QT50R-US-AFHQ
QT50R-US-AFHQ
    BANNER(邦纳)
QT50R-US-AFHQ 数据手册
R-GAGE® QT50R-AFH Sensor Datasheet Radar-Based Sensors for Detection of Moving and Stationary Targets • • • • • • • FMCW radar detects moving and stationary objects Higher sensitivity and longer range Adjustable sensing field—ignores objects beyond setpoint Easy setup and configuration of range, sensitivity, and output with simple DIP switches Sensing functions are unaffected by wind, falling rain or snow, fog, humidity, air temperatures, or light Sensor operates in Industrial, Scientific, and Medical (ISM) telecommunication band Rugged IP67 housing withstands harsh environments WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Models Maximum Range Models 1 Connection Supply Voltage QT50R-US-AFH Telecom Approval 2 Output Telecom approved for US, Canada and Brazil QT50R-EU-AFH 24 m (78 ft) QT50R-KR-AFH QT50R-TW-AFH 5-wire 2 m (6.5 ft) Integral cable 12 to 30 V DC Telecom approved for Europe, UK, Australia, New Zealand, China, and Japan 12 to 24 V DC Telecom approved for South Korea Telecom approved for Taiwan 12 to 30 V DC QT50R-SG-AFH Bipolar NPN/PNP DIP-switch-selectable normally open (NO) or normally closed (NC) Telecom approved for Singapore Overview The R-GAGE sensor emits a well-defined beam of high-frequency radio waves from an internal antenna. Some of this emitted energy reflects back to the receiving antenna. Signal processing electronics in the sensor determine the distance from the sensor to the object based on the time delay of the return signal. The sensor can be configured (via DIP switches) to sense objects up to a specific distance, ignoring objects beyond this distance (also called background suppression). Figure 1. R-GAGE setpoint Setpoint X Y D 1 Cabled models only are listed. To order the integral 5-pin M12 quick-disconnect fitting, add suffix "Q" to the model number (for example, QT50R-xx-AFHQ). Quick-disconnect models require a mating cordset; see Quick Disconnect (QD) Cordsets on p. 6. 2 For additional countries, contact Banner Engineering. Original Document 162359 Rev. J 11 June 2021 162359 R-GAGE® QT50R-AFH Sensor Setpoints EU, KR Models TW, US Models X Minimum setpoint distance 2 m (6.6 ft) 3.5 m (11.5 ft) Y Maximum setpoint distance 24 m (78.7 ft) 24 m (78.7 ft) D Dead Zone 3 1. Power LED: Green (power ON) 2. Signal Strength LED: Red (flashes in proportion to the signal strength) 3. Output LEDs: Yellow (output energized); Red (configuration) Figure 2. R-GAGE features Access the DIP switches behind the threaded cap on the sensor back (not shown) R-GAGE setpoint distances, minimum and maximum (sensor will detect objects up to setpoint and ignore objects beyond the setpoint) Sensor Configuration The sensing zone distance, sensitivity, and output configuration can be selected via the DIP switches on the back of the sensor. Use the included spanner to open the screw-off cover on the back of the sensor and access the DIP switches. Important: Tighten the DIP switch cover a full quarter turn after contact to maintain the watertight seal. DIP Switch Functions Switch Function 1, 2, 3 Sensing distance (detects objects from sensor face to this point) 4, 5 Sensitivity (higher sensitivity sees weaker objects and has a larger beam pattern) 6 Normally open/normally closed output functionality 7, 8 Response Speed DIP switch 1 is on the left and DIP switch 8 is on the right. Distance Settings * Default settings Switch 1 Switch 2 Switch 3 0 0 0 0 0 0 1 0 Distance EU, KR Models TW, US Models 2 m (6.6 ft) 3.5 m (11.5 ft) 1 3 m (9.8 ft) 4 m (13.1 ft) 0 4 m (13.1 ft) 5 m (16.4 ft) 1 1 6 m (19.7 ft) 6 m (19.7 ft) 1* 0* 0* 8 m (26.2 ft) 8 m (26.2 ft) 1 0 1 12 m (39.4 ft) 12 m (39.4 ft) 1 1 0 16 m (52.5 ft) 16 m (52.5 ft) 1 1 1 24 m (78.7 ft) 24 m (78.7 ft) Note: Highest sensitivity is achieved only if sensing distance is 8 m (26.2 ft) or less. 3 Typical dead zone: 0.4 m (1.3 ft) for moving and 1.0 m (3.3 ft) for stationary targets, but varies with target reflectivity 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 162359 Rev. J R-GAGE® QT50R-AFH Sensor Note: Near-field sensitivity boost is enabled when set to 4 m (13.1 ft) or less. Sensitivity Selection Switch 4 Switch 5 Sensitivity 0* 0* 4 (Highest) 0 1 3 (High) 1 0 2 (Medium) 1 1 1 (Low) * Default settings Note: Use the sensitivity selection to ignore unwanted weak reflections within the field of view, and not to narrow the beam width. Narrow-beam R-GAGE sensor models are available. Output Configuration Switch 6 Normally Open/Normally Closed 0* Normally open 1 Normally closed * Default settings Response Speed Switch 7 Switch 8 On Total (ms) Off Total (ms) Total (ms) 0 0 30 70 100 0* 1* 50 300 350 1 0 30 1000 1030 1 1 120 6000 6120 * Default settings Windows The R-GAGE sensor can be placed behind a glass or a plastic window, but the configuration must be tested and the distance from the sensor to the window must be determined and controlled prior to installation. There is typically a 20% signal reduction when the sensor is placed behind a window. Polycarbonate at 4 mm thickness performs well in most situations, but the performance depends on filler materials. Thinner (1 to 3 mm) windows have high reflection. The amount of reflection depends on the material, thickness, and distance from the sensor to the window. Locate the sensor in a position of minimum reflection from the window, which will repeat every 6.1 mm of distance between the sensor and the window. The positions of maximum reflection from the window repeat between the minimums, and decrease in effect until the window is approximately 150 mm (5.9 in) away. Consult the factory for pre-tested window materials which can be used at any distance without issue. Additionally, the face of the window should be protected from flowing water and ice by use of a flow diverter or hood directly above the window. Falling rain or snow in the air in front of the window, light water mist, or small beads on the face of the window are typically not an issue. However, a thick, continuous surface of water or ice directly on the face of the window can be detected as a dielectric boundary. P/N 162359 Rev. J www.bannerengineering.com - Tel: + 1 888 373 6767 3 R-GAGE® QT50R-AFH Sensor Wiring There is no connection to the gray (gy) wire. bn + 12–30 V dc – bu wh bk Note: Banner recommends that the shield wire (quickdisconnect cordsets only) be connected to earth ground or dc common. Shielded cordsets are recommended for all quickdisconnect models. Load 1 Load 2 gy shield (QD cordset) Specifications Range The sensor is able to detect a proper object (see Detectable Objects) from 1 m to 24 m (3.3 ft to 78.7 ft), depending on target Detectable Objects Objects containing metal, water, or similar high-dielectric materials Operating Principle Frequency modulated continuous-wave (FMCW) radar Operating Frequency US, TW Models: 24.075–24.175 GHz, ISM Band EU, KR, SG Models: 24.050-24.250 GHz, ISM Band Supply Voltage 12 V DC to 30 V DC, less than 100 mA, exclusive of load For KR models: 12 V DC to 24 V DC, less than 100 mA exclusive of load Supply Protection Circuitry Protected against reverse polarity and transient overvoltages Delay at Power-up Less than 2 seconds Operating Temperature –40 °C to +65 °C (–40 °F to +149 °F) Environmental Rating IP67 Connections Integral 5-wire 2 m (6.5 ft) cable or M12 Euro-style QD fitting. QD models require a mating cordset Certifications Output Configuration Bipolar NPN/PNP output, 150mA; DIP switch 6 selects N.O. (default) or N.C. operation Response Time DIP switches 7 & 8 select ON/OFF response time Adjustments DIP-switch-configurable sensing distance, sensitivity, response time, and output configuration Construction Housing: ABS/polycarbonate Lightpipes: Acrylic Access Cap: Polyester Maximum Output Power ERP: 3.3 mW, 5 dBm EIRP: 100 mW, 20 dBm Output Protection Protected against short circuit conditions Indicators Power LED: Green (power ON) Signal Strength LED: Red, flashes in proportion to signal strength. Steady on at 4x excess gain. Only indicates signal amplitude, not target distance. Output LEDs: Yellow (output energized) / Red (configuration) See Figure 2 on p. 2 ETSI/EN 300 440 FCC part 15 RSS-210 ANATEL Category II CMIIT Category G ARIB STD T-73 KC mark - MSIP/RRA NCC IDA Singapore for others, contact Banner Engineering Country of Origin: USA FCC ID: UE3QT50RUS—This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. IC: 7044A-QT50RCA—This device complies with Industry Canada license-exempt RSS standard(s). Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of the device. Cet appareil est conforme aux CNR exempts de licence d'Industrie Canada. Son fonctionnement est soumis aux deux conditions suivantes:(1) Ce dispositif ne peut causer des interférences; et(2) Ce dispositif doit accepter toute interférence, y compris les interférences qui peuvent entraîner un mauvais fonctionnement de l'appareil. 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 162359 Rev. J R-GAGE® QT50R-AFH Sensor Este equipamento não tem direito à proteção contra interferência prejudicial e não pode causar interferência em sistemas devidamente autorizados. SRD24-IO3B24100.2TR0.1 South Korea Class A Certification A 급 기기 ( 업무용 방송통신기자재 ) 이 기기는 업무용 (A 급 ) 으로 전자파적합기기로 서 판매자 또는 사용자는 이 점을 주의하시기 바라며 , 가정외의 지역에서 사용하는 것을 목 적으로 합니다 . Beam Pattern Typical Beam Pattern (with BRTR-CC20E Radar Target, Radar Cross Section = 50 m2) Typical Beam Pattern (with 4 different targets) at highest sensitivity level Left-Right Beam Pattern Left-Right Beam Pattern 20 m 20 m Sensitivity 1 Sensitivity 4 10 m 3 Target 4 Target 1 4 10 m 4 3 2 2 1 0m 0m 10 m 10 m 20 m 1 20 m 0 10 m 20 m 30 m 40 m 0 Distance 1–4: Indicates sensitivity level 10 m 20 m 30 m 40 m Distance 1: Weak Object (Radar cross section = 0.25 m2) 2: Car (Radar cross section = 3 m2) 3: Large Truck (Radar cross section = 50 m2) 4: Passenger Train (Radar cross section = 300 m2) Note: The effective beam pattern depends on the sensitivity level and target properties. P/N 162359 Rev. J www.bannerengineering.com - Tel: + 1 888 373 6767 5 R-GAGE® QT50R-AFH Sensor Dimensions 74.1 mm (2.92") 46.1 mm (1.82") 37.0 mm (1.46") 38.1 mm (1.50") 4X Ø4.4 mm (Ø 0.17") 33.0 mm (1.30") 50.8 mm (2.00") 66.0 mm (2.60") 19.7 mm (0.78") R45.0 mm (R1.77") 34.2 mm (1.35") 37.0 mm (1.46") M30 X 1.5 ISO-6g 50.8 mm (2.00") Accessories Quick Disconnect (QD) Cordsets 5-Pin Threaded M12 Cordsets with Shield—Single Ended Model Length MQDEC2-506 2 m (6.56 ft) MQDEC2-515 5 m (16.4 ft) MQDEC2-530 9 m (29.5 ft) MQDEC2-550 15 m (49.2 ft) MQDEC2-506RA 2 m (6.56 ft) MQDEC2-515RA 5 m (16.4 ft) MQDEC2-530RA 9 m (29.5 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 15 m (49.2 ft) 1 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDEC2-550RA Pinout (Female) 2 3 5 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray M12 x 1 ø 14.5 [0.57"] Note: Pin 5 is not used. 6 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 162359 Rev. J R-GAGE® QT50R-AFH Sensor Mounting Brackets All measurements are listed in millimeters, unless noted otherwise. SMB30SC Swivel bracket with 30 mm • mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 67 B 58 29 Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 SMB30MM 12-ga. stainless steel bracket • with curved mounting slots for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor 57 70 C 57 B A A Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 Weather Deflectors and Shields QT50RCK Weather Deflector • • Required if the R-GAGE is exposed to rain or snow Prevents buildup of water or ice from interfering with sensor performance QT50RWS Weather Shield • • Coated to help repel water and maximize signal strength Hardware included for easy installation and replacement Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
QT50R-US-AFHQ 价格&库存
很抱歉,暂时无法提供与“QT50R-US-AFHQ”相匹配的价格&库存,您可以联系我们找货
