Photoelectrics
Retro-reflective, Polarized
Type PD30CNP06....RT
• Miniature sensor range
• Range: 6 m, with reflector
• Sensitivity adjustment by Teach-In programming
• Modulated, red light 660 nm, polarized
• Supply voltage: 10 to 30 VDC
• Output: 100 mA, NPN or PNP preset
• Make and break switching function programmable
• LED indication for output, stability and power ON
• Protection: reverse polarity, short circuit and transients
• Cable and plug versions
• Excellent EMC performance
• Remote teach features
Product Description
Ordering Key
The PD30CNP06 sensor
family comes in a compact
10 x 30 x 20 mm reinforced
PMMA/ABS housing.
The sensors are useful in
applications where high-accuracy detection as well as
small size is required.
Compact housing and high
power LED for excellent performance-size ratio.
Type
Housing style
Housing size
Housing material
Housing length
Detection principle
Sensing distance
Output type
Output configuration
Connection type
Remote teach
The Teach-In function for
adjustment of the sensitivity makes the sensors highly
flexible. The output type is
preset (NPN or PNP), and the
output switching function is
programmable (NO or NC).
A remote teach feature allow
the sensor to be set up from
e.g. a PLC.
PD30CNP06PPM5RT
Type Selection
Housing
Range
Connection
WxHxD
Sn
Ordering no.
NPN
Make or break switching
Ordering no.
PNP
10 x 30 x 20 mm 6 m
10 x 30 x 20 mm 6 m
PD 30 CNP 06 NPRT
PD 30 CNP 06 NPM5RT
PD 30 CNP 06 PPRT
PD 30 CNP 06 PPM5RT
Cable
Plug
Note: Reflectors to be ordered separately
Specifications
EN 60947-5-2
Rated operating distance (Sn) Up to 6 m, with reflector
Ø 80 mm (ER4)
4 m on ER4060 reflector
Blind zone
100 mm
Sensitivity
Adjustable by Teach-In
Temperature drift
≤ 0.1%/ºC
Hysteresis (H)
(differential travel)
≤ 10%
Rated operational volt. (UB )
10 to 30 VDC
(ripple included)
Ripple (Urpp )
≤ 10%
Output current
Continuous (Ie)
≤ 100 mA
Short-time (I)
≤ 100 mA
(max. load capacity 100 nF)
No load supply current (Io)
≤ 30 mA @ 24 VDC
Minimum operational current (Im) 0.5 mA
OFF-state current (Ir )
≤ 100 µA
Voltage drop (Ud )
≤ 2.4 VDC @ 100 mA
Protection
Short-circuit, reverse polarity
and transients
Light source
GaAlAs, LED, 660 nm
Specifications are subject to change without notice (05.08.2016)
Light type
Red, modulated
Sensing angle
± 2º
Ambient light
10,000 lux
Light spot
110 mm @ 1.5 m
Operating frequency
1000 Hz
Response time
OFF-ON (tON)
≤ 0.5 ms
ON-OFF (tOFF )
≤ 0.5 ms
Power ON delay (tv)
≤ 300 ms
Output function
NPN and PNP
Preset
NO/NC switching function
Set up by button
Remote teach function
Teach on (push button active) 0 to 2.5 VDC (NPN)
5 to 30 VDC (PNP)
Tamper proof
When activated more than
20 sec. the sensor goes into
a Tamper proof mode.
Indication
Output ON
LED, yellow
Signal stability ON and power ON LED, green
1
PD30CNP06....RT
Specifications (cont.)
Environment
Installation category
Pollution degree
Degree of protection
Ambient temperature
Operating
Storage
Vibration
Shock
EN 60947-5-2
III (IEC 60664/60664A;
60947-1)
3 (IEC 60664/60664A;
60947-1)
IP 67 (IEC 60529; 60947-1)
-25° to +55°C (-13° to +131°F)
-40° to +70°C (-40° to +158°F)
10 to 55 Hz, 0.5 mm/7.5 g
(IEC 60068-2-6)
30 g / 11ms, 3 pos, 3 neg
per axis
(IEC 60068-2-6, 60068-2-32)
Rated insulation voltage 500 VAC (rms)
Housing material
Body
ABS
Front material
PMMA, red
Connection
Cable
PVC, black, 2 m
4 x 0.14 mm2, Ø = 3.3 mm
Plug
M8, 4-pin (CON, 54-series)
Weight
With cable: 40 g
With plug: 10 g
CE-marking Yes
Approvals
cULus (UL508)
Operation Diagram
tv = Power ON delay
ON
OFF
Power supply
Make Output (N.O.)
Present
Not Present
Tv
ON
OFF
Break Output (N.C.)
ON
OFF
Object
Tv
Wiring Diagrams
NPN
1 BN
Remote teach
PNP
V
2 WH
4 BK
Remote teach
3 BU
1 BN
V
4 BK
2 WH
3 BU
V (GND)
V (GND)
Remote teach input
active when connected
to GND
Remote teach input
to V+
Excess Gain
Detection Diagram
300
100
200
Exess gain
(mm)
100
-100
-200
-300
1
4
6
(m)
2
8
10
0.1
1
10
Distance (m)
PD30CNP06....RT
Accessories
Signal Stability Indication
21.2
14
9°
32.4
1.2
25.4
Excess Gain
9°
26,3
29.3
39
3.2
Operation level x 1.25
Operation level
Operation level x 0.75
1.2
10
1.25
1.0
0.75
25.4
3.2
13.5
16.2
6.0
5.2
3
Yellow LED ON
4.4
14
4.4
6.0
16
10
7.3
Green LED ON
8.2
5.7
Time
4.4
Mounting bracket: APD30-1
Mounting bracket: APD30-2
Dimensions
Plug version
Cable version
10.6
PD30CNP
06NPM5T
10-30 V
100 mA
BN: V+
UL
BU: VBK: OUT
WH: ET
10.8
10-30 V
100 mA
BN: V+
UL
BU: VBK: OUT
WH: ET
xxxxxxS
Incorrect
Correct
Emitter
Two M3
Two, 9.5 dia.
Lenses
15
30
15
22
Receiver
Optical axis
5.5 5.5
Two, 9.5 dia.
Lenses
10.8
17
22
Receiver
Optical axis
R
25.4
17
R
Power / Stability LED
Green
10.6
1.1
PD30CNP
06NPM5T
25.4
30
Output LED
Yellow
Green
5.5 5.5
1.1
Output LED
Yellow
xxxxxxS
6
6
Teach Button
Teach Button
Two M3
> 100 mm
Emitter
10.25
Installation Hints
To avoid interference from inductive voltage / Relief of the cable strain
current peaks, separate the proximity switch
cables from any other power cables. E.g.
Engine, contactor or solenoid cables
Protection of the sensing face
Sensor mounted on a mobile carrier
Incorrect
Incorrect
Incorrect
Correct
Correct
> 100 mm
The cable should not be pulled
A proximity switch should not serve
as mechanical stop
Any repetitive flexing of the
cable should be avoided
Delivery Contents
Accessories
• Photoelectric switch: PD 30 CNP 06 ...
• Installation instruction
• Mountingbracket APD30-MB1
• Packaging: Cardboard box
• Reflector is to be purchased separately
• Mounting bracket APD30-MB2 to be purchased separately
3
PD30CNP06....RT
Teach functions
Normal operation, optimized switching point
1. Line up the sensor with the reflector. Yellow LED and
Green LED are ON.
2. Press the button for 3 seconds until both LEDs
flashes simultaneously.
(The first switch point is stored)
3. Place the object between the sensor and reflector in
the detection zone.
4. Press the button once and the sensor is ready to
operate (Green LED ON, Yellow LED ON)
(The second switch point is stored)
1
2
3
4
3 sec.
1
1
Push once
For maximum sensing distance
(default setting)
1. Line up the sensor with the reflector, place the object
between the sensor and reflector in the detection
zone. Yellow LED is OFF and Green LED is ON.
3. Press the button a second time and the sensor is
ready to operate (Green LED ON, Yellow LED ON)
For dynamic setup (running process)
1. Line up the sensor with the reflector. Green LED is ON,
status on the yellow LED is not important.
2. Press the button for 3 second until both LEDs flashes
simultaneously.
3. Press the button a second time for at least one
second, both LED’s flashes fast simultaneously and
keep the button pressed for at least one process
cycle, release the button and the sensor is ready to
operate (The second switch point is stored)
2
3 sec.
3
One cycle
For make or break setup (N.O. or N.C.)
1. Press the button for 10 seconds, until the green LEDs
flashes.
2. While the green LED flashes, the output is inverted
each time the button is pressed. Yellow LED indicates
N.O. function selected.
If the button is not pressed within the next 10
seconds, the current output is stored.
1
2
3
10 sec.
3 sec.
2
Push once
Push once
For minimum sensing distance
Green LED are ON.
1
2
3 sec.
4
3
Push once
很抱歉,暂时无法提供与“PD30CNP06PPM5RT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+982.612051+127.11587
