emitter Type selection Connection Cable Plug Output Code NPN PNP NPN PNP PD30CNB25NAPS PD30CNB25PAPS PD30CNB25NAM5PS PD30CNB25PAM5PS 06/03/2017 PD30CNB25xxPS ENG Carlo Gavazzi Industri A/S 2 PD30CNB25xxPS  Sensing Detection Rated operating distance (Sn) Reference target, white paper with 90 % reflectivity, Size 100x100 mm White object 90% reflection Grey object 18% reflection Black object 6% reflection Single-turn potentiometer Electrical adjustment Mechanical adjustment White object 90% reflection Grey object 18% reflection Black object 6% reflection ≤ 250 mm < 250 mm < 250 mm < 250 mm 25 mm ... 250 mm 210° 240° ≤ 15 mm ≤ 17 mm ≤ 19 mm ≤ 10% 621 nm Red modulated ± 1.0° 5.5 mm ± 1.6° Maximum detection distance Sensitivity adjustment Blind zone Hysteresis Light source Light type Detection angle Light spot size Emitter beam angle Red - PointSpot @ 100 mm @ 100 mm @ 100 mm Accuracy Temperature drift ≤ 0.1%/ºC Detection diagram D 3 A 0,0 2,0 3,9 5,9 7,9 9,8 11,8 0,12 2 0,08 1 0,04 0 0,00 E C Y X -1 -0,04 -2 -0,08 -3 0 50 100 150 200 250 300 F -0,12 B A B C D Detection width (mm) Sensing range (mm) Detection width (inches) Sensing range (inches) 06/03/2017 PD30CNB25xxPS ENG E F Sensor Object Carlo Gavazzi Industri A/S 3 PD30CNB25xxPS  Sensing conditions C 16,0% 0,0 1,0 2,0 3,0 3,9 4,9 5,9 6,9 7,9 8,9 9,8 10,8 11,8 0 25 50 75 100 125 150 175 200 225 250 275 300 14,0% 12,0% 10,0% A 8,0% 6,0% 4,0% 2,0% 0,0% B A B C Distance from background (%) White background 90% (mm) White background 90% (inches] 06/03/2017 PD30CNB25xxPS ENG Poly. (Black on white 6%/90%) Poly. (Grey on white 18%/90%) Poly. (White on white 90%/90%) Carlo Gavazzi Industri A/S 4 PD30CNB25xxPS  Features Power Supply Rated operational voltage (UB) Ripple (Urpp ) 10 ... 30 VDC (ripple included) ≤ 10% ≤ 50 mA @ UB min. ≤ 20 mA @ UB Max. ≤ 200 ms No load supply current (Io) Power-ON delay (tv) Outputs Output functions Output switching function NPN or PNP by sensor type Open collector N.O. and N.C. < 100 mA Continuous(Ie) ≤ 100 mA @ 100 nF load Short-time (I) 0.5 mA 100 μA 2 VDC @ (Ie) max. Short circuit, reverse polarity and transients Control of resistive loads and DC-12 solid-state loads with optical isolation DC-13 Control of electromagnets Output current Minimum operational current (Im) OFF-state current(Ir) Voltage drop (Ud) Protection Utilization category Operation diagram Tv = Power-ON delay Power supply Target (Object) Break output (N.C.) Make output (N.O.) ON Present ON Tv Tv ON Response times Operating frequency (f) Response times 06/03/2017 PD30CNB25xxPS ENG ≤ 500 Hz ≤ 1.0 ms ≤ 1.0 ms OFF-ON (tON) ON-OFF (tON) Carlo Gavazzi Industri A/S 5 PD30CNB25xxPS  Indication Green LED ON OFF ON Yellow LED OFF OFF ON Power ON OFF ON Output OFF ON Environmental Ambient temperature Ambient light Vibration Shock Drop test Rated insulation voltage (Ui) Dielectric insulation voltage Rated impulse withstand voltage Pollution degree Overvoltage category Degree of protection NEMA Enclosure Types Ambient humidity range 1) 2) -25°... +60°C (-13°... +140°F) -40° ... +70°C (-40° ... +158°F) ≤ 45 000 lux 10 ...150 Hz, 1.0 mm/15 g 30 gn / 11ms, 6 pos, 6 neg per axis 2 x 1 m and 100 x 0.5 m 50 VDC ≥ 500 VAC rms ≥ 2 kV 3 III IP67 1 35% ... 95% 35% ... 95% Operating 1) Storage 1) @ 3000 … 3200 °K EN 60068-2-6 EN60068-2-27 EN 60068-2-31 50/60 Hz for 1 min. 1.2/50 µs EN60947-1 IEC60664; EN60947-1 IEC60539; EN60947-1 NEMA 250 Operating 2) Storage 2) Do not bend the cable in temperatures below -10°C With no icing or condensation EMC Electrostatic discharge immunity test Radiated radio-frequency electromagnetic field immunity test (80 MHz ... 1 GHz and 1..4 GHz ... 2 GHz) Electrical fast transient/Burst immunity test Conducted disturbances induced by radio-frequency fields immunity test (150 kHz ... 80 MHz) Power frequency magnetic field immunity test 06/03/2017 PD30CNB25xxPS ENG ± 8 kV @ air discharge or ± 4 kV @ contact discharge IEC 61000-4-2 10 V/m IEC 61000-4-3 2 kV / 5 kHz using the capacitive coupling clamp IEC 61000-4-4 10 Vrms IEC 61000-4-6 30 A/m 38 µT IEC 61000-4-8 Carlo Gavazzi Industri A/S 6 PD30CNB25xxPS  Mechanics/electronics Connection Cable Plug 2 m, 4-wire 4 x 0.14 mm2, Ø = 3.3 mm, PVC, Black M8, 4-pin, male Wiring BN 1BN 1BN 2WH 4BK 4BK 2WH 3BU 3BU Fig. 1 NPN Fig. 2 PNP Brown WH White Colour code BK Black BU Blue Housing Body Front glass Trimmer shaft Indication Sealing Dimensions Weight 06/03/2017 PD30CNB25xxPS ENG ABS PMMA, Red POM, Grey TPU, Transparent NBR70 10.8 x 30 x 20 mm ≤ 50 g Cable version ≤ 20 g Plug version Carlo Gavazzi Industri A/S 7 PD30CNB25xxPS  20 10.6 Dimensions 10.6 10.8 15 5.5 5.5 22 25.4 30 7 1.1 17 20 10.6 Fig. 3 Cable 10.6 10.8 15 5.5 5.5 22 25.4 30 7 1.1 17 10.25 Fig. 4 Plug 06/03/2017 PD30CNB25xxPS ENG Carlo Gavazzi Industri A/S 8 PD30CNB25xxPS  Compatibility and conformity Approvals and markings General reference MTTFd Sensor designed according to EN60947-5-2 165 years @ 40°C (+104°F) EN ISO 13849-1, SN 29500 CE-marking Approvals 06/03/2017 PD30CNB25xxPS ENG (UL508 + C22.2) Carlo Gavazzi Industri A/S 9 PD30CNB25xxPS  Delivery contents and accessories Delivery contents • Photoelectric switch: PD30CNB25… • Screwdriver • Packaging: Plastic bag Accessories • Mounting bracket: ADP30-MB1 or APD30-MB2 to be purchased separately • Connector type: CO..54NF... series to be purchased separately COPYRIGHT ©2017 Content subject to change. Download the PDF: www.productselection.net 06/03/2017 PD30CNB25xxPS ENG Carlo Gavazzi Industri A/S 10
PD30CNB25PAPS 价格&库存
很抱歉,暂时无法提供与“PD30CNB25PAPS”相匹配的价格&库存,您可以联系我们找货
PD30CNB25PAPS
  • 1+1163.974511+150.87326
库存:3
PD30CNB25PAPS
  • 1+1043.091371+135.20450
  • 5+973.522885+126.18710
  • 10+903.9544010+117.16970
PD30CNB25PAPS
  • 1+937.85069
库存:4
